On POWER6 systems RA needs to be the base and RB the index.
If they are reversed you take a misdirect hit.
Signed-off-by: Mike Wolf <mjwolf@us.ibm.com>
The way I intend to use tophys/tovirt on 64-bit BookE is different
from the "trick" that we currently play for 32-bit BookE so change
the condition of definition of these macros to make it so.
Also, make sure we only use rfid and mtmsrd instead of rfi and mtmsr
for 64-bit server processors, not all 64-bit processors.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Cleans up the VSX load/store instructions by moving them into
ppc-opcode.h.
Signed-off-by: Michael Neuling <mikey@neuling.org>
The section .text.init.refok is deprecated and __REF (.ref.text)
should be used in assembly files instead. This patch cleans up a few
uses of .text.init.refok in the powerpc architecture.
Signed-off-by: Tim Abbott <tabbott@mit.edu>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Create a new header that becomes a single location for defining PowerPC
opcodes used by code that is either generationg instructions
at runtime (fixups, debug, etc.), emulating instructions, or just
compiling instructions old assemblers don't know about.
We currently don't handle the floating point emulation or alignment decode
as both are better handled by the specific decode support they already
have.
Added support for the new dcbzl, dcbal, msgsnd, tlbilx, & wait instructions
since older assemblers don't know about them.
Add the ability for a classic ppc kernel to be loaded at an address
of 32MB. This done by fixing a few places that assume we are loaded
at address 0, and by changing several uses of KERNELBASE to use
PAGE_OFFSET, instead.
Signed-off-by: Dale Farnsworth <dale@farnsworth.org>
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Using LOAD_REG_IMMEDIATE to get the address of kernel symbols
generates 5 instructions where LOAD_REG_ADDR can do it in one,
and will generate R_PPC64_ADDR16_* relocations in the output when
we get to making the kernel as a position-independent executable,
which we'd rather not have to handle. This changes various bits
of assembly code to use LOAD_REG_ADDR when we need to get the
address of a symbol, or to use suitable position-independent code
for cases where we can't access the TOC for various reasons, or
if we're not running at the address we were linked at.
It also cleans up a few minor things; there's no reason to save and
restore SRR0/1 around RTAS calls, __mmu_off can get the return
address from LR more conveniently than the caller can supply it in
R4 (and we already assume elsewhere that EA == RA if the MMU is on
in early boot), and enable_64b_mode was using 5 instructions where
2 would do.
from include/asm-powerpc. This is the result of a
mkdir arch/powerpc/include/asm
git mv include/asm-powerpc/* arch/powerpc/include/asm
Followed by a few documentation/comment fixups and a couple of places
where <asm-powepc/...> was being used explicitly. Of the latter only
one was outside the arch code and it is a driver only built for powerpc.
