path: root/arch/powerpc/mm/mem.c
2006-02-07[PATCH] powerpc: Cleanup, consolidating icache dirtying logicDavid Gibson
The code to mark a page as icache dirty (so that it will later be icache-dcache flushed when we try to execute from it) is duplicated in three places: flush_dcache_page() does this marking and nothing else, but clear_user_page() and copy_user_page() duplicate it, since those functions make the page icache dirty themselves. This patch makes those other functions call flush_dcache_page() instead, so the logic's all in one place. This will make life less confusing if we ever need to tweak the details of the the lazy icache flush mechanism. arch/powerpc/mm/mem.c | 14 ++------------ 1 file changed, 2 insertions(+), 12 deletions(-) Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Don't use KERNELBASE in add_memory()Michael Ellerman
In add_memory() we should be using __va() to get a virtual address. Spotted by Mike Kravetz. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: numa placement for dynamically added memoryMike Kravetz
This places dynamically added memory within the appropriate numa node. A new routine hot_add_scn_to_nid() replicates most of the memory scanning code in parse_numa_properties(). Signed-off-by: Mike Kravetz <kravetz@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-23[PATCH] mm: powerpc ptlock commentsHugh Dickins
Update comments (only) on page_table_lock and mmap_sem in arch/powerpc. Removed the comment on page_table_lock from hash_huge_page: since it's no longer taking page_table_lock itself, it's irrelevant whether others are; but how it is safe (even against huge file truncation?) I can't say. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-15[PATCH] powerpc: Fix sparsemem with memory holes [was Re: ppc64 oops..]Paul Mackerras
This patch should fix the crashes we have been seeing on 64-bit powerpc systems with a memory hole when sparsemem is enabled. I'd appreciate it if people who know more about NUMA and sparsemem than me could look over it. There were two bugs. The first was that if NUMA was enabled but there was no NUMA information for the machine, the setup_nonnuma() function was adding a single region, assuming memory was contiguous. The second was that the loops in mem_init() and show_mem() assumed that all pages within the span of a pgdat were valid (had a valid struct page). I also fixed the incorrect setting of num_physpages that Mike Kravetz pointed out. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-11[PATCH] powerpc: Merge vdso's and add vdso support to 32 bits kernelBenjamin Herrenschmidt
This patch moves the vdso's to arch/powerpc, adds support for the 32 bits vdso to the 32 bits kernel, rename systemcfg (finally !), and adds some new (still untested) routines to both vdso's: clock_gettime() with support for CLOCK_REALTIME and CLOCK_MONOTONIC, clock_getres() (same clocks) and get_tbfreq() for glibc to retreive the timebase frequency. Tom,Steve: The implementation of get_tbfreq() I've done for 32 bits returns a long long (r3, r4) not a long. This is such that if we ever add support for >4Ghz timebases on ppc32, the userland interface won't have to change. I have tested gettimeofday() using some glibc patches in both ppc32 and ppc64 kernels using 32 bits userland (I haven't had a chance to test a 64 bits userland yet, but the implementation didn't change and was tested earlier). I haven't tested yet the new functions. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-08[PATCH] Memory Add Fixes for ppc64Mike Kravetz
memmap_init_zone() sets page count to 1. Before 'freeing' the page, we need to clear the count. This is the same that is done on free_all_bootmem_core() for memory discovered at boot time. Signed-off-by: Mike Kravetz <kravetz@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-08[PATCH] revised Memory Add Fixes for ppc64Mike Kravetz
Add the create_section_mapping() routine to create hptes for memory sections dynamically added after system boot. Signed-off-by: Mike Kravetz <kravetz@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-08[PATCH] ppc64: fix Memory: summary lineAnton Blanchard
On ppc64 we end up with a negative value for the data size in the memory boot message: Memory: 2035560k/2097152k available (5792k kernel code, 89564k reserved, 18014398509481632k data, 870k bss, 352k init) It turns out the section ordering of the linker script is different on ppc32 and ppc64, so just count data as _edata - _sdata which should work on both. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-06[PATCH] ppc64: support 64k pagesBenjamin Herrenschmidt
Adds a new CONFIG_PPC_64K_PAGES which, when enabled, changes the kernel base page size to 64K. The resulting kernel still boots on any hardware. On current machines with 4K pages support only, the kernel will maintain 16 "subpages" for each 64K page transparently. Note that while real 64K capable HW has been tested, the current patch will not enable it yet as such hardware is not released yet, and I'm still verifying with the firmware architects the proper to get the information from the newer hypervisors. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-31Merge ../linux-2.6 by handPaul Mackerras
2005-10-31powerpc: Fix bug arising from having multiple memory_limit variablesPaul Mackerras
We had a static memory_limit in prom.c, and then another one defined in setup_64.c and used in numa.c, which resulted in the kernel crashing when mem=xxx was given on the command line. This puts the declaration in system.h and the definition in mem.c. This also moves the definition of tce_alloc_start/end out of setup_64.c. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-29[PATCH] ppc: make phys_mem_access_prot() work with pfns instead of addressesRoland Dreier
Change the phys_mem_access_prot() function to take a pfn instead of an address. This allows mmap64() to work on /dev/mem for addresses above 4G on 32-bit architectures. We start with a pfn in mmap_mem(), so there's no need to convert to an address; in fact, it's actively bad, since the conversion can overflow when the address is above 4G. Similarly fix the ppc32 page_is_ram() function to avoid a conversion to an address by directly comparing to max_pfn. Working with max_pfn instead of high_memory fixes page_is_ram() to give the right answer for highmem pages. Signed-off-by: Roland Dreier <rolandd@cisco.com> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-27[PATCH] powerpc: Purge bootinfo.hDavid Gibson
With ARCH=powerpc we assume the presence of a device tree, so we don't require any support for the old bi_recs method of passing boot parameters. Likewise, we've never needed it for ppc64, but we still had an include/asm-ppc64/bootinfo.h from which nothing was used. This patch removes that file, and all references to it in arch/ppc64 and arch/powerpc. A related, unused variable 'boot_mem_size' is also removed from setup_32.c. The bootinfo stuff remains in ARCH=ppc for the time being. Built and booted on Power5 (ARCH=ppc64 and ARCH=powerpc), built for 32-bit powermac (ARCH=powerpc and ARCH=ppc). Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-22Merge changes from linux-2.6 by handPaul Mackerras
2005-10-10powerpc: Merge arch/ppc64/mm to arch/powerpc/mmPaul Mackerras
This moves the remaining files in arch/ppc64/mm to arch/powerpc/mm, and arranges that we use them when compiling with ARCH=ppc64. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-06powerpc: Merge lmb.c and make MM initialization use it.Paul Mackerras
This also creates merged versions of do_init_bootmem, paging_init and mem_init and moves them to arch/powerpc/mm/mem.c. It gets rid of the mem_pieces stuff. I made memory_limit a parameter to lmb_enforce_memory_limit rather than a global referenced by that function. This will require some small changes to ppc64 if we want to continue building ARCH=ppc64 using the merged lmb.c. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-26powerpc: Merge enough to start building in arch/powerpc.Paul Mackerras
This creates the directory structure under arch/powerpc and a bunch of Kconfig files. It does a first-cut merge of arch/powerpc/mm, arch/powerpc/lib and arch/powerpc/platforms/powermac. This is enough to build a 32-bit powermac kernel with ARCH=powerpc. For now we are getting some unmerged files from arch/ppc/kernel and arch/ppc/syslib, or arch/ppc64/kernel. This makes some minor changes to files in those directories and files outside arch/powerpc. The boot directory is still not merged. That's going to be interesting. Signed-off-by: Paul Mackerras <paulus@samba.org>
