path: root/arch/powerpc/include/asm/ehv_pic.h
2012-02-14irq_domain/powerpc: Use common irq_domain structure instead of irq_hostGrant Likely
This patch drops the powerpc-specific irq_host structures and uses the common irq_domain strucutres defined in linux/irqdomain.h. It also fixes all the users to use the new structure names. Renaming irq_host to irq_domain has been discussed for a long time, and this patch is a step in the process of generalizing the powerpc virq code to be usable by all architecture. An astute reader will notice that this patch actually removes the irq_host structure instead of renaming it. This is because the irq_domain structure already exists in include/linux/irqdomain.h and has the needed data members. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com> Tested-by: Olof Johansson <olof@lixom.net>
2011-06-27powerpc: introduce the ePAPR embedded hypervisor vmpic driverAshish Kalra
The Freescale ePAPR reference hypervisor provides interrupt controller services via a hypercall interface, instead of emulating the MPIC controller. This is called the VMPIC. The ePAPR "virtual interrupt controller" provides interrupt controller services for external interrupts. External interrupts received by a partition can come from two sources: - Hardware interrupts - hardware interrupts come from external interrupt lines or on-chip I/O devices. - Virtual interrupts - virtual interrupts are generated by the hypervisor as part of some hypervisor service or hypervisor-created virtual device. Both types of interrupts are processed using the same programming model and same set of hypercalls. Signed-off-by: Ashish Kalra <ashish.kalra@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
