path: root/arch/powerpc/include/asm/cputhreads.h
2011-05-04powerpc: Convert old cpumask API into new oneKOSAKI Motohiro
Adapt new API. Almost change is trivial. Most important change is the below line because we plan to change task->cpus_allowed implementation. - ctx->cpus_allowed = current->cpus_allowed; Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-11-29powerpc: Cleanup APIs for cpu/thread/core mappingsVaidyanathan Srinivasan
These APIs take logical cpu number as input Change cpu_first_thread_in_core() to cpu_first_thread_sibling() Change cpu_last_thread_in_core() to cpu_last_thread_sibling() These APIs convert core number (index) to logical cpu/thread numbers Add cpu_first_thread_of_core(int core) Changed cpu_thread_to_core() to cpu_core_index_of_thread(int cpu) The goal is to make 'threads_per_core' accessible to the pseries_energy module. Instead of making an API to read threads_per_core, this is a higher level wrapper function to convert from logical cpu number to core number. The current APIs cpu_first_thread_in_core() and cpu_last_thread_in_core() returns logical CPU number while cpu_thread_to_core() returns core number or index which is not a logical CPU number. The new APIs are now clearly named to distinguish 'core number' versus first and last 'logical cpu number' in that core. The new APIs cpu_{first,last}_thread_sibling() work on logical cpu numbers. While cpu_first_thread_of_core() and cpu_core_index_of_thread() work on core index. Example usage: (4 threads per core system) cpu_first_thread_sibling(5) = 4 cpu_last_thread_sibling(5) = 7 cpu_core_index_of_thread(5) = 1 cpu_first_thread_of_core(1) = 4 cpu_core_index_of_thread() is used in cpu_to_drc_index() in the module and cpu_first_thread_of_core() is used in drc_index_to_cpu() in the module. Make API changes to few callers. Export symbols for use in modules. Signed-off-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-20powerpc/mm: Add HW threads support to no_hash TLB managementBenjamin Herrenschmidt
The current "no hash" MMU context management code is written with the assumption that one CPU == one TLB. This is not the case on implementations that support HW multithreading, where several linux CPUs can share the same TLB. This adds some basic support for this to our context management and our TLB flushing code. It also cleans up the optional debugging output a bit Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-08-04powerpc: Move include files to arch/powerpc/include/asmStephen Rothwell
from include/asm-powerpc. This is the result of a mkdir arch/powerpc/include/asm git mv include/asm-powerpc/* arch/powerpc/include/asm Followed by a few documentation/comment fixups and a couple of places where <asm-powepc/...> was being used explicitly. Of the latter only one was outside the arch code and it is a driver only built for powerpc. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
