[ Upstream commit b87a358b4a1421abd544c0b554b1b7159b2b36c0 ]
Add a missing include <platforms/chrp/chrp.h>.
These functions can all be static, make it so. Fix warnings treated as
errors with W=1:
arch/powerpc/platforms/chrp/time.c:41:13: error: no previous prototype for ‘chrp_time_init’ [-Werror=missing-prototypes]
arch/powerpc/platforms/chrp/time.c:66:5: error: no previous prototype for ‘chrp_cmos_clock_read’ [-Werror=missing-prototypes]
arch/powerpc/platforms/chrp/time.c:74:6: error: no previous prototype for ‘chrp_cmos_clock_write’ [-Werror=missing-prototypes]
arch/powerpc/platforms/chrp/time.c:86:5: error: no previous prototype for ‘chrp_set_rtc_time’ [-Werror=missing-prototypes]
arch/powerpc/platforms/chrp/time.c:130:6: error: no previous prototype for ‘chrp_get_rtc_time’ [-Werror=missing-prototypes]
Signed-off-by: Mathieu Malaterre <malat@debian.org>
NO_IRQ has been == 0 on powerpc for just over ten years (since commit
0ebfff1491ef ("[POWERPC] Add new interrupt mapping core and change
platforms to use it")). It's also 0 on most other arches.
Although it's fairly harmless, every now and then it causes confusion
when a driver is built on powerpc and another arch which doesn't define
NO_IRQ. There's at least 6 definitions of NO_IRQ in drivers/, at least
some of which are to work around that problem.
So we'd like to remove it. This is fairly trivial in the arch code, we
just convert:
if (irq == NO_IRQ) to if (!irq)
if (irq != NO_IRQ) to if (irq)
irq = NO_IRQ; to irq = 0;
return NO_IRQ; to return 0;
And a few other odd cases as well.
At least for now we keep the #define NO_IRQ, because there is driver
code that uses NO_IRQ and the fixes to remove those will go via other
trees.
Note we also change some occurrences in PPC sound drivers, drivers/ps3,
and drivers/macintosh.
It is now called right after platform probe, so the probe function
can just do the job.
powernv marks it's halt and restart calls as __noreturn. However,
ppc_md does not have this annotation. Add the annotation to ppc_md,
and then to every halt/restart function that is missing it.
Additionally, I have verified that all of these functions do not
return. Occasionally I have added a spin loop to be sure.
Signed-off-by: Daniel Axtens <dja@axtens.net>
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
This patch fixes a section mismatch warning
WARNING: vmlinux.o(.text+0x213b6): Section mismatch in reference from the function chrp_init_early() to the variable .init.data:boot_command_line
The function chrp_init_early() references
the variable __initdata boot_command_line.
This is often because chrp_init_early lacks a __initdata
annotation or the annotation of boot_command_line is wrong.
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
The generic Linux framework to power off the machine is a function pointer
called pm_power_off. The trick about this pointer is that device drivers can
potentially implement it rather than board files.
Today on powerpc we set pm_power_off to invoke our generic full machine power
off logic which then calls ppc_md.power_off to invoke machine specific power
off.
However, when we want to add a power off GPIO via the "gpio-poweroff" driver,
this card house falls apart. That driver only registers itself if pm_power_off
is NULL to ensure it doesn't override board specific logic. However, since we
always set pm_power_off to the generic power off logic (which will just not
power off the machine if no ppc_md.power_off call is implemented), we can't
implement power off via the generic GPIO power off driver.
To fix this up, let's get rid of the ppc_md.power_off logic and just always use
pm_power_off as was intended. Then individual drivers such as the GPIO power off
driver can implement power off logic via that function pointer.
With this patch set applied and a few patches on top of QEMU that implement a
power off GPIO on the virt e500 machine, I can successfully turn off my virtual
machine after halt.
[mpe: Squash into one patch and update changelog based on cover letter]
There is no need for yet another copy of the command line, just
use boot_command_line like everyone else.
Make of_get_flat_dt_prop arguments compatible with libfdt fdt_getprop
call in preparation to convert FDT code to use libfdt. Make the return
value const and the property length ptr type an int.
Signed-off-by: Rob Herring <robh@kernel.org>
Tested-by: Michal Simek <michal.simek@xilinx.com>
Tested-by: Grant Likely <grant.likely@linaro.org>
Tested-by: Stephen Chivers <schivers@csc.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
The one instance where we add an include for init.h covers off
a case where that file was implicitly getting it from another
header which itself didn't need it.
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
This patch converts the Marvell MV643XX ethernet driver to use the
Marvell Orion MDIO driver. As a result, PowerPC and ARM platforms
registering the Marvell MV643XX ethernet driver are also updated to
register a Marvell Orion MDIO driver. This driver voluntarily overlaps
with the Marvell Ethernet shared registers because it will use a subset
of this shared register (shared_base + 0x4 to shared_base + 0x84). The
Ethernet driver is also updated to look up for a PHY device using the
Orion MDIO bus driver.
For ARM and PowerPC we register a single instance of the "mvmdio" driver
in the system like it used to be done with the use of the "shared_smi"
platform_data cookie on ARM.
Note that it is safe to register the mvmdio driver only for the "ge00"
instance of the driver because this "ge00" interface is guaranteed to
always be explicitely registered by consumers of
arch/arm/plat-orion/common.c and other instances (ge01, ge10 and ge11)
were all pointing their shared_smi to ge00. For PowerPC the in-tree
Device Tree Source files mention only one MV643XX ethernet MAC instance
so the MDIO bus driver is registered only when id == 0.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
There are two separate flags controlling whether or not the MPIC is
reset during initialization, which is completely unnecessary, and only
one of them can be specified in the device tree.
Also, most platforms in-tree right now do actually want to reset the
MPIC during initialization anyways, which means lots of duplicate code
passing the MPIC_WANTS_RESET flag.
Fix all of the callers which currently do not pass the MPIC_WANTS_RESET
flag to pass the MPIC_NO_RESET flag, then remove the MPIC_WANTS_RESET
flag and make the code reset the MPIC by default.
Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
It turns out that there are only 2 in-tree platforms which use MPICs
which are not "primary": IBM Cell and PowerMac. To reduce the
complexity of the typical board setup code, invert the MPIC_PRIMARY bit
into MPIC_SECONDARY.
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: Consolidate the clkdev header files
ARM: set vga memory base at run-time
ARM: convert PCI defines to variables
ARM: pci: make pcibios_assign_all_busses use pci_has_flag
ARM: remove unnecessary mach/hardware.h includes
pci: move microblaze and powerpc pci flag functions into asm-generic
powerpc: rename ppc_pci_*_flags to pci_*_flags
Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
This renames pci flags functions and enums in preparation for creating
generic version in asm-generic/pci-bridge.h. The following search and
replace is done:
s/ppc_pci_/pci_/
s/PPC_PCI_/PCI_/
Direct accesses to ppc_pci_flag variable are replaced with helper
functions.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
Lenghty lists of the kind "depends on ARCH1 || ARCH2 ... || ARCH123" are
usually either wrong or too coarse grained. Or plain an ugly sin.
[ tglx: Fixed up amigaone ]
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: linux-alpha@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: Gerhard Pircher <gerhard_pircher@gmx.net>
Link: http://lkml.kernel.org/r/20110601180610.984881988@duck.linux-mips.net
When we start a cpu we use smp_ops->kick_cpu(), which currently
returns void, it should be able to fail. Convert it to return
int, and update all uses.
Convert all the current error cases to return -ENOENT, which is
what would eventually be returned by __cpu_up() currently when
it doesn't detect the cpu as coming up in time.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Scripted with coccinelle.
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
This moves a bunch of definitions out of asm/nvram.h to the files
that use them or just outright remove completely unused stuff.
We leave the partition signatures definitions, they will be useful
Add a call to of_node_put in the error handling code following a call to
of_find_node_by_type.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
local idexpression x;
expression E,E1,E2;
statement S;
*x =
(of_find_node_by_path
|of_find_node_by_name
|of_find_node_by_phandle
|of_get_parent
|of_get_next_parent
|of_get_next_child
|of_find_compatible_node
|of_match_node
|of_find_node_with_property
|of_find_matching_node
|of_parse_phandle
if (x == NULL) S
<... when != x = E
*if (...) {
... when != of_node_put(x)
when != if (...) { ... of_node_put(x); ... }
return <+...x...+>;
* return ...;
E2 = x;
of_node_put(x);
// </smpl>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits)
net: fix for utsrelease.h moving to generated
gen_init_cpio: fixed fwrite warning
kbuild: fix make clean after mismerge
kbuild: generate modules.builtin
genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}()
score: add asm/asm-offsets.h wrapper
unifdef: update to upstream revision 1.190
kbuild: specify absolute paths for cscope
kbuild: create include/generated in silentoldconfig
scripts/package: deb-pkg: use fakeroot if available
scripts/package: add KBUILD_PKG_ROOTCMD variable
scripts/package: tar-pkg: use tar --owner=root
Kbuild: clean up marker
net: add net_tstamp.h to headers_install
kbuild: move utsrelease.h to include/generated
kbuild: move autoconf.h to include/generated
drop explicit include of autoconf.h
kbuild: move compile.h to include/generated
kbuild: drop include/asm
kbuild: do not check for include/asm-$ARCH
Fixed non-conflicting clean merge of modpost.c as per comments from
Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h
that needed to be changed to generated/autoconf.h)
Fix up all users of utsrelease.h
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
The CHRP code has some fishy timer based code to scan the RTAS event
log, which uses a 1KB stack buffer and doesn't even use the results.
The pSeries code as a nicer daemon that allows userspace to read the
event log and basically uses the same RTAS interface
This patch moves rtasd.c out of platform/pseries and makes it usable
by CHRP, after removing the old crufty event log mechanism in there.
The nvram logging part of the daemon is still only available on 64-bit
since the underlying nvram management routines aren't currently shared.
Several platforms use their own copy of what is essentially the same code,
using RTAS to synchronize the timebases when bringing up new CPUs. This
moves it all into a single common implementation and additionally
turns the spinlock into a raw spinlock since the former can rely on
the timebase not being frozen when spinlock debugging is enabled, and finally
masks interrupts while the timebase is disabled.
We shouldn't directly access sysdata to get the pci_controller. Instead
use pci_bus_to_host() for this purpose. In the future we might have
sysdata be a device_node to match ppc64 and unify the code between ppc32
& ppc64.
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumask:
oprofile: Thou shalt not call __exit functions from __init functions
cpumask: remove the now-obsoleted pcibus_to_cpumask(): generic
cpumask: remove cpumask_t from core
cpumask: convert rcutorture.c
cpumask: use new cpumask_ functions in core code.
cpumask: remove references to struct irqaction's mask field.
cpumask: use mm_cpumask() wrapper: kernel/fork.c
cpumask: use set_cpu_active in init/main.c
cpumask: remove node_to_first_cpu
cpumask: fix seq_bitmap_*() functions.
cpumask: remove dangerous CPU_MASK_ALL_PTR, &CPU_MASK_ALL
Impact: cleanup
It's unused, since about 1995. So remove all initialization of it in
preparation for actually removing the field.
CONFIG_PPC_MULTIPLATFORM is a remain of the pre-powerpc days and isn't
really meaningful anymore. It was basically equivalent to PPC64 || 6xx.
This removes it along with the following changes:
- 32-bit platforms that relied on PPC32 && PPC_MULTIPLATFORM now rely
on 6xx which is what they want anyway.
- A new symbol, PPC_BOOK3S, is defined that represent compliance with
the "Server" variant of the architecture. This is set when either 6xx
or PPC64 is set and open the door for future BOOK3E 64-bit.
- 64-bit platforms that relied on PPC64 && PPC_MULTIPLATFORM now use
PPC64 && PPC_BOOK3S
- A separate and selectable CONFIG_PPC_OF_BOOT_TRAMPOLINE option is now
used to control the use of prom_init.c
After the last changes, the mv643xx_eth driver now detects
a spurious interface on port 0. Since only port 1 is actually
connected to a PHY, remove its description.
Signed-off-by: Gabriel Paubert <paubert@iram.es>
Currently there are a number of platforms that open code access to
the ppc_pci_flags global variable. However, that variable is not
present if CONFIG_PCI is not set, which can lead to a build break.
This introduces a number of accessor functions that are defined
to be empty in the case of CONFIG_PCI being disabled. The
various platform files in the kernel are updated to use these.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
of_node_put is needed before discarding a value received from
of_find_node_by_name, eg in error handling code or when the device
node is no longer used.
The semantic match that catches the bug is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r exists@
local idexpression struct device_node *n;
position p1, p2;
statement S1,S2;
expression E,E1;
expression *ptr != NULL;
if (!(n@p1 = of_find_node_by_name(...))) S1
<... when != of_node_put(n)
when != if (...) { <+... of_node_put(n) ...+> }
when != true !n || ...
when != n = E
when != E = n
if (!n || ...) S2
return \(0\|<+...n...+>\|ptr\);
return@p2 ...;
n = E1
E1 = n
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s of_find_node_by_name %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
// </smpl>
Signed-off-by: Nicolas Palix <npalix@diku.dk>
Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
Manual fixup of conflicts on:
arch/powerpc/include/asm/dcr-regs.h
drivers/net/ibm_newemac/core.h
Recently, indirect_pci was changed to test if the bus number requested
is the one hanging straight off the PHB, then it substitutes the bus
number with another one contained in a new "self_busno" field of the
pci_controller structure.
However, this breaks CHRP which didn't initialize this new field, and
which relies on having the right bus number passed to the hardware.
This fixes it by initializing this variable properly for all CHRP bridges
The detection of the IBM "Python" PCI host bridge on IBM CHRP
machines such as old RS6000 was broken when we changed
of_device_is_compatible() from strncasecmp to strcasecmp (dropped
the "n" variant) due to the way IBM encodes the chip version.
We fix that by instead doing a match on the model property like
we do for others bridges in that file. It should be good enough
for those machines. If yours is still broken, let me know.
This patch also includes the required removal of (unused) inclusion of
<asm/a.out.h> <linux/a.out.h>'s in the arch/ code for these
architectures.
[dwmw2: updated for 2.6.27-rc]
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This changes powerpc to use the new bcd2bin/bin2bcd functions
instead of the obsolete BCD_TO_BIN/BIN_TO_BCD macros.
We have the dev_printk() variants for this kind of thing, use them
instead of directly trying to access the bus_id field of struct device.
This is done in order to remove bus_id entirely.
Cc: Kay Sievers <kay.sievers@vrfy.org>
The typdef for irqreturn_t was moved into its own header a
while back, so there's no reason we can't move xmon_irq()
into xmon.h now.
Move mv643xx_eth's static state (ethernet register block base address
and MII management interface spinlock) into a struct hanging off the
shared platform device. This is necessary to support chips that
contain multiple mv643xx_eth silicon blocks.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
Acked-by: Nicolas Pitre <nico@marvell.com>
Signed-off-by: Dale Farnsworth <dale@farnsworth.org>
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Commit 6d98bda79bea0e1be26c0767d0e9923ad3b72f2e changed the init order
for chrp_pci_fixup_vt8231_ata().
It can not work anymore because either the irq is not yet set to 14 or
pci_get_device() returns nothing. At least the printk() in
chrp_pci_fixup_vt8231_ata() does not trigger anymore.
pata_via works again on Pegasos with the change below.
This fixes a possible NULL pointer dereference inside of strncmp() if
of_get_property() fails.
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com>
This adds to the 32 bits PCI code some flags, replacing the old
pci_assign_all_busses global, that allow us to control various
aspects of the PCI probing, such as whether to re-assign all
resources or not, or to not try to assign anything at all.
This also adds the flag x86 already has to avoid ISA alignment
on bridges that don't have ISA forwarding enabled (no legacy
devices on the top level bus) and sets it for PowerMacs.
