Enable the audio drivers in the non-corenet 85xx defconfigs so that audio
is enabled on the Freescale P1022DS reference board.
Enable framebuffer console support by default in the defconfigs for the
Freescale 85xx-based reference board. This allows the boot messages to
be shown on the video display on the P1022DS.
The P1023 processor is an e500v2 based SoC that utilizes the DPAA
networking architecture. This adds basic board support for non-DPAA
functionality (device tree, board file, etc).
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
This debug option has no overhead other than a slight increase in
kernel size, and makes bug reports more useful. While some end users
may prefer to save the space, as a default on a kernel config aimed
primarily at development on reference boards, it should be enabled.
Uwe Kleine-König reported:
while working on an defconfig (arm/mx27) I noticed that just updating
it[1] results in removing CONFIG_EEPROM_AT24=y. The reason is that
since commit
v2.6.36-5965-g5f2365d (misc devices: do not enable by default)
MISC_DEVICES isn't enabled anymore by default. So all defconfigs that
have CONFIG_SOME_SYMBOL=y (or =m) (with SOME_SYMBOL depending on
MISC_DEVICES) but not CONFIG_MISC_DEVICES=y suffer from the same
problem.
This restores those misc devices to the powerpc defconfigs.
Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de
Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Acked-by: Uwe Kleine-König
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
The Freescale P1022DS has an on-chip video controller called the DIU, and a
driver for this device already exists. Update the platform file for the
P1022DS reference board to enable the driver, and update the defconfig for
Freescale MPC85xx boards to add the driver.
[Edited to resolve header add/add conflict and drop #define DEBUG.
-- broonie]
Acked-by: Kumar Gala <kumar.gala@freescale.com>
This trims all our defconfigs using make savedefconfig
Introduce basic support for the Freescale P1022DS reference board, based on the
Freescale BSP for this board. This patch excludes the DIU, SSI, and MMC/SD
drivers. Only a 36-bit DTS is provided.
Update mpc86xx_smp_defconfig and mpc85xx_defconfig to support the P1022DS.
This means enabling 64-bit physical address support, increasing the maximum
zone order to 12 (to allow the DIU driver to allocate large chunks), and
clean up the audio options to disable the deprecated OSS support.
a recent fc11 udev update on an 83xx board made root console login
disappear:
Updating : udev-141-8.fc11.ppc 32/83
udev: starting version 141
udev: deprecated sysfs layout; update the kernel or disable CONFIG_SYSFS_DEPRECATED;
some udev features will not work correctly
and sure enough, turning off SYSFS_DEPRECATED brings the login prompt back.
Updated mpc85xx_{smp_}defconfig to enable:
* XES_MPC85xx board
* PCI MSI
* RapidIO
Since the vast majority of 85xx platforms are UP we introduce a new SMP
config for the few platforms that have more than one core. Beyond
CONFIG_SMP=y and its dependencies this should be identical to
mpc85xx_defconfig.
