path: root/arch/powerpc/configs/storcenter_defconfig
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09powerpc: Trim defconfigsBenjamin Herrenschmidt
This trims all our defconfigs using make savedefconfig Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-06-15powerpc: Disable CONFIG_SYSFS_DEPRECATEDGrant Likely
Acked-by: Grant Likely <grant.likely@secretlab.ca> On 5 May 2010 21:33, "Anton Blanchard" <anton@samba.org> wrote: CONFIG_SYSFS_DEPRECATED can cause issues with newer distros and should not be required for any distro in the last 3 or 4 years, so disable it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-04-19powerpc: 2.6.34 update of defconfigs for embedded 6xx/7xxx, 8xx, 8xxxKumar Gala
2010-01-06powerpc: 2.6.33 update of defconfigs for embedded 6xx/7xxx, 8xx, 8xxxKumar Gala
2009-11-05powerpc: 2.6.32 update of defconfigs for embedded 6xx/7xxx, 8xx, 8{3,5,6}xxxKumar Gala
Updated mpc85xx_{smp_}defconfig to enable: * XES_MPC85xx board * PCI MSI * RapidIO Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-29powerpc: Update defconfigs for embedded 6xx/7xxx, 8xx, 8{3,5,6}xxxKumar Gala
2009-05-13powerpc/embedded6xx: Update defconfigsKumar Gala
2009-03-09powerpc: fix linkstation and storcenter compilation breakageGuennadi Liakhovetski
Defining flash partition table in platform code is deprecated, and due to recent changes linkstation and storcenter do not compile any more with their default configurations because of undefined references to physmap_set_partitions(). Instead of fixing them by using the correct kernel configuration macro in preprocessor conditional, remove partition table definitions altogether. Instead add support for partition definition on the command-line and in device tree to the default configurations. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-28Merge commit 'kumar/kumar-merge' into mergeBenjamin Herrenschmidt
2009-01-26powerpc/embedded6xx: Update defconfigsKumar Gala
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2008-11-08powerpc: Updated Freescale PPC related defconfigsKumar Gala
unset CONFIG_PCI_LEGACY in the defconfigs as none of them enable ISDN drivers which seem to be the only place we are using pci_find_device Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-21powerpc: Update defconfigs for FSL PPC boardsKumar Gala
Since we are updated defconfigs I went ahead and moved the asp8347_defconfig under 83xx/ and the mpc8536_ds_defconfig under 85xx/ as that is where they should have been to start with. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-09[POWERPC] Updated Freescale PPC defconfigsKumar Gala
2008-03-31[POWERPC] Fix defconfigs so we dont set both GENRTC and RTCLIBKumar Gala
The new rtc subsystem conflicts with genrtc so don't enable GENRTC if RTCLIB is enabled. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-24[POWERPC] Update some defconfigsKumar Gala
2008-01-23[POWERPC] Add initial storcenter config file.Jon Loeliger
Signed-off-by: Jon Loeliger <jdl@freescale.com> Acked-by: Andy Wilcox <andy@protium.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
