path: root/arch/powerpc/configs/linkstation_defconfig
2007-08-29[POWERPC] Update defconfigsKumar Gala
2007-06-26[POWERPC] Update defconfigsPaul Mackerras
2007-02-09[POWERPC] Update to linkstation / kurobox supportGuennadi Liakhovetski
Linkstation systems capable of running mainline kernels use u-boot as a bootloader, so, specifying a suitable kernel command is not a problem. Don't guess. Also extend linkstation_defconfig to support the linkstation HS model with a IT8212 IDE controller and kuroboxHD/HD-HLAN linkstation models with a tulip ethernet chip. The latter also require a slightly different .dts file, which is also included with this patch. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-01-22[POWERPC] Update defconfigsPaul Mackerras
Mostly took the defaults, except tried to get the netfilter options more or less as they were before. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[POWERPC] Linkstation / kurobox supportGuennadi Liakhovetski
Support for the Kurobox(HG)/LinkStation-I NAS systems by Buffalo Technology, should be also applicable to the PPC TeraStation family. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
