path: root/arch/powerpc/configs/85xx/ksi8560_defconfig
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09powerpc: Trim defconfigsBenjamin Herrenschmidt
This trims all our defconfigs using make savedefconfig Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-04-19powerpc: 2.6.34 update of defconfigs for embedded 6xx/7xxx, 8xx, 8xxxKumar Gala
2010-04-19powerpc/mpc8xxx defconfigs - turn off SYSFS_DEPRECATEDKim Phillips
a recent fc11 udev update on an 83xx board made root console login disappear: Updating : udev-141-8.fc11.ppc 32/83 udev: starting version 141 udev: deprecated sysfs layout; update the kernel or disable CONFIG_SYSFS_DEPRECATED; some udev features will not work correctly and sure enough, turning off SYSFS_DEPRECATED brings the login prompt back. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-06powerpc: 2.6.33 update of defconfigs for embedded 6xx/7xxx, 8xx, 8xxxKumar Gala
2009-11-05powerpc: 2.6.32 update of defconfigs for embedded 6xx/7xxx, 8xx, 8{3,5,6}xxxKumar Gala
Updated mpc85xx_{smp_}defconfig to enable: * XES_MPC85xx board * PCI MSI * RapidIO Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-29powerpc: Update defconfigs for embedded 6xx/7xxx, 8xx, 8{3,5,6}xxxKumar Gala
2009-05-13powerpc/85xx: Update defconfigsKumar Gala
2009-01-26powerpc/85xx: Update defconfigsKumar Gala
2008-11-08powerpc: Updated Freescale PPC related defconfigsKumar Gala
unset CONFIG_PCI_LEGACY in the defconfigs as none of them enable ISDN drivers which seem to be the only place we are using pci_find_device Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-21powerpc: Update defconfigs for FSL PPC boardsKumar Gala
Since we are updated defconfigs I went ahead and moved the asp8347_defconfig under 83xx/ and the mpc8536_ds_defconfig under 85xx/ as that is where they should have been to start with. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-09[POWERPC] Updated Freescale PPC defconfigsKumar Gala
2008-04-17[POWERPC] 83xx/85xx: Reorganize defconfigsKumar Gala
Board specific defconfigs are useful, however with the ability to do multi-board defconfigs they aren't needed in the top level configs directory Move the 83xx/85xx board specific defconfigs to individual directories under arch/powerpc/configs. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
