path: root/arch/powerpc/boot
2012-08-09powerpc/85xx: use the BRx registers to enable indirect mode on the P1022DSTimur Tabi
commit 6bd825f02966be8ba544047cab313d6032c23819 upstream. In order to enable the DIU video controller on the P1022DS, the FPGA needs to be switched to "indirect mode", where the localbus is disabled and the FPGA is accessed via writes to localbus chip select signals CS0 and CS1. To obtain the address of CS0 and CS1, the platform driver uses an "indirect pixis mode" device tree node. This node assumes that the localbus 'ranges' property is sorted in chip-select order. That is, reg value 0 maps to CS0, reg value 1 maps to CS1, etc. This is how the 'ranges' property is supposed to be arranged. Unfortunately, the 'ranges' property is often mis-arranged, and not just on the P1022DS. Linux normally does not care, since it does not program the localbus. But the indirect-mode code on the P1022DS does care. The "proper" fix is to have U-Boot fix the 'ranges' property, but this would be too cumbersome. The names and 'reg' properties of all the localbus devices would also need to be updated, and determining which localbus device maps to which chip select is board-specific. Instead, we determine the CS0/CS1 base addresses the same way that U-boot does -- by reading the BRx registers directly and mapping them to physical addresses. This code is simpler and more reliable, and it does not require a U-boot or device tree change. Since the indirect pixis device tree node is no longer needed, the node is deleted from the DTS. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-19powerpc/mpc85xx: add MPIC message dts nodeMingkai Hu
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-29powerpc/dts: Removed fsl,msi property from dts.Diana CRACIUN
The association in the decice tree between PCI and MSI using fsl,msi property was an artificial one and it does not reflect the actual hardware. Signed-off-by: Diana CRACIUN <Diana.Craciun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-29powerpc/85xx: add the P1020UTM-PC DTS supportJerry Huang
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-29powerpc/85xx: add the P1020MBG-PC DTS supportJerry Huang
2012-03-28powerpc: Random little legacy iSeries removal tidy upsStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-03-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc merge from Benjamin Herrenschmidt: "Here's the powerpc batch for this merge window. It is going to be a bit more nasty than usual as in touching things outside of arch/powerpc mostly due to the big iSeriesectomy :-) We finally got rid of the bugger (legacy iSeries support) which was a PITA to maintain and that nobody really used anymore. Here are some of the highlights: - Legacy iSeries is gone. Thanks Stephen ! There's still some bits and pieces remaining if you do a grep -ir series arch/powerpc but they are harmless and will be removed in the next few weeks hopefully. - The 'fadump' functionality (Firmware Assisted Dump) replaces the previous (equivalent) "pHyp assisted dump"... it's a rewrite of a mechanism to get the hypervisor to do crash dumps on pSeries, the new implementation hopefully being much more reliable. Thanks Mahesh Salgaonkar. - The "EEH" code (pSeries PCI error handling & recovery) got a big spring cleaning, motivated by the need to be able to implement a new backend for it on top of some new different type of firwmare. The work isn't complete yet, but a good chunk of the cleanups is there. Note that this adds a field to struct device_node which is not very nice and which Grant objects to. I will have a patch soon that moves that to a powerpc private data structure (hopefully before rc1) and we'll improve things further later on (hopefully getting rid of the need for that pointer completely). Thanks Gavin Shan. - I dug into our exception & interrupt handling code to improve the way we do lazy interrupt handling (and make it work properly with "edge" triggered interrupt sources), and while at it found & fixed a wagon of issues in those areas, including adding support for page fault retry & fatal signals on page faults. - Your usual random batch of small fixes & updates, including a bunch of new embedded boards, both Freescale and APM based ones, etc..." I fixed up some conflicts with the generalized irq-domain changes from Grant Likely, hopefully correctly. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (141 commits) powerpc/ps3: Do not adjust the wrapper load address powerpc: Remove the rest of the legacy iSeries include files powerpc: Remove the remaining CONFIG_PPC_ISERIES pieces init: Remove CONFIG_PPC_ISERIES powerpc: Remove FW_FEATURE ISERIES from arch code tty/hvc_vio: FW_FEATURE_ISERIES is no longer selectable powerpc/spufs: Fix double unlocks powerpc/5200: convert mpc5200 to use of_platform_populate() powerpc/mpc5200: add options to mpc5200_defconfig powerpc/mpc52xx: add a4m072 board support powerpc/mpc5200: update mpc5200_defconfig to fit for charon board Documentation/powerpc/mpc52xx.txt: Checkpatch cleanup powerpc/44x: Add additional device support for APM821xx SoC and Bluestone board powerpc/44x: Add support PCI-E for APM821xx SoC and Bluestone board MAINTAINERS: Update PowerPC 4xx tree powerpc/44x: The bug fixed support for APM821xx SoC and Bluestone board powerpc: document the FSL MPIC message register binding powerpc: add support for MPIC message register API powerpc/fsl: Added aliased MSIIR register address to MSI node in dts powerpc/85xx: mpc8548cds - add 36-bit dts ...
2012-03-21powerpc/ps3: Do not adjust the wrapper load addressStephen Rothwell
Commit c55aef0e5bc6 "powerpc/boot: Change the load address for the wrapper to fit the kernel" adjusted the laod address if the uncompressed kernel was too large. Ps3 does not compress the kernel and uses a different linker script, so do not adjust the load address in that case. fixes this build error: powerpc64-linux-ld: section .text loaded at [0000000000e00000,0000000000e0721b] overlaps section .kernel:dtb loaded at [0000000000e00000,0000000000e0066f] Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-03-21powerpc: Remove the remaining CONFIG_PPC_ISERIES piecesStephen Rothwell
2012-03-21Merge remote-tracking branch 'kumar/next' into nextBenjamin Herrenschmidt
2012-03-21Merge remote-tracking branch 'jwb/next' into nextBenjamin Herrenschmidt
2012-03-21powerpc/mpc52xx: add a4m072 board supportHeiko Schocher
Add DTS file for a4m072 board and add its name to the list of the supported boards. Signed-off-by: Heiko Schocher <hs@denx.de> cc: Grant Likely <grant.likely@secretlab.ca> cc: devicetree-discuss@ozlabs.org cc: Wolfgang Denk <wd@denx.de> cc: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-03-17powerpc/44x: Add additional device support for APM821xx SoC and Bluestone boardVinh Nguyen Huu Tuong
This patch updates the dts file for bluestone board with support: - UART1 - L2 cache - NAND with NDFC - PCI-E Signed-off-by: Vinh Nguyen Huu Tuong <vhtnguyen@apm.com> Signed-off-by: Josh Boyer <jwboyer@gmail.com>
2012-03-16powerpc/fsl: Added aliased MSIIR register address to MSI node in dtsDiana CRACIUN
The MSIIR register for each MSI bank is aliased to a different address. The MSI node reg property was updated to contain this address: e.g. reg = <0x41600 0x200 0x44140 4>; The first region contains the address and length of the MSI register set and the second region contains the address of the aliased MSIIR register at 0x44140. Signed-off-by: Diana CRACIUN <Diana.Craciun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: mpc8548cds - add 36-bit dtsZhao Chenhui
Create mpc8548cds_36b.dts. Support 36-bit mode. Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: Refactor mpc8548cds device treeZhao Chenhui
* Create mpc8548cds.dtsi * Move lbc, soc and pci0 nodes to mpc8548cds_32b.dtsi * Change cuImage.mpc8548cds to cuImage.mpc8548cds_32b * Rename mpc8548cds.dts to mpc8548cds_32b.dts Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: mpc8548cds - Add FPGA node to dtschenhui zhao
Remove FPGA(CADMUS) macros in code. Move it to dts. Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: mpc8548cds - fix alias in mpc8548si-pre.dtsiZhao Chenhui
Correct ethernet1 and add ethernet2 and ethernet3. Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: mpc8548cds - Add RapidIO node to dtschenhui zhao
Enable RapidIO and add rapidio and rmu nodes to dts. Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: mpc8548cds - Add NOR flash node to dtschenhui zhao
2012-03-16powerpc/dts: fix the compatible string of sec 4.0Liu Shuo
Fix the compatible string of sec 4.0 to match with CAAM driver according to Documentation/devicetree/bindings/crypto/fsl-sec4.txt Signed-off-by: Liu Shuo <shuo.liu@freescale.com> Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/83xx: mpc836x - fix failed phy detection for ucc ethernet on MDSPaul Gortmaker
The mpc836x_mds platform has been broken since the commit 6fe3264945ee63292cdfb27b6e95bc52c603bb09 "netdev/phy: Use mdiobus_read() so that proper locks are taken" which caused the fsl_pq_mdio TBI autoprobe to oops. The oops was "fixed" in commit 28d8ea2d568534026ccda3e8936f5ea1e04a86a1 "fsl_pq_mdio: Clean up tbi address configuration" by simply removing the the autoscan code, and making tbi nodes mandatory. Some of the newer reference platforms were updated to have tbi nodes in 220669495bf8b68130a8218607147c7b74c28d2b "powerpc: Add TBI PHY node to first MDIO bus" but the older mpc836x didn't get one and hence was just failing with -EBUSY as follows: fsl-pq_mdio: probe of e0102120.mdio failed with error -16 ... net eth0: Could not attach to PHY eth0: Cannot initialize PHY, aborting. Add a TBI node and use the 1st free address for it. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: Board support for GE IMP3AMartyn Welch
Initial board support for the GE IMP3A, a 3U compactPCI card with a p2020 processor. Signed-off-by: Martyn Welch <martyn.welch@ge.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: Add dts for p1020rdb-pc boardZhicheng Fan
P1020RDB-PC Overview ------------------ 1Gbyte DDR3 SDRAM 32 Mbyte NAND flash 10 16Mbyte NOR flash 16 Mbyte SPI flash SD connector to interface with the SD memory card Real-time clock on I2C bus PCIe: - x1 PCIe slot - x1 mini-PCIe slot 10/100/1000 BaseT Ethernet ports: - eTSEC1, RGMII: one 10/100/1000 port using VitesseTM VSC7385 L2 switch - eTSEC2, SGMII: one 10/100/1000 port using VitesseTM VSC8221 - eTSEC3, RGMII: one 10/100/1000 port using AtherosTM AR8021 USB 2.0 port: - Two USB2.0 Type A receptacles - One USB2.0 signal to Mini PCIe slot Dual RJ45 UART ports: - DUART interface: supports two UARTs up to 115200 bps for console display Signed-off-by: Zhicheng Fan <b32736@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: Clean up partition nodes in dts for MPC8572DSJia Hongtao
Signed-off-by: Jin Qing <b24347@freescale.com> Signed-off-by: Jia Hongtao <B38951@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: p1022ds: disable the NOR flash node if video is enabledTimur Tabi
The Freescale P1022 has a unique pin muxing "feature" where the DIU video controller's video signals are muxed with 24 of the local bus address signals. When the DIU is enabled, the bulk of the local bus is disabled, preventing access to memory-mapped devices like NOR flash and the pixis FPGA. Therefore, if the DIU is going to be enabled, then memory-mapped devices on the localbus, like NOR flash, need to be disabled. This also means that the localbus is not a 'simple-bus' any more, so remove that string from the compatible node. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: create 32-bit DTS for the P1022DSTimur Tabi
Create a 32-bit address space version of p1022ds.dts. To avoid confusion, p1022ds.dts is renamed to p1022ds_36b.dts. We also create p1022ds.dtsi to store some common nodes. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: Add magic-packet properties for etsecXie Xiaobo
The properties indicates that the hardware supports waking up via magic packet. Signed-off-by: Xie Xiaobo <X.Xie@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: Add some DTS nodes and attributes for mpc8536dsXie Xiaobo
Add partitions for NOR and NAND Flash. Signed-off-by: Xie Xiaobo <X.Xie@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: fix typo in p1010rdb.dtsiGustavo Zacarias
Fix typo introduced by "powerpc: Add TBI PHY node to first MDIO bus" from Andy Fleming. It's device_type rather than device-type, which causes the mdio probe to fail thus making all gianfar ethernet interfaces unusable. Signed-off-by: Gustavo Zacarias <gustavo@zacarias.com.ar> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: p2020rdb & p1010rdb - lower spi flash freq to 40MhzSebastian Andrzej Siewior
This is here most likely since the FSL bsp. Back in the FSL bsp it was set to 50Mhz and working. However the driver divided the SoC freq. only by 2. According to the TRM the platform clock (which the manual refers in its formula) is the system clock divided by two. So in the end it has to divide by 4 and this is what the fsl-spi driver in tree is doing. Since then the flash is not wokring I guess. After chaning the freq from 50Mhz to 40Mhz like others do then I can access the flash. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: p2020rdb - move the NAND address.Sebastian Andrzej Siewior
It is not at 0xffa00000. According to current u-boot source the NAND controller is always at 0xff800000 and it is either at CS0 or CS1 depending on NAND or NAND+NOR mode. In 36bit mode it is shifted to 0xfff800000 but it has always an eight there and never an A. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: Add dts for p1025rdb boardZhicheng Fan
P1025RDB Overview ------------------ 1Gbyte DDR3 SDRAM 32 Mbyte NAND flash 16Mbyte NOR flash 16 Mbyte SPI flash SD connector to interface with the SD memory card Real-time clock on I2C bus PCIe: - x1 PCIe slot - x1 mini-PCIe slot 10/100/1000 BaseT Ethernet ports: - eTSEC1, RGMII: one 10/100/1000 port using AtherosTM AR8021 - eTSEC2, SGMII: one 10/100/1000 port using VitesseTM VSC8221 - eTSEC3, RGMII: one 10/100/1000 port using AtherosTM AR8021 USB 2.0 port: - Two USB2.0 Type A receptacles - One USB2.0 signal to Mini PCIe slot Dual RJ45 UART ports: - DUART interface: supports two UARTs up to 115200 bps for console display Signed-off-by: Zhicheng Fan <b32736@freescale.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: Add usb controller version infoRamneek Mehresh
Add usb controller version info for the following: MPC8536, P1010, P1020, P1021, P1022, P1023, P2020, P2041, P3041, P3060, P5020 Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: Add p2020rdb-pc dts supportTang Yuantian
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Tang Yuantian <b29983@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-16powerpc/85xx: Added dts for P1021RDB-PC boardXu Jiucheng
P1021RDB-PC Overview ----------------- 1Gbyte DDR3 (on board DDR) 16Mbyte NOR flash 32Mbyte eSLC NAND Flash 256 Kbit M24256 I2C EEPROM 128 Mbit SPI Flash memory Real-time clock on I2C bus SD/MMC connector to interface with the SD memory card PCIex - x1 PCIe slot or x1 PCIe to dual SATA controller - x1 mini-PCIe slot USB 2.0 - ULPI PHY interface: SMSC USB3300 USB PHY and Genesys Logic’s GL850A - Two USB2.0 Type A receptacles - One USB2.0 signal to Mini PCIe slot eTSEC1: Connected to RGMII PHY VSC7385 eTSEC2: Connected to SGMII PHY VSC8221 eTSEC3: Connected to SGMII PHY AR8021 DUART interface: supports two UARTs up to 115200 bps for console display Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Xu Jiucheng <B37781@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-06powerpc/44x: Add new compatible value for EMAC node of APM821XX dts file.Duc Dang
This compatible value will be used to distinguish some special features of APM821XX EMAC: no half duplex mode support, configuring jumbo frame. Signed-off-by: Duc Dang <dhdang@apm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-23powerpc/mpic: Add "last-interrupt-source" property to override hardwareKyle Moffett
The FreeScale PowerQUICC-III-compatible (mpc85xx/mpc86xx) MPICs do not correctly report the number of hardware interrupt sources, so software needs to override the detected value with "256". To avoid needing to write custom board-specific code to detect that scenario, allow it to be easily overridden in the device-tree. Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-02-23fsl/mpic: Create and document the "single-cpu-affinity" device-tree flagKyle Moffett
The Freescale MPIC (and perhaps others in the future) is incapable of routing non-IPI interrupts to more than once CPU at a time. Currently all of the Freescale boards msut pass the MPIC_SINGLE_DEST_CPU flag to mpic_alloc(), but that information should really be present in the device-tree. Older board code can't rely on the device-tree having the property set, but newer platforms won't need it manually specified in the code. [BenH: Remove unrelated changes, folded in a different patch] Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-02-23fsl/mpic: Document and use the "big-endian" device-tree flagKyle Moffett
The MPIC code checks for a "big-endian" property and sets the flag MPIC_BIG_ENDIAN if one is present, although prior to the "mpic->flags" fixup that would never have worked anways. Unfortunately, even now that it works properly, the Freescale mpic device-node (the "PowerQUICC-III"-compatible one) does not specify it, so all of the board ports need to manually pass it to mpic_alloc(). Document the flag and add it to the pq3 device tree. Existing code will still need to pass the MPIC_BIG_ENDIAN flag because their dtb may not have this property, but new platforms shouldn't need to do so. Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-01-18powerpc/85xx: Add dr_mode property in USB nodesRamneek Mehresh
Add usb2 controller node for P1020RDB, P2020RDB, P2020DS, P1021MDS Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-18powerpc/85xx: Enable USB2 controller node for P1020RDBRamneek Mehresh
Enable USB2 controller node for P1020RDB. USB2 controller is used only when board boots from SPI or SD as it is muxed with eLBC Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-18powerpc/85xx: Fix cmd12 bug and add the chip compatible for eSDHCJerry Huang
According to latest kernel, the auto-cmd12 property should be "sdhci,auto-cmd12", and according to the SDHC binding and the workaround for the special chip, add the chip compatible for eSDHC: "fsl,p1022-esdhc", "fsl,mpc8536-esdhc", "fsl,p1020-esdhc", "fsl,p2020-esdhc" and "fsl,p1010-esdhc". Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-16Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Kbuild: Use dtc's -d (dependency) option dtc: Implement -d option to write out a dependency file kbuild: Fix comment in Makefile.lib scripts/genksyms: clean lex/yacc generated files kbuild: Correctly deal with make options which contain an "s"
2012-01-15Kbuild: Use dtc's -d (dependency) optionStephen Warren
This hooks dtc into Kbuild's dependency system. Thus, for example, "make dtbs" will rebuild tegra-harmony.dtb if only tegra20.dtsi has changed yet tegra-harmony.dts has not. The previous lack of this feature recently caused me to have very confusing "git bisect" results. For ARM, it's obvious what to add to $(targets). I'm not familiar enough with other architectures to know what to add there. Powerpc appears to already add various .dtb files into $(targets), but the other archs may need something added to $(targets) to work. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> [mmarek: Dropped arch/c6x part to avoid merging commits from the middle of the merge window] Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (185 commits) powerpc: fix compile error with 85xx/p1010rdb.c powerpc: fix compile error with 85xx/p1023_rds.c powerpc/fsl: add MSI support for the Freescale hypervisor arch/powerpc/sysdev/fsl_rmu.c: introduce missing kfree powerpc/fsl: Add support for Integrated Flash Controller powerpc/fsl: update compatiable on fsl 16550 uart nodes powerpc/85xx: fix PCI and localbus properties in p1022ds.dts powerpc/85xx: re-enable ePAPR byte channel driver in corenet32_smp_defconfig powerpc/fsl: Update defconfigs to enable some standard FSL HW features powerpc: Add TBI PHY node to first MDIO bus sbc834x: put full compat string in board match check powerpc/fsl-pci: Allow 64-bit PCIe devices to DMA to any memory address powerpc: Fix unpaired probe_hcall_entry and probe_hcall_exit offb: Fix setting of the pseudo-palette for >8bpp offb: Add palette hack for qemu "standard vga" framebuffer offb: Fix bug in calculating requested vram size powerpc/boot: Change the WARN to INFO for boot wrapper overlap message powerpc/44x: Fix build error on currituck platform powerpc/boot: Change the load address for the wrapper to fit the kernel powerpc/44x: Enable CRASH_DUMP for 440x ... Fix up a trivial conflict in arch/powerpc/include/asm/cputime.h due to the additional sparse-checking code for cputime_t.
2012-01-04powerpc/fsl: update compatiable on fsl 16550 uart nodesKumar Gala
The Freescale serial port's are pretty much a 16550, however there are some FSL specific bugs and features. Add a "fsl,ns16550" compatiable string to allow code to handle those FSL specific issues. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-04powerpc/85xx: fix PCI and localbus properties in p1022ds.dtsTimur Tabi
PCI ranges, localbus reg and localbus chip-select 2 range do not match the memory map setup by bootloader. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-04powerpc: Add TBI PHY node to first MDIO busAndy Fleming
Systems which use the fsl_pq_mdio driver need to specify an address for TBI PHY transactions such that the address does not conflict with any PHYs on the bus (all transactions to that address are directed to the onboard TBI PHY). The driver used to scan for a free address if no address was specified, however this ran into issues when the PHY Lib was fixed so that all MDIO transactions were protected by a mutex. As it is, the code was meant to serve as a transitional tool until the device trees were all updated to specify the TBI address. The best fix for the mutex issue was to remove the scanning code, but it turns out some of the newer SoCs have started to omit the tbi-phy node when SGMII is not being used. As such, these devices will now fail unless we add a tbi-phy node to the first mdio controller. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-12-21powerpc/boot: Change the WARN to INFO for boot wrapper overlap messageSuzuki Poulose
commit c55aef0e5bc6 ("powerpc/boot: Change the load address for the wrapper to fit the kernel") introduced a WARNING to inform the user that the uncompressed kernel would overlap the boot uncompressing wrapper code. Change it to an INFO. I initially thought, this would be a 'WARNING' for the those boards, where the link_address should be fixed, so that the user can take actions accordingly. Changing the same to INFO. Signed-off-by: Suzuki K. Poulose <suzuki@in.ibm.com> Signed-off-by: Josh Boyer <jwboyer@gmail.com>
