path: root/arch/powerpc/boot/dts/adder875-uboot.dts
2008-02-05[POWERPC] 8xx: Add clock-frequency to adder875 and mpc885ads dtsBryan O'Donoghue
cpm_uart_core has a dependency on fsl,cpm-brg/clock-frequency, this means that a .dts that uses the cpm uart driver needs to supply a clock-frequency entry for get_brgfreq to return a meaningful number. Signed-off-by: Bryan O'Donoghue <bodonoghue@codehermit.ie> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-23[POWERPC] 8xx: adder875 - Fix flash bus-width and remove duplicate __initdataScott Wood
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-23[POWERPC] 8xx: Analogue & Micro Adder875 board support.Scott Wood
