This driver for Freescale MPC512x LocalPlus Bus FIFO (called SCLPC
in the Reference Manual) allows Direct Memory Access transfers
between RAM and peripheral devices on LocalPlus Bus.
Signed-off-by: Alexander Popov <alex.popov@linux.com>
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Cc: linuxppc-dev@lists.ozlabs.org
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
- support "hybrid" iommu/direct DMA ops for coherent_mask < dma_mask
from Benjamin Herrenschmidt
- EEH fixes for SRIOV from Gavin
- introduce rtas_get_sensor_fast() for IRQ handlers from Thomas Huth
- use hardware RNG for arch_get_random_seed_* not arch_get_random_*
from Paul Mackerras
- seccomp filter support from Michael Ellerman
- opal_cec_reboot2() handling for HMIs & machine checks from Mahesh
Salgaonkar
- add powerpc timebase as a trace clock source from Naveen N. Rao
- misc cleanups in the xmon, signal & SLB code from Anshuman Khandual
- add an inline function to update POWER8 HID0 from Gautham R. Shenoy
- fix pte_pagesize_index() crash on 4K w/64K hash from Michael Ellerman
- drop support for 64K local store on 4K kernels from Michael Ellerman
- move dma_get_required_mask() from pnv_phb to pci_controller_ops from
Andrew Donnellan
- initialize distance lookup table from drconf path from Nikunj A
Dadhania
- enable RTC class support from Vaibhav Jain
- disable automatically blocked PCI config from Gavin Shan
- add LEDs driver for PowerNV platform from Vasant Hegde
- fix endianness issues in the HVSI driver from Laurent Dufour
- kexec endian fixes from Samuel Mendoza-Jonas
- fix corrupted pdn list from Gavin Shan
- fix fenced PHB caused by eeh_slot_error_detail() from Gavin Shan
- Freescale updates from Scott: Highlights include 32-bit memcpy/memset
optimizations, checksum optimizations, 85xx config fragments and
updates, device tree updates, e6500 fixes for non-SMP, and misc
cleanup and minor fixes.
- a ton of cxl updates & fixes:
- add explicit precision specifiers from Rasmus Villemoes
- use more common format specifier from Rasmus Villemoes
- destroy cxl_adapter_idr on module_exit from Johannes Thumshirn
- destroy afu->contexts_idr on release of an afu from Johannes
Thumshirn
- compile with -Werror from Daniel Axtens
- EEH support from Daniel Axtens
- plug irq_bitmap getting leaked in cxl_context from Vaibhav Jain
- add alternate MMIO error handling from Ian Munsie
- allow release of contexts which have been OPENED but not STARTED
from Andrew Donnellan
- remove use of macro DEFINE_PCI_DEVICE_TABLE from Vaishali Thakkar
- release irqs if memory allocation fails from Vaibhav Jain
- remove racy attempt to force EEH invocation in reset from Daniel
Axtens
- fix + cleanup error paths in cxl_dev_context_init from Ian Munsie
- fix force unmapping mmaps of contexts allocated through the kernel
api from Ian Munsie
- set up and enable PSL Timebase from Philippe Bergheaud
* tag 'powerpc-4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (140 commits)
cxl: Set up and enable PSL Timebase
cxl: Fix force unmapping mmaps of contexts allocated through the kernel api
cxl: Fix + cleanup error paths in cxl_dev_context_init
powerpc/eeh: Fix fenced PHB caused by eeh_slot_error_detail()
powerpc/pseries: Cleanup on pci_dn_reconfig_notifier()
powerpc/pseries: Fix corrupted pdn list
powerpc/powernv: Enable LEDS support
powerpc/iommu: Set default DMA offset in dma_dev_setup
cxl: Remove racy attempt to force EEH invocation in reset
cxl: Release irqs if memory allocation fails
cxl: Remove use of macro DEFINE_PCI_DEVICE_TABLE
powerpc/powernv: Fix mis-merge of OPAL support for LEDS driver
powerpc/powernv: Reset HILE before kexec_sequence()
powerpc/kexec: Reset secondary cpu endianness before kexec
powerpc/hvsi: Fix endianness issues in the HVSI driver
leds/powernv: Add driver for PowerNV platform
powerpc/powernv: Create LED platform device
powerpc/powernv: Add OPAL interfaces for accessing and modifying system LED states
powerpc/powernv: Fix the log message when disabling VF
cxl: Allow release of contexts which have been OPENED but not STARTED
Pull irq updates from Thomas Gleixner:
"This updated pull request does not contain the last few GIC related
patches which were reported to cause a regression. There is a fix
available, but I let it breed for a couple of days first.
The irq departement provides:
- new infrastructure to support non PCI based MSI interrupts
- a couple of new irq chip drivers
- the usual pile of fixlets and updates to irq chip drivers
- preparatory changes for removal of the irq argument from interrupt
flow handlers
- preparatory changes to remove IRQF_VALID"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits)
irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources
irqchip: Add bcm2836 interrupt controller for Raspberry Pi 2
irqchip: Add documentation for the bcm2836 interrupt controller
irqchip/bcm2835: Add support for being used as a second level controller
irqchip/bcm2835: Refactor handle_IRQ() calls out of MAKE_HWIRQ
PCI: xilinx: Fix typo in function name
irqchip/gic: Ensure gic_cpu_if_up/down() programs correct GIC instance
irqchip/gic: Only allow the primary GIC to set the CPU map
PCI/MSI: pci-xgene-msi: Consolidate chained IRQ handler install/remove
unicore32/irq: Prepare puv3_gpio_handler for irq argument removal
tile/pci_gx: Prepare trio_handle_level_irq for irq argument removal
m68k/irq: Prepare irq handlers for irq argument removal
C6X/megamode-pic: Prepare megamod_irq_cascade for irq argument removal
blackfin: Prepare irq handlers for irq argument removal
arc/irq: Prepare idu_cascade_isr for irq argument removal
sparc/irq: Use access helper irq_data_get_affinity_mask()
sparc/irq: Use helper irq_data_get_irq_handler_data()
parisc/irq: Use access helper irq_data_get_affinity_mask()
mn10300/irq: Use access helper irq_data_get_affinity_mask()
irqchip/i8259: Prepare i8259_irq_dispatch for irq argument removal
the PPC_MPC512x config automatically selected USB_EHCI_BIG_ENDIAN_*
switches, which made Kconfig warn about "unmet direct dependencies":
scripts/kconfig/conf --silentoldconfig Kconfig
warning: (PPC_MPC512x && 440EPX) selects USB_EHCI_BIG_ENDIAN_DESC which has unmet direct dependencies (USB_SUPPORT && USB && USB_EHCI_HCD)
warning: (PPC_MPC512x && PPC_PS3 && PPC_CELLEB && 440EPX) selects USB_EHCI_BIG_ENDIAN_MMIO which has unmet direct dependencies (USB_SUPPORT && USB && USB_EHCI_HCD)
make the selected entries additionally depend on USB_EHCI_HCD which
silences the warning
Signed-off-by: Gerhard Sittig <gsi@denx.de>
It is not uncommon (at least with the ARM stuff) to have a piece
of hardware that implements different flavours of "interrupts".
A typical example of this is the GICv3 ITS, which implements
standard PCI/MSI support, but also some form of "generic MSI".
So far, the PCI/MSI domain is registered using the ITS device_node,
so that irq_find_host can return it. On the contrary, the raw MSI
domain is not registered with an device_node, making it impossible
to be looked up by another subsystem (obviously, using the same
device_node twice would only result in confusion, as it is not
defined which one irq_find_host would return).
A solution to this is to "type" domains that may be aliasing, and
to be able to lookup an device_node that matches a given type.
For this, we introduce irq_find_matching_host() as a superset
of irq_find_host:
struct irq_domain *irq_find_matching_host(struct device_node *node,
enum irq_domain_bus_token bus_token);
where bus_token is the "type" we want to match the domain against
(so far, only DOMAIN_BUS_ANY is defined). This result in some
moderately invasive changes on the PPC side (which is the only
user of the .match method).
This has otherwise no functionnal change.
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Cc: <linux-arm-kernel@lists.infradead.org>
Cc: Yijing Wang <wangyijing@huawei.com>
Cc: Ma Jun <majun258@huawei.com>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: Duc Dang <dhdang@apm.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Link: http://lkml.kernel.org/r/1438091186-10244-2-git-send-email-marc.zyngier@arm.com
This clock provider uses the consumer API, so include clk.h
explicitly.
Cc: Gerhard Sittig <gsi@denx.de>
Cc: Scott Wood <scottwood@freescale.com>
Acked-by: Anatolij Gustschin <agust@denx.de>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
So the boards which has COMMON_CLK enabled don't have to
invoke this in its board specific file.
Signed-off-by: Kevin Hao <haokexin@gmail.com>
Acked-by: Scott Wood <scottwood@freescale.com>
Acked-by: Michael Turquette <mturquette@linaro.org>
Signed-off-by: Michael Turquette <mturquette@linaro.org>
At the moment we transition from the memblock alloctor to the bootmem
allocator. Gitting rid of the bootmem allocator removes a bunch of
complicated code (most of which I owe the dubious honour of being
responsible for writing).
Tested-by: Emil Medve <Emilian.Medve@Freescale.com>
of_device_ids (i.e. compatible strings and the respective data) are not
supposed to change at runtime. All functions working with of_device_ids
provided by <linux/of.h> work with const of_device_ids. This allows to
mark all struct of_device_id const, too.
While touching these line also put the __init annotation at the right
position where necessary.
improve the common clock support code for MPC512x
- expand the CCM register set declaration with MPC5125 related registers
(which reside in the previously "reserved" area)
- tell the MPC5121, MPC5123, and MPC5125 SoC variants apart, and derive
the availability of components and their clocks from the detected SoC
(MBX, AXE, VIU, SPDIF, PATA, SATA, PCI, second FEC, second SDHC,
number of PSC components, type of NAND flash controller,
interpretation of the CPMF bitfield, PSC/CAN mux0 stage input clocks,
output clocks on SoC pins)
- add backwards compatibility (allow operation against a device tree
which lacks clock related specs) for MPC5125 FECs, too
telling SoC variants apart and adjusting the clock tree's generation
occurs at runtime, a common generic binary supports all of the chips
the MPC5125 approach to the NFC clock (one register with two counters
for the high and low periods of the clock) is not implemented, as there
are no users and there is no common implementation which supports this
kind of clock -- the new implementation would be unused and could not
get verified, so it shall wait until there is demand
Acked-by: Mike Turquette <mturquette@linaro.org>
the SDHC clock is derived from CSB with a fractional divider which can
address "quarters"; the implementation multiplies CSB by 4 and divides
it by the (integer) divider value
a bug in the clock domain synchronisation requires that only even
divider values get setup; we achieve this by
- multiplying CSB by 2 only instead of 4
- registering with CCF the divider's bit field without bit0
- the divider's lowest bit remains clear as this is the reset value
and later operations won't touch it
this change keeps fully utilizing common clock primitives (needs no
additional support logic, and avoids an excessive divider table) and
satisfies the hardware's constraint of only supporting even divider
values
adjust (expand on or move) a few comments,
add markers for easier navigation around helpers
this change removes workarounds which have become obsolete after
migration to common clock support has completed
- remove clkdev registration calls (compatibility clock item aliases)
after all peripheral drivers were adjusted for device tree based
clock lookup
- remove pre-enable workarounds after all peripheral drivers were
adjusted to acquire their respective clock items
workarounds for these clock items get removed: FEC (ethernet), I2C,
PSC (UART, SPI), PSC FIFO, USB, NFC (NAND flash), VIU (video capture),
BDLC (CAN), CAN MCLK, DIU (video output)
these clkdev registered names won't be provided any longer by the
MPC512x platform's clock driver: "psc%d_mclk", "mscan%d_mclk",
"usb%d_clk", "nfc_clk", "viu_clk", "sys_clk", "ref_clk"
the pre-enable workaround for PCI remains, but depends on the presence
of PCI related device tree nodes (disables the PCI clock in the absence
of PCI nodes, keeps the PCI clock enabled in the presence of nodes) --
moving clock acquisition into the peripheral driver isn't possible for
PCI because its initialization takes place before the platform clock
driver gets initialized, thus the clock provider isn't available then
Cc: Mike Turquette <mturquette@linaro.org>
adapt the DIU clock initialization to the COMMON_CLK approach:
device tree based clock lookup, prepare and unprepare for clocks,
work with frequencies not dividers, call the appropriate clk_*()
routines and don't access CCM registers
the "best clock" determination now completely relies on the
platform's clock driver to pick a frequency close to what the
caller requests, and merely checks whether the desired frequency
was met (fits the tolerance of the monitor)
this approach shall succeed upon first try in the usual case,
will test a few less desirable yet acceptable frequencies in
edge cases, and will fallback to "best effort" if none of the
previously tried frequencies pass the test
provide a fallback clock lookup approach in case the OF based clock
lookup for the DIU fails, this allows for successful operation in
the presence of an outdated device tree which lacks clock specs
the setup before the change was
- arch/powerpc/Kconfig had the PPC_CLOCK option, off by default
- depending on the PPC_CLOCK option the arch/powerpc/kernel/clock.c file
was built, which implements the clk.h API but always returns -ENOSYS
unless a platform registers specific callbacks
- the MPC52xx platform selected PPC_CLOCK but did not register any
callbacks, thus all clk.h API calls keep resulting in -ENOSYS errors
(which is OK, all peripheral drivers deal with the situation)
- the MPC512x platform selected PPC_CLOCK and registered specific
callbacks implemented in arch/powerpc/platforms/512x/clock.c, thus
provided real support for the clock API
- no other powerpc platform did select PPC_CLOCK
the situation after the change is
- the MPC512x platform implements the COMMON_CLK interface, and thus the
PPC_CLOCK approach in arch/powerpc/platforms/512x/clock.c has become
obsolete
- the MPC52xx platform still lacks genuine support for the clk.h API
while this is not a change against the previous situation (the error
code returned from COMMON_CLK stubs differs but every call still
results in an error)
- with all references gone, the arch/powerpc/kernel/clock.c wrapper and
the PPC_CLOCK option have become obsolete, as did the clk_interface.h
header file
the switch from PPC_CLOCK to COMMON_CLK is done for all platforms within
the same commit such that multiplatform kernels (the combination of 512x
and 52xx within one executable) keep working
extend the recently added COMMON_CLK platform support for MPC512x such
that it works with incomplete device tree data which lacks clock specs
[agust@denx.de: moved node macro definitions out of the function body]
this change implements a clock driver for the MPC512x PowerPC platform
which follows the COMMON_CLK approach and uses common clock drivers
shared with other platforms
this driver implements the publicly announced set of clocks (those
listed in the dt-bindings header file), as well as generates additional
'struct clk' items where the SoC hardware cannot easily get mapped to
the common primitives (shared code) of the clock API, or requires
"intermediate clock nodes" to represent clocks that have both gates and
dividers
the previous PPC_CLOCK implementation is kept in place and remains
active for the moment, the newly introduced CCF clock driver will
receive additional support for backwards compatibility in a subsequent
patch before it gets enabled and will replace the PPC_CLOCK approach
some of the clock items get pre-enabled in the clock driver to not have
them automatically disabled by the underlying clock subsystem because of
their being unused -- this approach is desirable because
- some of the clocks are useful to have for diagnostics and information
despite their not getting claimed by any drivers (CPU, internal and
external RAM, internal busses, boot media)
- some of the clocks aren't claimed by their peripheral drivers yet,
either because of missing driver support or because device tree specs
aren't available yet (but the workarounds will get removed as the
drivers get adjusted and the device tree provides the clock specs)
clkdev registration provides "alias names" for few clock items
- to not break those peripheral drivers which encode their component
index into the name that is used for clock lookup (UART, SPI, USB)
- to not break those drivers which use names for the clock lookup which
were encoded in the previous PPC_CLOCK implementation (NFC, VIU, CAN)
this workaround will get removed as these drivers get adjusted after
device tree based clock lookup has become available
the COMMON_CLK implementation copes with device trees which lack an
oscillator node (backwards compat), the REF clock is then derived from
the IPS bus frequency and multiplier values fetched from hardware
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree updates from Rob Herring:
"DeviceTree updates for 3.13. This is a bit larger pull request than
usual for this cycle with lots of clean-up.
- Cross arch clean-up and consolidation of early DT scanning code.
- Clean-up and removal of arch prom.h headers. Makes arch specific
prom.h optional on all but Sparc.
- Addition of interrupts-extended property for devices connected to
multiple interrupt controllers.
- Refactoring of DT interrupt parsing code in preparation for
deferred probe of interrupts.
- ARM cpu and cpu topology bindings documentation.
- Various DT vendor binding documentation updates"
* tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits)
powerpc: add missing explicit OF includes for ppc
dt/irq: add empty of_irq_count for !OF_IRQ
dt: disable self-tests for !OF_IRQ
of: irq: Fix interrupt-map entry matching
MIPS: Netlogic: replace early_init_devtree() call
of: Add Panasonic Corporation vendor prefix
of: Add Chunghwa Picture Tubes Ltd. vendor prefix
of: Add AU Optronics Corporation vendor prefix
of/irq: Fix potential buffer overflow
of/irq: Fix bug in interrupt parsing refactor.
of: set dma_mask to point to coherent_dma_mask
of: add vendor prefix for PHYTEC Messtechnik GmbH
DT: sort vendor-prefixes.txt
of: Add vendor prefix for Cadence
of: Add empty for_each_available_child_of_node() macro definition
arm/versatile: Fix versatile irq specifications.
of/irq: create interrupts-extended property
microblaze/pci: Drop PowerPC-ism from irq parsing
of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code.
of/irq: Use irq_of_parse_and_map()
Several functions are only ever referenced locally, so make them static.
Of those functions, many of them are protected by an #if. However, the
code which can compile fine in either case.
Now that (1) the unneeded code is marked 'static' and (2) the code is
only used under a C 'if (IS_ENABLED(CONFIG_FB_FSL_DIU))', the compiler
can automatically remove the unneeded code, and we don't need the #if or
the empty stub functions.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
a disabled Kconfig option results in a reference to a not implemented
routine when the IS_ENABLED() macro is used for both conditional
implementation of the routine as well as a C language source code test
at the call site -- the "if (0) func();" construct only gets eliminated
later by the optimizer, while the compiler already has emitted its
warning about "func()" being undeclared
provide an empty implementation for the mpc512x_setup_diu() and
mpc512x_init_diu() routines in case of the disabled option, to avoid the
compiler warning which is considered fatal and breaks compilation
the bug appeared with commit 2abbbb63c90ab55ca3f054772c2e5ba7df810c48
"powerpc/mpc512x: move common code to shared.c file", how to reproduce:
make mpc512x_defconfig
echo CONFIG_FB_FSL_DIU=n >> .config && make olddefconfig
make
CC arch/powerpc/platforms/512x/mpc512x_shared.o
.../arch/powerpc/platforms/512x/mpc512x_shared.c: In function 'mpc512x_init_early':
.../arch/powerpc/platforms/512x/mpc512x_shared.c:456:3: error: implicit declaration of function 'mpc512x_init_diu' [-Werror=implicit-function-declaration]
.../arch/powerpc/platforms/512x/mpc512x_shared.c: In function 'mpc512x_setup_arch':
.../arch/powerpc/platforms/512x/mpc512x_shared.c:469:3: error: implicit declaration of function 'mpc512x_setup_diu' [-Werror=implicit-function-declaration]
cc1: all warnings being treated as errors
make[4]: *** [arch/powerpc/platforms/512x/mpc512x_shared.o] Error 1
CC: <stable@vger.kernel.org> # v3.11
When removing prom.h include by of.h, several OF headers will no longer
be implicitly included. Add explicit includes of of_*.h as needed.
Acked-by: Grant Likely <grant.likely@linaro.org>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Olof Johansson <olof@lixom.net>
Only part of MPC5125 reset module is like as MPC5121.
In detail, RCWH register doesn't contain informations about:
- PCI arbiter
- NAND flash page size
- NAND flash port size
For this reason, in device tree, this module has a different name then
MPC5121 reset module but use the same "struct mpc512x_reset_module"
register definition and the same restart procedure.
Signed-off-by: Matteo Facchinetti <engineering@sirius-es.it>
move the MPC512x restart initialization from the shared init routine
to the shared init_early routine
recent problems in the proc(5) filesystem initialization led to the
situation where the platform's restart routine was invoked yet the
registers required for software reset were not yet available, which
made the board hang instead of reboot
- implement all of the init, init early, and setup arch routines in the
shared source file for the MPC512x PowerPC platform, and make all
MPC512x based boards (ADS, PDM, generic) use those common routines
- remove declarations from header files for routines which aren't
referenced from external callers any longer
this modification concentrates knowledge about the optional FSL DIU
support in one spot within the shared code, and makes all boards benefit
transparently from future improvements in the shared platform code
the change does not modify any behaviour but preserves all code paths
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc update from Benjamin Herrenschmidt:
"The main highlights this time around are:
- A pile of addition POWER8 bits and nits, such as updated
performance counter support (Michael Ellerman), new branch history
buffer support (Anshuman Khandual), base support for the new PCI
host bridge when not using the hypervisor (Gavin Shan) and other
random related bits and fixes from various contributors.
- Some rework of our page table format by Aneesh Kumar which fixes a
thing or two and paves the way for THP support. THP itself will
not make it this time around however.
- More Freescale updates, including Altivec support on the new e6500
cores, new PCI controller support, and a pile of new boards support
and updates.
- The usual batch of trivial cleanups & fixes"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits)
powerpc: Fix build error for book3e
powerpc: Context switch the new EBB SPRs
powerpc: Turn on the EBB H/FSCR bits
powerpc: Replace CPU_FTR_BCTAR with CPU_FTR_ARCH_207S
powerpc: Setup BHRB instructions facility in HFSCR for POWER8
powerpc: Fix interrupt range check on debug exception
powerpc: Update tlbie/tlbiel as per ISA doc
powerpc: Print page size info during boot
powerpc: print both base and actual page size on hash failure
powerpc: Fix hpte_decode to use the correct decoding for page sizes
powerpc: Decode the pte-lp-encoding bits correctly.
powerpc: Use encode avpn where we need only avpn values
powerpc: Reduce PTE table memory wastage
powerpc: Move the pte free routines from common header
powerpc: Reduce the PTE_INDEX_SIZE
powerpc: Switch 16GB and 16MB explicit hugepages to a different page table format
powerpc: New hugepage directory format
powerpc: Don't truncate pgd_index wrongly
powerpc: Don't hard code the size of pte page
powerpc: Save DAR and DSISR in pt_regs on MCE
Use common help functions to free reserved pages.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Add dts file for ac14xx board and its board compatible
string to the generic mpc512x board match list.
Also add phandle to the dma DT node since there is a change
(for MPC5121 SDHC DMA support) merged via linux-mmc tree
with reference to the dma controller node in the sdhc node.
Tested on MPC5125 Tower evaluation board with
mpc512x_defconfig compile configuration.
In detail, supports for:
- PSC / UART
- RTC
- ETH
- DIU
- I2C
Signed-off-by: Matteo Facchinetti <matteo.facchinetti@sirius-es.it>
Just like the OHCI counter part we just can remove the architecture
specific symbols which prevent these configuration symbols from being
selected by platforms/architectures requiring it. The original
implementation did not scale at all since it required each and every
single architecture to be added for these configuration symbols to be
selected. Now it is up to the EHCI driver and/or platform to select
these configuration symbols accordingly.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
This provides a base for using 512x_generic platform on mpc5125 boards.
By this way 512x_GENERIC it could be used for all generic mpc512x boards
and kernel could be compiled with mpc512x_defconfig.
[agust: applied s/mpc5121/mpc512x in mpc512x_generic.c]
Create devices for mbx, sram, pci and gpio-leds nodes and
also move nfc compatible to of_bus_id list for automatic
nfc device creation.
Please pull mpc5xxx patches for v3.9. The bestcomm driver is
moved to drivers/dma (so it will be usable for ColdFire).
mpc5121 now provides common dtsi file and existing mpc5121 device
trees use it. There are some minor clock init and sparse fixes
and updates for various 5200 device tree files from Grant. Some
fixes for bugs in the mpc5121 DIU driver are also included here
(Andrew Morton suggested to push them via my mpc5xxx tree).
The Freescale DIU driver was recently updated to not require every DIU
platform function, so now we can remove the unneeded functions from
some boards.
Fix warnings:
symbol 'clockctl' was not declared. Should it be static?
symbol 'rate_clks' was not declared. Should it be static?
symbol 'dev_clks' was not declared. Should it be static?
symbol 'mpc5121_clk_init' was not declared. Should it be static?
Fix:
warning: dereference of noderef expression
Add ability to configure chip select (CS) parameters for devices
that need different CS parameters setup after their configuration.
I.e. an FPGA device on LP bus can require different CS parameters
for its bus interface after loading firmware into it. A driver
can easily reconfigure the LPC CS parameters using this function.
Acked-by: Timur Tabi <timur@tabi.org>
Early driver probing can fail due to not available clocks
(clk_get() fails) since the clk API init didn't take place yet.
Move clocks init before bus probing.
The .dtsi now names all PSC nodes as "psc", so this ac97
check won't work. Check for ac97 PSC using compatible
property.
Don't use cell-index from device tree, obtain the PSC number
from PSCx register offset.
If the DIU framebuffer driver is not enabled, then there's no point in
compiling any platform DIU code, because it will never be used. Most of
the platform code was protected in the appropriate #ifdef, but not all.
This caused a break in some randconfig builds.
This is only a problem on the 512x platforms. The P1022DS and MPC8610HPCD
platforms are already correct.
This patch reverts commit 12e36309f8774f4ccc769d5e3ff11ef092e524bc ("powerpc:
Option FB_FSL_DIU is not really optional for mpc512x") and restores the
ability to configure DIU support.
Pull powerpc updates from Benjamin Herrenschmidt:
"Some highlights in addition to the usual batch of fixes:
- 64TB address space support for 64-bit processes by Aneesh Kumar
- Gavin Shan did a major cleanup & re-organization of our EEH support
code (IBM fancy PCI error handling & recovery infrastructure) which
paves the way for supporting different platform backends, along
with some rework of the PCIe code for the PowerNV platform in order
to remove home made resource allocations and instead use the
generic code (which is possible after some small improvements to it
done by Gavin).
- Uprobes support by Ananth N Mavinakayanahalli
- A pile of embedded updates from Freescale folks, including new SoC
and board supports, more KVM stuff including preparing for 64-bit
BookE KVM support, ePAPR 1.1 updates, etc..."
Fixup trivial conflicts in drivers/scsi/ipr.c
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (146 commits)
powerpc/iommu: Fix multiple issues with IOMMU pools code
powerpc: Fix VMX fix for memcpy case
driver/mtd:IFC NAND:Initialise internal SRAM before any write
powerpc/fsl-pci: use 'Header Type' to identify PCIE mode
powerpc/eeh: Don't release eeh_mutex in eeh_phb_pe_get
powerpc: Remove tlb batching hack for nighthawk
powerpc: Set paca->data_offset = 0 for boot cpu
powerpc/perf: Sample only if SIAR-Valid bit is set in P7+
powerpc/fsl-pci: fix warning when CONFIG_SWIOTLB is disabled
powerpc/mpc85xx: Update interrupt handling for IFC controller
powerpc/85xx: Enable USB support in p1023rds_defconfig
powerpc/smp: Do not disable IPI interrupts during suspend
powerpc/eeh: Fix crash on converting OF node to edev
powerpc/eeh: Lock module while handling EEH event
powerpc/kprobe: Don't emulate store when kprobe stwu r1
powerpc/kprobe: Complete kprobe and migrate exception frame
powerpc/kprobe: Introduce a new thread flag
powerpc: Remove unused __get_user64() and __put_user64()
powerpc/eeh: Global mutex to protect PE tree
powerpc/eeh: Remove EEH PE for normal PCI hotplug
In powerpc randconfig builds, this keeps showing up:
arch/powerpc/platforms/512x/mpc512x_shared.c:70:9: warning: 'enum fsl_diu_monitor_port' declared inside parameter list
arch/powerpc/platforms/512x/mpc512x_shared.c:70:9: warning: its scope is only this definition or declaration, which is probably not what you want
arch/powerpc/platforms/512x/mpc512x_shared.c:69:56: error: parameter 1 ('port') has incomplete type
arch/powerpc/platforms/512x/mpc512x_shared.c:69:5: warning: function declaration isn't a prototype
arch/powerpc/platforms/512x/mpc512x_shared.c:84:9: warning: 'enum fsl_diu_monitor_port' declared inside parameter list
arch/powerpc/platforms/512x/mpc512x_shared.c:83:56: error: parameter 1 ('port') has incomplete type
arch/powerpc/platforms/512x/mpc512x_shared.c:83:6: warning: function declaration isn't a prototype
arch/powerpc/platforms/512x/mpc512x_shared.c:88:36: warning: 'enum fsl_diu_monitor_port' declared inside parameter list
arch/powerpc/platforms/512x/mpc512x_shared.c:88:57: error: parameter 1 ('port') has incomplete type
arch/powerpc/platforms/512x/mpc512x_shared.c:88:6: warning: function declaration isn't a prototype
arch/powerpc/platforms/512x/mpc512x_shared.c:187:54: error: parameter 1 ('port') has incomplete type
arch/powerpc/platforms/512x/mpc512x_shared.c:187:1: error: return type is an incomplete type
arch/powerpc/platforms/512x/mpc512x_shared.c:187:1: warning: function declaration isn't a prototype
arch/powerpc/platforms/512x/mpc512x_shared.c: In function 'mpc512x_valid_monitor_port':
arch/powerpc/platforms/512x/mpc512x_shared.c:189:9: error: 'FSL_DIU_PORT_DVI' undeclared (first use in this function)
arch/powerpc/platforms/512x/mpc512x_shared.c:189:9: note: each undeclared identifier is reported only once for each function it appears in
arch/powerpc/platforms/512x/mpc512x_shared.c:189:2: warning: 'return' with a value, in function returning void
make[2]: *** [arch/powerpc/platforms/512x/mpc512x_shared.o] Error 1
The reason is that mpc512x_shared.c has a couple token #ifdef
on FB_FSL_DIU/FB_FSL_DIU_MODULE, but they don't come close to
masking all the DIU dependencies, as the above fail shows.
Rather than sprinkle more pointless #ifdef in this file, just
remove the existing two, and make FB_FSL_DIU part of the
dependency. The mpc512x_defconfig already has the line
"CONFIG_FB_FSL_DIU=y" so this change should be zero impact
on real world configs.
If try_module_get() fails, mpc5121_clk_get() might return
a wrong clock.
Signed-off-by: Richard Weinberger <richard@nod.at>
Make all the irq_domain_ops structures in powerpc 'static const'
Cc: Milton Miller <miltonm@bga.com>
Tested-by: Olof Johansson <olof@lixom.net>
Each revmap type has different arguments for setting up the revmap.
This patch splits up the generator functions so that each revmap type
can do its own setup and the user doesn't need to keep track of how
each revmap type handles the arguments.
This patch also adds a host_data argument to the generators. There are
cases where the host_data pointer will be needed before the function returns.
ie. the legacy map calls the .map callback for each irq before returning.
v2: - Add void *host_data argument to irq_domain_add_*() functions
- fixed failure to compile
- Moved IRQ_DOMAIN_MAP_* defines into irqdomain.c
Cc: Rob Herring <rob.herring@calxeda.com>
This patch drops the powerpc-specific irq_host structures and uses the common
irq_domain strucutres defined in linux/irqdomain.h. It also fixes all
the users to use the new structure names.
Renaming irq_host to irq_domain has been discussed for a long time, and this
patch is a step in the process of generalizing the powerpc virq code to be
usable by all architecture.
An astute reader will notice that this patch actually removes the irq_host
structure instead of renaming it. This is because the irq_domain structure
already exists in include/linux/irqdomain.h and has the needed data members.
There is no Kconfig symbol named MPC5121_ADS_CPLD. The select statement
for that symbol is a nop. Drop it.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
