commit 6d183ca8baec983dc4208ca45ece3c36763df912 upstream.
'nobats' kernel parameter or some options like CONFIG_DEBUG_PAGEALLOC
deny the use of BATS for mapping memory.
This patch makes sure that the specific wii RAM mapping function
takes it into account as well.
Fixes: de32400dd26e ("wii: use both mem1 and mem2 as ram")
Cc: stable@vger.kernel.org
Reviewed-by: Jonathan Neuschafer <j.neuschaefer@gmx.net>
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
The generic Linux framework to power off the machine is a function pointer
called pm_power_off. The trick about this pointer is that device drivers can
potentially implement it rather than board files.
Today on powerpc we set pm_power_off to invoke our generic full machine power
off logic which then calls ppc_md.power_off to invoke machine specific power
off.
However, when we want to add a power off GPIO via the "gpio-poweroff" driver,
this card house falls apart. That driver only registers itself if pm_power_off
is NULL to ensure it doesn't override board specific logic. However, since we
always set pm_power_off to the generic power off logic (which will just not
power off the machine if no ppc_md.power_off call is implemented), we can't
implement power off via the generic GPIO power off driver.
To fix this up, let's get rid of the ppc_md.power_off logic and just always use
pm_power_off as was intended. Then individual drivers such as the GPIO power off
driver can implement power off logic via that function pointer.
With this patch set applied and a few patches on top of QEMU that implement a
power off GPIO on the virt e500 machine, I can successfully turn off my virtual
machine after halt.
[mpe: Squash into one patch and update changelog based on cover letter]
of_device_ids (i.e. compatible strings and the respective data) are not
supposed to change at runtime. All functions working with of_device_ids
provided by <linux/of.h> work with const of_device_ids. This allows to
mark all struct of_device_id const, too.
While touching these line also put the __init annotation at the right
position where necessary.
The only function of memblock_analyze() is now allowing resize of
memblock region arrays. Rename it to memblock_allow_resize() and
update its users.
* The following users remain the same other than renaming.
arm/mm/init.c::arm_memblock_init()
microblaze/kernel/prom.c::early_init_devtree()
powerpc/kernel/prom.c::early_init_devtree()
openrisc/kernel/prom.c::early_init_devtree()
sh/mm/init.c::paging_init()
sparc/mm/init_64.c::paging_init()
unicore32/mm/init.c::uc32_memblock_init()
* In the following users, analyze was used to update total size which
is no longer necessary.
powerpc/kernel/machine_kexec.c::reserve_crashkernel()
powerpc/mm/init_32.c::MMU_init()
powerpc/mm/tlb_nohash.c::__early_init_mmu()
powerpc/platforms/ps3/mm.c::ps3_mm_add_memory()
powerpc/platforms/embedded6xx/wii.c::wii_memory_fixups()
sh/kernel/machine_kexec.c::reserve_crashkernel()
* x86/kernel/e820.c::memblock_x86_fill() was directly setting
memblock_can_resize before populating memblock and calling analyze
afterwards. Call memblock_allow_resize() before start populating.
memblock_can_resize is now static inside memblock.c.
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
* early_init_devtree(): Total memory size is aligned to PAGE_SIZE;
however, alignment isn't enforced if memory_limit is explicitly
specified. Simplify the logic and always apply PAGE_SIZE alignment.
* MMU_init(): memblock regions is truncated by directly modifying
memblock.memory.cnt. This is incomplete (reserved array is not
truncated) and unnecessarily low level hindering further memblock
improvments. Use memblock_enforce_memory_limit() instead.
* wii_memory_fixups(): Unnecessarily low level direct manipulation of
memblock regions. The same result can be achieved using properly
abstracted operations. Reimplement using memblock API.
We check for a valid handler before calling ppc_md.machine_kexec_prepare
so we can just remove these empty handlers.
Fix memblock API change fallout in the WII code.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: linux-mm@kvack.org
LKML-Reference: <4C8B2AFA.2000705@kernel.org>
memblock_region
via following scripts
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/lmb/memblock/g' \
-e 's/LMB/MEMBLOCK/g' \
$FILES
for N in $(find . -name lmb.[ch]); do
M=$(echo $N | sed 's/lmb/memblock/g')
mv $N $M
done
and remove some wrong change like lmbench and dlmb etc.
also move memblock.c from lib/ to mm/
Suggested-by: Ingo Molnar <mingo@elte.hu>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
discontiguous => discontinuous
coealesce => coalesce
Signed-off-by: Thomas Weber <weber@corscience.de>
Enable the flag that allows a platform to ioremap memory marked
as reserved.
This is currently needed on the Nintendo Wii video game console
due to the workaround introduced in "wii: use both mem1 and mem2 as ram".
This will no longer be needed when proper discontig memory support
for 32-bit PowerPC is added to the kernel.
Signed-off-by: Albert Herranz <albert_herranz@yahoo.es>
The Nintendo Wii video game console has two discontiguous RAM regions:
- MEM1: 24MB @ 0x00000000
- MEM2: 64MB @ 0x10000000
Unfortunately, the kernel currently does not support discontiguous RAM
memory regions on 32-bit PowerPC platforms.
This patch adds a series of workarounds to allow the use of the second
memory region (MEM2) as RAM by the kernel.
Basically, a single range of memory from the beginning of MEM1 to the
end of MEM2 is reported to the kernel, and a memory reservation is
created for the hole between MEM1 and MEM2.
With this patch the system is able to use all the available RAM and not
just ~27% of it.
Add platform support for the Nintendo Wii video game console.
Acked-by: Segher Boessenkool <segher@kernel.crashing.org>
