path: root/arch/powerpc/kernel/eeh_dev.c
2017-09-21powerpc/eeh: Create PHB PEs after EEH is initializedBenjamin Herrenschmidt
Otherwise we end up not yet having computed the right diag data size on powernv where EEH initialization is delayed, thus causing memory corruption later on when calling OPAL. Fixes: 5cb1f8fdddb7 ("powerpc/powernv/pci: Dynamically allocate PHB diag data") Cc: stable@vger.kernel.org # v4.13+ Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Russell Currey <ruscur@russell.cc> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2017-09-01powerpc/eeh: Delete an error out of memory message at init timeMarkus Elfring
Omit an extra message for a memory allocation failure in eeh_dev_init(). This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> [mpe: Do not drop the message that can happen at runtime and lead to an event not being handled] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2017-08-31powerpc/eeh: Remove unnecessary pointer to phb from eeh_devAlexey Kardashevskiy
The eeh_dev struct already holds a pointer to pci_dn which it does not exist without and pci_dn itself holds the very same pointer so just use it. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2016-06-21powerpc/pci: Delay populating pdnGavin Shan
The pdn (struct pci_dn) instances are allocated from memblock or bootmem when creating PCI controller (hoses) in setup_arch(). PCI hotplug, which will be supported by proceeding patches, releases PCI device nodes and their corresponding pdn on unplugging event. The memory chunks for pdn instances allocated from memblock or bootmem are hard to reused after being released. This delays creating pdn by pci_devs_phb_init() from setup_arch() to core_initcall() so that they are allocated from slab. The memory consumed by pdn can be released to system without problem during PCI unplugging time. It indicates that pci_dn is unavailable in setup_arch() and the the fixup on pdn (like AGP's) can't be carried out that time. We have to do that in pcibios_root_bridge_prepare() on maple/pasemi/powermac platforms where/when the pdn is available. pcibios_root_bridge_prepare is called from subsys_initcall() which is executed after core_initcall() so the code flow does not change. At the mean while, the EEH device is created when pdn is populated, meaning pdn and EEH device have same life cycle. In turn, we needn't call eeh_dev_init() to create EEH device explicitly. Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Reviewed-by: Alexey Kardashevskiy <aik@ozlabs.ru> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2016-03-09powerpc/eeh: powerpc/eeh: Support error recovery for VF PEWei Yang
PFs are enumerated on PCI bus, while VFs are created by PF's driver. In EEH recovery, it has two cases: 1. Device and driver is EEH aware, error handlers are called. 2. Device and driver is not EEH aware, un-plug the device and plug it again by enumerating it. The special thing happens on the second case. For a PF, we could use the original pci core to enumerate the bus, while for VF we need to record the VFs which aer un-plugged then plug it again. Also The patch caches the VF index in pci_dn, which can be used to calculate VF's bus, device and function number. Those information helps to locate the VF's PCI device instance when doing hotplug during EEH recovery if necessary. Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com> Acked-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-03-24powerpc/eeh: Create eeh_dev from pci_dn instead of device_nodeGavin Shan
The patch adds function traverse_pci_dn(), which is similar to traverse_pci_devices() except it takes pci_dn, not device_node as parameter. The pci_dev.c has been reworked to create eeh_dev from pci_dn, instead of device_node. Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-08-05powerpc/eeh: Replace pr_warning() with pr_warn()Gavin Shan
pr_warn() is equal to pr_warning(), but the former is a bit more formal according to commit fc62f2f ("kernel.h: add pr_warn for symmetry to dev_warn, netdev_warn"). The patch replaces pr_warning() with pr_warn(). Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-06-20powerpc/eeh: Move common part to kernel directoryGavin Shan
The patch moves the common part of EEH core into arch/powerpc/kernel directory so that we needn't PPC_PSERIES while compiling POWERNV platform: * Move the EEH common part into arch/powerpc/kernel * Move the functions for PCI hotplug from pSeries platform to arch/powerpc/kernel/pci-hotplug.c * Move CONFIG_EEH from arch/powerpc/platforms/pseries/Kconfig to arch/powerpc/platforms/Kconfig * Adjust makefile accordingly Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
