It looks like it's ~4 years since we updated some of these, so do a bulk
update.
Verified that the before and after generated configs are exactly the
same.
Which begs the question why update them? The answer is that it can be
confusing when the stored defconfig drifts too far from the generated
result.
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
This trims all our defconfigs using make savedefconfig
On 5 May 2010 21:33, "Anton Blanchard" <anton@samba.org> wrote:
CONFIG_SYSFS_DEPRECATED can cause issues with newer distros and should not
be required for any distro in the last 3 or 4 years, so disable it.
Updated mpc85xx_{smp_}defconfig to enable:
* XES_MPC85xx board
* PCI MSI
* RapidIO
unset CONFIG_PCI_LEGACY in the defconfigs as none of them enable
ISDN drivers which seem to be the only place we are using pci_find_device
Since we are updated defconfigs I went ahead and moved the
asp8347_defconfig under 83xx/ and the mpc8536_ds_defconfig under
85xx/ as that is where they should have been to start with.
This updates all the defconfigs in arch/powerpc/configs except iseries
and ps3, which were updated by the preceding commits.
This mostly takes the defaults, except that I turned on tickless idle
and high-resolution timers for everything, and turned off instrumentation
support and "Fair group CPU scheduler" for the smaller/embedded platforms.
When checking out the new NO_HZ support in powerpc, I noticed we never
slept for more than 2 seconds. It turns out SLAB has a 2 second per cpu
timer that causes this.
After switching to SLUB I see some nice 4 second sleeps which is the
limit on this POWER6 box (the decrementer ticks at 512MHz):
slept 4.19 sec
slept 4.19 sec
slept 4.19 sec
slept 4.19 sec
slept 3.96 sec
slept 3.80 sec
slept 2.99 sec
Since SLUB is now the default and some powerpc defconfigs already enable
it, lets enable SLUB across the board for consistency. While doing this
I also noticed that the maple defconfig has SLAB debugging enabled which
is sure to make your box nice and slow. Fix that too.
Mostly took the defaults, except tried to get the netfilter options
more or less as they were before.
Update defconfig files after libata .config breakage
sed -i 's/CONFIG_SCSI_SATA_/CONFIG_SATA_/;s/CONFIG_SCSI_SATA/CONFIG_ATA/' arch/powerpc/configs/*g
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Add default config for mpc7448 hpc2 (taiga) board.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
