path: root/arch/powerpc/include/asm/mmu.h
2014-07-28powerpc: Remove MMU_FTR_SLBMichael Ellerman
We now only support cpus that use an SLB, so we don't need an MMU feature to indicate that. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-07-11powerpc: Clean up MMU_FTRS_A2 and MMU_FTR_TYPE_3EMichael Ellerman
In fb5a515704d7 "powerpc: Remove platforms/wsp and associated pieces", we removed the last user of MMU_FTRS_A2. So remove it. MMU_FTRS_A2 was the last user of MMU_FTR_TYPE_3E, so remove it also. This leaves some unreachable code in mmu_context_nohash.c, so remove that also. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-01-09powerpc/e6500: TLB miss handler with hardware tablewalk supportScott Wood
There are a few things that make the existing hw tablewalk handlers unsuitable for e6500: - Indirect entries go in TLB1 (though the resulting direct entries go in TLB0). - It has threads, but no "tlbsrx." -- so we need a spinlock and a normal "tlbsx". Because we need this lock, hardware tablewalk is mandatory on e6500 unless we want to add spinlock+tlbsx to the normal bolted TLB miss handler. - TLB1 has no HES (nor next-victim hint) so we need software round robin (TODO: integrate this round robin data with hugetlb/KVM) - The existing tablewalk handlers map half of a page table at a time, because IBM hardware has a fixed 1MiB indirect page size. e6500 has variable size indirect entries, with a minimum of 2MiB. So we can't do the half-page indirect mapping, and even if we could it would be less efficient than mapping the full page. - Like on e5500, the linear mapping is bolted, so we don't need the overhead of supporting nested tlb misses. Note that hardware tablewalk does not work in rev1 of e6500. We do not expect to support e6500 rev1 in mainline Linux. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Mihai Caraman <mihai.caraman@freescale.com>
2012-11-15powerpc: POWER8 cputable entryMichael Neuling
Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-09-17powerpc/mm: Make some of the PGTABLE_RANGE dependency explicitAneesh Kumar K.V
slice array size and slice mask size depend on PGTABLE_RANGE. Reviewed-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-07-03powerpc/mm: remove obsolete comment about page size name arrayScott Wood
The array of names in hugetlbpage.c no longer exists. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-09-20powerpc: Hugetlb for BookEBecky Bruce
Enable hugepages on Freescale BookE processors. This allows the kernel to use huge TLB entries to map pages, which can greatly reduce the number of TLB misses and the amount of TLB thrashing experienced by applications with large memory footprints. Care should be taken when using this on FSL processors, as the number of large TLB entries supported by the core is low (16-64) on current processors. The supported set of hugepage sizes include 4m, 16m, 64m, 256m, and 1g. Page sizes larger than the max zone size are called "gigantic" pages and must be allocated on the command line (and cannot be deallocated). This is currently only fully implemented for Freescale 32-bit BookE processors, but there is some infrastructure in the code for 64-bit BooKE. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-07-22Merge remote-tracking branch 'jwb/next' into nextBenjamin Herrenschmidt
2011-07-12powerpc/44x: don't use tlbivax on AMP systemsDave Kleikamp
Since other OS's may be running on the other cores don't use tlbivax Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2011-07-08powerpc: Create next_tlbcam_idx percpu variable for FSL_BOOKEBecky Bruce
This is used to round-robin TLBCAM entries. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-05-04powerpc: Use new CPU feature bit to select 2.06 tlbieMichael Neuling
This removes MMU_FTR_TLBIE_206 as we can now use CPU_FTR_HVMODE_206. It also changes the logic to select which tlbie to use to be based on this new CPU feature bit. This also duplicates the ASM_FTR_IF/SET/CLR defines for CPU features (copied from MMU features). Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-27powerpc: Free up some CPU feature bits by moving out MMU-related featuresMatt Evans
Some of the 64bit PPC CPU features are MMU-related, so this patch moves them to MMU_FTR_ bits. All cpu_has_feature()-style tests are moved to mmu_has_feature(), and seven feature bits are freed as a result. Signed-off-by: Matt Evans <matt@ozlabs.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-08-05memblock: Remove rmo_size, burry it in arch/powerpc where it belongsBenjamin Herrenschmidt
The RMA (RMO is a misnomer) is a concept specific to ppc64 (in fact server ppc64 though I hijack it on embedded ppc64 for similar purposes) and represents the area of memory that can be accessed in real mode (aka with MMU off), or on embedded, from the exception vectors (which is bolted in the TLB) which pretty much boils down to the same thing. We take that out of the generic MEMBLOCK data structure and move it into arch/powerpc where it belongs, renaming it to "RMA" while at it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-05-05powerpc/47x: Base ppc476 supportDave Kleikamp
This patch adds the base support for the 476 processor. The code was primarily written by Ben Herrenschmidt and Torez Smith, but I've been maintaining it for a while. The goal is to have a single binary that will run on 44x and 47x, but we still have some details to work out. The biggest is that the L1 cache line size differs on the two platforms, but it's currently a compile-time option. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Torez Smith <lnxtorez@linux.vnet.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-08-28powerpc/mm: Add MMU features for TLB reservation & Paired MAS registersKumar Gala
Support for TLB reservation (or TLB Write Conditional) and Paired MAS registers are optional for a processor implementation so we handle them via MMU feature sections. We currently only used paired MAS registers to access the full RPN + perm bits that are kept in MAS7||MAS3. We assume that if an implementation has hardware page table at this time it also implements in TLB reservations. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-20powerpc: Add memory management headers for new 64-bit BookEBenjamin Herrenschmidt
This adds the PTE and pgtable format definitions, along with changes to the kernel memory map and other definitions related to implementing support for 64-bit Book3E. This also shields some asm-offset bits that are currently only relevant on 32-bit We also move the definition of the "linux" page size constants to the common mmu.h file and add a few sizes that are relevant to embedded processors. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-09powerpc: Shield code specific to 64-bit server processorsBenjamin Herrenschmidt
This is a random collection of added ifdef's around portions of code that only mak sense on server processors. Using either CONFIG_PPC_STD_MMU_64 or CONFIG_PPC_BOOK3S as seems appropriate. This is meant to make the future merging of Book3E 64-bit support easier. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-21powerpc: Add 2.06 tlbie mnemonicsMilton Miller
This adds the PowerPC 2.06 tlbie mnemonics and keeps backwards compatibilty for CPUs before 2.06. Only useful for bare metal systems. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-04-23Revert "powerpc: Add support for early tlbilx opcode"Kumar Gala
This reverts commit e9965577406a2148ade97b5e0ce7c448b4ba4ef6. Our HW guys were able to fix this so it never sees the light of day. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-04-07powerpc: Add support for early tlbilx opcodeKumar Gala
During the ISA 2.06 development the opcode for tlbilx changed and some early implementations used to old opcode. Add support for a MMU_FTR fixup to deal with this. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-24powerpc/mm: Introduce early_init_mmu() on 64-bitBenjamin Herrenschmidt
This moves some MMU related init code out of setup_64.c into hash_utils_64.c and calls it early_init_mmu() and early_init_mmu_secondary(). This will make it easier to plug in a new MMU type. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-03-24powerpc/mm: e300c2/c3/c4 TLB errata workaroundKumar Gala
Complete workaround for DTLB errata in e300c2/c3/c4 processors. Due to the bug, the hardware-implemented LRU algorythm always goes to way 1 of the TLB. This fix implements the proposed software workaround in form of a LRW table for chosing the TLB-way. Based on patch from David Jander <david@protonic.nl> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-03-09powerpc/fsl-booke: Add support for tlbilx instructionsKumar Gala
The e500mc core supports the new tlbilx instructions that do core local invalidates and also provide us the ability to take down all TLB entries matching a given PID. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-12powerpc/book-3e: Introduce concept of Book-3e MMUKumar Gala
The Power ISA 2.06 spec introduces a standard MMU programming model that is based on the Freescale Book-E MMU programing model. The Freescale version is pretty backwards compatiable with the ISA 2.06 definition so we are starting to refactor some of the Freescale code so it can be easily shared. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-21powerpc/mm: Add SMP support to no-hash TLB handlingBenjamin Herrenschmidt
This commit moves the whole no-hash TLB handling out of line into a new tlb_nohash.c file, and implements some basic SMP support using IPIs and/or broadcast tlbivax instructions. Note that I'm using local invalidations for D->I cache coherency. At worst, if another processor is trying to execute the same and has the old entry in its TLB, it will just take a fault and re-do the TLB flush locally (it won't re-do the cache flush in any case). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-12-21powerpc/mm: Introduce MMU featuresBenjamin Herrenschmidt
We're soon running out of CPU features and I need to add some new ones for various MMU related bits, so this patch separates the MMU features from the CPU features. I moved over the 32-bit MMU related ones, added base features for MMU type families, but didn't move over any 64-bit only feature yet. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-04powerpc: Move include files to arch/powerpc/include/asmStephen Rothwell
from include/asm-powerpc. This is the result of a mkdir arch/powerpc/include/asm git mv include/asm-powerpc/* arch/powerpc/include/asm Followed by a few documentation/comment fixups and a couple of places where <asm-powepc/...> was being used explicitly. Of the latter only one was outside the arch code and it is a driver only built for powerpc. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
