The taskstats interface uses microsecond granularity for the user and
system time values. The conversion from cputime to the taskstats values
uses the cputime_to_msecs primitive which effectively limits the
granularity to milliseconds. Add the cputime_to_usecs primitive for
architectures that have better, more precise CPU time values. Remove
cputime_to_msecs primitive because there are no more users left.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Luck Tony <tony.luck@intel.com>
Cc: Shailabh Nagar <nagar1234@in.ibm.com>
Cc: Shailabh Nagar <nagar@us.ibm.com>
The cputime code has a few places that do per_cpu(, smp_processor_id()).
Replace them with __get_cpu_var().
For powerpc with CONFIG_VIRT_CPU_ACCOUNTING
jiffies_to_cputime(1) is not compile time constant and run time
calculations are quite expensive. To optimize we use
precomputed value. For all other architectures is is
preprocessor definition.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <1248862529-6063-5-git-send-email-sgruszka@redhat.com>
from include/asm-powerpc. This is the result of a
mkdir arch/powerpc/include/asm
git mv include/asm-powerpc/* arch/powerpc/include/asm
Followed by a few documentation/comment fixups and a couple of places
where <asm-powepc/...> was being used explicitly. Of the latter only
one was outside the arch code and it is a driver only built for powerpc.
