path: root/arch/powerpc/crypto
2013-03-05powerpc: Fix compile of sha1-powerpc-asm.S on 32-bitTony Breeds
When building with CRYPTO_SHA1_PPC enabled we fail with: powerpc/crypto/sha1-powerpc-asm.S: Assembler messages: powerpc/crypto/sha1-powerpc-asm.S:116: Error: can't resolve `0' {*ABS* section} - `STACKFRAMESIZE' {*UND* section} powerpc/crypto/sha1-powerpc-asm.S:116: Error: expression too complex powerpc/crypto/sha1-powerpc-asm.S:178: Error: unsupported relocation against STACKFRAMESIZE Use INT_FRAME_SIZE instead of STACKFRAMESIZE. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Tested-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-01-10powerpc: Add a powerpc implementation of SHA-1Michael Ellerman
This patch adds a crypto driver which provides a powerpc accelerated implementation of SHA-1, accelerated in that it is written in asm. Original patch by Paul, minor fixups for upstream by moi. Lightly tested on 64-bit with the test program here: http://michael.ellerman.id.au/files/junkcode/sha1test.c Seems to work, and is "not slower" than the generic version. Needs testing on 32-bit. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
