OPAL is not callable from 32-bit mode and the assembly code for it
may not even build (depending on how binutils was configured).
References: https://buildd.debian.org/status/fetch.php?pkg=linux&arch=powerpcspe&ver=4.8.7-1&stamp=1479203712
Fixes: 656ad58ef19e ("powerpc/boot: Add OPAL console to epapr wrappers")
Cc: stable@vger.kernel.org # v4.8+
This patch adds an option to use XZ compression for the kernel image.
Currently this is only enabled for 64-bit Book3S targets, which is
roughly equivalent to the platforms that use the kernel's zImage
wrapper, and that have been tested.
The bulk of the 32-bit platforms and 64-bit BookE use uboot images,
which relies on uboot implementing XZ. In future we can enable XZ
support for those targets once someone has tested it.
Signed-off-by: Oliver O'Halloran <oohall@gmail.com>
This modifies the wrapper script so that the -Z option takes an argument
to specify the compression type. It can either be 'gz', 'xz' or 'none'.
The legazy --no-gzip and -z options are still supported and will set the
compression to none and gzip respectively, but they are not documented.
Only XZ -6 is used for compression rather than XZ -9. Using compression
levels higher than 6 requires the decompressor to build a large (64MB)
dictionary when decompressing and some environments cannot satisfy such
large allocations (e.g. POWER 6 LPAR partition firmware).
Currently the powerpc boot wrapper has its own wrapper around zlib to
handle decompressing gzipped kernels. The kernel decompressor library
functions now provide a generic interface that can be used in the
pre-boot environment. This allows boot wrappers to easily support
different compression algorithms. This patch converts the wrapper to use
this new API, but does not add support for using new algorithms.
Most architectures allow the compression algorithm used to produced the
vmlinuz image to be selected as a kernel config option. In preperation
for supporting algorithms other than gzip in the powerpc boot wrapper
the makefile needs to be modified to use these config options.
The powerpc boot wrapper is potentially compiled with a separate
toolchain and/or toolchain flags than the rest of the kernel. The usual
case is a 64-bit big endian kernel builds a 32-bit big endian wrapper.
The main problem with this is that the wrapper does not have access to
the kernel headers (without a lot of gross hacks). To get around this
the required headers are copied into the build directory via several sed
scripts which rewrite problematic includes. This patch moves these
fixups out of the makefile into a separate .sed script file to clean up
makefile slightly.
[mpe: Reword first paragraph of change log a little]
Some of the rules in the boot Makefile use @ to hide the command, this
means "make V=1" doesn't show them, which is confusing.
So use the Kbuild standard $(Q) which means KBUILD_VERBOSE=1 or V=1 will
work as expected.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
- GCC plugin support by Emese Revfy from grsecurity, with a fixup from
Kees Cook. The plugins are meant to be used for static analysis of
the kernel code. Two plugins are provided already.
- reduction of the gcc commandline by Arnd Bergmann.
- IS_ENABLED / IS_REACHABLE macro enhancements by Masahiro Yamada
- bin2c fix by Michael Tautschnig
- setlocalversion fix by Wolfram Sang
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
gcc-plugins: disable under COMPILE_TEST
kbuild: Abort build on bad stack protector flag
scripts: Fix size mismatch of kexec_purgatory_size
kbuild: make samples depend on headers_install
Kbuild: don't add obj tree in additional includes
Kbuild: arch: look for generated headers in obtree
Kbuild: always prefix objtree in LINUXINCLUDE
Kbuild: avoid duplicate include path
Kbuild: don't add ../../ to include path
vmlinux.lds.h: replace config_enabled() with IS_ENABLED()
kconfig.h: allow to use IS_{ENABLE,REACHABLE} in macro expansion
kconfig.h: use already defined macros for IS_REACHABLE() define
export.h: use __is_defined() to check if __KSYM_* is defined
kconfig.h: use __is_defined() to check if MODULE is defined
kbuild: setlocalversion: print error to STDERR
Add sancov plugin
Add Cyclomatic complexity GCC plugin
GCC plugin infrastructure
Shared library support
There are very few files that need add an -I$(obj) gcc for the preprocessor
or the assembler. For C files, we add always these for both the objtree and
srctree, but for the other ones we require the Makefile to add them, and
Kbuild then adds it for both trees.
As a preparation for changing the meaning of the -I$(obj) directive to
only refer to the srctree, this changes the two instances in arch/x86 to use
an explictit $(objtree) prefix where needed, otherwise we won't find the
headers any more, as reported by the kbuild 0day builder.
arch/x86/realmode/rm/realmode.lds.S:75:20: fatal error: pasyms.h: No such file or directory
Signed-off-by: Michal Marek <mmarek@suse.com>
Add support for the Artesyn MVME7100 Single Board Computer.
The MVME7100 is a 6U form factor VME64 computer with:
- A two e600 cores Freescale MPC8641D CPU
- 2 GB of DDR2 onboard memory
- Four Gigabit Ethernets
- Five 16550 compatible UARTs
- One USB 2.0 port
- Two PCI/PCI eXpress Mezzanine Card (PMC/XMC) Slots
- A DS1375 Real Time Clock (RTC)
- 512 KB of Non-Volatile Memory (NVRAM)
- Two 64 KB EEPROMs
- 128 MB NOR and 4/8 GB NAND Flash
This patch is based on linux-4.7-rc1 and has been only boot tested.
Limitations:
This patch covers only models 171 and 173
No plans to support CPLD timers
Know issues:
All four PHYs work in polling mode
Configuration is missing for:
PCI IDSEL and PCI Interrupt definition
Support is missing for:
Cache and memory controllers (which are very similar to the 85xx ones
but right now I don't know if we can re-use their support)
Watchdog, USB, NVRAM, NOR, NAND, EEPROMs, VME, PMC/XMC and RTC
Signed-off-by: Alessio Igor Bogani <alessio.bogani@elettra.eu>
Signed-off-by: Scott Wood <oss@buserror.net>
This patch adds an OPAL console backend to the powerpc boot wrapper so
that decompression failures inside the wrapper can be reported to the
user. This is important since it typically indicates data corruption in
the firmware and other nasty things.
Currently this only works when building a little endian kernel. When
compiling a 64 bit BE kernel the wrapper is always build 32 bit to be
compatible with some 32 bit firmwares. BE support will be added at a
later date. Another limitation of this is that only the "raw" type of
OPAL console is supported, however machines that provide a hvsi console
also provide a raw console so this is not an issue in practice.
Actually-written-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
[mpe: Move #ifdef __powerpc64__ to avoid warnings on 32-bit]
Commit dc37374b9c833 ("powerpc/fsl: Move Freescale device tree files
into fsl folder") moved a lot of device tree files into fsl directory,
fixing Makefile for cuImage target only. Unfortunately there are other
targets which require embedding a device tree into the kernel image
(e.g. dtbImage.%). So use a more generic approach.
[scottwood: cleaned up commit message]
All users of QPACE have upgraded to QPACE2 so remove the Cell QPACE code.
Signed-off-by: Rashmica Gupta <rashmicy@gmail.com>
It makes no sense that some Freescale device tree files are in fsl
directory while some others not. This patch move Freescale device tree
files into fsl folder. To do that the following two steps are made:
- Move Freescale device tree files into fsl folder.
- Update the include path in these files from "fsl/*.dtsi" to "*.dtsi".
Please add "fsl/" prefix when you make dtb using Makefile.
Signed-off-by: Jia Hongtao <hongtao.jia@freescale.com>
[scottwood: fixed cuImage rule]
The kernel does it, not the boot wrapper, which breaks with some
cross compilers that still default to ABI v1.
Fixes: 147c05168fc8 ("powerpc/boot: Add support for 64bit little endian wrapper")
Cc: stable@vger.kernel.org # v3.16+
The celleb code has seen no actual development for ~7 years.
We (maintainers) have no access to test hardware, and it is highly
likely the code has bit-rotted.
As far as we're aware the hardware was never widely available, and is
certainly no longer available, and no one on the list has shown any
interest in it over the years.
So remove it. If anyone has one and cares please speak up.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Jeremy Kerr <jk@ozlabs.org>
The $(image-n) variable will never exist, because unset Kconfig options
are '' and not 'n'.
in commit 29f1aff2c (powerpc: Copy bootable images in the default
install script) we changed to copying all the built boot targets based
on the assumption that it's backwards compatible. It turns out that
debian devived installkernel scripts will barf if not given exactly 4
args.
This change reverts make install to just install the vmlinux (we can
change the dfault in a seperate patch) and introduces a new make
zInstall which works with a more flexible installkernel script.
Cc: Grant Likely <grant.likely@secretlab.ca>
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
"Kbuild changes for v3.16-rc1:
- cross-compilation fix so that cc-option is testing the right
compiler
- Fix for make defconfig all
- Using relative paths to the object and source directory where
possible, plus fixes for the fallout of the change
- several cleanups in the Makefiles and scripts
The powerpc fix is from today, because it was only discovered
recently. The rest has been in linux-next for some time"
powerpc: Avoid circular dependency with zImage.%
kbuild: create include/config directory in scripts/kconfig/Makefile
kbuild: do not create include/linux directory
Makefile: Fix unrecognized cross-compiler command line options
kbuild: do not add "selinux" to subdir- twice
um: Fix for relative objtree when generating x86 headers
kbuild: Use relative path when building in a subdir of the source tree
kbuild: Use relative path when building in the source tree
kbuild: Use relative path for $(objtree)
firmware: Use $(quote) in the Makefile
firmware: Simplify directory creation
kbuild: trivial - fix comment block indent
kbuild: trivial - remove trailing spaces
kbuild: support simultaneous "make %config" and "make all"
kbuild: move extra gcc checks to scripts/Makefile.extrawarn
The rule to create the final images uses a zImage.% pattern.
Unfortunately, this also matches the names of the zImage.*.lds linker
scripts, which appear as a dependency of the final images. This somehow
worked when $(srctree) used to be an absolute path, but now the pattern
matches too much. List only the images from $(image-y) as the target of
the rule, to avoid the circular dependency.
Reported-and-tested-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
This patch adds support for the IBM Akebono board.
Signed-off-by: Alistair Popple <alistair@popple.id.au>
The code is only slightly modified : entry points now use the
FIXUP_ENDIAN trampoline to switch endian order. The 32bit wrapper
is kept for big endian kernels and 64bit is enforced for little
endian kernels with a PPC64_BOOT_WRAPPER config option.
The linker script is generated using the kernel preprocessor flags
to make use of the CONFIG_* definitions and the wrapper script is
modified to take into account the new elf64ppc format.
Finally, the zImage file is compiled as a position independent
executable (-pie) which makes it loadable at any address by the
firmware.
Signed-off-by: Cédric Le Goater <clg@fr.ibm.com>
When entering the boot wrapper in little endian, we will need to fix
the endian order using a fixup trampoline like in the kernel. This
patch overrides the _zimage_start entry point for this purpose.
This processor/memory module was mostly used on ATCA blades and
before that, on cPCI blades. It wasn't really user friendly, with
custom non u-boot bootloaders (powerboot/motload) and no real way
to recover corrupted boot flash (which was a common problem).
As such, it had its day back before the big ppc --> powerpc move
to device trees, and that was largely through commercial BSPs that
started to dry up around 2007.
Systems using one were largely in a "deploy and sustain" mode,
so interest in upgrading to new kernels in the field was nil.
Also, requiring 50A, 48V power supplies and a 2'x2'x2' ATCA
chassis largely rules out any hobbyist/enthusiast interest.
The point of all this, is that we might as well delete the in
kernel files relating to this platform. No point in continuing
to build it via walking the defconfigs or via linux-next testing.
Cc: linuxppc-dev@lists.ozlabs.org
As of commit b81f18e55e9f4ea81759bcb00fea295de679bbe8 ("powerpc/boot:
Only build board support files when required.") the two defconfigs
ep88xc_defconfig and storcenter_defconfig would fail final link as
follows:
WRAP arch/powerpc/boot/dtbImage.ep88xc
arch/powerpc/boot/wrapper.a(mpc8xx.o): In function `mpc885_get_clock':
arch/powerpc/boot/mpc8xx.c:30: undefined reference to `fsl_get_immr'
make[1]: *** [arch/powerpc/boot/dtbImage.ep88xc] Error 1
...and...
WRAP arch/powerpc/boot/cuImage.storcenter
arch/powerpc/boot/cuboot-pq2.o: In function `pq2_platform_fixups':
cuboot-pq2.c:(.text+0x324): undefined reference to `fsl_get_immr'
make[1]: *** [arch/powerpc/boot/cuImage.storcenter] Error 1
We need the fsl-soc board files built for these two platforms.
Cc: Tony Breeds <tony@bakeyournoodle.com>
Fixes: b81f18e55e9f ("powerpc/boot: Only build board support files when required.")
Add support for the Motorola/Emerson MVME5100 Single Board Computer.
The MVME5100 is a 6U form factor VME64 computer with:
- A single MPC7410 or MPC750 CPU
- A HAWK Processor Host Bridge (CPU to PCI) and
MultiProcessor Interrupt Controller (MPIC)
- Up to 500Mb of onboard memory
- A M48T37 Real Time Clock (RTC) and Non-Volatile Memory chip
- Two 16550 compatible UARTS
- Two Intel E100 Fast Ethernets
- Two PCI Mezzanine Card (PMC) Slots
- PPCBug Firmware
The HAWK PHB/MPIC is compatible with the MPC10x devices.
There is no onboard disk support. This is usually provided by installing a PMC
in first PMC slot.
This patch revives the board support, it was present in early 2.6
series kernels. The board support in those days was by Matt Porter of
MontaVista Software.
CSC Australia has around 31 of these boards in service. The kernel in use
for the boards is based on 2.6.31. The boards are operated without disks
from a file server.
This patch is based on linux-3.13-rc2 and has been boot tested.
Only boards with 512 Mb of memory are known to work.
Signed-off-by: Stephen Chivers <schivers@csc.com>
Tested-by: Alessio Igor Bogani <alessio.bogani@elettra.eu>
This patch allows the kbuild system to successfully compile a kernel
for the little endian PowerPC64 architecture. A subsequent patch
will add the CONFIG_CPU_LITTLE_ENDIAN kernel config option which
must be set to build such a kernel.
If cross compiling, CROSS_COMPILE must point to a suitable toolchain
(compiled for the powerpc64le-linux and powerpcle-linux targets).
Signed-off-by: Ian Munsie <imunsie@au1.ibm.com>
This makes the "OF" zImage wrapper (zImage.pseries, zImage.pmac,
zImage.maple) work if booted via a flat device-tree (ePAPR boot
mode), and thus potentially usable with kexec.
Several files in obj-plat depend on libfdt header file. Sometimes
when building one can see the following issue. This patch adds
libfdt as dependency to those object files
| In file included from arch/powerpc/boot/treeboot-iss4xx.c:33:0:
| arch/powerpc/boot/libfdt.h:854:1: error: unterminated comment
| arch/powerpc/boot/libfdt.h:1:0: error: unterminated #ifndef
| BOOTCC arch/powerpc/boot/inffast.o
| make[1]: *** [arch/powerpc/boot/treeboot-iss4xx.o] Error 1
| make[1]: *** Waiting for unfinished jobs....
| BOOTCC arch/powerpc/boot/inflate.o
| make: *** [uImage] Error 2
| ERROR: oe_runmake failed
| ERROR: Function failed: do_compile (see /srv/home/pokybuild/yocto-autobuilder/yocto-slave/p1022ds/build/build/tmp/work/p1022ds-poky-linux-gnuspe/linux-qoriq-sdk-3.0.34-r5/temp/log.do_compile.2167 for further information)
NOTE: recipe linux-qoriq-sdk-3.0.34-r5: task do_compile: Failed
Signed-off-by: Matthew McClintock <msm@freescale.com>
This reference board dates back to 2004, and is largely a legacy
EOL product. The MPC8560 is a pre e500v2 CPU. The SBC8548 is
a more modern, better e500v2 target for people to use as a
reference board with today's kernels, should they require one.
Removing support for it will also allow us to remove some
sbc8560 specific quirk handling in 8250 UART code, and some
MTD mapping support.
Cc: David Woodhouse <David.Woodhouse@intel.com>
Currently we build all board files regardless of the final zImage
target. This is sub-optimal (in terms on compilation) and leads to
problems in one platform needlessly causing failures for other
platforms.
Use the Kconfig variables to selectively construct this board files to
build.
* Create mpc8548cds.dtsi
* Move lbc, soc and pci0 nodes to mpc8548cds_32b.dtsi
* Change cuImage.mpc8548cds to cuImage.mpc8548cds_32b
* Rename mpc8548cds.dts to mpc8548cds_32b.dts
Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com>
Signed-off-by: Li Yang <leoli@freescale.com>
Kbuild: Use dtc's -d (dependency) option
dtc: Implement -d option to write out a dependency file
kbuild: Fix comment in Makefile.lib
scripts/genksyms: clean lex/yacc generated files
kbuild: Correctly deal with make options which contain an "s"
This hooks dtc into Kbuild's dependency system.
Thus, for example, "make dtbs" will rebuild tegra-harmony.dtb if only
tegra20.dtsi has changed yet tegra-harmony.dts has not. The previous
lack of this feature recently caused me to have very confusing "git
bisect" results.
For ARM, it's obvious what to add to $(targets). I'm not familiar enough
with other architectures to know what to add there. Powerpc appears to
already add various .dtb files into $(targets), but the other archs may
need something added to $(targets) to work.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
[mmarek: Dropped arch/c6x part to avoid merging commits from the middle
of the merge window]
arch/powerpc/platforms/40x/ppc40x_simple.c
Based on original work by David 'Shaggy' Kleikamp.
Signed-off-by: Josh Boyer <jwboyer@gmail.com>
So I've had one of these for a while and it looks like the vendor never
bothered submitting the support upstream.
This adds it using ppc40x_simple and provides a device-tree.
There are some changes to the boot wrapper because the way u-boot works
on this thing, it seems to expect a multipart image with the kernel,
initrd and dtb in it.
The USB support is missing as it needs the yet unmerged driver for
the DWC OTG part and the GPIOs may need further definition in the dts.
This adds a skeletton for the new Power "Non Virtualized"
platform which will be used by machines supporting running
without an hypervisor, for example in order to run KVM.
These machines will be using a new firmware called OPAL
for which the support will be provided by later patches.
The PowerNV platform is intended to be also usable under
the BML environment used internally for early CPU bringup
which is why the code also supports using RTAS instead of
OPAL in various places.
Currently, the build can (very rarely) fail to build because libfdt.h has
not been created or is in the process of being copied.
This is a first cut at making bootwrapper code which will
produce a zImage compliant with the requirements set down
by ePAPR.
This is a very simple bootwrapper, taking the device tree
blob supplied by the ePAPR boot program and passing it on
to the kernel. It builds on the earlier patch to build a
relocatable ET_DYN zImage to meet the other ePAPR image
requirements.
For good measure we have some paranoid checks which will
generate warnings if some of the ePAPR entry condition
guarantees are not met.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
The dts-installed variable is initialised using a wildcard path that
will be expanded relative to the build directory. Use the existing
variable dtstree to generate an absolute wildcard path that will work
when building in a separate directory.
Reported-by: Gerhard Pircher <gerhard_pircher@gmx.net>
Tested-by: Gerhard Pircher <gerhard_pircher@gmx.net> [against 2.6.32]
Modify arch/powerpc/boot/Makefile to use dtc command in
scripts/Makefile.lib
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
It was used in the dim distant past for adding initrds to images
for legacy iSeries, but it's not even used for that now that we
have initramfs. So remove it.
This is a trivial 4xx plaform that uses the new simple bsp from
Josh and is handy to use in simulators such as ISS or even Mambo
who don't properly implement most of the actual devices in the
SoC but really only the core.
Signed-off-by: Torez Smith <lnxtorez@linux.vnet.ibm.com>
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
The maple platform failed to load because it's firmware could not take a
link address of 0x4000000. A new platform type with a link address of
0x400000 had to be created for the maple.
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Commit ac4c2a3bbe5db5fc570b1d0ee1e474db7cb22585 broke the build
of all powerpc boot wrappers.
It attempts to add an include of autoconf.h but used the wrong
path for it. It also adds -D__KERNEL__ to our boot wrapper, both
things that we pretty much didn't do on purpose so far.
We want our boot wrapper to remain independent enough of the kernel
for various reasons, one of them being that you can "wrap" an existing
kernel at distro install time which allows to ship one kernel image
and a set of boot wrappers for different platforms, the wrappers
don't have to be built out of the same kernel build tree.
It's also incorrect to do what the patch does in our boot environment
since we may not have a proper alignment exception handler which means
we may not be able to fixup the few cases where an unaligned access will
need SW emulation (depends on the core variant, could be when crossing
page or segment boundaries for example).
This patch fixes it by putting the old code back in and using the
new "fancy" variant only when CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS
is set, which happens not to be set on powerpc since we don't include
autoconf.h. It also reverts the changes to our boot wrapper Makefile.
This means that x86 should, afaik, keep the optimisations since its
boot wrapper does include autoconf.h and define __KERNEL__ (though I
doubt they make that much different outside of slow embedded processors).
JFFS2 uses lesser compression ratio and inflate always ends up in "copy
direct from output" case.
This patch tries to optimize the direct copy procedure. Uses
get_unaligned() but only in one place.
The copy loop just above this one can also use this optimization, but I
havn't done so as I have not tested if it is a win there too.
On my MPC8321 this is about 17% faster on my JFFS2 root FS than the
original.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Cc: Roel Kluin <roel.kluin@gmail.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Add support for the Nintendo Wii video game console to the powerpc
bootwrapper.
dtbImage.wii is a wrapped image that contains a flat device tree,
an entry point compatible with the Homebrew Channel and BootMii,
and an optional initrd.
Signed-off-by: Albert Herranz <albert_herranz@yahoo.es>
Acked-by: Segher Boessenkool <segher@kernel.crashing.org>
