path: root/arch/powerpc/mm/hash_low_32.S
2008-05-20[POWERPC] powerpc/mm/hash_low_32.S: Remove CVS keywordAdrian Bunk
This removes a CVS keyword that wasn't updated for a long time from a comment. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-24[POWERPC] Clean up access to thread_info in assemblyKumar Gala
Use (31-THREAD_SHIFT) to get to thread_info from stack pointer. This makes the code a bit easier to read and more robust if we ever change THREAD_SHIFT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-03[POWERPC] Fix deadlock with mmu_hash_lock in hash_page_syncBenjamin Herrenschmidt
hash_page_sync() takes and releases the low level mmu hash lock in order to sync with other processors disposing of page tables. Because that lock can be needed to service hash misses triggered by interrupt handlers, taking it must be done with interrupts off. However, hash_page_sync() appears to be called with interrupts enabled, thus causing occasional deadlocks. We fix it by making sure hash_page_sync() masks interrupts while holding the lock. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-17[POWERPC] Fix COMMON symbol warningsKumar Gala
We get the following warnings in various ARCH=powerpc builds: WARNING: "ee_restarts" [arch/powerpc/kernel/built-in] is COMMON symbol WARNING: "fee_restarts" [arch/powerpc/kernel/built-in] is COMMON symbol WARNING: "htab_hash_searches" [arch/powerpc/mm/built-in] is COMMON symbol WARNING: "next_slot" [arch/powerpc/mm/built-in] is COMMON symbol WARNING: "mmu_hash_lock" [arch/powerpc/mm/built-in] is COMMON symbol WARNING: "primary_pteg_full" [arch/powerpc/mm/built-in] is COMMON symbol WARNING: "global_dbcr0" [arch/powerpc/kernel/built-in] is COMMON symbol Switch to moving local symbols (except mmu_hash_lock which is global) and space directive instead. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-13[POWERPC] Fix 32-bit mm operations when not using BATsBenjamin Herrenschmidt
On hash table based 32 bits powerpc's, the hash management code runs with a big spinlock. It's thus important that it never causes itself a hash fault. That code is generally safe (it does memory accesses in real mode among other things) with the exception of the actual access to the code itself. That is, the kernel text needs to be accessible without taking a hash miss exceptions. This is currently guaranteed by having a BAT register mapping part of the linear mapping permanently, which includes the kernel text. But this is not true if using the "nobats" kernel command line option (which can be useful for debugging) and will not be true when using DEBUG_PAGEALLOC implemented in a subsequent patch. This patch fixes this by pre-faulting in the hash table pages that hit the kernel text, and making sure we never evict such a page under hash pressure. Signed-off-by: Benjamin Herrenchmidt <benh@kernel.crashing.org> arch/powerpc/mm/hash_low_32.S | 22 ++++++++++++++++++++-- arch/powerpc/mm/mem.c | 3 --- arch/powerpc/mm/mmu_decl.h | 4 ++++ arch/powerpc/mm/pgtable_32.c | 11 +++++++---- 4 files changed, 31 insertions(+), 9 deletions(-) Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-15[POWERPC] Remove stale 64bit on 32bit kernel codeAnton Blanchard
Remove some stale POWER3/POWER4/970 on 32bit kernel support. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-10[PATCH] powerpc: trivial: modify comments to refer to new location of filesJon Mason
This patch removes all self references and fixes references to files in the now defunct arch/ppc64 tree. I think this accomplises everything wanted, though there might be a few references I missed. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-10powerpc: Use reg.h instead of processor.h when we just want reg namesPaul Mackerras
Now that the register names and bit definitions are all in reg.h, use that instead of processor.h in assembly code in a few places. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-10powerpc: Rename files to have consistent _32/_64 suffixesPaul Mackerras
This doesn't change any code, just renames things so we consistently have foo_32.c and foo_64.c where we have separate 32- and 64-bit versions. Signed-off-by: Paul Mackerras <paulus@samba.org>
