I noticed ksm spending quite a lot of time in memcmp on a large
KVM box. The current memcmp loop is very unoptimised - byte at a
time compares with no loop unrolling. We can do much much better.
Optimise the loop in a few ways:
- Unroll the byte at a time loop
- For large (at least 32 byte) comparisons that are also 8 byte
aligned, use an unrolled modulo scheduled loop using 8 byte
loads. This is similar to our glibc memcmp.
A simple microbenchmark testing 10000000 iterations of an 8192 byte
memcmp was used to measure the performance:
baseline: 29.93 s
modified: 1.70 s
Just over 17x faster.
v2: Incorporated some suggestions from Segher:
- Use andi. instead of rdlicl.
- Convert bdnzt eq, to bdnz. It's just duplicating the earlier compare
and was a relic from a previous version.
- Don't use cr5, we have plans to use that CR field for fast local
atomics.
In the Makefile, string.o (which is generated from string.S) is
included into the list of objects being built unconditionally
(obj-y) in line 12.
Additionally, if CONFIG_PPC64 is set, it is included again in
line 17.
This patch removes the latter unnecessary inclusion.
Signed-off-by: Andreas Ruprecht <rupran@einserver.de>
Added in 2008, but has never had any in-tree users, and no other
architectures provide it.
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Move the lib symbol exports closer to their function definitions
Unaligned stores take alignment exceptions on POWER7 running in little-endian.
This is a dumb little-endian base memcpy that prevents unaligned stores.
Once booted the feature fixup code switches over to the VMX copy loops
(which are already endian safe).
The question is what we do before that switch over. The base 64bit
memcpy takes alignment exceptions on POWER7 so we can't use it as is.
Fixing the causes of alignment exception would slow it down, because
we'd need to ensure all loads and stores are aligned either through
rotate tricks or bytewise loads and stores. Either would be bad for
all other 64bit platforms.
[ I simplified the loop a bit - Anton ]
Signed-off-by: Philippe Bergheaud <felix@linux.vnet.ibm.com>
Add a VMX optimised xor, used primarily for RAID5. On a POWER7 blade
this is a decent win:
32regs : 17932.800 MB/sec
altivec : 19724.800 MB/sec
The bigger gain is when the same test is run in SMT4 mode, as it
would if there was a lot of work going on:
8regs : 8377.600 MB/sec
altivec : 15801.600 MB/sec
I tested this against an array created without the patch, and also
verified it worked as expected on a little endian kernel.
[ Fix !CONFIG_ALTIVEC build -- BenH ]
We need to fix some endian issues in our memcpy code. For now
just enable the generic memcpy routine for little endian builds.
We need to fix some endian issues in our checksum code. For now
just enable the generic checksum routines for little endian builds.
Uprobes uses emulate_step in sstep.c, but we haven't explicitly specified
the dependency. On pseries HAVE_HW_BREAKPOINT protects us, but 44x has no
such luxury.
Consolidate other users that depend on sstep and create a new config option.
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Signed-off-by: Suzuki K. Poulose <suzuki@in.ibm.com>
Cc: linuxppc-dev@ozlabs.org
Cc: stable@vger.kernel.org
Finally remove the two level TOC and build with -mcmodel=medium.
Unfortunately we can't build modules with -mcmodel=medium due to
the tricks the kernel module loader plays with percpu data:
# -mcmodel=medium breaks modules because it uses 32bit offsets from
# the TOC pointer to create pointers where possible. Pointers into the
# percpu data area are created by this method.
# The kernel module loader relocates the percpu data section from the
# original location (starting with 0xd...) to somewhere in the base
# kernel percpu data space (starting with 0xc...). We need a full
# 64bit relocation for this to work, hence -mcmodel=large.
On older kernels we fall back to the two level TOC (-mminimal-toc)
Implement a POWER7 optimised memcpy using VMX and enhanced prefetch
instructions.
This is a copy of the POWER7 optimised copy_to_user/copy_from_user
loop. Detailed implementation and performance details can be found in
commit a66086b8197d (powerpc: POWER7 optimised
copy_to_user/copy_from_user using VMX).
I noticed memcpy issues when profiling a RAID6 workload:
.memcpy
.async_memcpy
.async_copy_data
.__raid_run_ops
.handle_stripe
.raid5d
.md_thread
I created a simplified testcase by building a RAID6 array with 4 1GB
ramdisks (booting with brd.rd_size=1048576):
# mdadm -CR -e 1.2 /dev/md0 --level=6 -n4 /dev/ram[0-3]
I then timed how long it took to write to the entire array:
# dd if=/dev/zero of=/dev/md0 bs=1M
Before: 892 MB/s
After: 999 MB/s
A 12% improvement.
Implement a POWER7 optimised copy_page using VMX and enhanced
prefetch instructions. We use enhanced prefetch hints to prefetch
both the load and store side. We copy a cacheline at a time and
fall back to regular loads and stores if we are unable to use VMX
(eg we are in an interrupt).
The following microbenchmark was used to assess the impact of
the patch:
http://ozlabs.org/~anton/junkcode/page_fault_file.c
We test MAP_PRIVATE page faults across a 1GB file, 100 times:
# time ./page_fault_file -p -l 1G -i 100
Before: 22.25s
After: 18.89s
17% faster
Subsequent patches will add more VMX library functions and it makes
sense to keep all the c-code helper functions in the one file.
I noticed __clear_user high up in a profile of one of my RAID stress
tests. The testcase was doing a dd from /dev/zero which ends up
calling __clear_user.
__clear_user is basically a loop with a single 4 byte store which
is horribly slow. We can do much better by aligning the desination
and doing 32 bytes of 8 byte stores in a loop.
The following testcase was used to verify the patch:
http://ozlabs.org/~anton/junkcode/stress_clear_user.c
To show the improvement in performance I ran a dd from /dev/zero
to /dev/null on a POWER7 box:
Before:
# dd if=/dev/zero of=/dev/null bs=1M count=10000
10485760000 bytes (10 GB) copied, 3.72379 s, 2.8 GB/s
After:
# time dd if=/dev/zero of=/dev/null bs=1M count=10000
10485760000 bytes (10 GB) copied, 0.728318 s, 14.4 GB/s
Over 5x faster.
Implement a POWER7 optimised copy_to_user/copy_from_user using VMX.
For large aligned copies this new loop is over 10% faster, and for
large unaligned copies it is over 200% faster.
If we take a fault we fall back to the old version, this keeps
things relatively simple and easy to verify.
On POWER7 unaligned stores rarely slow down - they only flush when
a store crosses a 4KB page boundary. Furthermore this flush is
handled completely in hardware and should be 20-30 cycles.
Unaligned loads on the other hand flush much more often - whenever
crossing a 128 byte cache line, or a 32 byte sector if either sector
is an L1 miss.
Considering this information we really want to get the loads aligned
and not worry about the alignment of the stores. Microbenchmarks
confirm that this approach is much faster than the current unaligned
copy loop that uses shifts and rotates to ensure both loads and
stores are aligned.
We also want to try and do the stores in cacheline aligned, cacheline
sized chunks. If the store queue is unable to merge an entire
cacheline of stores then the L2 cache will have to do a
read/modify/write. Even worse, we will serialise this with the stores
in the next iteration of the copy loop since both iterations hit
the same cacheline.
Based on this, the new loop does the following things:
1 - 127 bytes
Get the source 8 byte aligned and use 8 byte loads and stores. Pretty
boring and similar to how the current loop works.
128 - 4095 bytes
Get the source 8 byte aligned and use 8 byte loads and stores,
1 cacheline at a time. We aren't doing the stores in cacheline
aligned chunks so we will potentially serialise once per cacheline.
Even so it is much better than the loop we have today.
4096 - bytes
If both source and destination have the same alignment get them both
16 byte aligned, then get the destination cacheline aligned. Do
cacheline sized loads and stores using VMX.
If source and destination do not have the same alignment, we get the
destination cacheline aligned, and use permute to do aligned loads.
In both cases the VMX loop should be optimal - we always do aligned
loads and stores and are always doing stores in cacheline aligned,
cacheline sized chunks.
To be able to use VMX we must be careful about interrupts and
sleeping. We don't use the VMX loop when in an interrupt (which should
be rare anyway) and we wrap the VMX loop in disable/enable_pagefault
and fall back to the existing copy_tofrom_user loop if we do need to
sleep.
The VMX breakpoint of 4096 bytes was chosen using this microbenchmark:
http://ozlabs.org/~anton/junkcode/copy_to_user.c
Since we are using VMX and there is a cost to saving and restoring
the user VMX state there are two broad cases we need to benchmark:
- Best case - userspace never uses VMX
- Worst case - userspace always uses VMX
In reality a userspace process will sit somewhere between these two
extremes. Since we need to test both aligned and unaligned copies we
end up with 4 combinations. The point at which the VMX loop begins to
win is:
0% VMX
aligned 2048 bytes
unaligned 2048 bytes
100% VMX
aligned 16384 bytes
unaligned 8192 bytes
Considering this is a microbenchmark, the data is hot in cache and
the VMX loop has better store queue merging properties we set the
breakpoint to 4096 bytes, a little below the unaligned breakpoints.
Some future optimisations we can look at:
- Looking at the perf data, a significant part of the cost when a
task is always using VMX is the extra exception we take to restore
the VMX state. As such we should do something similar to the x86
optimisation that restores FPU state for heavy users. ie:
* If the task has used fpu the last 5 timeslices, just do a full
* restore of the math state immediately to avoid the trap; the
* chances of needing FPU soon are obviously high now
preload_fpu = tsk_used_math(next_p) && next_p->fpu_counter > 5;
and
* fpu_counter contains the number of consecutive context switches
* that the FPU is used. If this is over a threshold, the lazy fpu
* saving becomes unlazy to save the trap. This is an unsigned char
* so that after 256 times the counter wraps and the behavior turns
* lazy again; this to deal with bursty apps that only use FPU for
* a short time
- We could create a paca bit to mirror the VMX enabled MSR bit and check
that first, avoiding multiple calls to calling enable_kernel_altivec.
That should help with iovec based system calls like readv.
- We could have two VMX breakpoints, one for when we know the user VMX
state is loaded into the registers and one when it isn't. This could
be a second bit in the paca so we can calculate the break points quickly.
- One suggestion from Ben was to save and restore the VSX registers
we use inline instead of using enable_kernel_altivec.
[BenH: Fixed a problem with preempt and fixed build without CONFIG_ALTIVEC]
POWER5 added popcntb, and POWER7 added popcntw and popcntd. As a first step
this patch does all the work out of line, but it would be nice to implement
them as inlines with an out of line fallback.
The performance issue with hweight was noticed when disabling SMT on a large
(192 thread) POWER7 box. The patch improves that testcase by about 8%.
Replace EXTRA_CFLAGS with ccflags-y and EXTRA_AFLAGS with asflags-y.
Signed-off-by: matt mooney <mfm@muteddisk.com>
csum_and_copy_from_user
We use the same core loop as the new csum_partial, adding in the
stores and exception handling code. To keep things simple we do all the
exception fixup in csum_and_copy_from_user. This wrapper function is
modelled on the generic checksum code and is careful to always calculate
a complete checksum even if we only copied part of the data to userspace.
To test this I forced checksumming on over loopback and ran socklib (a
simple TCP benchmark). On a POWER6 575 throughput improved by 19% with
this patch. If I forced both the sender and receiver onto the same cpu
(with the hope of shifting the benchmark from being cache bandwidth limited
to cpu limited), adding this patch improved performance by 55%
Gcc 4.5 is now generating out of line register save and restore
in the function prefix and postfix when we use -Os.
Implement perf-events based hw-breakpoint interfaces for PowerPC
64-bit server (Book III S) processors. This allows access to a
given location to be used as an event that can be counted or
profiled by the perf_events subsystem.
This is done using the DABR (data breakpoint register), which can
also be used for process debugging via ptrace. When perf_event
hw_breakpoint support is configured in, the perf_event subsystem
manages the DABR and arbitrates access to it, and ptrace then
creates a perf_event when it is requested to set a data breakpoint.
[Adopted suggestions from Paul Mackerras <paulus@samba.org> to
- emulate_step() all system-wide breakpoints and single-step only the
per-task breakpoints
- perform arch-specific cleanup before unregistration through
arch_unregister_hw_breakpoint()
Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com>
This extends the emulate_step() function to handle a large proportion
of the Book I instructions implemented on current 64-bit server
processors. The aim is to handle all the load and store instructions
used in the kernel, plus all of the instructions that appear between
l[wd]arx and st[wd]cx., so this handles the Altivec/VMX lvx and stvx
and the VSX lxv2dx and stxv2dx instructions (implemented in POWER7).
The new code can emulate user mode instructions, and checks the
effective address for a load or store if the saved state is for
user mode. It doesn't handle little-endian mode at present.
For floating-point, Altivec/VMX and VSX instructions, it checks
that the saved MSR has the enable bit for the relevant facility
set, and if so, assumes that the FP/VMX/VSX registers contain
valid state, and does loads or stores directly to/from the
FP/VMX/VSX registers, using assembly helpers in ldstfp.S.
Instructions supported now include:
* Loads and stores, including some but not all VMX and VSX instructions,
and lmw/stmw
* Atomic loads and stores (l[dw]arx, st[dw]cx.)
* Arithmetic instructions (add, subtract, multiply, divide, etc.)
* Compare instructions
* Rotate and mask instructions
* Shift instructions
* Logical instructions (and, or, xor, etc.)
* Condition register logical instructions
* mtcrf, cntlz[wd], exts[bhw]
* isync, sync, lwsync, ptesync, eieio
* Cache operations (dcbf, dcbst, dcbt, dcbtst)
The overflow-checking arithmetic instructions are not included, but
they appear not to be ever used in C code.
This uses decimal values for the minor opcodes in the switch statements
because that is what appears in the Power ISA specification, thus it is
easier to check that they are correct if they are in decimal.
If this is used to single-step an instruction where a data breakpoint
interrupt occurred, then there is the possibility that the instruction
is a lwarx or ldarx. In that case we have to be careful not to lose the
reservation until we get to the matching st[wd]cx., or we'll never make
forward progress. One alternative is to try to arrange that we can
return from interrupts and handle data breakpoint interrupts without
losing the reservation, which means not using any spinlocks, mutexes,
or atomic ops (including bitops). That seems rather fragile. The
other alternative is to emulate the larx/stcx and all the instructions
in between. This is why this commit adds support for a wide range
of integer instructions.
Add the option to build the code under arch/powerpc with -Werror.
The intention is to make it harder for people to inadvertantly introduce
warnings in the arch/powerpc code. It needs to be configurable so that
if a warning is introduced, people can easily work around it while it's
being fixed.
The option is a negative, ie. don't enable -Werror, so that it will be
turned on for allyes and allmodconfig builds.
The default is n, in the hope that developers will build with -Werror,
that will probably lead to some build breaks, I am prepared to be flamed.
It's not enabled for math-emu, which is a steaming pile of warnings.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
(pre-requisite to make the next patches more palatable)
Impact: fix for PowerPC 32 code
There were some early init code that was not safe for static
ftrace to boot on my PowerBook. This code must only use relative
addressing, and static mcount performs a compare of the
ftrace_trace_function pointer, and gets that with an absolute address.
In the early init boot up code, this will cause a fault.
This patch removes tracing from the files containing the offending
functions.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Now that arch/ppc is gone and CONFIG_PPC_MERGE is always set, remove
the dead code associated with !CONFIG_PPC_MERGE from arch/powerpc
and include/asm-powerpc.
This commit adds tests of the feature fixup code, they are run during
boot if CONFIG_FTR_FIXUP_SELFTEST=y. Some of the tests manually invoke
the patching routines to check their behaviour, and others use the
macros and so are patched during the normal patching done during boot.
Because we have two sets of macros with different names, we use a macro
to generate the test of the macros, very niiiice.
The logic to patch CPU feature sections lives in cputable.c, but these days
it's used for CPU features as well as firmware features. Move it into
it's own file for neatness and as preparation for some additions.
While we're moving the code, we pull the loop body logic into a separate
routine, and remove a comment which doesn't apply anymore.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
We currently have a few routines for patching code in asm/system.h, because
they didn't fit anywhere else. I'd like to clean them up a little and add
some more, so first move them into a dedicated C file - they don't need to
be inlined.
While we're moving the code, drop create_function_call(), it's intended
caller never got merged and will be replaced in future with something
different.
GCC 4.4.x looks to be adding support for generating out-of-line register
saves/restores based on:
http://gcc.gnu.org/ml/gcc-patches/2008-04/msg01678.html
This breaks the kernel if we enable CONFIG_CC_OPTIMIZE_FOR_SIZE. To fix
this we add the use the save/restore code from gcc and simplified it down
for our needs (integer only).
Additionally, we have to link this code into each module. The other
solution was to add EXPORT_SYMBOL() which meant going through the
trampoline which seemed nonsensical for these out-of-line routines.
Finally, we add some checks to prom_init_check.sh to ignore the
out-of-line save/restore functions.
This fixes a few more miscellaneous compile problems with ARCH=ppc.
1. Don't compile devres.c on ARCH=ppc, it doesn't have ioremap_flags.
2. Include <asm/irq.h> in setup.c for the __DO_IRQ_CANON definition.
3. Include <linux/proc_fs.h> in residual.c for the
definition of create_proc_read_entry.
4. Fix xchg_ptr to be a static inline to eliminate a compiler warning.
We provide an ioremap_flags, so this provides a corresponding
devm_ioremap_prot. The slight name difference is at Ben
Herrenschmidt's request as he plans on changing ioremap_flags to
ioremap_prot in the future.
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
Acked-by: Tejun Heo <htejun@gmail.com>
Instead of having in the makefile all the option that
requires rheap, we define a configuration symbol
and when needed we make sure it's selected.
Signed-off-by: Sylvain Munaut <tnt@246tNt.com>
Linus made this suggestion for the x86 merge and this starts the process
for powerpc. We assume that CONFIG_PPC64 implies CONFIG_PPC_MERGE and
CONFIG_PPC_STD_MMU_32 implies CONFIG_PPC_STD_MMU.
Create a helper function (alloc_maybe_bootmem) that is marked __init_refok
to limit the chances of mistakenly referring to other __init routines.
WARNING: vmlinux.o(.text+0x2a9c4): Section mismatch: reference to .init.text:.__alloc_bootmem (between '.update_dn_pci_info' and '.pci_dn_reconfig_notifier')
WARNING: vmlinux.o(.text+0x36430): Section mismatch: reference to .init.text:.__alloc_bootmem (between '.mpic_msi_init_allocator' and '.find_ht_magic_addr')
WARNING: vmlinux.o(.text+0x5e804): Section mismatch: reference to .init.text:.__alloc_bootmem (between '.celleb_setup_phb' and '.celleb_fake_pci_write_config')
WARNING: vmlinux.o(.text+0x5e8e8): Section mismatch: reference to .init.text:.__alloc_bootmem (between '.celleb_setup_phb' and '.celleb_fake_pci_write_config')
WARNING: vmlinux.o(.text+0x5e968): Section mismatch: reference to .init.text:.__alloc_bootmem (between '.celleb_setup_phb' and '.celleb_fake_pci_write_config')
Removed rheap in arch/ppc/lib and changed build system to use the
one in arch/powerpc/lib.
We have several platforms using local copies of identical
code.
Added kprobes to ppc32 platforms that have use single_step_exception. This
excludes 4xx and anything Book-E since their debug mechanisms for single stepping
are completely different.
Including support for non-coherent cache, some mm-related things +
relevant field in Kconfig and Makefiles. Also included rheap.o compilation
if 8xx is defined.
Non-coherent mapping were refined and renamed according to Cristoph
Hellwig. Orphaned functions were cleaned up.
[Also removed arch/ppc/kernel/dma-mapping.c, because otherwise
compiling with ARCH=ppc for a non DMA-cache-coherent platform ends up
with two copies of __dma_alloc_coherent etc.
-- paulus.]
Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com>
Honor alignment parameter in the rheap allocator. This is needed by
qe_lib.
Remove compile warning.
Signed-off-by: Pantelis Antoniou <pantelis@embeddedalley.com>
Signed-off-by: Li Yang <leoli@freescale.com>
Acked-by: Kumar Galak <galak@kernel.crashing.org>
This moves the cpm2 common code and PIC stuff to the powerpc. Most of the files
were just copied from ppc/, with minor tuning to make it compile, and, subsequently, work.
The ASCII -> EBCDIC functions, e2a() and strne2a() are now only used in
dt.c, so move them in there.
Micro-optimisation - add no-minimal-toc to some more arch/powerpc Makefiles.
There already exists a big endian safe bitops implementation in
lib/find_next_bit.c. The code in it is 90%+ common with the powerpc
specific version, so the powerpc version is redundant. This patch
makes the necessary changes to use the generic bitops in powerpc, and
removes the powerpc specific version.
Signed-off-by: Jon Mason <jdmason@us.ibm.com>
Here's a revised version. This re-introduces the set_bits() function
from ppc64, which I removed because I thought it was unused (it exists
on no other arch). In fact it is used in the powermac interrupt code
(but not on pSeries).
- We use LARXL/STCXL macros to generate the right (32 or 64 bit)
instructions, similar to LDL/STL from ppc_asm.h, used in fpu.S
- ppc32 previously used a full "sync" barrier at the end of
test_and_*_bit(), whereas ppc64 used an "isync". The merged version
uses "isync", since I believe that's sufficient.
- The ppc64 versions of then minix_*() bitmap functions have changed
semantics. Previously on ppc64, these functions were big-endian
(that is bit 0 was the LSB in the first 64-bit, big-endian word).
On ppc32 (and x86, for that matter, they were little-endian. As far
as I can tell, the big-endian usage was simply wrong - I guess
no-one ever tried to use minixfs on ppc64.
- On ppc32 find_next_bit() and find_next_zero_bit() are no longer
inline (they were already out-of-line on ppc64).
- For ppc64, sched_find_first_bit() has moved from mmu_context.h to
the merged bitops. What it was doing in mmu_context.h in the first
place, I have no idea.
- The fls() function is now implemented using the cntlzw instruction
on ppc64, instead of generic_fls(), as it already was on ppc32.
- For ARCH=ppc, this patch requires adding arch/powerpc/lib to the
arch/ppc/Makefile. This in turn requires some changes to
arch/powerpc/lib/Makefile which didn't correctly handle ARCH=ppc.
Built and running on G5.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Change USER/KERNEL_DS so that the merged version of
__strnlen_user can be used which allows us to complete the
removal of arch/ppc64/lib/.
The merged version follows the ppc64 version pretty closely mostly,
and in fact ARCH=ppc64 now uses the arch/powerpc/xmon version.
The main difference for ppc64 is that the 'p' command to call
show_state (which was always pretty dodgy) has been replaced by
the ppc32 'p' command, which calls a given procedure (so in fact
the old 'p' command behaviour can be achieved with 'p $show_state').
and remove the same bits from ppc64/lib/string.S.
