The switch from using irq_map to irq_alloc_desc*() for managing irq
number allocations introduced new bugs in some of the powerpc
interrupt code. Several functions rely on the value of NR_IRQS to
determine the maximum irq number that could get allocated. However,
with sparse_irq and using irq_alloc_desc*() the maximum possible irq
number is now specified with 'nr_irqs' which may be a number larger
than NR_IRQS. This has caused breakage on powermac when
CONFIG_NR_IRQS is set to 32.
This patch removes most of the direct references to NR_IRQS in the
powerpc code and replaces them with either a nr_irqs reference or by
using the common for_each_irq_desc() macro. The powerpc-specific
for_each_irq() macro is removed at the same time.
Also, the Cell axon_msi driver is refactored to remove the global
build assumption on the size of NR_IRQS and instead add a limit to the
maximum irq number when calling irq_domain_add_nomap().
It makes no sense to export this trivial function. Make it a static inline
instead.
This patch also drops virq_to_hw from arch/c6x since it is unused by that
architecture.
v2: Move irq_hw_number_t into types.h to fix ARM build failure
Now that legacy iSeries is gone, this is no longer used.
Add support for a legacy mapping where irq = (hwirq - first_hwirq + first_irq)
so that a controller driver can allocate a fixed range of irq_descs and use
a simple calculation to translate back and forth between linux and hw irq
numbers. This is needed to use an irq_domain with many of the ARM interrupt
controller drivers that manage their own irq_desc allocations. Ultimately
the goal is to migrate those drivers to use the linear revmap, but doing it
this way allows each driver to be converted separately which makes the
migration path easier.
This patch generalizes the IRQ_DOMAIN_MAP_LEGACY method to use
(first_irq-first_hwirq) as the offset between hwirq and linux irq number,
and adds checks to make sure that the hwirq number does not exceed range
assigned to the controller.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Milton Miller <miltonm@bga.com>
Tested-by: Olof Johansson <olof@lixom.net>
This patch only moves the code. It doesn't make any changes, and the
code is still only compiled for powerpc. Follow-on patches will generalize
the code for other architectures.
There is only one user, and it is trivial to open-code.
This patch drops the powerpc-specific irq_map table and replaces it with
directly using the irq_alloc_desc()/irq_free_desc() interfaces for allocating
and freeing irq_desc structures.
This patch is a preparation step for generalizing the powerpc-specific virq
infrastructure to become irq_domains.
As part of this change, the irq_big_lock is changed to a mutex from a raw
spinlock. There is no longer any need to use a spin lock since the irq_desc
allocation code is now responsible for the critical section of finding
an unused range of irq numbers.
The radix lookup table is also changed to store the irq_data pointer instead
of the irq_map entry since the irq_map is removed. This should end up being
functionally equivalent since only allocated irq_descs are ever added to the
radix tree.
v5: - Really don't ever allocate virq 0. The previous version could still
do it if hint == 0
- Respect irq_virq_count setting for NOMAP. Some NOMAP domains cannot
use virq values above irq_virq_count.
- Use numa_node_id() when allocating irq_descs. Ideally the API should
obtain that value from the caller, but that touches a lot of call sites
so will be deferred to a follow-on patch.
- Fix irq_find_mapping() to include irq numbers lower than
NUM_ISA_INTERRUPTS. With the switch to irq_alloc_desc*(), the lowest
possible allocated irq is now returned by arch_probe_nr_irqs().
v4: - Fix incorrect access to irq_data structure in debugfs code
- Don't ever allocate virq 0
This patch drops the powerpc-specific irq_host structures and uses the common
irq_domain strucutres defined in linux/irqdomain.h. It also fixes all
the users to use the new structure names.
Renaming irq_host to irq_domain has been discussed for a long time, and this
patch is a step in the process of generalizing the powerpc virq code to be
usable by all architecture.
An astute reader will notice that this patch actually removes the irq_host
structure instead of renaming it. This is because the irq_domain structure
already exists in include/linux/irqdomain.h and has the needed data members.
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Move irq_choose_cpu() into arch/powerpc/kernel/irq.c so that it can be used
by other PIC drivers. The function is not MPIC-specific.
Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com>
The only references to the irq_map[].host field are internal to
Signed-off-by: Milton Miller <miltonm@bga.com>
Some irq_host implementations are using virq_to_host to check if
they are the irq_host for a virtual irq. To allow us to make space
versus time tradeoffs, replace this usage with an assertive
virq_is_host that confirms or denies the irq is associated with the
given irq_host.
It was called from irq_create_mapping if that was called for a host
and hwirq that was previously mapped, "to update the flags". But the
only implementation was in beat_interrupt and all it did was repeat a
hypervisor call without error checking that was performed with error
checking at the beginning of the map hook. In addition, the comment on
the beat remap hook says it will only called once for a given mapping,
which would apply to map not remap.
All flags should be known by the time the match hook is called, before
we call the map hook. Removing this mostly unused hook will simpify
the requirements of irq_domain concept.
First step in eliminating irq_map[] table entirely
This is a significant rework of the XICS driver, too significant to
conveniently break it up into a series of smaller patches to be honest.
The driver is moved to a more generic location to allow new platforms
to use it, and is broken up into separate ICP and ICS "backends". For
now we have the native and "hypervisor" ICP backends and one common
RTAS ICS backend.
The driver supports one ICP backend instanciation, and many ICS ones,
in order to accomodate future platforms with multiple possibly different
interrupt "sources" mechanisms.
arch/sparc/kernel/prom_64.c
Merge common code between PowerPC and Microblaze. SPARC implements
irq_of_parse_and_map(), but the implementation is different, so it
does not use this code.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Jeremy Kerr <jeremy.kerr@canonical.com>
Irq stacks provide an essential protection from stack overflows through
external interrupts, at the cost of two additionals stacks per CPU.
Enable them unconditionally to simplify the kernel build and prevent
people from accidentally disabling them.
Writing a driver using SCLPC on the MPC5200B I detected, that the
intspec arrays to map irqs to Linux virq cannot be const, because the
mapping and xlate functions only take non const pointers. All those
functions do not modify the intspec, so a const pointer could be used.
Signed-off-by: Roman Fietze <roman.fietze@telemotive.de>
Defining CONFIG_SPARSE_IRQ enables generic code that gets rid of the
static irq_desc array, and replaces it with an array of pointers to
irq_descs.
It also allows node local allocation of irq_descs, however we
currently don't have the information available to do that, so we just
allocate them on all on node 0.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
get_irq_desc() is a powerpc-specific version of irq_to_desc(). That
is reason enough to remove it, but it also doesn't know about sparse
irq_desc support which irq_to_desc() does (when we enable it).
The irq_desc array consumes quite a lot of space, and for systems
that don't need or can't have 512 irqs it's just wasted space.
The first 16 are reserved for ISA, so the minimum of 32 is really
16 - and no one has asked for more than 512 so leave that as the
maximum.
The OF helpers look like nanodoc but are missing the header. Fix this and a
typo (s/nad/and/) while we are here.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
irq_radix_revmap() currently serves 2 purposes, irq mapping lookup
and insertion which happen in interrupt and process context respectively.
Separate the function into its 2 components, one for lookup only and one
for insertion only.
Fix the only user of the revmap tree (XICS) to use the new functions.
Also, move the insertion into the radix tree of those irqs that were
requested before it was initialized at said tree initialization.
Mutual exclusion between the tree initialization and readers/writers is
handled via a state variable (revmap_trees_allocated) set to 1 when the tree
has been initialized and set to 2 after the already requested irqs have been
inserted in the tree by the init path. This state is checked before any reader
or writer access just like we used to check for tree.gfp_mask != 0 before.
Finally, now that we're not any longer inserting nodes into the radix-tree
in interrupt context, turn the GFP_ATOMIC allocations into GFP_KERNEL ones.
Signed-off-by: Sebastien Dugue <sebastien.dugue@bull.net>
Cc: Michael Ellerman <michael@ellerman.id.au>
Now that arch/ppc is gone and CONFIG_PPC_MERGE is always set, remove
the dead code associated with !CONFIG_PPC_MERGE from arch/powerpc
and include/asm-powerpc.
from include/asm-powerpc. This is the result of a
mkdir arch/powerpc/include/asm
git mv include/asm-powerpc/* arch/powerpc/include/asm
Followed by a few documentation/comment fixups and a couple of places
where <asm-powepc/...> was being used explicitly. Of the latter only
one was outside the arch code and it is a driver only built for powerpc.
