path: root/arch/powerpc/kernel/head_44x.S
2016-08-07ppc: move exports to definitionsAl Viro
2016-03-01powerpc: Fix misspellings in comments.Adam Buchbinder
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-08-13powerpc/ppc476: Disable BTACAlistair Popple
This patch disables the branch target address CAM which under specific circumstances may cause the processor to skip execution of 1-4 instructions. This fixes IBM Erratum #47. Signed-off-by: Alistair Popple <alistair@popple.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-08-14powerpc: Remove the empty giveup_fpu() function on 32bit kernelKevin Hao
Instead of implementing an empty giveup_fpu() function for each 32bit processor type, replace them with an unique empty inline function. Signed-off-by: Kevin Hao <haokexin@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-02powerpc: Fix interrupt range check on debug exceptionBharat Bhushan
We do not want to take single step and branch-taken debug exception in kernel exception code. But the address range check was not covering all kernel exception handlers address range. With this patch we defined the interrupt_end label which defines the end on kernel exception code. So now we check interrupt_base to interrupt_end range for not handling debug exception in kernel exception entry. Signed-off-by: Bharat Bhushan <bharat.bhushan@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-05-24Merge branch 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM changes from Avi Kivity: "Changes include additional instruction emulation, page-crossing MMIO, faster dirty logging, preventing the watchdog from killing a stopped guest, module autoload, a new MSI ABI, and some minor optimizations and fixes. Outside x86 we have a small s390 and a very large ppc update. Regarding the new (for kvm) rebaseless workflow, some of the patches that were merged before we switch trees had to be rebased, while others are true pulls. In either case the signoffs should be correct now." Fix up trivial conflicts in Documentation/feature-removal-schedule.txt arch/powerpc/kvm/book3s_segment.S and arch/x86/include/asm/kvm_para.h. I suspect the kvm_para.h resolution ends up doing the "do I have cpuid" check effectively twice (it was done differently in two different commits), but better safe than sorry ;) * 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (125 commits) KVM: make asm-generic/kvm_para.h have an ifdef __KERNEL__ block KVM: s390: onereg for timer related registers KVM: s390: epoch difference and TOD programmable field KVM: s390: KVM_GET/SET_ONEREG for s390 KVM: s390: add capability indicating COW support KVM: Fix mmu_reload() clash with nested vmx event injection KVM: MMU: Don't use RCU for lockless shadow walking KVM: VMX: Optimize %ds, %es reload KVM: VMX: Fix %ds/%es clobber KVM: x86 emulator: convert bsf/bsr instructions to emulate_2op_SrcV_nobyte() KVM: VMX: unlike vmcs on fail path KVM: PPC: Emulator: clean up SPR reads and writes KVM: PPC: Emulator: clean up instruction parsing kvm/powerpc: Add new ioctl to retreive server MMU infos kvm/book3s: Make kernel emulated H_PUT_TCE available for "PR" KVM KVM: PPC: bookehv: Fix r8/r13 storing in level exception handler KVM: PPC: Book3S: Enable IRQs during exit handling KVM: PPC: Fix PR KVM on POWER7 bare metal KVM: PPC: Fix stbux emulation KVM: PPC: bookehv: Use lwz/stw instead of PPC_LL/PPC_STL for 32-bit fields ...
2012-04-30powerpc: Remove empty giveup_altivec function on book3e CPUsAnton Blanchard
Use an empty inline instead of an empty function to implement giveup_altivec on book3e CPUs, similar to flush_altivec_to_thread. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-04-08powerpc/booke: Provide exception macros with interrupt nameScott Wood
DO_KVM will need to identify the particular exception type. There is an existing set of arbitrary numbers that Linux passes, but it's an undocumented mess that sort of corresponds to server/classic exception vectors but not really. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-20powerpc/44x: Enable CONFIG_RELOCATABLE for PPC44xSuzuki Poulose
The following patch adds relocatable kernel support - based on processing of dynamic relocations - for PPC44x kernel. We find the runtime address of _stext and relocate ourselves based on the following calculation. virtual_base = ALIGN(KERNELBASE,256M) + MODULO(_stext.run,256M) relocate() is called with the Effective Virtual Base Address (as shown below) | Phys. Addr| Virt. Addr | Page (256M) |------------------------| Boundary | | | | | | | | | Kernel Load |___________|_ __ _ _ _ _|<- Effective Addr(_stext)| | ^ |Virt. Base Addr | | | | | | | | | |reloc_offset| | | | | | | | | | |______v_____|<-(KERNELBASE)%256M | | | | | | | | | Page(256M) |-----------|------------| Boundary | | | The virt_phys_offset is updated accordingly, i.e, virt_phys_offset = effective. kernel virt base - kernstart_addr I have tested the patches on 440x platforms only. However this should work fine for PPC_47x also, as we only depend on the runtime address and the current TLB XLAT entry for the startup code, which is available in r25. I don't have access to a 47x board yet. So, it would be great if somebody could test this on 47x. Signed-off-by: Suzuki K. Poulose <suzuki@in.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Tony Breeds <tony@bakeyournoodle.com> Cc: Josh Boyer <jwboyer@gmail.com> Cc: linuxppc-dev <linuxppc-dev@lists.ozlabs.org> Signed-off-by: Josh Boyer <jwboyer@gmail.com>
2011-12-20powerpc/44x: Enable DYNAMIC_MEMSTART for 440xSuzuki Poulose
DYNAMIC_MEMSTART(old RELOCATABLE) was restricted only to PPC_47x variants of 44x. This patch enables DYNAMIC_MEMSTART for 440x based chipsets. Signed-off-by: Suzuki K. Poulose <suzuki@in.ibm.com> Cc: Josh Boyer <jwboyer@gmail.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: linux ppc dev <linuxppc-dev@lists.ozlabs.org> Signed-off-by: Josh Boyer <jwboyer@gmail.com>
2011-12-20powerpc: Rename mapping based RELOCATABLE to DYNAMIC_MEMSTART for BookESuzuki Poulose
The current implementation of CONFIG_RELOCATABLE in BookE is based on mapping the page aligned kernel load address to KERNELBASE. This approach however is not enough for platforms, where the TLB page size is large (e.g, 256M on 44x). So we are renaming the RELOCATABLE used currently in BookE to DYNAMIC_MEMSTART to reflect the actual method. The CONFIG_RELOCATABLE for PPC32(BookE) based on processing of the dynamic relocations will be introduced in the later in the patch series. This change would allow the use of the old method of RELOCATABLE for platforms which can afford to enforce the page alignment (platforms with smaller TLB size). Changes since v3: * Introduced a new config, NONSTATIC_KERNEL, to denote a kernel which is either a RELOCATABLE or DYNAMIC_MEMSTART(Suggested by: Josh Boyer) Suggested-by: Scott Wood <scottwood@freescale.com> Tested-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Suzuki K. Poulose <suzuki@in.ibm.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Josh Boyer <jwboyer@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: linux ppc dev <linuxppc-dev@lists.ozlabs.org> Signed-off-by: Josh Boyer <jwboyer@gmail.com>
2011-12-09powerpc/476fpe: Add 476fpe SoC codeTony Breeds
Based on original work by David 'Shaggy' Kleikamp. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Josh Boyer <jwboyer@gmail.com>
2011-09-20powerpc/32: Pass device tree address as u64 to machine_initScott Wood
u64 is used rather than phys_addr_t to keep things simple, as this is called from assembly code. Update callers to pass a 64-bit address in r3/r4. Other unused register assignments that were once parameters to machine_init are dropped. For FSL BookE, look up the physical address of the device tree from the effective address passed in r3 by the loader. This is required for situations where memory does not start at zero (due to AMP or IOMMU-less virtualization), and thus the IMA doesn't start at zero, and thus the device tree effective address does not equal the physical address. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-07-12powerpc/47x: allow kernel to be loaded in higher physical memoryDave Kleikamp
The 44x code (which is shared by 47x) assumes the available physical memory begins at 0x00000000. This is not necessarily the case in an AMP environment. Support CONFIG_RELOCATABLE for 476 in order to allow the kernel to be loaded into a higher memory range. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2010-11-29powerpc: Remove second definition of STACK_FRAME_OVERHEADStephen Rothwell
Since STACK_FRAME_OVERHEAD is defined in asm/ptrace.h and that is ASSEMBER safe, we can just include that instead of going via asm-offsets.h. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-08-23powerpc/47x: Make sure mcsr is cleared before enabling machine check interruptsDave Kleikamp
Clear the machine check syndrom register before enabling machine check interrupts. The initial state of the tlb can lead to parity errors being flagged early after a cold boot. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2010-05-05powerpc/4xx: Simple platform for the ISS 4xx simulatorTorez Smith
This is a trivial 4xx plaform that uses the new simple bsp from Josh and is handy to use in simulators such as ISS or even Mambo who don't properly implement most of the actual devices in the SoC but really only the core. Signed-off-by: Torez Smith <lnxtorez@linux.vnet.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2010-05-05powerpc/47x: Base ppc476 supportDave Kleikamp
This patch adds the base support for the 476 processor. The code was primarily written by Ben Herrenschmidt and Torez Smith, but I've been maintaining it for a while. The goal is to have a single binary that will run on 44x and 47x, but we still have some details to work out. The biggest is that the L1 cache line size differs on the two platforms, but it's currently a compile-time option. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Torez Smith <lnxtorez@linux.vnet.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2010-05-05powerpc/44x: break out cpu init code into stand-alone functionDave Kleikamp
The 47x platform supports multiple cores and shares code with 44x. Break out code that is common for initializing the primary and secondary cpus into a function which can be called for both. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-08-27powerpc/mm: Cleanup handling of execute permissionBenjamin Herrenschmidt
This is an attempt at cleaning up a bit the way we handle execute permission on powerpc. _PAGE_HWEXEC is gone, _PAGE_EXEC is now only defined by CPUs that can do something with it, and the myriad of #ifdef's in the I$/D$ coherency code is reduced to 2 cases that hopefully should cover everything. The logic on BookE is a little bit different than what it was though not by much. Since now, _PAGE_EXEC will be set by the generic code for executable pages, we need to filter out if they are unclean and recover it. However, I don't expect the code to be more bloated than it already was in that area due to that change. I could boast that this brings proper enforcing of per-page execute permissions to all BookE and 40x but in fact, we've had that now for some time as a side effect of my previous rework in that area (and I didn't even know it :-) We would only enable execute permission if the page was cache clean and we would only cache clean it if we took and exec fault. Since we now enforce that the later only work if VM_EXEC is part of the VMA flags, we de-fact already enforce per-page execute permissions... Unless I missed something Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-20powerpc: Use names rather than numbers for SPRGs (v2)Benjamin Herrenschmidt
The kernel uses SPRG registers for various purposes, typically in low level assembly code as scratch registers or to hold per-cpu global infos such as the PACA or the current thread_info pointer. We want to be able to easily shuffle the usage of those registers as some implementations have specific constraints realted to some of them, for example, some have userspace readable aliases, etc.. and the current choice isn't always the best. This patch should not change any code generation, and replaces the usage of SPRN_SPRGn everywhere in the kernel with a named replacement and adds documentation next to the definition of the names as to what those are used for on each processor family. The only parts that still use the original numbers are bits of KVM or suspend/resume code that just blindly needs to save/restore all the SPRGs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-04-26powerpc: convert to use __HEAD and HEAD_TEXT macros.Tim Abbott
This has the consequence of changing the section name use for head code from ".text.head" to ".head.text". Since this commit changes all users in the architecture, this change should be harmless. Signed-off-by: Tim Abbott <tabbott@mit.edu> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-29powerpc/44x: Support 16K/64K base page sizes on 44xIlya Yanok
This adds support for 16k and 64k page sizes on PowerPC 44x processors. The PGDIR table is much smaller than a page when using 16k or 64k pages (512 and 32 bytes respectively) so we allocate the PGDIR with kzalloc() instead of __get_free_pages(). One PTE table covers rather a large memory area when using 16k or 64k pages (32MB or 512MB respectively), so we can easily put FIXMAP and PKMAP in the area covered by one PTE table. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Vladimir Panfilov <pvr@emcraft.com> Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-12-21powerpc/44x: 44x TLB doesn't need "Guarded" set for all pagesBenjamin Herrenschmidt
After discussing with chip designers, it appears that it's not necessary to set G everywhere on 440 cores. The various core errata related to prefetch should be sorted out by firmware by disabling icache prefetching in CCR0. We add the workaround to the kernel however just in case oooold firmwares don't do it. This is valid for -all- 4xx core variants. Later ones hard wire the absence of prefetch but it doesn't harm to clear the bits in CCR0 (they should already be cleared anyway). We still leave G=1 on the linear mapping for now, we need to stop over-mapping RAM to be able to remove it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-12-21powerpc/mm: Rework usage of _PAGE_COHERENT/NO_CACHE/GUARDEDBenjamin Herrenschmidt
Currently, we never set _PAGE_COHERENT in the PTEs, we just OR it in in the hash code based on some CPU feature bit. We also manipulate _PAGE_NO_CACHE and _PAGE_GUARDED by hand in all sorts of places. This changes the logic so that instead, the PTE now contains _PAGE_COHERENT for all normal RAM pages thay have I = 0 on platforms that need it. The hash code clears it if the feature bit is not set. It also adds some clean accessors to setup various valid combinations of access flags and change various bits of code to use them instead. This should help having the PTE actually containing the bit combinations that we really want. I also removed _PAGE_GUARDED from _PAGE_BASE on 44x and instead set it explicitely from the TLB miss. I will ultimately remove it completely as it appears that it might not be needed after all but in the meantime, having it in the TLB miss makes things a lot easier. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-07-09powerpc: rework 4xx PTE access and TLB missBenjamin Herrenschmidt
This is some preliminary work to improve TLB management on SW loaded TLB powerpc platforms. This introduce support for non-atomic PTE operations in pgtable-ppc32.h and removes write back to the PTE from the TLB miss handlers. In addition, the DSI interrupt code no longer tries to fixup write permission, this is left to generic code, and _PAGE_HWWRITE is gone. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-06-30Merge branch 'linux-2.6'Paul Mackerras
2008-06-18[POWERPC] 4xx: Clear new TLB cache attribute bits in Data Storage vectorJosh Boyer
A recent commit added support for the new 440x6 and 464 cores that have the added WL1, IL1I, IL1D, IL2I, and ILD2 bits for the caching attributes in the TLBs. The new bits were cleared in the finish_tlb_load function, however a similar bit of code was missed in the DataStorage interrupt vector. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-02[POWERPC] Move to runtime allocated exception stacksKumar Gala
For the additonal exception levels (critical, debug, machine check) on 40x/book-e we were using "static" allocations of the stack in the associated head.S. Move to a runtime allocation to make the code a bit easier to read as we mimic how we handle IRQ stacks. Its also a bit easier to setup the stack with a "dummy" thread_info in C code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Paul Mackerras <paulus@samba.org>
2008-05-06[POWERPC] 4xx: Fix problem with new TLB storage attibute fields on 440x6 coreStefan Roese
The new 440x6 core used on AMCC 460EX/GT introduces new storage attibure fields to the TLB2 word. Those are: Bit 11 12 13 14 15 WL1 IL1I IL1D IL2I IL2D With these bits the cache (L1 and L2) can be configured in a more flexible way, instruction- and data-cache independently now. The "old" I and W bits are still available and setting these old bits will automically set these new bits too (for backward compatibilty). The current code does not clear these fields resulting in disabling the cache by chance. This patch now makes sure that these new bits are cleared when the TLB2 word is written. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-04-17[POWERPC] Rework Book-E debug exception handlingKumar Gala
The architecture allows for "Book-E" style debug interrupts to either go to critial interrupts of their own debug interrupt level. To allow for a dynamic kernel to support machines of either type we want to be able to compile in the interrupt handling code for both exception levels. Towards this goal we renamed the debug handling macros to specify the interrupt level in their name (DEBUG_CRIT_EXCEPTION/DebugCrit and DEBUG_DEBUG_EXCEPTION/DebugDebug). Additionally, on the Freescale Book-e parts we expanded the exception stacks to cover the maximum case of needing three exception stacks (normal, machine check and debug). There is some kernel text space optimization to be gained if a kernel is configured for a specific Freescale implementation but we aren't handling that now to allow for the single kernel image support. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-23[POWERPC] Reworking machine check handling and Fix 440/440ABenjamin Herrenschmidt
This adds a cputable function pointer for the CPU-side machine check handling. The semantic is still the same as the old one, the one in ppc_md. overrides the one in cputable, though ultimately we'll want to change that so the CPU gets first. This removes CONFIG_440A which was a problem for multiplatform kernels and instead fixes up the IVOR at runtime from a setup_cpu function. The "A" version of the machine check also tweaks the regs->trap value to differenciate the 2 versions at the C level. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-06[POWERPC] Fix swapper_pg_dir size when CONFIG_PTE_64BIT=y on FSL_BOOKEKumar Gala
The size of swapper_pg_dir is 8k instead of 4k when using 64-bit PTEs (CONFIG_PTE_64BIT). This was reported by Cedric Hombourger <chombourger@gmail.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-11[POWERPC] Use PAGE_OFFSET to tell if an address is user/kernel in SW TLB ↵Kumar Gala
handlers Move to using PAGE_OFFSET instead of TASK_SIZE or KERNELBASE value on 6xx/40x/44x/fsl-booke to determine if the faulting address is a kernel or user space address. This mimics how the macro is_kernel_addr() works. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-03[POWERPC] 4xx: Move 440EP(x) FPU setup from head_44x to cpu_setup_4xxValentine Barshak
The PowerPC 440EP(x) FPU init is currently done in head_44x under ifdefs. Since we should support more then one board in the same kernel, we move FPU initialization code from head_44x to cpu_setup_44x and add cpu_setup callbacks for 440EP(x). Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-09-19[POWERPC] Remove cmd_line from head*.SStephen Rothwell
It is just a C char array, so declare it thusly. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-09-14[POWERPC] Fix modpost warnings from head*.S on ppc32Kumar Gala
We get warnings like the following from the various ppc32 head*.S files: WARNING: vmlinux.o(.text+0x358): Section mismatch: reference to .init.text:early_init (between 'skpinv' and 'interrupt_base') WARNING: vmlinux.o(.text+0x380): Section mismatch: reference to .init.text:machine_init (between 'skpinv' and 'interrupt_base') WARNING: vmlinux.o(.text+0x384): Section mismatch: reference to .init.text:MMU_init (between 'skpinv' and 'interrupt_base') WARNING: vmlinux.o(.text+0x3aa): Section mismatch: reference to .init.text:start_kernel (between 'skpinv' and 'interrupt_base') WARNING: vmlinux.o(.text+0x3ae): Section mismatch: reference to .init.text:start_kernel (between 'skpinv' and 'interrupt_base') Added a .text.head section simliar to what other architectures do since modpost already excludes this from its warnings. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-07[POWERPC] PowerPC 440EPx: Sequoia board supportValentine Barshak
AMCC PPC440EPx Sequoia board support. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-05-08[POWERPC] Early serial debug support for PPC44xDavid Gibson
This adds support for early serial debugging via the built in port on IBM/AMCC PowerPC 44x CPUs. It uses a bolted TLB entry in address space 1 for the UART's mapping, allowing robust debugging both before and after the initialization of the MMU. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08[POWERPC] Add powerpc/platforms/44x, disable platforms/4xx for nowDavid Gibson
This prepares for Ebony/440 support by creating an arch/powerpc/platforms/44x directory. It is populated with a single misc_44x.S file, into which is moved the 44x specific reset code from head_44x.S (on the grounds that we should really stop clogging up the head_* files with random asm helper routines). At the same time, we disable the (empty save Kconfig and Makefile) arch/powerpc/platforms/4xx directory from the arch/powerpc/platforms Makefile. Contrary to the comment in arch/powerpc/platforms/4xx/Makefile, attempting to build such an empty Makefile will fail, thus breaking compile for the 44x platforms we're about to add. It can go back in once we start porting some of the 40x platforms (and thus it becomes non-empty). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Revise PPC44x MMU code for arch/powerpcDavid Gibson
This patch takes the definitions for the PPC44x MMU (a software loaded TLB) from asm-ppc/mmu.h, cleans them up of things no longer necessary in arch/powerpc and puts them in a new asm-powerpc/mmu_44x.h file. It also substantially simplifies arch/powerpc/mm/44x_mmu.c and makes a couple of small fixes necessary for the 44x MMU code to build and work properly in arch/powerpc. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13[POWERPC] Remove ibm4{xx,4x}.h from arch/powerpcDavid Gibson
ARCH=powerpc should not use the ghastly un-multiplatformable tangle of includes that starts with asm-ppc/ibm4xx.h. This patch removes a compile-breaking include of it from head_44x.S. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-10[PATCH] powerpc: trivial: modify comments to refer to new location of filesJon Mason
This patch removes all self references and fixes references to files in the now defunct arch/ppc64 tree. I think this accomplises everything wanted, though there might be a few references I missed. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-17[PATCH] powerpc: replace use of _GLOBAL with .globlKumar Gala
The _GLOBAL() macro is for text symbols only. Changed to using .globl for .data symbols. Signed-off-by: Kumar K. Gala <kumar.gala@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-01powerpc: merge idle_power4.S and trapc.sStephen Rothwell
Use idle_power4.S from ppc64 as we are not going to support 32 bit power4 in the merged tree. Merge ppc64 traps.c into powerpc traps.c: use ppc64 versions of exception routine names (as they don't have StudlyCaps) make all the versions if die() have the same prototype Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2005-09-26powerpc: Merge enough to start building in arch/powerpc.Paul Mackerras
This creates the directory structure under arch/powerpc and a bunch of Kconfig files. It does a first-cut merge of arch/powerpc/mm, arch/powerpc/lib and arch/powerpc/platforms/powermac. This is enough to build a 32-bit powermac kernel with ARCH=powerpc. For now we are getting some unmerged files from arch/ppc/kernel and arch/ppc/syslib, or arch/ppc64/kernel. This makes some minor changes to files in those directories and files outside arch/powerpc. The boot directory is still not merged. That's going to be interesting. Signed-off-by: Paul Mackerras <paulus@samba.org>
