path: root/arch/powerpc/configs/g5_defconfig
2010-08-09powerpc: Trim defconfigsBenjamin Herrenschmidt
This trims all our defconfigs using make savedefconfig Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-06-15powerpc: Disable CONFIG_SYSFS_DEPRECATEDGrant Likely
Acked-by: Grant Likely <grant.likely@secretlab.ca> On 5 May 2010 21:33, "Anton Blanchard" <anton@samba.org> wrote: CONFIG_SYSFS_DEPRECATED can cause issues with newer distros and should not be required for any distro in the last 3 or 4 years, so disable it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-18powerpc/defconfigs: Disable token ring in powerpc defconfigsAnton Blanchard
Token what? Lets save some space in our powerpc kernels and remove token ring support. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-18powerpc/defconfigs: Reduce 64bit vmlinux by making acenic and cramfs modulesAnton Blanchard
Machines with acenic adapters are rare these days, so we may as well make it a module. Cramfs is also very rarely used so we can make it a module. Together this saves 143kB on a 64bit compile: text data bss dec hex filename 8247176 1729404 1221988 11198568 aae068 vmlinux~ 8134997 1727588 1188836 11051421 a8a19d vmlinux Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2008-11-11powerpc: Update desktop/server defconfigsPaul Mackerras
Turned off CONFIG_PCI_LEGACY and turned on EXT4, and otherwise mostly took the defaults. This also updates ppc6xx_defconfig, which covers the 6xx/7xx/7xxx-based embedded boards. Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-26powerpc: Update defconfigs for most non-embedded platformsPaul Mackerras
2008-06-16[POWERPC] Turn on ATA_SFF so we get SATA_SVW back in defconfigsPaul Mackerras
This enables CONFIG_ATA_SFF in the defconfigs that are intended to work on a G5 powermac, i.e. g5_defconfig and ppc64_defconfig. Since the support for the SATA cell in the K2 chipset is provided by the sata_svw.c driver, and that depends on CONFIG_ATA_SFF, we need to turn that and CONFIG_SATA_SVW back on so we can get to the hard disk on G5s. Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-20[POWERPC] Update defconfigs for desktop/server systemsPaul Mackerras
2008-04-29[POWERPC] windfarm: Add PowerMac 12,1 supportÉtienne Bersac
This implements a new driver named windfarm_pm121, which drives the fans on PowerMac 12,1 machines : iMac G5 iSight (rev C) 17" and 20". It's based on the windfarm_pm81 driver from Benjamin Herrenschmidt. This includes fixes from David Woodhouse correcting the names of some of the sensors. Signed-off-by: Étienne Bersac <bersace@gmail.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-07[POWERPC] Remove CONFIG_PCI_LEGACY from some configsStephen Rothwell
This will remove some build warnings and doesn't stop us building any drivers that we were building previously with these configs. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-03-20[POWERPC] Update some defconfigsPaul Mackerras
2007-12-06[POWERPC] Update defconfigsPaul Mackerras
This updates all the defconfigs in arch/powerpc/configs except iseries and ps3, which were updated by the preceding commits. This mostly takes the defaults, except that I turned on tickless idle and high-resolution timers for everything, and turned off instrumentation support and "Fair group CPU scheduler" for the smaller/embedded platforms. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-17[POWERPC] Enable SLUB in *_defconfigAnton Blanchard
When checking out the new NO_HZ support in powerpc, I noticed we never slept for more than 2 seconds. It turns out SLAB has a 2 second per cpu timer that causes this. After switching to SLUB I see some nice 4 second sleeps which is the limit on this POWER6 box (the decrementer ticks at 512MHz): slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 3.96 sec slept 3.80 sec slept 2.99 sec Since SLUB is now the default and some powerpc defconfigs already enable it, lets enable SLUB across the board for consistency. While doing this I also noticed that the maple defconfig has SLAB debugging enabled which is sure to make your box nice and slow. Fix that too. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-30[POWERPC] Update defconfigsPaul Mackerras
2007-06-26[POWERPC] Update defconfigsPaul Mackerras
2007-06-26[POWERPC] Update g5_defconfigwill schmidt
Update the g5_defconfig with default settings. This is to keep things up to date, and specifically to ensure that the CONFIG_MACINTOSH_DRIVERS option is enabled. This also turns on CONFIG_MSI. Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com> cc: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-24[POWERPC] Rename MPIC_BROKEN_U3 to MPIC_U3_HT_IRQSMichael Ellerman
Rename MPIC_BROKEN_U3 to something a little more descriptive. Its effect is to enable support for HT irqs behind the PCI-X/HT bridge on U3/U4 (aka. CPC9x5) parts. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-01-22[POWERPC] Update defconfigsPaul Mackerras
Mostly took the defaults, except tried to get the netfilter options more or less as they were before. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-26[POWERPC] update powerpc defconfig files after libata kconfig breakageOlaf Hering
Update defconfig files after libata .config breakage sed -i 's/CONFIG_SCSI_SATA_/CONFIG_SATA_/;s/CONFIG_SCSI_SATA/CONFIG_ATA/' arch/powerpc/configs/*g Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-10[POWERPC] Update defconfigsPaul Mackerras
2006-08-17[POWERPC] update {g5,iseries,pseries}_defconfigsWill Schmidt
Updating the defconfigs for iseries, pseries, and G5. Sticking with the defaults, with the following exceptions: I've turned off HW_RANDOM for all three configs. For G5, I've enabled SND_AOA and friends as modules; this includes the FABRIC_LAYOUT, ONYX, TAS, TOONIE and SOUNDBUS* config options. Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-21[PATCH] powerpc: update {g5,iseries,pseries}_defconfigsWill Schmidt
Default choices for all. Signed-off-by: Will Schmidt <willschm@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-24[PATCH] powerpc: Update {g5,pseries,ppc64}_defconfigOlof Johansson
Update defconfigs for g5, pseries and generic ppc64. Default choices for everything, with the following exceptions: * Enable WINDFARM_PM112 on g5 and ppc64. * Increase CONFIG_NR_CPUS to 4 in g5_defconfig * CONFIG_TIGON3=y instead of =m in g5_defconfig Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-18[PATCH] e1000: Added disable packet split capabilityJesse Brandeburg
Adds the ability to disability packet split at compile time and use the legacy receive path on PCI express hardware. Made this a CONFIG option and modified the Kconfig, to reflect the new option. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: John Ronciak <john.ronciak@intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-12-20powerpc: update defconfigsPaul Mackerras
2005-11-16[PATCH] powerpc: update defconfigsBenjamin Herrenschmidt
My patch moving ppc64 RTC to genrtc was supposed to update all defconfigs, but for some reason, the patch actually posted only had the pseries one... ouch. This patch properly updates all defconfigs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-08[PATCH] ppc64: Update g5_defconfig for ARCH=powerpcBenjamin Herrenschmidt
This patch updates g5_defconfig for ARCH=powerpc in order to add the SMU support & thermal drivers to it, the pmac sound driver (works on some G5s) and replaces rivafb with nvidiafb which works better for the cards found in G5 based machines. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-03powerpc: Copy default configs into arch/powerpc/configsMichael Ellerman
Copy default configs into arch/powerpc/configs, rename bpa_defconfig to cell_defconfig while we're at it. Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
