Remove the check for CONFIG_PPC_85xx and CONFIG_PPC_86xx from fsl_guts.h.
The check was originally intended to allow the same header file to
be used on 85xx and 86xx systems, even though the Global Utilities
register could be different. It turns out that they're not actually
different, and so the check is not necessary. In addition, neither
macro is defined for 64-bit e5500 kernels, so that causes a build
break.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Disintegrate asm/system.h for PowerPC.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
cc: linuxppc-dev@lists.ozlabs.org
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-3.x into fbdev-next
drivers/video/atmel_lcdfb.c
Instead of using ill-defined numbers (0, 1, and 2) for the monitor port, allow
the user to specify the port by name ("dvi", "lvds", or "dlvds"). This works
on the kernel command line, the module command-line, and the sysfs "monitor"
device.
Note that changing the monitor port does not currently work on the P1022DS,
because the code that talks to the PIXIS FPGA is broken.
Acked-by: Anatolij Gustschin <agust@denx.de>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
mpc8610hpcd_set_pixel_clock() calculates the correct value of the PXCLK
bits in the CLKDVDR register for a given pixel clock rate. The code which
performs this calculation is overly complicated and includes an error
estimation routine that doesn't work most of the time anyway. Replace the
code with the simpler routine that's currently used on the P1022DS.
If the video mode is set to 16-, 24-, or 32-bit pixels, then the pixel data
contains actual levels of red, blue, and green. However, if the video mode
is set to 8-bit pixels, then the 8-bit value represents an index into color
table. This is called "palette mode" on the Freescale DIU video controller.
The DIU driver does not currently support palette mode, but the MPC8610 HPCD
board file returned a non-zero (although incorrect) pixel format value for
8-bit mode.
It may trigger a warning in fs/proc/generic.c:__xlate_proc_name() when
trying to add an entry for the interrupt handler to sysfs.
Acked-by: Timur Tabi <timur@freescale.com>
A future version of the MPC8610 HPCD's ASoC DMA driver will probe on individual
DMA channel nodes, so the DMA controller nodes' compatible string must be listed
in mpc8610_ids[] for the probe to work.
Also remove the "gianfar" compatible from mpc8610_ids[], since there is no
gianfar (or any other networking device) on the 8610.
This patch adds needed nodes and properties to support suspend/resume
on the MPC8610HPCD boards.
There is a dedicated switch (SW9) that is used to wake up the boards.
By default the SW9 button is routed to IRQ8, but could be re-routed
(via PIXIS) to sreset.
With 'no_console_suspend' kernel command line argument specified, the
board is also able to wakeup upon serial port input.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: Scott Wood <scottwood@freescale.com> [dts]
This patch adds spi and mmc-spi-slot nodes, plus a gpio-controller for
PIXIS' sdcsr bank that is used for managing SPI chip-select and for
reading card's states.
Cc: Kumar Gala <galak@gate.crashing.org>
Cc: David Brownell <david-b@pacbell.net>
Removed the need for asm/mpc86xx.h as it was only used in mpc86xx_smp.c
and just moved the defines it cared about into there. Also fixed up
the ioremap to only map the one 4k page we need access to and to iounmap
when we are done.
Currently it doesn't matter where the mdio nodes are placed, but with
power management support (i.e. when sleep = <> properties will take
effect), mdio nodes placement will become important: mdio controller
is a part of the ethernet block, so the mdio nodes should be placed
correctly. Otherwise we may wrongly assume that MDIO controllers are
available during sleep.
Suggested-by: Scott Wood <scottwood@freescale.com>
Early versions of the Freescale DIU framebuffer driver depended on a bootmem
allocation of memory for the video buffer. The need for this feature was
removed in commit 6b51d51a, so now we can remove the platform-specific code
that allocated that memory.
- Get rid of uses_fsl_uli_m1575, it does not scale for all cases.
Instead, let's explicitly use machine_is() for each fixup.
- Factor out MPC8610HPCD quirks to fsl_uli1575, and protect them with
machine_is(). One step closer to multiplatform kernels.
- Actually use fsl_uli1575 on MPC8610HPCD, so RTC quirk will be applied.
- RTC quirk applies to all boards though, so no machine_is() checks.
Moved the pic initialization into its own common file and out of the board
code. Also fixed the OF reference counting on the mpic node.
This patch enable the MSI on 8610hpcd board.
Through the msi-available-ranges property, All the 256
msi interrupts can be tested on this board.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
DIU platform code should not just write to the PIXIS' BRDCFG0 register,
it should set and clear its own bits only, otherwise it will break
firmware setup (in fact it breaks second uart).
Also get rid of magic numbers in the related code.
This patch adds device tree nodes for NOR and NAND flashes and places
board-control node inside the localbus.
defconfig and board file updated appropriately.
Add platform code to support Freescale DIU. The platform code includes
framebuffer memory allocation, pixel format, monitor port, etc.
Signed-off-by: York Sun <yorksun@freescale.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cleanups as suggested by Stephen Rothwell and Dale Farnsworth, which
incudes marking a bunch of functions static and add a vendor prefix to
the compat node check for uniqueness.
Update the MPC8610 HPCD files to support the audio driver. Update
booting-without-of.txt with information on the SSI device.
On the majority of 85xx & 86xx we have a register that's ability to
assert HRESET_REQ to reset the board. We refactored that code so it
can be shared between both platforms into fsl_soc.c and removed all
the duplication in each platform directory.
Add basic board support for the MPC8610 HPCD. This does
not include any support the SoC Display or Audio controllers.
Signed-off-by: Xianghua Xiao <x.xiao@freescale.com>
Signed-off-by: Jon Loelier <jdl@freescale.com>
