path: root/arch/powerpc/configs/pmac32_defconfig
2007-12-06[POWERPC] Update defconfigsPaul Mackerras
This updates all the defconfigs in arch/powerpc/configs except iseries and ps3, which were updated by the preceding commits. This mostly takes the defaults, except that I turned on tickless idle and high-resolution timers for everything, and turned off instrumentation support and "Fair group CPU scheduler" for the smaller/embedded platforms. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-18serial: turn serial console suspend a boot rather than compile time optionAndres Salomon
Currently, there's a CONFIG_DISABLE_CONSOLE_SUSPEND that allows one to stop the serial console from being suspended when the rest of the machine goes to sleep. This is incredibly useful for debugging power management-related things; however, having it as a compile-time option has proved to be incredibly inconvenient for us (OLPC). There are plenty of times that we want serial console to not suspend, but for the most part we'd like serial console to be suspended. This drops CONFIG_DISABLE_CONSOLE_SUSPEND, and replaces it with a kernel boot parameter (no_console_suspend). By default, the serial console will be suspended along with the rest of the system; by passing 'no_console_suspend' to the kernel during boot, serial console will remain alive during suspend. For now, this is pretty serial console specific; further fixes could be applied to make this work for things like netconsole. Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@suspend2.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17[POWERPC] Enable SLUB in *_defconfigAnton Blanchard
When checking out the new NO_HZ support in powerpc, I noticed we never slept for more than 2 seconds. It turns out SLAB has a 2 second per cpu timer that causes this. After switching to SLUB I see some nice 4 second sleeps which is the limit on this POWER6 box (the decrementer ticks at 512MHz): slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 4.19 sec slept 3.96 sec slept 3.80 sec slept 2.99 sec Since SLUB is now the default and some powerpc defconfigs already enable it, lets enable SLUB across the board for consistency. While doing this I also noticed that the maple defconfig has SLAB debugging enabled which is sure to make your box nice and slow. Fix that too. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-30[POWERPC] Update defconfigsPaul Mackerras
2007-07-29Replace CONFIG_SOFTWARE_SUSPEND with CONFIG_HIBERNATIONRafael J. Wysocki
Replace CONFIG_SOFTWARE_SUSPEND with CONFIG_HIBERNATION to avoid confusion (among other things, with CONFIG_SUSPEND introduced in the next patch). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-26[POWERPC] Update defconfigsPaul Mackerras
2007-01-22[POWERPC] Update defconfigsPaul Mackerras
Mostly took the defaults, except tried to get the netfilter options more or less as they were before. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-26[POWERPC] update powerpc defconfig files after libata kconfig breakageOlaf Hering
Update defconfig files after libata .config breakage sed -i 's/CONFIG_SCSI_SATA_/CONFIG_SATA_/;s/CONFIG_SCSI_SATA/CONFIG_ATA/' arch/powerpc/configs/*g Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-26[POWERPC] enable sysrq in pmac32_defconfigOlaf Hering
Enable sysrq also for pmac32 Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-10[POWERPC] Update defconfigsPaul Mackerras
2006-07-26[POWERPC] fix up front-LED KconfigJohannes Berg
This patch fixes the front-LED Kconfig issues I introduced while creating it. Apparently having a dependency isn't enough to have the select not evaluated or something like that. The patch also changes the default configuration for pmac32 select the default for the LED to be the IDE trigger. While I was at it, I completely updated the defconfig and also added snd-aoa to it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-15[POWERPC] update pmac32_defconfigAnton Blanchard
Some updates to the pmac32_defconfig to make it more useful: - Enable LSF (large single files) since we enable LBD (large block devices) - Enable IPSEC related options - Enable remaining raid/dm options as modules - Disable eth1394, I doubt any has that hardware and it has a nasty habit of auto loading first and skewing network device numbering - Enable dummy and tun as modules, always useful to have them around - Enable EHCI, no wonder my usb2 disk was so slow - Enable USB storage - Enable ext3 acls - Disable autofs and enable autofsv4 instead - Enable nfs v3/v4 client and server. Dont want to be left in the dark ages of pre v3 - Enable all crypto as modules, things like cryptsetup want some of them I havent enabled the BCM43xx, perhaps we should now? Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-16powerpc: update defconfigsPaul Mackerras
2006-01-15[PATCH] powerpc: Update pmac32_defconfigBenjamin Herrenschmidt
2006-01-09[PATCH] powerpc: Add pmac32 defconfig for ARCH=powerpcBenjamin Herrenschmidt
This adds a defconfig for PowerMac with ARCH=powerpc Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
