This adds support for running KVM guests in supervisor mode on those
PPC970 processors that have a usable hypervisor mode. Unfortunately,
Apple G5 machines have supervisor mode disabled (MSR[HV] is forced to
1), but the YDL PowerStation does have a usable hypervisor mode.
There are several differences between the PPC970 and POWER7 in how
guests are managed. These differences are accommodated using the
CPU_FTR_ARCH_201 (PPC970) and CPU_FTR_ARCH_206 (POWER7) CPU feature
bits. Notably, on PPC970:
* The LPCR, LPID or RMOR registers don't exist, and the functions of
those registers are provided by bits in HID4 and one bit in HID0.
* External interrupts can be directed to the hypervisor, but unlike
POWER7 they are masked by MSR[EE] in non-hypervisor modes and use
SRR0/1 not HSRR0/1.
* There is no virtual RMA (VRMA) mode; the guest must use an RMO
(real mode offset) area.
* The TLB entries are not tagged with the LPID, so it is necessary to
flush the whole TLB on partition switch. Furthermore, when switching
partitions we have to ensure that no other CPU is executing the tlbie
or tlbsync instructions in either the old or the new partition,
otherwise undefined behaviour can occur.
* The PMU has 8 counters (PMC registers) rather than 6.
* The DSCR, PURR, SPURR, AMR, AMOR, UAMOR registers don't exist.
* The SLB has 64 entries rather than 32.
* There is no mediated external interrupt facility, so if we switch to
a guest that has a virtual external interrupt pending but the guest
has MSR[EE] = 0, we have to arrange to have an interrupt pending for
it so that we can get control back once it re-enables interrupts. We
do that by sending ourselves an IPI with smp_send_reschedule after
hard-disabling interrupts.
architecture bits
This replaces the single CPU_FTR_HVMODE_206 bit with two bits, one to
indicate that we have a usable hypervisor mode, and another to indicate
that the processor conforms to PowerISA version 2.06. We also add
another bit to indicate that the processor conforms to ISA version 2.01
and set that for PPC970 and derivatives.
Some PPC970 chips (specifically those in Apple machines) have a
hypervisor mode in that MSR[HV] is always 1, but the hypervisor mode
is not useful in the sense that there is no way to run any code in
supervisor mode (HV=0 PR=0). On these processors, the LPES0 and LPES1
bits in HID4 are always 0, and we use that as a way of detecting that
hypervisor mode is not useful.
Where we have a feature section in assembly code around code that
only applies on POWER7 in hypervisor mode, we use a construct like
END_FTR_SECTION_IFSET(CPU_FTR_HVMODE | CPU_FTR_ARCH_206)
The definition of END_FTR_SECTION_IFSET is such that the code will
be enabled (not overwritten with nops) only if all bits in the
provided mask are set.
Note that the CPU feature check in __tlbie() only needs to check the
ARCH_206 bit, not the HVMODE bit, because __tlbie() can only get called
if we are running bare-metal, i.e. in hypervisor mode.
This lifts the restriction that book3s_hv guests can only run one
hardware thread per core, and allows them to use up to 4 threads
per core on POWER7. The host still has to run single-threaded.
This capability is advertised to qemu through a new KVM_CAP_PPC_SMT
capability. The return value of the ioctl querying this capability
is the number of vcpus per virtual CPU core (vcore), currently 4.
To use this, the host kernel should be booted with all threads
active, and then all the secondary threads should be offlined.
This will put the secondary threads into nap mode. KVM will then
wake them from nap mode and use them for running guest code (while
they are still offline). To wake the secondary threads, we send
them an IPI using a new xics_wake_cpu() function, implemented in
arch/powerpc/sysdev/xics/icp-native.c. In other words, at this stage
we assume that the platform has a XICS interrupt controller and
we are using icp-native.c to drive it. Since the woken thread will
need to acknowledge and clear the IPI, we also export the base
physical address of the XICS registers using kvmppc_set_xics_phys()
for use in the low-level KVM book3s code.
When a vcpu is created, it is assigned to a virtual CPU core.
The vcore number is obtained by dividing the vcpu number by the
number of threads per core in the host. This number is exported
to userspace via the KVM_CAP_PPC_SMT capability. If qemu wishes
to run the guest in single-threaded mode, it should make all vcpu
numbers be multiples of the number of threads per core.
We distinguish three states of a vcpu: runnable (i.e., ready to execute
the guest), blocked (that is, idle), and busy in host. We currently
implement a policy that the vcore can run only when all its threads
are runnable or blocked. This way, if a vcpu needs to execute elsewhere
in the kernel or in qemu, it can do so without being starved of CPU
by the other vcpus.
When a vcore starts to run, it executes in the context of one of the
vcpu threads. The other vcpu threads all go to sleep and stay asleep
until something happens requiring the vcpu thread to return to qemu,
or to wake up to run the vcore (this can happen when another vcpu
thread goes from busy in host state to blocked).
It can happen that a vcpu goes from blocked to runnable state (e.g.
because of an interrupt), and the vcore it belongs to is already
running. In that case it can start to run immediately as long as
the none of the vcpus in the vcore have started to exit the guest.
We send the next free thread in the vcore an IPI to get it to start
to execute the guest. It synchronizes with the other threads via
the vcore->entry_exit_count field to make sure that it doesn't go
into the guest if the other vcpus are exiting by the time that it
is ready to actually enter the guest.
Note that there is no fixed relationship between the hardware thread
number and the vcpu number. Hardware threads are assigned to vcpus
as they become runnable, so we will always use the lower-numbered
hardware threads in preference to higher-numbered threads if not all
the vcpus in the vcore are runnable, regardless of which vcpus are
runnable.
This adds support for KVM running on 64-bit Book 3S processors,
specifically POWER7, in hypervisor mode. Using hypervisor mode means
that the guest can use the processor's supervisor mode. That means
that the guest can execute privileged instructions and access privileged
registers itself without trapping to the host. This gives excellent
performance, but does mean that KVM cannot emulate a processor
architecture other than the one that the hardware implements.
This code assumes that the guest is running paravirtualized using the
PAPR (Power Architecture Platform Requirements) interface, which is the
interface that IBM's PowerVM hypervisor uses. That means that existing
Linux distributions that run on IBM pSeries machines will also run
under KVM without modification. In order to communicate the PAPR
hypercalls to qemu, this adds a new KVM_EXIT_PAPR_HCALL exit code
to include/linux/kvm.h.
Currently the choice between book3s_hv support and book3s_pr support
(i.e. the existing code, which runs the guest in user mode) has to be
made at kernel configuration time, so a given kernel binary can only
do one or the other.
This new book3s_hv code doesn't support MMIO emulation at present.
Since we are running paravirtualized guests, this isn't a serious
restriction.
With the guest running in supervisor mode, most exceptions go straight
to the guest. We will never get data or instruction storage or segment
interrupts, alignment interrupts, decrementer interrupts, program
interrupts, single-step interrupts, etc., coming to the hypervisor from
the guest. Therefore this introduces a new KVMTEST_NONHV macro for the
exception entry path so that we don't have to do the KVM test on entry
to those exception handlers.
We do however get hypervisor decrementer, hypervisor data storage,
hypervisor instruction storage, and hypervisor emulation assist
interrupts, so we have to handle those.
In hypervisor mode, real-mode accesses can access all of RAM, not just
a limited amount. Therefore we put all the guest state in the vcpu.arch
and use the shadow_vcpu in the PACA only for temporary scratch space.
We allocate the vcpu with kzalloc rather than vzalloc, and we don't use
anything in the kvmppc_vcpu_book3s struct, so we don't allocate it.
We don't have a shared page with the guest, but we still need a
kvm_vcpu_arch_shared struct to store the values of various registers,
so we include one in the vcpu_arch struct.
The POWER7 processor has a restriction that all threads in a core have
to be in the same partition. MMU-on kernel code counts as a partition
(partition 0), so we have to do a partition switch on every entry to and
exit from the guest. At present we require the host and guest to run
in single-thread mode because of this hardware restriction.
This code allocates a hashed page table for the guest and initializes
it with HPTEs for the guest's Virtual Real Memory Area (VRMA). We
require that the guest memory is allocated using 16MB huge pages, in
order to simplify the low-level memory management. This also means that
we can get away without tracking paging activity in the host for now,
since huge pages can't be paged or swapped.
This also adds a few new exports needed by the book3s_hv code.
There are several fields in struct kvmppc_book3s_shadow_vcpu that
temporarily store bits of host state while a guest is running,
rather than anything relating to the particular guest or vcpu.
This splits them out into a new kvmppc_host_state structure and
modifies the definitions in asm-offsets.c to suit.
On 32-bit, we have a kvmppc_host_state structure inside the
kvmppc_book3s_shadow_vcpu since the assembly code needs to be able
to get to them both with one pointer. On 64-bit they are separate
fields in the PACA. This means that on 64-bit we don't need to
copy the kvmppc_host_state in and out on vcpu load/unload, and
in future will mean that the book3s_hv code doesn't need a
shadow_vcpu struct in the PACA at all. That does mean that we
have to be careful not to rely on any values persisting in the
hstate field of the paca across any point where we could block
or get preempted.
Instead of branching out-of-line with the DO_KVM macro to check if we
are in a KVM guest at the time of an interrupt, this moves the KVM
check inline in the first-level interrupt handlers. This speeds up
the non-KVM case and makes sure that none of the interrupt handlers
are missing the check.
Because the first-level interrupt handlers are now larger, some things
had to be move out of line in exceptions-64s.S.
This all necessitated some minor changes to the interrupt entry code
in KVM. This also streamlines the book3s_32 KVM test.
After looking at our system call path, Mary Brown suggested that we
should put all mfspr SRR* instructions before any mtspr SRR*.
To test this I used a very simple null syscall (actually getppid)
testcase at http://ozlabs.org/~anton/junkcode/null_syscall.c
I tested with the following changes against the pseries_defconfig:
CONFIG_VIRT_CPU_ACCOUNTING=n
CONFIG_AUDIT=n
to remove the overhead of virtual CPU accounting and syscall
auditing.
POWER6:
baseline: mean = 757.2 cycles sd = 2.108
modified: mean = 759.1 cycles sd = 2.020
POWER7:
baseline: mean = 411.4 cycles sd = 0.138
modified: mean = 404.1 cycles sd = 0.109
So we have 1.77% improvement on POWER7 which looks significant. The
POWER6 suggest a 0.25% slowdown, but the results are within 1
standard deviation and may be in the noise.
Recent 64-bit server processors (POWER6 and POWER7) have a "Come-From
Address Register" (CFAR), that records the address of the most recent
branch or rfid (return from interrupt) instruction for debugging purposes.
This saves the value of the CFAR in the exception entry code and stores
it in the exception frame. We also make xmon print the CFAR value in
its register dump code.
Rather than extend the pt_regs struct at this time, we steal the orig_gpr3
field, which is only used for system calls, and use it for the CFAR value
for all exceptions/interrupts other than system calls. This means we
don't save the CFAR on system calls, which is not a great problem since
system calls tend not to happen unexpectedly, and also avoids adding the
overhead of reading the CFAR to the system call entry path.
When we take an interrupt or exception from kernel mode and the stack
pointer is obviously not a kernel address (i.e. the top bit is 0), we
switch to an emergency stack, save register values and panic. However,
on 64-bit server machines, we don't actually save the values of r9 - r13
at the time of the interrupt, but rather values corrupted by the
exception entry code for r12-r13, and nothing at all for r9-r11.
This fixes it by passing a pointer to the register save area in the paca
through to the bad_stack code in r3. The register values are saved in
one of the paca register save areas (depending on which exception this
is). Using the pointer in r3, the bad_stack code now retrieves the
saved values of r9 - r13 and stores them in the exception frame on the
emergency stack. This also stores the normal exception frame marker
("regshere") in the exception frame.
Some of the 64bit PPC CPU features are MMU-related, so this patch moves
them to MMU_FTR_ bits. All cpu_has_feature()-style tests are moved to
mmu_has_feature(), and seven feature bits are freed as a result.
Signed-off-by: Matt Evans <matt@ozlabs.org>
Wakeup comes from the system reset handler with a potential loss of
the non-hypervisor CPU state. We save the non-volatile state on the
stack and a pointer to it in the PACA, which the system reset handler
uses to restore things
This uses feature sections to arrange that we always use HSPRG1
as the scratch register in the interrupt entry code rather than
SPRG2 when we're running in hypervisor mode on POWER7. This will
ensure that we don't trash the guest's SPRG2 when we are running
KVM guests. To simplify the code, we define GET_SCRATCH0() and
SET_SCRATCH0() macros like the GET_PACA/SET_PACA macros.
Rework exception macros a bit to split offset from vector and add
some basic support for HDEC, HDSI, HISI and a few more.
Pass the register type to the prolog, also provides alternate "HV"
version of hardware interrupt (0x500) and adjust LPES accordingly
We tag those interrupts by setting bit 0x2 in the trap number
When running in Hypervisor mode (arch 2.06 or later), we store the PACA
in HSPRG0 instead of SPRG1. The architecture specifies that SPRGs may be
lost during a "nap" power management operation (though they aren't
currently on POWER7) and this enables use of SPRG1 by KVM guests.
Recent upstream builds with allmodconfig fail due to lack of space
between 0x3000 and 0x6000. We have a hard block at 0x7000 but we can
spare a page by moving the STAB0 from 0x6000 to 0x8000.
Since STACK_FRAME_OVERHEAD is defined in asm/ptrace.h and that
is ASSEMBER safe, we can just include that instead of going via
asm-offsets.h.
* 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (321 commits)
KVM: Drop CONFIG_DMAR dependency around kvm_iommu_map_pages
KVM: Fix signature of kvm_iommu_map_pages stub
KVM: MCE: Send SRAR SIGBUS directly
KVM: MCE: Add MCG_SER_P into KVM_MCE_CAP_SUPPORTED
KVM: fix typo in copyright notice
KVM: Disable interrupts around get_kernel_ns()
KVM: MMU: Avoid sign extension in mmu_alloc_direct_roots() pae root address
KVM: MMU: move access code parsing to FNAME(walk_addr) function
KVM: MMU: audit: check whether have unsync sps after root sync
KVM: MMU: audit: introduce audit_printk to cleanup audit code
KVM: MMU: audit: unregister audit tracepoints before module unloaded
KVM: MMU: audit: fix vcpu's spte walking
KVM: MMU: set access bit for direct mapping
KVM: MMU: cleanup for error mask set while walk guest page table
KVM: MMU: update 'root_hpa' out of loop in PAE shadow path
KVM: x86 emulator: Eliminate compilation warning in x86_decode_insn()
KVM: x86: Fix constant type in kvm_get_time_scale
KVM: VMX: Add AX to list of registers clobbered by guest switch
KVM guest: Move a printk that's using the clock before it's ready
KVM: x86: TSC catchup mode
When using a relocatable kernel we need to make sure that the trampline code
and the interrupt handlers are both copied to low memory. The only way to do
this reliably is to put them in the copied section.
This patch should make relocated kernels work with KVM.
KVM-Stable-Tag
Signed-off-by: Avi Kivity <avi@redhat.com>
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration,
it maps:
local_irq_enable() -> raw_local_irq_enable()
local_irq_disable() -> raw_local_irq_disable()
local_irq_save() -> raw_local_irq_save()
and under the other configuration, it maps:
raw_local_irq_enable() -> local_irq_enable()
raw_local_irq_disable() -> local_irq_disable()
raw_local_irq_save() -> local_irq_save()
This is quite confusing. There should be one set of names expected of the
arch, and this should be wrapped to give another set of names that are expected
by users of this facility.
Change this to have the arch provide:
flags = arch_local_save_flags()
flags = arch_local_irq_save()
arch_local_irq_restore(flags)
arch_local_irq_disable()
arch_local_irq_enable()
arch_irqs_disabled_flags(flags)
arch_irqs_disabled()
arch_safe_halt()
Then linux/irqflags.h wraps these to provide:
raw_local_save_flags(flags)
raw_local_irq_save(flags)
raw_local_irq_restore(flags)
raw_irqs_disabled_flags(flags)
raw_irqs_disabled()
raw_safe_halt()
with type checking on the flags 'arguments', and then wraps those to provide:
local_irq_disable()
local_irq_enable()
irqs_disabled()
safe_halt()
with tracing included if enabled.
The arch functions can now all be inline functions rather than some of them
having to be macros.
Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300]
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile]
Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze]
Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM]
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR]
Acked-by: Tony Luck <tony.luck@intel.com> [IA-64]
Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R]
Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU]
Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS]
Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC]
Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC]
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390]
Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score]
Acked-by: Matt Fleming <matt@console-pimps.org> [SH]
Acked-by: David S. Miller <davem@davemloft.net> [Sparc]
Acked-by: Chris Zankel <chris@zankel.net> [Xtensa]
Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha]
Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300]
Cc: starvik@axis.com [CRIS]
Cc: jesper.nilsson@axis.com [CRIS]
Cc: linux-cris-kernel@axis.com
Implement perf-events based hw-breakpoint interfaces for PowerPC
64-bit server (Book III S) processors. This allows access to a
given location to be used as an event that can be counted or
profiled by the perf_events subsystem.
This is done using the DABR (data breakpoint register), which can
also be used for process debugging via ptrace. When perf_event
hw_breakpoint support is configured in, the perf_event subsystem
manages the DABR and arbitrates access to it, and ptrace then
creates a perf_event when it is requested to set a data breakpoint.
[Adopted suggestions from Paul Mackerras <paulus@samba.org> to
- emulate_step() all system-wide breakpoints and single-step only the
per-task breakpoints
- perform arch-specific cleanup before unregistration through
arch_unregister_hw_breakpoint()
Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com>
Data address breakpoint exceptions are currently handled along with page-faults
which require interrupts to remain in enabled state. Since exception handling
for data breakpoints aren't pre-empt safe, we handle them separately.
include/linux/kvm.h
We need to run some KVM trampoline code in real mode. Unfortunately, real mode
only covers 8MB on Cell so we need to squeeze ourselves as low as possible.
Also, we need to trap interrupts to get us back from guest state to host state
without telling Linux about it.
This patch adds interrupt traps and includes the KVM code that requires real
mode in the real mode parts of Linux.
Add some dummy symbols for the branches at 0xf00, 0xf20 and 0xf40,
otherwise hits end up in trap_0e which is confusing to the user.
The STAB code used on Power3 and RS/64 uses a second scratch SPRG to
save a GPR in order to decide whether to go to do_stab_bolted_* or
to handle a normal data access exception.
This prevents our scheme of freeing SPRG3 which is user visible for
user uses since we cannot use SPRG0 which, on RS/64, seems to be
read-only for supervisor mode (like POWER4).
This reworks the STAB exception entry to use the PACA as temporary
storage instead.
The kernel uses SPRG registers for various purposes, typically in
low level assembly code as scratch registers or to hold per-cpu
global infos such as the PACA or the current thread_info pointer.
We want to be able to easily shuffle the usage of those registers
as some implementations have specific constraints realted to some
of them, for example, some have userspace readable aliases, etc..
and the current choice isn't always the best.
This patch should not change any code generation, and replaces the
usage of SPRN_SPRGn everywhere in the kernel with a named replacement
and adds documentation next to the definition of the names as to
what those are used for on each processor family.
The only parts that still use the original numbers are bits of KVM
or suspend/resume code that just blindly needs to save/restore all
the SPRGs.
The file include/asm/exception.h contains definitions
that are specific to exception handling on 64-bit server
type processors.
This renames the file to exception-64s.h to reflect that
fact and avoid confusion.
This provides a mechanism to allow the perf_counters code to access
user memory in a PMU interrupt routine. Such an access can cause
various kinds of interrupt: SLB miss, MMU hash table miss, segment
table miss, or TLB miss, depending on the processor. This commit
only deals with 64-bit classic/server processors, which use an MMU
hash table. 32-bit processors are already able to access user memory
at interrupt time. Since we don't soft-disable on 32-bit, we avoid
the possibility of reentering hash_page or the TLB miss handlers,
since they run with interrupts disabled.
On 64-bit processors, an SLB miss interrupt on a user address will
update the slb_cache and slb_cache_ptr fields in the paca. This is
OK except in the case where a PMU interrupt occurs in switch_slb,
which also accesses those fields. To prevent this, we hard-disable
interrupts in switch_slb. Interrupts are already soft-disabled at
this point, and will get hard-enabled when they get soft-enabled
later.
This also reworks slb_flush_and_rebolt: to avoid hard-disabling twice,
and to make sure that it clears the slb_cache_ptr when called from
other callers than switch_slb, the existing routine is renamed to
__slb_flush_and_rebolt, which is called by switch_slb and the new
version of slb_flush_and_rebolt.
Similarly, switch_stab (used on POWER3 and RS64 processors) gets a
hard_irq_disable() to protect the per-cpu variables used there and
in ste_allocate.
If a MMU hashtable miss interrupt occurs, normally we would call
hash_page to look up the Linux PTE for the address and create a HPTE.
However, hash_page is fairly complex and takes some locks, so to
avoid the possibility of deadlock, we check the preemption count
to see if we are in a (pseudo-)NMI handler, and if so, we don't call
hash_page but instead treat it like a bad access that will get
reported up through the exception table mechanism. An interrupt
whose handler runs even though the interrupt occurred when
soft-disabled (such as the PMU interrupt) is considered a pseudo-NMI
handler, which should use nmi_enter()/nmi_exit() rather than
irq_enter()/irq_exit().
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
To prepare for future support of Book3E 64-bit PowerPC processors,
which use a completely different exception handling, we move that
code to a new exceptions-64s.S file.
This file is #included from head_64.S due to some of the absolute
address requirements which can currently only be fulfilled from
within that file.
