path: root/arch/powerpc/include/asm/io.h
2011-05-19powerpc: Remove ioremap_flagsAnton Blanchard
We have a confusing number of ioremap functions. Make things just a bit simpler by merging ioremap_flags and ioremap_prot. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-19powerpc: Add ioremap_wcAnton Blanchard
Add ioremap_wc so drivers can request write combining on kernel mappings. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-27powerpc/pci: Split IO vs MMIO indirect access hooksMichael Ellerman
The goal is to avoid adding overhead to MMIO when only PIO is needed Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-03-11powerpc: Wire up /proc/vmallocinfo to our ioremap()Benjamin Herrenschmidt
This adds the necessary bits and pieces to powerpc implementation of ioremap to benefit from caller tracking in /proc/vmallocinfo, at least for ioremap's done after mem init as the older ones aren't tracked. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-12-16powerpc: Remove dead BIO_VMERGE_BOUNDARY definitionFUJITA Tomonori
The block layer dropped the virtual merge feature (b8b3e16cfe6435d961f6aaebcfd52a1ff2a988c5). BIO_VMERGE_BOUNDARY definition is meaningless now (For POWER, BIO_VMERGE_BOUNDARY has been meaningless for a long time since POWER disables the virtual merge feature). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-24POWERPC: Allow 32-bit hashed pgtable code to support 36-bit physicalBecky Bruce
This rearranges a bit of code, and adds support for 36-bit physical addressing for configs that use a hashed page table. The 36b physical support is not enabled by default on any config - it must be explicitly enabled via the config system. This patch *only* expands the page table code to accomodate large physical addresses on 32-bit systems and enables the PHYS_64BIT config option for 86xx. It does *not* allow you to boot a board with more than about 3.5GB of RAM - for that, SWIOTLB support is also required (and coming soon). Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-04powerpc: Move include files to arch/powerpc/include/asmStephen Rothwell
from include/asm-powerpc. This is the result of a mkdir arch/powerpc/include/asm git mv include/asm-powerpc/* arch/powerpc/include/asm Followed by a few documentation/comment fixups and a couple of places where <asm-powepc/...> was being used explicitly. Of the latter only one was outside the arch code and it is a driver only built for powerpc. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
