The division was somewhat artificial and cumbersome, and had no functional
benefit anyways: we can only guests built for the real host processor.
Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
This will ease ports to other cores.
Also remove unused "struct kvm_tlb" while we're at it.
This will make it easier to provide implementations for other cores.
When we use TID=N userspace mappings, we must ensure that kernel mappings have
been destroyed when entering userspace. Using TID=1/TID=0 for kernel/user
mappings and running userspace with PID=0 means that userspace can't access the
kernel mappings, but the kernel can directly access userspace.
The net is that we don't need to flush the TLB on privilege switches, but we do
on guest context switches (which are far more infrequent). Guest boot time
performance improvement: about 30%.
Signed-off-by: Avi Kivity <avi@qumranet.com>
Allow host userspace to program hardware debug registers to set breakpoints
inside guests.
Signed-off-by: Jerone Young <jyoung5@us.ibm.com>
This was left behind from some code movement.
This patch adds the delivery of INTERRUPT_FP_UNAVAIL exceptions to the guest.
It's needed if a guest uses ppc binaries using the Floating point instructions.
Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com>
Acked-by: Hollis Blanchard <hollisb@us.ibm.com>
This reduces host CPU usage when the guest is idle. However, the guest must
set MSR[WE] in its idle loop, which Linux did not do until 2.6.26.
This functionality is definitely experimental, but is capable of running
unmodified PowerPC 440 Linux kernels as guests on a PowerPC 440 host. (Only
tested with 440EP "Bamboo" guests so far, but with appropriate userspace
support other SoC/board combinations should work.)
See Documentation/powerpc/kvm_440.txt for technical details.
[stephen: build fix]
Acked-by: Paul Mackerras <paulus@samba.org>
