path: root/arch/powerpc/platforms/85xx/Kconfig
2009-08-24powerpc/85xx: Add support for P2020RDB boardPoonam Aggrwal
Add support for the P2020RDB reference board from Freescale. Overview of P2020RDB platform - DDR DDR2 1G - NOR Flash 16MByte - NAND Flash 32MByte - 3 Ethernet interfaces 1) etSEC1 - RGMII - connected to a 5 port Vitesse Switch(VSC7385) - Switch is memory mapped through eLBC interface(CS#2) - IRQ1 2) etSEC2 - SGMII - connected to VSC8221 - IRQ2 3) etSEC3 - RGMII - connected to VSC8641 - IRQ3 - 2 1X PCIe interfaces - SD/MMC ,USB - SPI EEPROM - Serial I2C EEPROM Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-15powerpc/85xx: Add platform support for X-ES MPC85xx boardsNate Case
Add support for X-ES single-board computers based on the Freescale MPC85xx processors. Signed-off-by: Nate Case <ncase@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-15powerpc/85xx: Add SWIOTLB support to FSL boardsKumar Gala
Add the platform-specific code for enabling SWIOTLB if needed on P2020DS, MPC85xx DS, and MPC85xx MDS boards as they are capable of having >4G of memory. We determine if we need to enable swiotlb based on how much memory is in the board and if it exceeds 4G or what we can map via PCI inbound windows. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-05-19powerpc/85xx: Enable Serial RapidIO for MPC85xx MDS boardsAnton Vorontsov
Select HAS_RAPIDIO symbol and add rio nodes for MPC8568E-MDS and MPC8569E-MDS boards. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-27powerpc/85xx: Add support for the "socrates" board (MPC8544).Wolfgang Grandegger
Supported are Ethernet, serial console, I2C, I2C-based RTC and temperature sensors, NOR and NAND flash, PCI, USB, CAN and Lime display controller. The multiplexing of FPGA interrupts onto PowerPC interrupt lines is supported through our own fpga_pic interrupt controller driver. For example the SJA1000 controller is level low sensitive connected to fpga_pic line 2 and is routed to the second (of three) irq lines to the CPU: can@3,100 { compatible = "philips,sja1000"; reg = <3 0x100 0x80>; interrupts = <2 2>; interrupts = <2 8 1>; // number, type, routing interrupt-parent = <&fpga_pic>; }; Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-13powerpc: make Freescale QE support a selectable Kconfig optionTimur Tabi
Modify the Kconfig so that Freescale QUICC Engine (QE) support is a selectable option, thereby allowing users to compile kernels without any QE support. The drawback is that QE support is now disabled by default on platforms that have a QE, and so a defconfig is needed to enable QE and QE devices (like UCC GETH). Fortunately, all the current relevant defconfigs do that already. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-16powerpc: Remove Kconfig PPC_CPM_NEW_BINDINGKumar Gala
With arch/ppc gone and all in kernel users of CONFIG_PPC_CPM_NEW_BINDING fixed up we dont have need for the Kconfig option anymore. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-16powerpc: pci config cleanupJohn Rigby
Choosing PCI or not at config time is allowed on some platforms via an if expression in arch/powerpc/Kconfig. To add a new platform with PCI support selectable at config time, you must change the if expression. This patch makes this easier by changing: bool "PCI support" if <long expression> to bool "PCI support" if PPC_PCI_CHOICE and adding select PPC_PCI_CHOICE to all the config nodes that were previously in the PCI if expression. Platforms with unconditional PCI support continue to just select PCI in their config nodes. Signed-off-by: John Rigby <jrigby@freescale.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-14powerpc/85xx: Add support for MPC8536DSKumar Gala
Add support for the MPC8536 process and MPC8536DS reference board. The MPC8536 is an e500v2 based SoC which eTSEC, USB, SATA, PCI, and PCIe. The USB and SATA IP blocks are similiar to those on the PQ2 Pro SoCs and thus use the same drivers. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-30Merge branch 'linux-2.6'Paul Mackerras
2008-06-10powerpc/85xx: add board support for the TQM8548 modulesWolfgang Grandegger
This patch adds support for the TQM8548 modules from TQ-Components GmbH (http://www.tqc.de). Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-09[POWERPC] 85xx: MPC85xx MDS - Unconditionally select PHYLIB for board fixupsKumar Gala
The MPC85xx MDS board requires some board level tweaks of the PHYs that either the eTSEC (gianfar) or UCC ethernet controllers are connected to. Its possible to build the phylib as a module, however this breaks the board level fix ups because phy_read and phy_write are not available if we build as a module. So we unconditionally select PHYLIB to ensure its built into the kernel if we are building in MPC85xx MDS support. This was determined to be the easiest soultion even though it prevents the user from removing PHYLIB support if they decide they don't want it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-17[POWERPC] CPM: Always use new binding.Scott Wood
The kconfig entry can go away once arch/ppc and references to the config in drivers are removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-26[POWERPC] 85xx: Emerson KSI8560 base supportAlexandr Smirnov
The KSI8560 is a single compact, mid-, or full-size Advanced Mezzanine Card (AdvancedMC™) based on the Freescale™ Semiconductor MPC8560 PowerQUICC III™ microprocessor. This product will serve in data and signaling applications such as signaling gateways (SGW) and softswitch signaling interface cards. The board has altera maxii CPLD, that is used to obtain and manage board configuration. Also there are two SCC UART serial consoles and FCC ethernet, that is routed to the front panel, while other ethernet controlers (TSEC's) are routed to the backplane. Signed-off-by: Alexandr Smirnov <asmirnov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] 85xx: rework platform KconfigKumar Gala
* Allow multiple boards to be selected in a single build * Removed Kconfig option '85xx' which existed only for compat with arch/ppc * Added a multiplatform 85xx defconfig (mpc85xx_defconfig). This builds all 85xx boards except sbc8560 and stx_gp3 since these to boards have board specific ifdef in driver code that may break all other boards Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] 85xx: Add basic support for Wind River SBC8548 boardPaul Gortmaker
This adds the basic support for the Wind River SBC8548 board, implemented as powerpc. It closely follows the implementation of the MPC8548CDS. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] CPM2: Make support for the CPM2 optional on 8560 based boardsPaul Gortmaker
Currently there is no way to disable the CPM2 support. Some boards, like the SBC8560 have their own external UART and don't have any direct dependencies on the CPM for a serial console or anything else. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] 85xx: Add support for Wind River SBC8560 in arch/powerpcPaul Gortmaker
This adds support for the Wind River SBC8560 board, implemented as powerpc. It closely follows the implementation of the MPC8560ADS. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-27[POWERPC] 85xx: Port TQM85xx boards over from arch/ppcKumar Gala
2008-01-27[POWERPC] 85xx: Port STX GP3 board over from arch/ppcKumar Gala
2007-10-11[POWERPC] 85xx: Convert mpc8560ads to the new CPM binding.Scott Wood
2007-10-08[POWERPC] mpc85xx_mds: select QUICC_ENGINEAnton Vorontsov
2007-09-13[POWERPC] 85xx: Renamed mpc8544_ds.c to mpc85xx_ds.cKumar Gala
Renamed the mpc8544_ds.c board code to mpc85xx_ds.c to make it more generic in prep for other boards based on the same platform. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-08-17[POWERPC] Fix interrupt routing and setup of ULI M1575 on FSL boardsKumar Gala
The interrupt routing in the device trees for the ULI M1575 was inproperly using the interrupt line field as pci function. Fixed up the device tree's to actual conform for to specification and changed the interrupt mapping code so it just uses a static mapping setup as follows: PIRQA - IRQ9 PIRQB - IRQ10 PIRQC - IRQ11 PIRQD - IRQ12 USB 1.1 OCHI (1c.0) - IRQ12 USB 1.1 OCHI (1c.1) - IRQ9 USB 1.1 OCHI (1c.2) - IRQ10 USB 1.1 ECHI (1c.3) - IRQ11 LAN (1b.0) - IRQ6 AC97 (1d.0) - IRQ6 Modem (1d.1) - IRQ6 HD Audio (1d.2) - IRQ6 SATA (1f.1) - IRQ5 SMB (1e.1) - IRQ7 PMU (1e.2) - IRQ7 PATA (1f.0) - IRQ14/15 Took the oppurtunity to refactor the code into a single file so we don't have to duplicate these fixes on the two current boards in the tree and several forth coming boards that will also need the code. Fixed RTC support that requires a dummy memory read on the P2P bridge to unlock the RTC and setup the default of the RTC alarm registers to match with a basic x86 style CMOS RTC. Moved code that poked ISA registers to a FIXUP_FINAL quirk to ensure the PCI IO space has been setup properly before we start poking ISA registers at random locations. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-23[POWERPC] 85xxCDS: Allow 8259 cascade to share an MPIC interrupt line.Randy Vinson
The Freescale MPC8555CDS and MPC8548CDS reference hardware has a legacy 8259 interrupt controller pair contained within a VIA VT82C686B Southbridge on the main carrier board. The processor complex plugs into the carrier card using a PCI slot which limits the available interrupts to the INTA-INTD PCI interrupts. The output of the 8259 cascade pair is routed through a gate array and connected to the PCI INTA interrupt line. The normal interrupt chaining hook (set_irq_chained_handler) does not allow sharing of the chained interrupt which prevents the use of PCI INTA by PCI devices. This patch allows the 8259 cascade pair to share their interrupt line with PCI devices. NOTE: The addition of the .end routine for the MPIC is not strictly necessary for this patch. It's there so this code will run from within the threaded interrupt context used by the Real Time patch. Signed-off-by: Randy Vinson <rvinson@mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-23[POWERPC] Add basic PCI/PCI Express support for 8544DS boardRoy Zang
Add basic support for the PCIe PHB and enable the ULI bridge. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-23[POWERPC] Make endianess of cfg_addr for indirect pci ops runtimeKumar Gala
Make it so we do a runtime check to know if we need to write cfg_addr as big or little endian. This is needed if we want to allow 86xx support to co-exist in the same kernel as other 6xx PPCs. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-23[POWERPC] Use Freescale pci/pcie common code for 85xx boardsRoy Zang
Switch the 85xx platform over to using the FSL generic PCI code. This gets ups PCIe support in addition to base PCI support. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-24Merge branch 'kconfig' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into for-2.6.22
2007-04-12[POWERPC] Convert 85xx platform to unified platform KconfigKumar Gala
Moved 85xx platform Kconfig over to being sourced by the unified arch/powerpc/platforms/Kconfig. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-13Merge branch 'linux-2.6' into for-2.6.22Paul Mackerras
2007-03-29[POWERPC] 85xx: Add initial MPC8544 DS platform files.Jon Loeliger
This patch provides the basic MPC8544 DS platform code and config. Follow-up patches will add peripherals such as PCI and SATA. Signed-off-by: Xianghua Xiao <x.xiao@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-03-07[POWERPC] 85xx: Enable CONFIG_SERIAL_8250_SHARE_IRQKumar Gala
On chip 8250 UARTs share an interrupts on existing 85xx processors. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-02-17[POWERPC] 85xx: Renamed MPC8568 MDS board code to match other boardsKumar Gala
Renamed the MPC8568 MDS platform code to follow other 85xx boards. There isn't anything specific about the 8568 MDS code that wouldn't apply to another 85xx MDS system at this point. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-02-13[POWERPC] 85xx: Add support for the 8568 MDS boardAndy Fleming
Add support for the MPC8568 MDS reference board Signed-off-by: Andrew Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-09-21POWERPC: Add support for the mpc8560 eval boardVitaly Bordug
This makes the 8560 evaluation board fully supported under arch/powerpc, as the first board with CPM2 SoC peripherals. The brand new devicetree nodes are introduced (intending to be a subset of the QuiccEngine-equipped models, with dts sources placed into the kernel according to the new convention. Assuming all the preceding stuff applied (PAL+fs_enet related+ CPM_UART update), the both TSEC eth ,FCC Eths, and both SCC UARTs are working. The relevant drivers are still capable to drive users in ppc, which was verified with 8272ADS (SCC uart+FCC eth). This is also verified on mpc8540 and actually make it work (PCI stuff working as well) Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com>
2006-08-23[POWERPC] Fix CDS IRQ handling and PCI codeAndy Fleming
* Fix IRQ support in the 85xx CDS boards so it uses the new generic stuff * Fix PCI IRQ mapping to use the device tree * Disabled i8259 support to allow the CDS to boot. This will be fixed soon, but the current code doesn't even compile, so this is a vast improvement Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-04Add 85xx CDS to arch/powerpcAndy Fleming
This patch adds support for 85xx CDS support to arch/powerpc Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-03-27powerpc: Make uImage default build output for MPC8540 ADSKumar Gala
When we build for the MPC8540 ADS produce a uImage by default. Updated the defconfig to reflect this as well. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-01-20[PATCH] powerpc: Updated Initial MPC8540 ADS port with OF Flat DevBecky Bruce
Updated patch for support for mpc8540_ads in arch/powerpc with a flat OF device tree. This patch does not yet support PCI or I2C. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-26powerpc: Merge enough to start building in arch/powerpc.Paul Mackerras
This creates the directory structure under arch/powerpc and a bunch of Kconfig files. It does a first-cut merge of arch/powerpc/mm, arch/powerpc/lib and arch/powerpc/platforms/powermac. This is enough to build a 32-bit powermac kernel with ARCH=powerpc. For now we are getting some unmerged files from arch/ppc/kernel and arch/ppc/syslib, or arch/ppc64/kernel. This makes some minor changes to files in those directories and files outside arch/powerpc. The boot directory is still not merged. That's going to be interesting. Signed-off-by: Paul Mackerras <paulus@samba.org>
