Instead of implementing an empty giveup_fpu() function for each
32bit processor type, replace them with an unique empty inline
function.
Signed-off-by: Kevin Hao <haokexin@gmail.com>
We do not want to take single step and branch-taken debug exception
in kernel exception code. But the address range check was not covering
all kernel exception handlers address range.
With this patch we defined the interrupt_end label which defines the
end on kernel exception code. So now we check interrupt_base to
interrupt_end range for not handling debug exception in kernel
exception entry.
Signed-off-by: Bharat Bhushan <bharat.bhushan@freescale.com>
Pull KVM changes from Avi Kivity:
"Changes include additional instruction emulation, page-crossing MMIO,
faster dirty logging, preventing the watchdog from killing a stopped
guest, module autoload, a new MSI ABI, and some minor optimizations
and fixes. Outside x86 we have a small s390 and a very large ppc
update.
Regarding the new (for kvm) rebaseless workflow, some of the patches
that were merged before we switch trees had to be rebased, while
others are true pulls. In either case the signoffs should be correct
now."
Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
arch/powerpc/kvm/book3s_segment.S and arch/x86/include/asm/kvm_para.h.
I suspect the kvm_para.h resolution ends up doing the "do I have cpuid"
check effectively twice (it was done differently in two different
commits), but better safe than sorry ;)
* 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (125 commits)
KVM: make asm-generic/kvm_para.h have an ifdef __KERNEL__ block
KVM: s390: onereg for timer related registers
KVM: s390: epoch difference and TOD programmable field
KVM: s390: KVM_GET/SET_ONEREG for s390
KVM: s390: add capability indicating COW support
KVM: Fix mmu_reload() clash with nested vmx event injection
KVM: MMU: Don't use RCU for lockless shadow walking
KVM: VMX: Optimize %ds, %es reload
KVM: VMX: Fix %ds/%es clobber
KVM: x86 emulator: convert bsf/bsr instructions to emulate_2op_SrcV_nobyte()
KVM: VMX: unlike vmcs on fail path
KVM: PPC: Emulator: clean up SPR reads and writes
KVM: PPC: Emulator: clean up instruction parsing
kvm/powerpc: Add new ioctl to retreive server MMU infos
kvm/book3s: Make kernel emulated H_PUT_TCE available for "PR" KVM
KVM: PPC: bookehv: Fix r8/r13 storing in level exception handler
KVM: PPC: Book3S: Enable IRQs during exit handling
KVM: PPC: Fix PR KVM on POWER7 bare metal
KVM: PPC: Fix stbux emulation
KVM: PPC: bookehv: Use lwz/stw instead of PPC_LL/PPC_STL for 32-bit fields
Use an empty inline instead of an empty function to implement
giveup_altivec on book3e CPUs, similar to flush_altivec_to_thread.
DO_KVM will need to identify the particular exception type.
There is an existing set of arbitrary numbers that Linux passes,
but it's an undocumented mess that sort of corresponds to server/classic
exception vectors but not really.
Signed-off-by: Avi Kivity <avi@redhat.com>
The following patch adds relocatable kernel support - based on processing
of dynamic relocations - for PPC44x kernel.
We find the runtime address of _stext and relocate ourselves based
on the following calculation.
virtual_base = ALIGN(KERNELBASE,256M) +
MODULO(_stext.run,256M)
relocate() is called with the Effective Virtual Base Address (as
shown below)
| Phys. Addr| Virt. Addr |
Page (256M) |------------------------|
Boundary | | |
Kernel Load |___________|_ __ _ _ _ _|<- Effective
Addr(_stext)| | ^ |Virt. Base Addr
| |reloc_offset|
| |______v_____|<-(KERNELBASE)%256M
Page(256M) |-----------|------------|
Boundary | | |
The virt_phys_offset is updated accordingly, i.e,
virt_phys_offset = effective. kernel virt base - kernstart_addr
I have tested the patches on 440x platforms only. However this should
work fine for PPC_47x also, as we only depend on the runtime address
and the current TLB XLAT entry for the startup code, which is available
in r25. I don't have access to a 47x board yet. So, it would be great if
somebody could test this on 47x.
Signed-off-by: Suzuki K. Poulose <suzuki@in.ibm.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Tony Breeds <tony@bakeyournoodle.com>
Cc: Josh Boyer <jwboyer@gmail.com>
Cc: linuxppc-dev <linuxppc-dev@lists.ozlabs.org>
Signed-off-by: Josh Boyer <jwboyer@gmail.com>
DYNAMIC_MEMSTART(old RELOCATABLE) was restricted only to PPC_47x variants
of 44x. This patch enables DYNAMIC_MEMSTART for 440x based chipsets.
Cc: linux ppc dev <linuxppc-dev@lists.ozlabs.org>
The current implementation of CONFIG_RELOCATABLE in BookE is based
on mapping the page aligned kernel load address to KERNELBASE. This
approach however is not enough for platforms, where the TLB page size
is large (e.g, 256M on 44x). So we are renaming the RELOCATABLE used
currently in BookE to DYNAMIC_MEMSTART to reflect the actual method.
The CONFIG_RELOCATABLE for PPC32(BookE) based on processing of the
dynamic relocations will be introduced in the later in the patch series.
This change would allow the use of the old method of RELOCATABLE for
platforms which can afford to enforce the page alignment (platforms with
smaller TLB size).
Changes since v3:
* Introduced a new config, NONSTATIC_KERNEL, to denote a kernel which is
either a RELOCATABLE or DYNAMIC_MEMSTART(Suggested by: Josh Boyer)
Suggested-by: Scott Wood <scottwood@freescale.com>
Tested-by: Scott Wood <scottwood@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
Based on original work by David 'Shaggy' Kleikamp.
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
u64 is used rather than phys_addr_t to keep things simple, as
this is called from assembly code.
Update callers to pass a 64-bit address in r3/r4. Other unused
register assignments that were once parameters to machine_init
are dropped.
For FSL BookE, look up the physical address of the device tree from the
effective address passed in r3 by the loader. This is required for
situations where memory does not start at zero (due to AMP or IOMMU-less
virtualization), and thus the IMA doesn't start at zero, and thus the
device tree effective address does not equal the physical address.
The 44x code (which is shared by 47x) assumes the available physical memory
begins at 0x00000000. This is not necessarily the case in an AMP
environment.
Support CONFIG_RELOCATABLE for 476 in order to allow the kernel to be
loaded into a higher memory range.
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Cc: linuxppc-dev@lists.ozlabs.org
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Since STACK_FRAME_OVERHEAD is defined in asm/ptrace.h and that
is ASSEMBER safe, we can just include that instead of going via
asm-offsets.h.
Clear the machine check syndrom register before enabling machine check
interrupts. The initial state of the tlb can lead to parity errors being
flagged early after a cold boot.
This is a trivial 4xx plaform that uses the new simple bsp from
Josh and is handy to use in simulators such as ISS or even Mambo
who don't properly implement most of the actual devices in the
SoC but really only the core.
Signed-off-by: Torez Smith <lnxtorez@linux.vnet.ibm.com>
This patch adds the base support for the 476 processor. The code was
primarily written by Ben Herrenschmidt and Torez Smith, but I've been
maintaining it for a while.
The goal is to have a single binary that will run on 44x and 47x, but
we still have some details to work out. The biggest is that the L1 cache
line size differs on the two platforms, but it's currently a compile-time
option.
The 47x platform supports multiple cores and shares code with 44x.
Break out code that is common for initializing the primary and secondary
cpus into a function which can be called for both.
This is an attempt at cleaning up a bit the way we handle execute
permission on powerpc. _PAGE_HWEXEC is gone, _PAGE_EXEC is now only
defined by CPUs that can do something with it, and the myriad of
#ifdef's in the I$/D$ coherency code is reduced to 2 cases that
hopefully should cover everything.
The logic on BookE is a little bit different than what it was though
not by much. Since now, _PAGE_EXEC will be set by the generic code
for executable pages, we need to filter out if they are unclean and
recover it. However, I don't expect the code to be more bloated than
it already was in that area due to that change.
I could boast that this brings proper enforcing of per-page execute
permissions to all BookE and 40x but in fact, we've had that now for
some time as a side effect of my previous rework in that area (and
I didn't even know it :-) We would only enable execute permission if
the page was cache clean and we would only cache clean it if we took
and exec fault. Since we now enforce that the later only work if
VM_EXEC is part of the VMA flags, we de-fact already enforce per-page
execute permissions... Unless I missed something
The kernel uses SPRG registers for various purposes, typically in
low level assembly code as scratch registers or to hold per-cpu
global infos such as the PACA or the current thread_info pointer.
We want to be able to easily shuffle the usage of those registers
as some implementations have specific constraints realted to some
of them, for example, some have userspace readable aliases, etc..
and the current choice isn't always the best.
This patch should not change any code generation, and replaces the
usage of SPRN_SPRGn everywhere in the kernel with a named replacement
and adds documentation next to the definition of the names as to
what those are used for on each processor family.
The only parts that still use the original numbers are bits of KVM
or suspend/resume code that just blindly needs to save/restore all
the SPRGs.
This has the consequence of changing the section name use for head
code from ".text.head" to ".head.text". Since this commit changes all
users in the architecture, this change should be harmless.
Signed-off-by: Tim Abbott <tabbott@mit.edu>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
This adds support for 16k and 64k page sizes on PowerPC 44x processors.
The PGDIR table is much smaller than a page when using 16k or 64k
pages (512 and 32 bytes respectively) so we allocate the PGDIR with
kzalloc() instead of __get_free_pages().
One PTE table covers rather a large memory area when using 16k or 64k
pages (32MB or 512MB respectively), so we can easily put FIXMAP and
PKMAP in the area covered by one PTE table.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Signed-off-by: Vladimir Panfilov <pvr@emcraft.com>
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
After discussing with chip designers, it appears that it's not
necessary to set G everywhere on 440 cores. The various core
errata related to prefetch should be sorted out by firmware by
disabling icache prefetching in CCR0. We add the workaround to
the kernel however just in case oooold firmwares don't do it.
This is valid for -all- 4xx core variants. Later ones hard wire
the absence of prefetch but it doesn't harm to clear the bits
in CCR0 (they should already be cleared anyway).
We still leave G=1 on the linear mapping for now, we need to
stop over-mapping RAM to be able to remove it.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Currently, we never set _PAGE_COHERENT in the PTEs, we just OR it in
in the hash code based on some CPU feature bit. We also manipulate
_PAGE_NO_CACHE and _PAGE_GUARDED by hand in all sorts of places.
This changes the logic so that instead, the PTE now contains
_PAGE_COHERENT for all normal RAM pages thay have I = 0 on platforms
that need it. The hash code clears it if the feature bit is not set.
It also adds some clean accessors to setup various valid combinations
of access flags and change various bits of code to use them instead.
This should help having the PTE actually containing the bit
combinations that we really want.
I also removed _PAGE_GUARDED from _PAGE_BASE on 44x and instead
set it explicitely from the TLB miss. I will ultimately remove it
completely as it appears that it might not be needed after all
but in the meantime, having it in the TLB miss makes things a
lot easier.
This is some preliminary work to improve TLB management on SW loaded
TLB powerpc platforms. This introduce support for non-atomic PTE
operations in pgtable-ppc32.h and removes write back to the PTE from
the TLB miss handlers. In addition, the DSI interrupt code no longer
tries to fixup write permission, this is left to generic code, and
_PAGE_HWWRITE is gone.
A recent commit added support for the new 440x6 and 464 cores that have the
added WL1, IL1I, IL1D, IL2I, and ILD2 bits for the caching attributes in the
TLBs. The new bits were cleared in the finish_tlb_load function, however a
similar bit of code was missed in the DataStorage interrupt vector.
For the additonal exception levels (critical, debug, machine check) on
40x/book-e we were using "static" allocations of the stack in the
associated head.S.
Move to a runtime allocation to make the code a bit easier to read as
we mimic how we handle IRQ stacks. Its also a bit easier to setup the
stack with a "dummy" thread_info in C code.
Acked-by: Paul Mackerras <paulus@samba.org>
The new 440x6 core used on AMCC 460EX/GT introduces new storage attibure
fields to the TLB2 word. Those are:
Bit 11 12 13 14 15
WL1 IL1I IL1D IL2I IL2D
With these bits the cache (L1 and L2) can be configured in a more flexible
way, instruction- and data-cache independently now. The "old" I and W bits
are still available and setting these old bits will automically set these
new bits too (for backward compatibilty).
The current code does not clear these fields resulting in disabling the cache
by chance. This patch now makes sure that these new bits are cleared when
the TLB2 word is written.
The architecture allows for "Book-E" style debug interrupts to either go
to critial interrupts of their own debug interrupt level. To allow for
a dynamic kernel to support machines of either type we want to be able to
compile in the interrupt handling code for both exception levels.
Towards this goal we renamed the debug handling macros to specify the
interrupt level in their name (DEBUG_CRIT_EXCEPTION/DebugCrit and
DEBUG_DEBUG_EXCEPTION/DebugDebug).
Additionally, on the Freescale Book-e parts we expanded the exception
stacks to cover the maximum case of needing three exception stacks (normal,
machine check and debug).
There is some kernel text space optimization to be gained if a kernel is
configured for a specific Freescale implementation but we aren't handling
that now to allow for the single kernel image support.
This adds a cputable function pointer for the CPU-side machine
check handling. The semantic is still the same as the old one,
the one in ppc_md. overrides the one in cputable, though
ultimately we'll want to change that so the CPU gets first.
This removes CONFIG_440A which was a problem for multiplatform
kernels and instead fixes up the IVOR at runtime from a setup_cpu
function. The "A" version of the machine check also tweaks the
regs->trap value to differenciate the 2 versions at the C level.
The size of swapper_pg_dir is 8k instead of 4k when using 64-bit PTEs
(CONFIG_PTE_64BIT).
This was reported by Cedric Hombourger <chombourger@gmail.com>
handlers
Move to using PAGE_OFFSET instead of TASK_SIZE or KERNELBASE value on
6xx/40x/44x/fsl-booke to determine if the faulting address is a kernel or
user space address. This mimics how the macro is_kernel_addr() works.
The PowerPC 440EP(x) FPU init is currently done in head_44x
under ifdefs. Since we should support more then one board
in the same kernel, we move FPU initialization code from head_44x
to cpu_setup_44x and add cpu_setup callbacks for 440EP(x).
Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com>
It is just a C char array, so declare it thusly.
We get warnings like the following from the various ppc32 head*.S files:
WARNING: vmlinux.o(.text+0x358): Section mismatch: reference to .init.text:early_init (between 'skpinv' and 'interrupt_base')
WARNING: vmlinux.o(.text+0x380): Section mismatch: reference to .init.text:machine_init (between 'skpinv' and 'interrupt_base')
WARNING: vmlinux.o(.text+0x384): Section mismatch: reference to .init.text:MMU_init (between 'skpinv' and 'interrupt_base')
WARNING: vmlinux.o(.text+0x3aa): Section mismatch: reference to .init.text:start_kernel (between 'skpinv' and 'interrupt_base')
WARNING: vmlinux.o(.text+0x3ae): Section mismatch: reference to .init.text:start_kernel (between 'skpinv' and 'interrupt_base')
Added a .text.head section simliar to what other architectures do since
modpost already excludes this from its warnings.
AMCC PPC440EPx Sequoia board support.
Acked-by: David Gibson <david@gibson.dropbear.id.au>
This adds support for early serial debugging via the built in
port on IBM/AMCC PowerPC 44x CPUs. It uses a bolted TLB entry in
address space 1 for the UART's mapping, allowing robust debugging both
before and after the initialization of the MMU.
Signed-off-by: David Gibson <dwg@au1.ibm.com>
This prepares for Ebony/440 support by creating an
arch/powerpc/platforms/44x directory. It is populated with a single
misc_44x.S file, into which is moved the 44x specific reset code from
head_44x.S (on the grounds that we should really stop clogging up the
head_* files with random asm helper routines).
At the same time, we disable the (empty save Kconfig and Makefile)
arch/powerpc/platforms/4xx directory from the arch/powerpc/platforms
Makefile. Contrary to the comment in
arch/powerpc/platforms/4xx/Makefile, attempting to build such an empty
Makefile will fail, thus breaking compile for the 44x platforms we're
about to add. It can go back in once we start porting some of the 40x
platforms (and thus it becomes non-empty).
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
This patch takes the definitions for the PPC44x MMU (a software loaded
TLB) from asm-ppc/mmu.h, cleans them up of things no longer necessary
in arch/powerpc and puts them in a new asm-powerpc/mmu_44x.h file. It
also substantially simplifies arch/powerpc/mm/44x_mmu.c and makes a
couple of small fixes necessary for the 44x MMU code to build and work
properly in arch/powerpc.
ARCH=powerpc should not use the ghastly un-multiplatformable tangle of
includes that starts with asm-ppc/ibm4xx.h. This patch removes a
compile-breaking include of it from head_44x.S.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This patch removes all self references and fixes references to files
in the now defunct arch/ppc64 tree. I think this accomplises
everything wanted, though there might be a few references I missed.
Signed-off-by: Jon Mason <jdmason@us.ibm.com>
The _GLOBAL() macro is for text symbols only. Changed to using
.globl for .data symbols.
Signed-off-by: Kumar K. Gala <kumar.gala@freescale.com>
Use idle_power4.S from ppc64 as we are not going to support
32 bit power4 in the merged tree.
Merge ppc64 traps.c into powerpc traps.c:
use ppc64 versions of exception routine names
(as they don't have StudlyCaps)
make all the versions if die() have the same
prototype
This creates the directory structure under arch/powerpc and a bunch
of Kconfig files. It does a first-cut merge of arch/powerpc/mm,
arch/powerpc/lib and arch/powerpc/platforms/powermac. This is enough
to build a 32-bit powermac kernel with ARCH=powerpc.
For now we are getting some unmerged files from arch/ppc/kernel and
arch/ppc/syslib, or arch/ppc64/kernel. This makes some minor changes
to files in those directories and files outside arch/powerpc.
The boot directory is still not merged. That's going to be interesting.
