path: root/arch/powerpc/kernel/signal_64.c
2014-05-13powerpc/tm: Disable IRQ in tm_recheckpointMichael Neuling
commit e6b8fd028b584ffca7a7255b8971f254932c9fce upstream. We can't take an IRQ when we're about to do a trechkpt as our GPR state is set to user GPR values. We've hit this when running some IBM Java stress tests in the lab resulting in the following dump: cpu 0x3f: Vector: 700 (Program Check) at [c000000007eb3d40] pc: c000000000050074: restore_gprs+0xc0/0x148 lr: 00000000b52a8184 sp: ac57d360 msr: 8000000100201030 current = 0xc00000002c500000 paca = 0xc000000007dbfc00 softe: 0 irq_happened: 0x00 pid = 34535, comm = Pooled Thread # R00 = 00000000b52a8184 R16 = 00000000b3e48fda R01 = 00000000ac57d360 R17 = 00000000ade79bd8 R02 = 00000000ac586930 R18 = 000000000fac9bcc R03 = 00000000ade60000 R19 = 00000000ac57f930 R04 = 00000000f6624918 R20 = 00000000ade79be8 R05 = 00000000f663f238 R21 = 00000000ac218a54 R06 = 0000000000000002 R22 = 000000000f956280 R07 = 0000000000000008 R23 = 000000000000007e R08 = 000000000000000a R24 = 000000000000000c R09 = 00000000b6e69160 R25 = 00000000b424cf00 R10 = 0000000000000181 R26 = 00000000f66256d4 R11 = 000000000f365ec0 R27 = 00000000b6fdcdd0 R12 = 00000000f66400f0 R28 = 0000000000000001 R13 = 00000000ada71900 R29 = 00000000ade5a300 R14 = 00000000ac2185a8 R30 = 00000000f663f238 R15 = 0000000000000004 R31 = 00000000f6624918 pc = c000000000050074 restore_gprs+0xc0/0x148 cfar= c00000000004fe28 dont_restore_vec+0x1c/0x1a4 lr = 00000000b52a8184 msr = 8000000100201030 cr = 24804888 ctr = 0000000000000000 xer = 0000000000000000 trap = 700 This moves tm_recheckpoint to a C function and moves the tm_restore_sprs into that function. It then adds IRQ disabling over the trechkpt critical section. It also sets the TEXASR FS in the signals code to ensure this is never set now that we explictly write the TM sprs in tm_recheckpoint. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-28powerpc: Increase stack redzone for 64-bit userspace to 512 bytesPaul Mackerras
The new ELFv2 little-endian ABI increases the stack redzone -- the area below the stack pointer that can be used for storing data -- from 288 bytes to 512 bytes. This means that we need to allow more space on the user stack when delivering a signal to a 64-bit process. To make the code a bit clearer, we define new USER_REDZONE_SIZE and KERNEL_REDZONE_SIZE symbols in ptrace.h. For now, we leave the kernel redzone size at 288 bytes, since increasing it to 512 bytes would increase the size of interrupt stack frames correspondingly. Gcc currently only makes use of 288 bytes of redzone even when compiling for the new little-endian ABI, and the kernel cannot currently be compiled with the new ABI anyway. In the future, hopefully gcc will provide an option to control the amount of redzone used, and then we could reduce it even more. This also changes the code in arch_compat_alloc_user_space() to preserve the expanded redzone. It is not clear why this function would ever be used on a 64-bit process, though. Signed-off-by: Paul Mackerras <paulus@samba.org> CC: <stable@vger.kernel.org> [v3.13] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-01-15powerpc: Don't corrupt transactional state when using FP/VMX in kernelPaul Mackerras
Currently, when we have a process using the transactional memory facilities on POWER8 (that is, the processor is in transactional or suspended state), and the process enters the kernel and the kernel then uses the floating-point or vector (VMX/Altivec) facility, we end up corrupting the user-visible FP/VMX/VSX state. This happens, for example, if a page fault causes a copy-on-write operation, because the copy_page function will use VMX to do the copy on POWER8. The test program below demonstrates the bug. The bug happens because when FP/VMX state for a transactional process is stored in the thread_struct, we store the checkpointed state in .fp_state/.vr_state and the transactional (current) state in .transact_fp/.transact_vr. However, when the kernel wants to use FP/VMX, it calls enable_kernel_fp() or enable_kernel_altivec(), which saves the current state in .fp_state/.vr_state. Furthermore, when we return to the user process we return with FP/VMX/VSX disabled. The next time the process uses FP/VMX/VSX, we don't know which set of state (the current register values, .fp_state/.vr_state, or .transact_fp/.transact_vr) we should be using, since we have no way to tell if we are still in the same transaction, and if not, whether the previous transaction succeeded or failed. Thus it is necessary to strictly adhere to the rule that if FP has been enabled at any point in a transaction, we must keep FP enabled for the user process with the current transactional state in the FP registers, until we detect that it is no longer in a transaction. Similarly for VMX; once enabled it must stay enabled until the process is no longer transactional. In order to keep this rule, we add a new thread_info flag which we test when returning from the kernel to userspace, called TIF_RESTORE_TM. This flag indicates that there is FP/VMX/VSX state to be restored before entering userspace, and when it is set the .tm_orig_msr field in the thread_struct indicates what state needs to be restored. The restoration is done by restore_tm_state(). The TIF_RESTORE_TM bit is set by new giveup_fpu/altivec_maybe_transactional helpers, which are called from enable_kernel_fp/altivec, giveup_vsx, and flush_fp/altivec_to_thread instead of giveup_fpu/altivec. The other thing to be done is to get the transactional FP/VMX/VSX state from .fp_state/.vr_state when doing reclaim, if that state has been saved there by giveup_fpu/altivec_maybe_transactional. Having done this, we set the FP/VMX bit in the thread's MSR after reclaim to indicate that that part of the state is now valid (having been reclaimed from the processor's checkpointed state). Finally, in the signal handling code, we move the clearing of the transactional state bits in the thread's MSR a bit earlier, before calling flush_fp_to_thread(), so that we don't unnecessarily set the TIF_RESTORE_TM bit. This is the test program: /* Michael Neuling 4/12/2013 * * See if the altivec state is leaked out of an aborted transaction due to * kernel vmx copy loops. * * gcc -m64 htm_vmxcopy.c -o htm_vmxcopy * */ /* We don't use all of these, but for reference: */ int main(int argc, char *argv[]) { long double vecin = 1.3; long double vecout; unsigned long pgsize = getpagesize(); int i; int fd; int size = pgsize*16; char tmpfile[] = "/tmp/page_faultXXXXXX"; char buf[pgsize]; char *a; uint64_t aborted = 0; fd = mkstemp(tmpfile); assert(fd >= 0); memset(buf, 0, pgsize); for (i = 0; i < size; i += pgsize) assert(write(fd, buf, pgsize) == pgsize); unlink(tmpfile); a = mmap(NULL, size, PROT_READ|PROT_WRITE, MAP_PRIVATE, fd, 0); assert(a != MAP_FAILED); asm __volatile__( "lxvd2x 40,0,%[vecinptr] ; " // set 40 to initial value TBEGIN "beq 3f ;" TSUSPEND "xxlxor 40,40,40 ; " // set 40 to 0 "std 5, 0(%[map]) ;" // cause kernel vmx copy page TABORT TRESUME TEND "li %[res], 0 ;" "b 5f ;" "3: ;" // Abort handler "li %[res], 1 ;" "5: ;" "stxvd2x 40,0,%[vecoutptr] ; " : [res]"=r"(aborted) : [vecinptr]"r"(&vecin), [vecoutptr]"r"(&vecout), [map]"r"(a) : "memory", "r0", "r3", "r4", "r5", "r6", "r7"); if (aborted && (vecin != vecout)){ printf("FAILED: vector state leaked on abort %f != %f\n", (double)vecin, (double)vecout); exit(1); } munmap(a, size); close(fd); printf("PASSED!\n"); return 0; } Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-11-25powerpc/signals: Improved mark VSX not saved with small contexts fixMichael Neuling
In a recent patch: commit c13f20ac48328b05cd3b8c19e31ed6c132b44b42 Author: Michael Neuling <mikey@neuling.org> powerpc/signals: Mark VSX not saved with small contexts We fixed an issue but an improved solution was later discussed after the patch was merged. Firstly, this patch doesn't handle the 64bit signals case, which could also hit this issue (but has never been reported). Secondly, the original patch isn't clear what MSR VSX should be set to. The new approach below always clears the MSR VSX bit (to indicate no VSX is in the context) and sets it only in the specific case where VSX is available (ie. when VSX has been used and the signal context passed has space to provide the state). This reverts the original patch and replaces it with the improved solution. It also adds a 64 bit version. Signed-off-by: Michael Neuling <mikey@neuling.org> Cc: stable@vger.kernel.org Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-11-21powerpc: ELF2 binaries signal handlingRusty Russell
For the ELFv2 ABI, the hander is the entry point, not a function descriptor. We also need to set up r12, and fortunately the fast_exception_return exit path restores r12 for us so nothing else is required. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-11Merge branch 'for-kvm' into nextBenjamin Herrenschmidt
Topic branch for commits that the KVM tree might want to pull in separately. Hand merged a few files due to conflicts with the LE stuff Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-11powerpc: Put FP/VSX and VR state into structuresPaul Mackerras
This creates new 'thread_fp_state' and 'thread_vr_state' structures to store FP/VSX state (including FPSCR) and Altivec/VSX state (including VSCR), and uses them in the thread_struct. In the thread_fp_state, the FPRs and VSRs are represented as u64 rather than double, since we rarely perform floating-point computations on the values, and this will enable the structures to be used in KVM code as well. Similarly FPSCR is now a u64 rather than a structure of two 32-bit values. This takes the offsets out of the macros such as SAVE_32FPRS, REST_32FPRS, etc. This enables the same macros to be used for normal and transactional state, enabling us to delete the transactional versions of the macros. This also removes the unused do_load_up_fpu and do_load_up_altivec, which were in fact buggy since they didn't create large enough stack frames to account for the fact that load_up_fpu and load_up_altivec are not designed to be called from C and assume that their caller's stack frame is an interrupt frame. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-11powerpc: Reset MSR_LE on signal entryAnton Blanchard
We always take signals in big endian which is wrong. Signals should be taken in native endian. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-08-14powerpc: Remove the redundant flush_fp_to_thread() in setup_sigcontext()Kevin Hao
In commit c6e6771b(powerpc: Introduce VSX thread_struct and CONFIG_VSX) we add a invocation of flush_fp_to_thread() before copying the FPR or VSR to users. But we already invoke the flush_fp_to_thread() in this function. So remove one of them. Signed-off-by: Kevin Hao <haokexin@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-08-14powerpc: Fix VRSAVE handlingPaul Mackerras
Since 2002, the kernel has not saved VRSAVE on exception entry and restored it on exit; rather, VRSAVE gets context-switched in _switch. This means that when executing in process context in the kernel, the userspace VRSAVE value is live in the VRSAVE register. However, the signal code assumes that current->thread.vrsave holds the current VRSAVE value, which is incorrect. Therefore, this commit changes it to use the actual VRSAVE register instead. (It still uses current->thread.vrsave as a temporary location to store it in, as __get_user and __put_user can only transfer to/from a variable, not an SPR.) This also modifies the transactional memory code to save and restore VRSAVE regardless of whether VMX is enabled in the MSR. This is because accesses to VRSAVE are not controlled by the MSR.VEC bit, but can happen at any time. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-08-14powerpc: Fix a number of sparse warningsAnton Blanchard
Address some of the trivial sparse warnings in arch/powerpc. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-06-20powerpc/tm: Fix return of active 64bit signalsMichael Neuling
Currently we only restore signals which are transactionally suspended but it's possible that the transaction can be restored even when it's active. Most likely this will result in a transactional rollback by the hardware as the transaction will have been doomed by an earlier treclaim. The current code is a legacy of earlier kernel implementations which did software rollback of active transactions in the kernel. That code has now gone but we didn't correctly fix up this part of the signals code which still makes assumptions based on having software rollback. This changes the signal return code to always restore both contexts on 64 bit signal return. It also ensures that the MSR TM bits are properly restored from the signal context which they are not currently. Signed-off-by: Michael Neuling <mikey@neuling.org> cc: stable@vger.kernel.org (v3.9+) Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-06-01powerpc/tm: Fix userspace stack corruption on signal delivery for active ↵Michael Neuling
transactions When in an active transaction that takes a signal, we need to be careful with the stack. It's possible that the stack has moved back up after the tbegin. The obvious case here is when the tbegin is called inside a function that returns before a tend. In this case, the stack is part of the checkpointed transactional memory state. If we write over this non transactionally or in suspend, we are in trouble because if we get a tm abort, the program counter and stack pointer will be back at the tbegin but our in memory stack won't be valid anymore. To avoid this, when taking a signal in an active transaction, we need to use the stack pointer from the checkpointed state, rather than the speculated state. This ensures that the signal context (written tm suspended) will be written below the stack required for the rollback. The transaction is aborted becuase of the treclaim, so any memory written between the tbegin and the signal will be rolled back anyway. For signals taken in non-TM or suspended mode, we use the normal/non-checkpointed stack pointer. Tested with 64 and 32 bit signals Signed-off-by: Michael Neuling <mikey@neuling.org> Cc: <stable@vger.kernel.org> # v3.9 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-10powerpc: fix compiling CONFIG_PPC_TRANSACTIONAL_MEM when CONFIG_ALTIVEC=nMichael Neuling
We can't compile a kernel with CONFIG_ALTIVEC=n when CONFIG_PPC_TRANSACTIONAL_MEM=y. We currently get: arch/powerpc/kernel/tm.S:320: Error: unsupported relocation against THREAD_VSCR arch/powerpc/kernel/tm.S:323: Error: unsupported relocation against THREAD_VR0 arch/powerpc/kernel/tm.S:323: Error: unsupported relocation against THREAD_VR0 etc. The below fixes this with a sprinkling of #ifdefs. This was found by mpe with kisskb: http://kisskb.ellerman.id.au/kisskb/buildresult/8539442/ Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2013-02-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull signal handling cleanups from Al Viro: "This is the first pile; another one will come a bit later and will contain SYSCALL_DEFINE-related patches. - a bunch of signal-related syscalls (both native and compat) unified. - a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE (fixing several potential problems with missing argument validation, while we are at it) - a lot of now-pointless wrappers killed - a couple of architectures (cris and hexagon) forgot to save altstack settings into sigframe, even though they used the (uninitialized) values in sigreturn; fixed. - microblaze fixes for delivery of multiple signals arriving at once - saner set of helpers for signal delivery introduced, several architectures switched to using those." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits) x86: convert to ksignal sparc: convert to ksignal arm: switch to struct ksignal * passing alpha: pass k_sigaction and siginfo_t using ksignal pointer burying unused conditionals make do_sigaltstack() static arm64: switch to generic old sigaction() (compat-only) arm64: switch to generic compat rt_sigaction() arm64: switch compat to generic old sigsuspend arm64: switch to generic compat rt_sigqueueinfo() arm64: switch to generic compat rt_sigpending() arm64: switch to generic compat rt_sigprocmask() arm64: switch to generic sigaltstack sparc: switch to generic old sigsuspend sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE sparc: kill sign-extending wrappers for native syscalls kill sparc32_open() sparc: switch to use of generic old sigaction sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE mips: switch to generic sys_fork() and sys_clone() ...
2013-02-15powerpc: Add new transactional memory state to the signal contextMichael Neuling
This adds the new transactional memory archtected state to the signal context in both 32 and 64 bit. Signed-off-by: Matt Evans <matt@ozlabs.org> Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-02-03powerpc: switch to generic sigaltstackAl Viro
2012-11-19Fix misspellings of "whether" in comments.Adam Buchbinder
"Whether" is misspelled in various comments across the tree; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-06-01powerpc: get rid of restore_sigmask()Al Viro
... it's just a call of set_current_blocked() now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-28Disintegrate asm/system.h for PowerPCDavid Howells
Disintegrate asm/system.h for PowerPC. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> cc: linuxppc-dev@lists.ozlabs.org
2011-10-31powerpc: remove non-required uses of include <linux/module.h>Paul Gortmaker
None of the files touched here are modules, and they are not exporting any symbols either -- so there is no need to be including the module.h. Builds of all the files remains successful. Even kernel/module.c does not need to include it, since it includes linux/moduleloader.h instead. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-06-29arch/powerpc: use printk_ratelimited instead of printk_ratelimitChristian Dietrich
Since printk_ratelimit() shouldn't be used anymore (see comment in include/linux/printk.h), replace it with printk_ratelimited. Signed-off-by: Christian Dietrich <christian.dietrich@informatik.uni-erlangen.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-27powerpc: Use MSR_64BIT in placesMichael Ellerman
Use the new MSR_64BIT in a few places. Some of these are already ifdef'ed for BOOKE vs BOOKS, but it's still clearer, MSR_SF does not immediately parse as "MSR bit for 64bit". Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-09-22powerpc: fix double syscall restartsAl Viro
Make sigreturn zero regs->trap, make do_signal() do the same on all paths. As it is, signal interrupting e.g. read() from fd 512 (== ERESTARTSYS) with another signal getting unblocked when the first handler finishes will lead to restart one insn earlier than it ought to. Same for multiple signals with in-kernel handlers interrupting that sucker at the same time. Same for multiple signals of any kind interrupting that sucker on 64bit... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27powerpc: Sanitize stack pointer in signal handling codeJosh Boyer
On powerpc64 machines running 32-bit userspace, we can get garbage bits in the stack pointer passed into the kernel. Most places handle this correctly, but the signal handling code uses the passed value directly for allocating signal stack frames. This fixes the issue by introducing a get_clean_sp function that returns a sanitized stack pointer. For 32-bit tasks on a 64-bit kernel, the stack pointer is masked correctly. In all other cases, the stack pointer is simply returned. Additionally, we pass an 'is_32' parameter to get_sigframe now in order to get the properly sanitized stack. The callers are know to be 32 or 64-bit statically. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-10-31powerpc: Fix swapcontext system for VSX + old ucontext sizeMichael Neuling
Since VSX support was added, we now have two sizes of ucontext_t; the older, smaller size without the extra VSX state, and the new larger size with the extra VSX state. A program using the sys_swapcontext system call and supplying smaller ucontext_t structures will currently get an EINVAL error if the task has used VSX (e.g. because of calling library code that uses VSX) and the old_ctx argument is non-NULL (i.e. the program is asking for its current context to be saved). Thus the program will start getting EINVAL errors on calls that previously worked. This commit changes this behaviour so that we don't send an EINVAL in this case. It will now return the smaller context but the VSX MSR bit will always be cleared to indicate that the ucontext_t doesn't include the extra VSX state, even if the task has executed VSX instructions. Both 32 and 64 bit cases are updated. [paulus@samba.org - also fix some access_ok() and get_user() calls] Thanks to Ben Herrenschmidt for noticing this problem. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-10-22powerpc: Remove empty #else from signal_64.cMichael Neuling
Remove empty/bogus #else from signal_64.c Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-15powerpc: fix giveup_vsx to save registers correctlyMichael Neuling
giveup_vsx didn't save the FPU and VMX regsiters. Change it to be like giveup_fpr/altivec which save these registers. Also update call sites where FPU and VMX are already saved to use the original giveup_vsx (renamed to __giveup_vsx). Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-09powerpc: fix swapcontext backwards compat. with VSX ucontext changesMichael Neuling
When the ucontext changed to add the VSX context, this broke backwards compatibly on swapcontext. swapcontext only compares the ucontext size passed in from the user to the new kernel ucontext size. This adds a check against the old ucontext size (with VMX but without VSX). It also adds some sanity check for ucontexts without VSX, but where VSX is used according the MSR. Fixes for both 32 and 64bit processes on 64bit kernels Kudos to Paulus for noticing. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-03powerpc: Clean up copy_to/from_user for vsx and fprMichael Neuling
This merges and cleans up some of the ugly copy/to from user code which is required for the new fpr and vsx layout in the thread_struct. Also fixes some hard coded buffer sizes and removes a redundant fpr_flush_to_thread. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-07-01powerpc: Fix compile error for CONFIG_VSXMichael Neuling
Fix compile error when CONFIG_VSX is enabled. arch/powerpc/kernel/signal_64.c: In function 'restore_sigcontext': arch/powerpc/kernel/signal_64.c:241: error: 'i' undeclared (first use in this function) Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-07-01powerpc: Explicitly copy elements of pt_regsStephen Rothwell
Gcc 4.3 produced this warning: arch/powerpc/kernel/signal_64.c: In function 'restore_sigcontext': arch/powerpc/kernel/signal_64.c:161: warning: array subscript is above array bounds This is caused by us copying to aliases of elements of the pt_regs structure. Make those explicit. This adds one extra __get_user and unrolls a loop. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-07-01powerpc: Add VSX context save/restore, ptrace and signal supportMichael Neuling
This patch extends the floating point save and restore code to use the VSX load/stores when VSX is available. This will make FP context save/restore marginally slower on FP only code, when VSX is available, as it has to load/store 128bits rather than just 64bits. Mixing FP, VMX and VSX code will get constant architected state. The signals interface is extended to enable access to VSR 0-31 doubleword 1 after discussions with tool chain maintainers. Backward compatibility is maintained. The ptrace interface is also extended to allow access to VSR 0-31 full registers. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-07-01powerpc: Introduce VSX thread_struct and CONFIG_VSXMichael Neuling
The layout of the new VSR registers and how they overlap on top of the legacy FPR and VR registers is: VSR doubleword 0 VSR doubleword 1 ---------------------------------------------------------------- VSR[0] | FPR[0] | | ---------------------------------------------------------------- VSR[1] | FPR[1] | | ---------------------------------------------------------------- | ... | | | ... | | ---------------------------------------------------------------- VSR[30] | FPR[30] | | ---------------------------------------------------------------- VSR[31] | FPR[31] | | ---------------------------------------------------------------- VSR[32] | VR[0] | ---------------------------------------------------------------- VSR[33] | VR[1] | ---------------------------------------------------------------- | ... | | ... | ---------------------------------------------------------------- VSR[62] | VR[30] | ---------------------------------------------------------------- VSR[63] | VR[31] | ---------------------------------------------------------------- VSX has 64 128bit registers. The first 32 regs overlap with the FP registers and hence extend them with and additional 64 bits. The second 32 regs overlap with the VMX registers. This commit introduces the thread_struct changes required to reflect this register layout. Ptrace and signals code is updated so that the floating point registers are correctly accessed from the thread_struct when CONFIG_VSX is enabled. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-09[POWERPC] Fix incorrect enabling of VMX when building signal or user contextBenjamin Herrenschmidt
When building a signal or a ucontext, we can incorrectly set the MSR_VEC bit of the kernel pt_regs->msr before returning to userspace if the task -ever- used VMX. This can lead to funny result if that stack used it in the past, then "lost" it (ie. it wasn't enabled after a context switch for example) and then called get_context. It can end up with VMX enabled and the registers containing values from some other task. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-12[POWERPC] Implement logging of unhandled signalsOlof Johansson
Implement show_unhandled_signals sysctl + support to print when a process is killed due to unhandled signals just as i386 and x86_64 does. Default to having it off, unlike x86 that defaults on. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-11Merge branch 'for-2.6.23' into mergePaul Mackerras
2007-06-26[POWERPC] Fix subtle FP state corruption bug in signal return on SMPPaul Mackerras
This fixes a bug which can cause corruption of the floating-point state on return from a signal handler. If we have a signal handler that has used the floating-point registers, and it happens to context-switch to another task while copying the interrupted floating-point state from the user stack into the thread struct (e.g. because of a page fault, or because it gets preempted), the context switch code will think that the FP registers contain valid FP state that needs to be copied into the thread_struct, and will thus overwrite the values that the signal return code has put into the thread_struct. This can occur because we clear the MSR bits that indicate the presence of valid FP state after copying the state into the thread_struct. To fix this we just move the clearing of the MSR bits to before the copy. A similar potential problem also occurs with the Altivec state, and this fixes that in the same way. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-14[POWERPC] Merge creation of signal frameBenjamin Herrenschmidt
The code for creating signal frames was still duplicated and split in strange ways between 32 and 64 bits, including the SA_ONSTACK handling being in do_signal on 32 bits but inside handle_rt_signal on 64 bits etc... This moves the 64 bits get_sigframe() to the generic signal.c, cleans it a bit, moves the access_ok() call done by all callers to it as well, and adapts/cleanups the 3 different signal handling cases to use that common function. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-14[POWERPC] Consolidate do_signalChristoph Hellwig
do_signal has exactly the same behaviour on 32bit and 64bit and 32bit compat on 64bit for handling 32bit signals. Consolidate all these into one common function in signal.c. The only odd left over is the try_to_free in the 32bit version that no other architecture has in mainline (only in i386 for some odd SuSE release). We should probably get rid of it in a separate patch. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-14[POWERPC] Consolidate restore_sigmaskChristoph Hellwig
restore_sigmask is exactly the same on 32 and 64bit, so move it to common code. Also move _BLOCKABLE to signal.h to avoid defining it multiple times. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-14[POWERPC] Consolidate sys_sigaltstackChristoph Hellwig
sys_sigaltstack is the same on 32bit and 64 and we can consolidate it to signal.c. The only difference is that the 32bit code uses ints for the unused register paramaters and 64bit unsigned long. I've changed it to unsigned long because it's the same width on 32bit. (I also wonder who came up with this awkward calling convention.. :)) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-14[POWERPC] Make syscall restart code more commonBenjamin Herrenschmidt
This patch moves the code in signal_32.c and signal_64.c for handling syscall restart into a common signal.c file and converge around a single implementation that is based on the 32 bits one, using trap, ccr and r3 rather than the special "result" field for deciding what to do. The "result" field is now pretty much deprecated. We still set it for the sake of whatever might rely on it in userland but we no longer use it's content. This, along with a previous patch that enables ptracers to write to "trap" and "orig_r3" should allow gdb to properly handle syscall restarting. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-12Merge branch 'merge'Paul Mackerras
2006-06-09[PATCH] powerpc: Implement support for setting little-endian mode via prctlPaul Mackerras
This adds the PowerPC part of the code to allow processes to change their endian mode via prctl. This also extends the alignment exception handler to be able to fix up alignment exceptions that occur in little-endian mode, both for "PowerPC" little-endian and true little-endian. We always enter signal handlers in big-endian mode -- the support for little-endian mode does not amount to the creation of a little-endian user/kernel ABI. If the signal handler returns, the endian mode is restored to what it was when the signal was delivered. We have two new kernel CPU feature bits, one for PPC little-endian and one for true little-endian. Most of the classic 32-bit processors support PPC little-endian, and this is reflected in the CPU feature table. There are two corresponding feature bits reported to userland in the AT_HWCAP aux vector entry. This is based on an earlier patch by Anton Blanchard. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-09[PATCH] powerpc vdso updatesBenjamin Herrenschmidt
This patch cleans up some locking & error handling in the ppc vdso and moves the vdso base pointer from the thread struct to the mm context where it more logically belongs. It brings the powerpc implementation closer to Ingo's new x86 one and also adds an arch_vma_name() function allowing to print [vsdo] in /proc/<pid>/maps if Ingo's x86 vdso patch is also applied. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-09powerpc: Fix machine check problem on 32-bit kernelsPaul Mackerras
This fixes a bug found by Dave Jones that means that it is possible for userspace to provoke a machine check on 32-bit kernels. This also fixes a couple of other places where I found similar problems by inspection. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-28[PATCH] powerpc: fix incorrect SA_ONSTACK behaviour for 64-bit processesLaurent MEYER
*) When setting a sighandler using sigaction() call, if the flag SA_ONSTACK is set and no alternate stack is provided via sigaltstack(), the kernel still try to install the alternate stack. This behavior is the opposite of the one which is documented in Single Unix Specifications V3. *) Also when setting an alternate stack using sigaltstack() with the flag SS_DISABLE, the kernel try to install the alternate stack on signal delivery. These two use cases makes the process crash at signal delivery. This fixes it. Signed-off-by: Laurent Meyer <meyerlau@fr.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
