On architectures with hardware broadcasting of TLB invalidation messages
, it makes sense to reduce the range of the mmu_gather structure when
unmapping page ranges based on the dirty address information passed to
tlb_remove_tlb_entry.
arm64 already does this by directly manipulating the start/end fields
of the gather structure, but this confuses the generic code which
does not expect these fields to change and can end up calculating
invalid, negative ranges when forcing a flush in zap_pte_range.
This patch moves the minimal range calculation out of the arm64 code
and into the generic implementation, simplifying zap_pte_range in the
process (which no longer needs to care about start/end, since they will
point to the appropriate ranges already). With the range being tracked
by core code, the need_flush flag is dropped in favour of checking that
the end of the range has actually been set.
Cc: Russell King - ARM Linux <linux@arm.linux.org.uk>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Paul Mackerras <paulus@samba.org>
This patch moves the common code to 32/64 bit headers and also duplicate
4K_PAGES and 64K_PAGES section. We will later change the 64 bit 64K_PAGES
version to support smaller PTE fragments. The patch doesn't introduce
any functional changes.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
In case other architectures require RCU freed page-tables to implement
gup_fast() and software filled hashes and similar things, provide the
means to do so by moving the logic into generic code.
Requested-by: David Miller <davem@davemloft.net>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
Fix up powerpc to the new mmu_gather stuff.
PPC has an extra batching queue to RCU free the actual pagetable
allocations, use the ARCH extentions for that for now.
For the ppc64_tlb_batch, which tracks the vaddrs to unhash from the
hardware hash-table, keep using per-cpu arrays but flush on context switch
and use a TLF bit to track the lazy_mmu state.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Currently we have a fair bit of rather fiddly code to manage the
various kmem_caches used to store page tables of various levels. We
generally have two caches holding some combination of PGD, PUD and PMD
tables, plus several more for the special hugepage pagetables.
This patch cleans this all up by taking a different approach. Rather
than the caches being designated as for PUDs or for hugeptes for 16M
pages, the caches are simply allocated to be a specific size. Thus
sharing of caches between different types/levels of pagetables happens
naturally. The pagetable size, where needed, is passed around encoded
in the same way as {PGD,PUD,PMD}_INDEX_SIZE; that is n where the
pagetable contains 2^n pointers.
Signed-off-by: David Gibson <dwg@au1.ibm.com>
The mask used to encode the page table cache number in the
batch when freeing page tables was too small for the new
possible values of MMU page sizes. This increases it along
with a comment explaining the constraints.
That patch used to just add a hook to page table flushing but
pulling that string brought out a whole bunch of issues, so it
now does that and more:
- We now make the RCU batching of page freeing SMP only, as I
believe it was intended initially. We make a few more things compile
to nothing on !CONFIG_SMP
- Some macros are turned into functions, though that forced me to
out of line a few stuffs due to unsolvable include depenencies,
however it's probably better that way anyway, it's not -that-
critical code path.
- 32-bit didn't call pte_free_finish() on tlb_flush() which means
that it wouldn't push out the batch to RCU for delayed freeing when
a bunch of page tables have been freed, they would just stay in there
until the batch gets full.
64-bit BookE will use that hook to maintain the virtually linear
page tables or the indirect entries in the TLB when using the
HW loader.
mm: Pass virtual address to [__]p{te,ud,md}_free_tlb()
Upcoming paches to support the new 64-bit "BookE" powerpc architecture
will need to have the virtual address corresponding to PTE page when
freeing it, due to the way the HW table walker works.
Basically, the TLB can be loaded with "large" pages that cover the whole
virtual space (well, sort-of, half of it actually) represented by a PTE
page, and which contain an "indirect" bit indicating that this TLB entry
RPN points to an array of PTEs from which the TLB can then create direct
entries. Thus, in order to invalidate those when PTE pages are deleted,
we need the virtual address to pass to tlbilx or tlbivax instructions.
The old trick of sticking it somewhere in the PTE page struct page sucks
too much, the address is almost readily available in all call sites and
almost everybody implemets these as macros, so we may as well add the
argument everywhere. I added it to the pmd and pud variants for consistency.
Acked-by: David Howells <dhowells@redhat.com> [MN10300 & FRV]
Acked-by: Nick Piggin <npiggin@suse.de>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390]
Refactor the RCU based pte free code that was used on ppc64 to be used
on all powerpc.
Additionally refactor pte_free() & pte_free_kernel() into common code
between ppc32 & ppc64.
from include/asm-powerpc. This is the result of a
mkdir arch/powerpc/include/asm
git mv include/asm-powerpc/* arch/powerpc/include/asm
Followed by a few documentation/comment fixups and a couple of places
where <asm-powepc/...> was being used explicitly. Of the latter only
one was outside the arch code and it is a driver only built for powerpc.
