Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
asm/tlbflush.h is only needed for:
- using functions xxx_flush_tlb_xxx()
- using MMU_NO_CONTEXT
- including asm-generic/pgtable.h
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
There are some error paths in kvmppc_core_vcpu_create_e500() where we
forget to set the error code. It means that we return ERR_PTR(0) which
is NULL and it results in a NULL pointer dereference in the caller.
Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
The function can return negative value.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/assign_signed_to_unsigned.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2046107
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Acked-by: Scott Wood <scottwood@freescale.com>
Pull KVM update from Paolo Bonzini:
"3.19 changes for KVM:
- spring cleaning: removed support for IA64, and for hardware-
assisted virtualization on the PPC970
- ARM, PPC, s390 all had only small fixes
For x86:
- small performance improvements (though only on weird guests)
- usual round of hardware-compliancy fixes from Nadav
- APICv fixes
- XSAVES support for hosts and guests. XSAVES hosts were broken
because the (non-KVM) XSAVES patches inadvertently changed the KVM
userspace ABI whenever XSAVES was enabled; hence, this part is
going to stable. Guest support is just a matter of exposing the
feature and CPUID leaves support"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (179 commits)
KVM: move APIC types to arch/x86/
KVM: PPC: Book3S: Enable in-kernel XICS emulation by default
KVM: PPC: Book3S HV: Improve H_CONFER implementation
KVM: PPC: Book3S HV: Fix endianness of instruction obtained from HEIR register
KVM: PPC: Book3S HV: Remove code for PPC970 processors
KVM: PPC: Book3S HV: Tracepoints for KVM HV guest interactions
KVM: PPC: Book3S HV: Simplify locking around stolen time calculations
arch: powerpc: kvm: book3s_paired_singles.c: Remove unused function
arch: powerpc: kvm: book3s_pr.c: Remove unused function
arch: powerpc: kvm: book3s.c: Remove some unused functions
arch: powerpc: kvm: book3s_32_mmu.c: Remove unused function
KVM: PPC: Book3S HV: Check wait conditions before sleeping in kvmppc_vcore_blocked
KVM: PPC: Book3S HV: ptes are big endian
KVM: PPC: Book3S HV: Fix inaccuracies in ICP emulation for H_IPI
KVM: PPC: Book3S HV: Fix KSM memory corruption
KVM: PPC: Book3S HV: Fix an issue where guest is paused on receiving HMI
KVM: PPC: Book3S HV: Fix computation of tlbie operand
KVM: PPC: Book3S HV: Add missing HPTE unlock
KVM: PPC: BookE: Improve irq inject tracepoint
arm/arm64: KVM: Require in-kernel vgic for the arch timers
Commit 69111bac42f5 ("powerpc: Replace __get_cpu_var uses") introduced
compile breakage to the e500 target by introducing invalid automatically
created C syntax.
Fix up the breakage and make the code compile again.
Removes some functions that are not used anywhere:
kvmppc_core_load_guest_debugstate() kvmppc_core_load_host_debugstate()
This was partially found by using a static code analysis program called cppcheck.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
This still has not been merged and now powerpc is the only arch that does
not have this change. Sorry about missing linuxppc-dev before.
V2->V2
- Fix up to work against 3.18-rc1
__get_cpu_var() is used for multiple purposes in the kernel source. One of
them is address calculation via the form &__get_cpu_var(x). This calculates
the address for the instance of the percpu variable of the current processor
based on an offset.
Other use cases are for storing and retrieving data from the current
processors percpu area. __get_cpu_var() can be used as an lvalue when
writing data or on the right side of an assignment.
__get_cpu_var() is defined as :
__get_cpu_var() always only does an address determination. However, store
and retrieve operations could use a segment prefix (or global register on
other platforms) to avoid the address calculation.
this_cpu_write() and this_cpu_read() can directly take an offset into a
percpu area and use optimized assembly code to read and write per cpu
variables.
This patch converts __get_cpu_var into either an explicit address
calculation using this_cpu_ptr() or into a use of this_cpu operations that
use the offset. Thereby address calculations are avoided and less registers
are used when code is generated.
At the end of the patch set all uses of __get_cpu_var have been removed so
the macro is removed too.
The patch set includes passes over all arches as well. Once these operations
are used throughout then specialized macros can be defined in non -x86
arches as well in order to optimize per cpu access by f.e. using a global
register that may be set to the per cpu base.
Transformations done to __get_cpu_var()
1. Determine the address of the percpu instance of the current processor.
DEFINE_PER_CPU(int, y);
int *x = &__get_cpu_var(y);
Converts to
int *x = this_cpu_ptr(&y);
2. Same as #1 but this time an array structure is involved.
DEFINE_PER_CPU(int, y[20]);
int *x = __get_cpu_var(y);
Converts to
int *x = this_cpu_ptr(y);
3. Retrieve the content of the current processors instance of a per cpu
variable.
int x = __get_cpu_var(y)
Converts to
int x = __this_cpu_read(y);
4. Retrieve the content of a percpu struct
DEFINE_PER_CPU(struct mystruct, y);
struct mystruct x = __get_cpu_var(y);
Converts to
memcpy(&x, this_cpu_ptr(&y), sizeof(x));
5. Assignment to a per cpu variable
__get_cpu_var(y) = x;
Converts to
__this_cpu_write(y, x);
6. Increment/Decrement etc of a per cpu variable
__get_cpu_var(y)++
Converts to
__this_cpu_inc(y)
CC: Paul Mackerras <paulus@samba.org>
Signed-off-by: Christoph Lameter <cl@linux.com>
[mpe: Fix build errors caused by set/or_softirq_pending(), and rework
assignment in __set_breakpoint() to use memcpy().]
Systems that support automatic loading of kernel modules through
device aliases should try and automatically load kvm when /dev/kvm
gets opened.
Add code to support that magic for all PPC kvm targets, even the
ones that don't support modules yet.
This moves the kvmppc_ops callbacks to be a per VM entity. This
enables us to select HV and PR mode when creating a VM. We also
allow both kvm-hv and kvm-pr kernel module to be loaded. To
achieve this we move /dev/kvm ownership to kvm.ko module. Depending on
which KVM mode we select during VM creation we take a reference
count on respective module
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
[agraf: fix coding style]
This patch add a new callback kvmppc_ops. This will help us in enabling
both HV and PR KVM together in the same kernel. The actual change to
enable them together is done in the later patch in the series.
[agraf: squash in booke changes]
MMU registers were exposed to user-space using sregs interface. Add them
to ONE_REG interface using kvmppc_get_one_reg/kvmppc_set_one_reg delegation
mechanism.
Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com>
Refactor Book3E ONE_REG ioctl implementation to use kvmppc_get_one_reg/
kvmppc_set_one_reg delegation interface introduced by Book3S. This is
necessary for MMU SPRs which are platform specifics.
Get rid of useless case braces in the process.
Current kvmppc_booke_handlers uses the same macro (KVM_HANDLER) and
all handlers are considered to be the same size. This will not be
the case if we want to use different macros for different handlers.
This patch improves the kvmppc_booke_handler so that it can
support different macros for different handlers.
Signed-off-by: Liu Yu <yu.liu@freescale.com>
[bharat.bhushan@freescale.com: Substantial changes]
Signed-off-by: Bharat Bhushan <bharat.bhushan@freescale.com>
The PID handling is e500v1/v2-specific, and is moved to e500.c.
The MMU sregs code and kvmppc_core_vcpu_translate will be shared with
e500mc, and is moved from e500.c to e500_tlb.c.
Partially based on patches from Liu Yu <yu.liu@freescale.com>.
[agraf: fix bisectability]
Signed-off-by: Avi Kivity <avi@redhat.com>
Keeping two separate headers for e500-specific things was a
pain, and wasn't even organized along any logical boundary.
There was TLB stuff in <asm/kvm_e500.h> despite the existence of
arch/powerpc/kvm/e500_tlb.h, and nothing in <asm/kvm_e500.h> needed
to be referenced from outside arch/powerpc/kvm.
This is in preparation for merging in the contents of
arch/powerpc/include/asm/kvm_e500.h.
e500mc will want to do lpid allocation/deallocation here.
This gives us a place to put load/put actions that correspond to
code that is booke-specific but not specific to a particular core.
When enabling the current KVM code on e500mc, I get the following oops:
Oops: Exception in kernel mode, sig: 4 [#1]
SMP NR_CPUS=8 P2041 RDB
Modules linked in:
NIP: c067df4c LR: c067df44 CTR: 00000000
REGS: ee055ed0 TRAP: 0700 Not tainted (3.2.0-10391-g36c5afe)
MSR: 00029002 <CE,EE,ME> CR: 24042022 XER: 00000000
TASK = ee0429b0[1] 'swapper/0' THREAD: ee054000 CPU: 2
GPR00: c067df44 ee055f80 ee0429b0 00000000 00000058 0000003f ee211600 60c6b864
GPR08: 7cc903a6 0000002c 00000000 00000001 44042082 2d180088 00000000 00000000
GPR16: c0000a00 00000014 3fffffff 03fe9000 00000015 7ff3be68 c06e0000 00000000
GPR24: 00000000 00000000 00001720 c067df1c c06e0000 00000000 ee054000 c06ab51c
NIP [c067df4c] kvmppc_e500_init+0x30/0xf8
LR [c067df44] kvmppc_e500_init+0x28/0xf8
Call Trace:
[ee055f80] [c067df44] kvmppc_e500_init+0x28/0xf8 (unreliable)
[ee055fb0] [c0001d30] do_one_initcall+0x50/0x1f0
[ee055fe0] [c06721dc] kernel_init+0xa4/0x14c
[ee055ff0] [c000e910] kernel_thread+0x4c/0x68
Instruction dump:
9421ffd0 7c0802a6 93410018 9361001c 90010034 93810020 93a10024 93c10028
93e1002c 4bfffe7d 2c030000 408200a4 <7c1082a6> 90010008 7c1182a6 9001000c
---[ end trace b8ef4903fcbf9dd3 ]---
Since it doesn't make sense to run the init function on any non-supported
platform, we can just call our "is this platform supported?" function and
bail out of init() if it's not.
This allows additional registers to be accessed by the guest
in PR-mode KVM without trapping.
SPRG4-7 are readable from userspace. On booke, KVM will sync
these registers when it enters the guest, so that accesses from
guest userspace will work. The guest kernel, OTOH, must consistently
use either the real registers or the shared area between exits. This
also applies to the already-paravirted SPRG3.
On non-booke, it's not clear to what extent SPRG4-7 are supported
(they're not architected for book3s, but exist on at least some classic
chips). They are copied in the get/set regs ioctls, but I do not see any
non-booke emulation. I also do not see any syncing with real registers
(in PR-mode) including the user-readable SPRG3. This patch should not
make that situation any worse.
The hardcoded behavior prevents proper SMP support.
user space shall specify the vcpu's PIR as the vcpu id.
This implements a shared-memory API for giving host userspace access to
the guest's TLB.
This is required for THIS_MODULE. We recently stopped acquiring
it via some other header.
There are multiple features in PowerPC KVM that can now be enabled
depending on the user's wishes. Some of the combinations don't make
sense or don't work though.
So this patch adds a way to check if the executing environment would
actually be able to run the guest properly. It also adds sanity
checks if PVR is set (should always be true given the current code
flow), if PAPR is only used with book3s_64 where it works and that
HV KVM is only used in PAPR mode.
This is done lazily. The SPE save will be done only if the guest has
used SPE since the last preemption or heavyweight exit. Restore will be
done only on demand, when enabling MSR_SPE in the shadow MSR, in response
to an SPE fault or mtmsr emulation.
For SPEFSCR, Linux already switches it on context switch (non-lazily), so
the only remaining bit is to save it between qemu and the guest.
Return the actual host SVR for now, as we already do for PVR. Eventually
we may support Qemu overriding PVR/SVR if the situation is appropriate,
once we implement KVM_SET_SREGS on e500.
The VCPU uninit calls some TLB functions, and the TLB uninit function
frees the memory used by them.
Acked-by: Liu Yu <yu.liu@freescale.com>
For transparent variable sharing between the hypervisor and guest, I introduce
a shared page. This shared page will contain all the registers the guest can
read and write safely without exiting guest context.
This patch only implements the stubs required for the basic structure of the
shared page. The actual register moving follows.
kvmppc_e500_exit() is a module_exit function, so it should be tagged
with __exit, not __init. The incorrect annotation was added by commit
2986b8c72c272ea58edd37903b042c6da985627d.
Cc: stable@kernel.org
vmx and svm vcpus have different contents and therefore may have different
alignmment requirements. Let each specify its required alignment.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
commit 513579e3a391a3874c478a8493080822069976e8 change the way
we emulate PVR/PIR,
which left PVR/PIR uninitialized on E500, and make guest puzzled.
Acked-by: Alexander Graf <agraf@suse.de>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Fixes a couple of warnings like this one:
WARNING: arch/powerpc/kvm/kvm-440.o(.text+0x1e8c): Section mismatch in reference from the function kvmppc_44x_exit() to the function .exit.text:kvmppc_booke_exit()
The function kvmppc_44x_exit() references a function in an exit section.
Often the function kvmppc_booke_exit() has valid usage outside the exit section
and the fix is to remove the __exit annotation of kvmppc_booke_exit.
Also add some __init annotations on obvious routines.
e500 has additional interrupt vectors (and corresponding IVORs) for SPE and
performance monitoring interrupts.
Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com>
