path: root/arch/powerpc/math-emu
2008-04-01[POWERPC] Replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-23[POWERPC] Fix carry bug in 128-bit unsigned integer addingLiu Yu
Synchronize it to the definition in include/math-emu/op-4.h for short term. Signed-off-by: Liu Yu <Yu.Liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-13[POWERPC] Fix rounding bug in emulation for double float operatingLiu Yu
This patch fixes rounding bug in emulation for double float operating on PowerPC platform. When pack double float operand, it need to truncate the tail due to the limited precision. If the truncated part is not zero, the last bit of work bit (totally 3 bits) need to '|' 1. This patch is completed in _FP_FRAC_SRS_2(X,N,sz) (arch/powerpc/math-emu/op-2.h). Originally the code leftwards rotates the operand to just keep the truncated part, then check whether it is zero. However, the number it rotates is not correct when N is not smaller than _FP_W_TYPE_SIZE, and it will cause the work bit '|' 1 in the improper case. This patch fixes this issue. Signed-off-by: Liu Yu <b13201@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-16[POWERPC] Fix handling of stfiwx math emulationKumar Gala
Its legal for the stfiwx instruction to have RA = 0 as part of its effective address calculation. This is illegal for all other XE form instructions. Add code to compute the proper effective address for stfiwx if RA = 0 rather than treating it as illegal. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-09-26[POWERPC] ppc math-emu needs -fno-builtin-fabs for math.c and fabs.cAl Viro
... since they deal with internal function with that name. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27powerpc: move math-emu over to arch/powerpcKumar Gala
Towards the goal of having arch/powerpc not build anything over in arch/ppc move math-emu over. Also, killed some references to arch/ppc/ in the arch/powerpc Makefile which should belong in drivers/ when the particular sub-arch's move over to arch/powerpc. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
