via following scripts
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/lmb/memblock/g' \
-e 's/LMB/MEMBLOCK/g' \
$FILES
for N in $(find . -name lmb.[ch]); do
M=$(echo $N | sed 's/lmb/memblock/g')
mv $N $M
done
and remove some wrong change like lmbench and dlmb etc.
also move memblock.c from lib/ to mm/
Suggested-by: Ingo Molnar <mingo@elte.hu>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
We need to keep track of the backing pages that get allocated by
vmemmap_populate() so that when we use kdump, the dump-capture kernel knows
where these pages are.
We use a simple linked list of structures that contain the physical address
of the backing page and corresponding virtual address to track the backing
pages.
To save space, we just use a pointer to the next struct vmemmap_backing. We
can also do this because we never remove nodes. We call the pointer "list"
to be compatible with changes made to the crash utility.
vmemmap_populate() is called either at boot-time or on a memory hotplug
operation. We don't have to worry about the boot-time calls because they
will be inherently single-threaded, and for a memory hotplug operation
vmemmap_populate() is called through:
sparse_add_one_section()
V
kmalloc_section_memmap()
V
sparse_mem_map_populate()
V
vmemmap_populate()
and in sparse_add_one_section() we're protected by pgdat_resize_lock().
So, we don't need a spinlock to protect the vmemmap_list.
We allocate space for the vmemmap_backing structs by allocating whole pages
in vmemmap_list_alloc() and then handing out chunks of this to
vmemmap_list_populate().
This means that we waste at most just under one page, but this keeps the code
is simple.
Signed-off-by: Mark Nelson <markn@au1.ibm.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Currently each available hugepage size uses a slightly different
pagetable layout: that is, the bottem level table of pointers to
hugepages is a different size, and may branch off from the normal page
tables at a different level. Every hugepage aware path that needs to
walk the pagetables must therefore look up the hugepage size from the
slice info first, and work out the correct way to walk the pagetables
accordingly. Future hardware is likely to add more possible hugepage
sizes, more layout options and more mess.
This patch, therefore reworks the handling of hugepage pagetables to
reduce this complexity. In the new scheme, instead of having to
consult the slice mask, pagetable walking code can check a flag in the
PGD/PUD/PMD entries to see where to branch off to hugepage pagetables,
and the entry also contains the information (eseentially hugepage
shift) necessary to then interpret that table without recourse to the
slice mask. This scheme can be extended neatly to handle multiple
levels of self-describing "special" hugepage pagetables, although for
now we assume only one level exists.
This approach means that only the pagetable allocation path needs to
know how the pagetables should be set out. All other (hugepage)
pagetable walking paths can just interpret the structure as they go.
There already was a flag bit in PGD/PUD/PMD entries for hugepage
directory pointers, but it was only used for debug. We alter that
flag bit to instead be a 0 in the MSB to indicate a hugepage pagetable
pointer (normally it would be 1 since the pointer lies in the linear
mapping). This means that asm pagetable walking can test for (and
punt on) hugepage pointers with the same test that checks for
unpopulated page directory entries (beq becomes bge), since hugepage
pointers will always be positive, and normal pointers always negative.
While we're at it, we get rid of the confusing (and grep defeating)
#defining of hugepte_shift to be the same thing as mmu_huge_psizes.
Signed-off-by: David Gibson <dwg@au1.ibm.com>
Currently we have a fair bit of rather fiddly code to manage the
various kmem_caches used to store page tables of various levels. We
generally have two caches holding some combination of PGD, PUD and PMD
tables, plus several more for the special hugepage pagetables.
This patch cleans this all up by taking a different approach. Rather
than the caches being designated as for PUDs or for hugeptes for 16M
pages, the caches are simply allocated to be a specific size. Thus
sharing of caches between different types/levels of pagetables happens
naturally. The pagetable size, where needed, is passed around encoded
in the same way as {PGD,PUD,PMD}_INDEX_SIZE; that is n where the
pagetable contains 2^n pointers.
For /proc/kcore, each arch registers its memory range by kclist_add().
In usual,
- range of physical memory
- range of vmalloc area
- text, etc...
are registered but "range of physical memory" has some troubles. It
doesn't updated at memory hotplug and it tend to include unnecessary
memory holes. Now, /proc/iomem (kernel/resource.c) includes required
physical memory range information and it's properly updated at memory
hotplug. Then, it's good to avoid using its own code(duplicating
information) and to rebuild kclist for physical memory based on
/proc/iomem.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
For /proc/kcore, vmalloc areas are registered per arch. But, all of them
registers same range of [VMALLOC_START...VMALLOC_END) This patch unifies
them. By this. archs which have no kclist_add() hooks can see vmalloc
area correctly.
Presently, kclist_add() only eats start address and size as its arguments.
Considering to make kclist dynamically reconfigulable, it's necessary to
know which kclists are for System RAM and which are not.
This patch add kclist types as
KCORE_RAM
KCORE_VMALLOC
KCORE_TEXT
KCORE_OTHER
This "type" is used in a patch following this for detecting KCORE_RAM.
The base TLB support didn't include support for SPARSEMEM_VMEMMAP, though
we did carve out some virtual space for it, the necessary support code
wasn't there. This implements it by using 16M pages for now, though the
page size could easily be changed at runtime if necessary.
This is a random collection of added ifdef's around portions of
code that only mak sense on server processors. Using either
CONFIG_PPC_STD_MMU_64 or CONFIG_PPC_BOOK3S as seems appropriate.
This is meant to make the future merging of Book3E 64-bit support
easier.
The typesafe version of the powerpc pagetable handling (with
USE_STRICT_MM_TYPECHECKS defined) has bitrotted again. This patch
makes a bunch of small fixes to get it back to building status.
It's still not enabled by default as gcc still generates worse
code with it for some reason.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
The function htab_bolt_mapping() is used to create permanent
mappings in the MMU hash table, for example, in order to create
the linear mapping of vmemmap. It's also used by early boot
ioremap (before mem_init_done).
However, the way ioremap uses it is incorrect as it passes it the
protection flags in the "linux PTE" form while htab_bolt_mapping()
expects them in the hash table format. This is made more confusing by
the fact that some of those flags are actually in the same position in
both cases.
This fixes it all by making htab_bolt_mapping() take normal linux
protection flags instead, and use a little helper to convert them to
htab flags. Callers can now use the usual PAGE_* definitions safely.
arch/powerpc/include/asm/mmu-hash64.h | 2 -
arch/powerpc/mm/hash_utils_64.c | 65 ++++++++++++++++++++--------------
arch/powerpc/mm/init_64.c | 9 +---
3 files changed, 44 insertions(+), 32 deletions(-)
Kmem cache passed to constructor is only needed for constructors that are
themselves multiplexeres. Nobody uses this "feature", nor does anybody uses
passed kmem cache in non-trivial way, so pass only pointer to object.
Non-trivial places are:
arch/powerpc/mm/hugetlbpage.c
This is flag day, yes.
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Jon Tollefson <kniht@linux.vnet.ibm.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Matt Mackall <mpm@selenic.com>
[akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c]
[akpm@linux-foundation.org: fix mm/slab.c]
[akpm@linux-foundation.org: fix ubifs]
Instead of using the variable mmu_huge_psize to keep track of the huge
page size we use an array of MMU_PAGE_* values. For each supported huge
page size we need to know the hugepte_shift value and have a
pgtable_cache. The hstate or an mmu_huge_psizes index is passed to
functions so that they know which huge page size they should use.
The hugepage sizes 16M and 64K are setup(if available on the hardware) so
that they don't have to be set on the boot cmd line in order to use them.
The number of 16G pages have to be specified at boot-time though (e.g.
hugepagesz=16G hugepages=5).
Signed-off-by: Jon Tollefson <kniht@linux.vnet.ibm.com>
Signed-off-by: Nick Piggin <npiggin@suse.de>
This changes vmemmap to use a different region (region 0xf) of the
address space, and to configure the page size of that region
dynamically at boot.
The problem with the current approach of always using 16M pages is that
it's not well suited to machines that have small amounts of memory such
as small partitions on pseries, or PS3's.
In fact, on the PS3, failure to allocate the 16M page backing vmmemmap
tends to prevent hotplugging the HV's "additional" memory, thus limiting
the available memory even more, from my experience down to something
like 80M total, which makes it really not very useable.
The logic used by my match to choose the vmemmap page size is:
- If 16M pages are available and there's 1G or more RAM at boot,
use that size.
- Else if 64K pages are available, use that
- Else use 4K pages
I've tested on a POWER6 (16M pages) and on an iSeries POWER3 (4K pages)
and it seems to work fine.
Note that I intend to change the way we organize the kernel regions &
SLBs so the actual region will change from 0xf back to something else at
one point, as I simplify the SLB miss handler, but that will be for a
later patch.
Make two vmemmap helpers static in init_64.c
Make stab variables static in stab.c
Make psize defs static in hash_utils_64.c
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Added support to allow an 85xx kernel to be run from a non-zero physical
address (useful for cooperative asymmetric multiprocessing situations and
kdump). The support can be configured at compile time by setting
CONFIG_PAGE_OFFSET, CONFIG_KERNEL_START, and CONFIG_PHYSICAL_START as
desired.
Alternatively, the kernel build can set CONFIG_RELOCATABLE. Setting this
config option causes the kernel to determine at runtime the physical
addresses of CONFIG_PAGE_OFFSET and CONFIG_KERNEL_START. If
CONFIG_RELOCATABLE is set, then CONFIG_PHYSICAL_START has no meaning.
However, CONFIG_PHYSICAL_START will always be used to set the LOAD program
header physical address field in the resulting ELF image.
Currently we are limited to running at a physical address that is a
multiple of 256M. This is due to how we map TLBs to cover
lowmem. This should be fixed to allow 64M or maybe even 16M alignment
in the future. It is considered an error to try and run a kernel at a
non-aligned physical address.
All the magic for this support is accomplished by proper initialization
of the kernel memory subsystem and use of ARCH_PFN_OFFSET.
The use of ARCH_PFN_OFFSET only affects normal memory and not IO mappings.
ioremap uses map_page and isn't affected by ARCH_PFN_OFFSET.
/dev/mem continues to allow access to any physical address in the system
regardless of how CONFIG_PHYSICAL_START is set.
Remove the __max_memory variable, as it is not referenced anywhere
in the tree besides some code in arch/ppc.
total_lowmem represents the amount of low memory, not the physical
address that low memory ends at. If the start of memory is at 0 it
happens that total_lowmem can be used as both the size and the address
that lowmem ends at (or more specifically one byte beyond the end).
To make the code a bit more clear and deal with the case when the start of
memory isn't at physical 0, we introduce lowmem_end_addr that represents
one byte beyond the last physical address in the lowmem region.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
vmemmap_populate will printk (with KERN_WARNING) for a lot of pages
if CONFIG_SPARSEMEM_VMEMMAP is enabled (at least it does on iSeries).
Use pr_debug for it instead.
Replace the only other use of DBG in this file with pr_debug as well.
Acked-by: Olof Johansson <olof@lixom.net>
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (24 commits)
[POWERPC] Fix vmemmap warning in init_64.c
[POWERPC] Fix 64 bits vDSO DWARF info for CR register
[POWERPC] Add 1TB workaround for PA6T
[POWERPC] Enable NO_HZ and high res timers for pseries and ppc64 configs
[POWERPC] Quieten cache information at boot
[POWERPC] Quieten clockevent printk
[POWERPC] Enable SLUB in *_defconfig
[POWERPC] Fix 1TB segment detection
[POWERPC] Fix iSeries_hpte_insert prototype
[POWERPC] Fix copyright symbol
[POWERPC] ibmebus: Move to of_device and of_platform_driver, match eHCA and eHEA drivers
[POWERPC] ibmebus: Add device creation and bus probing based on of_device
[POWERPC] ibmebus: Remove bus match/probe/remove functions
[POWERPC] Move of_device allocation into of_device.[ch]
[POWERPC] mpc52xx: device tree changes for FEC and MDIO
[POWERPC] bestcomm: GenBD task support
[POWERPC] bestcomm: FEC task support
[POWERPC] bestcomm: ATA task support
[POWERPC] bestcomm: core bestcomm support for Freescale MPC5200
[POWERPC] mpc52xx: Update mpc52xx_psc structure with B revision changes
Slab constructors currently have a flags parameter that is never used. And
the order of the arguments is opposite to other slab functions. The object
pointer is placed before the kmem_cache pointer.
Convert
ctor(void *object, struct kmem_cache *s, unsigned long flags)
to
ctor(struct kmem_cache *s, void *object)
throughout the kernel
[akpm@linux-foundation.org: coupla fixes]
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Use the right printk format to silence the following warning.
CC arch/powerpc/mm/init_64.o
arch/powerpc/mm/init_64.c: In function 'vmemmap_populate':
arch/powerpc/mm/init_64.c:243: warning: format '%p' expects type 'void *', but argument 4 has type 'long unsigned int'
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
htab_bolt_mapping takes another argument now the 1TB code has been
merged. Update vmemmap_populate to match.
Enable virtual memmap support for SPARSEMEM on PPC64 systems. Slice a 16th
off the end of the linear mapping space and use that to hold the vmemmap.
Uses the same size mapping as uses in the linear 1:1 kernel mapping.
[pbadari@gmail.com: fix warning]
Signed-off-by: Andy Whitcroft <apw@shadowen.org>
Acked-by: Mel Gorman <mel@csn.ul.ie>
Cc: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
The entries are only 32-bit, so restrict the virtual address to stay
below 0xffff_ffff. With KERNELBASE set to 0xc000_0000, this in effect
restricts access to the first 1GB of real memory.
Make setup_kcore conditional on CONFIG_PROC_KCORE for both 32/64.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Slab destructors were no longer supported after Christoph's
c59def9f222d44bb7e2f0a559f2906191a0862d7 change. They've been
BUGs for both slab and slub, and slob never supported them
either.
This rips out support for the dtor pointer from kmem_cache_create()
completely and fixes up every single callsite in the kernel (there were
about 224, not including the slab allocator definitions themselves,
or the documentation references).
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
APUS (the Amiga Power-Up System) is not supported under arch/powerpc
and it's unlikely it ever will be. Therefore, this patch removes the
fragments of APUS support code from arch/powerpc which have been
copied from arch/ppc.
A few APUS references are left in asm-powerpc in .h files which are
still used from arch/ppc.
The SLUB allocator relies on struct page fields first_page and slab,
overwritten by ptl when SPLIT_PTLOCK: so the SLUB allocator cannot then
be used for the lowest level of pagetable pages. This was obstructing
SLUB on PowerPC, which uses kmem_caches for its pagetables. So convert
its pte level to use normal gfp pages (whereas pmd, pud and 64k-page pgd
want partpages, so continue to use kmem_caches for pmd, pud and pgd).
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Use SLAB_PANIC and delete duplicated panic().
Cc: Ian Molton <spyro@f2s.com>
Cc: Andi Kleen <ak@suse.de>
It is not necessary to tell the slab allocators to align to a cacheline
if an explicit alignment was already specified. It is rather confusing
to specify multiple alignments.
Make sure that the call sites only use one form of alignment.
This patch was recently posted to lkml and acked by Pekka.
The flag SLAB_MUST_HWCACHE_ALIGN is
1. Never checked by SLAB at all.
2. A duplicate of SLAB_HWCACHE_ALIGN for SLUB
3. Fulfills the role of SLAB_HWCACHE_ALIGN for SLOB.
The only remaining use is in sparc64 and ppc64 and their use there
reflects some earlier role that the slab flag once may have had. If
its specified then SLAB_HWCACHE_ALIGN is also specified.
The flag is confusing, inconsistent and has no purpose.
Remove it.
Replace all uses of kmem_cache_t with struct kmem_cache.
The patch was generated using the following script:
#!/bin/sh
# Replace one string by another in all the kernel sources.
set -e
for file in `find * -name "*.c" -o -name "*.h"|xargs grep -l $1`; do
quilt add $file
sed -e "1,\$s/$1/$2/g" $file >/tmp/$$
mv /tmp/$$ $file
quilt refresh
done
The script was run like this
sh replace kmem_cache_t "struct kmem_cache"
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Localize poison values into one header file for better documentation and
easier/quicker debugging and so that the same values won't be used for
multiple purposes.
Use these constants in core arch., mm, driver, and fs code.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Matt Mackall <mpm@selenic.com>
Cc: Andi Kleen <ak@muc.de>
At present, ARCH=powerpc kernels can waste considerable space in
pagetables when making large hugepage mappings. Hugepage PTEs go in
PMD pages, but each PMD page maps 256M and so contains only 16
hugepage PTEs (128 bytes of data), but takes up a 1024 byte
allocation. With CONFIG_PPC_64K_PAGES enabled (64k base page size),
the situation is worse. Now hugepage PTEs are at the PTE page level
(also mapping 256M), so we store 16 hugepage PTEs in a 64k allocation.
The PowerPC MMU already means that any 256M region is either all
hugepage, or all normal pages. Thus, with some care, we can use a
different allocation for the hugepage PTE tables and only allocate the
128 bytes necessary.
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (78 commits)
[PATCH] powerpc: Add FSL SEC node to documentation
[PATCH] macintosh: tidy-up driver_register() return values
[PATCH] powerpc: tidy-up of_register_driver()/driver_register() return values
[PATCH] powerpc: via-pmu warning fix
[PATCH] macintosh: cleanup the use of i2c headers
[PATCH] powerpc: dont allow old RTC to be selected
[PATCH] powerpc: make powerbook_sleep_grackle static
[PATCH] powerpc: Fix warning in add_memory
[PATCH] powerpc: update mailing list addresses
[PATCH] powerpc: Remove calculation of io hole
[PATCH] powerpc: iseries: Add bootargs to /chosen
[PATCH] powerpc: iseries: Add /system-id, /model and /compatible
[PATCH] powerpc: Add strne2a() to convert a string from EBCDIC to ASCII
[PATCH] powerpc: iseries: Make more stuff static in platforms/iseries/mf.c
[PATCH] powerpc: iseries: Remove pointless iSeries_(restart|power_off|halt)
[PATCH] powerpc: iseries: mf related cleanups
[PATCH] powerpc: Replace platform_is_lpar() with a firmware feature
[PATCH] powerpc: trivial: Cleanup whitespace in cputable.h
[PATCH] powerpc: Remove unused iommu_off logic from pSeries_init_early()
[PATCH] powerpc: Unconfuse htab_bolt_mapping() callers
set_page_count usage outside mm/ is limited to setting the refcount to 1.
Remove set_page_count from outside mm/, and replace those users with
init_page_count() and set_page_refcounted().
This allows more debug checking, and tighter control on how code is allowed
to play around with page->_count.
In mm_init_ppc64() we calculate the location of the "IO hole", but then
no one ever looks at the value. So don't bother.
That's actually all mm_init_ppc64() does, so get rid of it too.
asm-ppc64/imalloc.h is only included from files in arch/powerpc/mm.
We already have a header for mm local definitions,
arch/powerpc/mm/mmu_decl.h. Thus, this patch moves the contents of
imalloc.h into mmu_decl.h. The only exception are the definitions of
PHBS_IO_BASE, IMALLOC_BASE and IMALLOC_END. Those are moved into
pgtable.h, next to similar definitions of VMALLOC_START and
VMALLOC_SIZE.
Built for multiplatform 32bit and 64bit (ARCH=powerpc).
This also make klimit have the same type on 32-bit as on 64-bit,
namely unsigned long, and defines and initializes it in one place.
This patch makes the kernel use a different kmem cache for PMD pages
as they are smaller than PTE pages. Avoids waste of memory.
The ancient ppcdebug/PPCDBG mechanism is now only used in two places.
First, in the hash setup code, one of the bits allows the size of the
hash table to be reduced by a factor of 8 - which would be better
accomplished with a command line option for that purpose. The other
was a bunch of bus walking related messages in the iSeries code, which
would seem to be insufficient reason to keep the mechanism.
This patch removes the last traces of this mechanism.
Built and booted on iSeries and pSeries POWER5 LPAR (ARCH=powerpc).
Adds a new CONFIG_PPC_64K_PAGES which, when enabled, changes the kernel
base page size to 64K. The resulting kernel still boots on any
hardware. On current machines with 4K pages support only, the kernel
will maintain 16 "subpages" for each 64K page transparently.
Note that while real 64K capable HW has been tested, the current patch
will not enable it yet as such hardware is not released yet, and I'm
still verifying with the firmware architects the proper to get the
information from the newer hypervisors.
This moves the remaining files in arch/ppc64/mm to arch/powerpc/mm,
and arranges that we use them when compiling with ARCH=ppc64.
