This patch renames GE Fanuc boards following the split-up of the GE Fanuc
joint venture. These boards are now made by GE Intelligent platorms.
Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com>
Add support for NVRAM on GE Fanuc's SBC310.
Removed the need for asm/mpc86xx.h as it was only used in mpc86xx_smp.c
and just moved the defines it cared about into there. Also fixed up
the ioremap to only map the one 4k page we need access to and to iounmap
when we are done.
Currently it doesn't matter where the mdio nodes are placed, but with
power management support (i.e. when sleep = <> properties will take
effect), mdio nodes placement will become important: mdio controller
is a part of the ethernet block, so the mdio nodes should be placed
correctly. Otherwise we may wrongly assume that MDIO controllers are
available during sleep.
Suggested-by: Scott Wood <scottwood@freescale.com>
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Patch to limit NEC fixup to SBC310, following similar patch to SBC610 by
Tony Breeds: 368a12117dd8abf6eaefa37c21ac313b517128b9
Support for the SBC310 VPX Single Board Computer from GE Fanuc (PowerPC
MPC8641D).
This is the basic board support for GE Fanuc's SBC310, a 3U single board
computer, based on Freescale's MPC8641D.
