commit 363edbe2614aa90df706c0f19ccfa2a6c06af0be upstream.
When adding cpuidle support to pSeries, we introduced two
regressions:
- The new cpuidle backend driver only works under hypervisors
supporting the "SLPLAR" option, which isn't the case of the
old POWER4 hypervisor and the HV "light" used on js2x blades
- The cpuidle driver registers fairly late, meaning that for
a significant portion of the boot process, we end up having
all threads spinning. This slows down the boot process and
increases the overall resource usage if the hypervisor has
shared processors.
This fixes both by implementing a "default" idle that will cede
to the hypervisor when possible, in a very simple way without
all the bells and whisles of cpuidle.
Reported-by: Paul Mackerras <paulus@samba.org>
Signed-off-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
Acked-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
On pseries machines the detection for max_bus_speed should be done
through an OpenFirmware property. This patch adds a function to perform
this detection and a hook to perform dynamic adding of the function only
for pseries. This is done by overwriting the weak
pcibios_root_bridge_prepare function which is called by
pci_create_root_bus().
From: Lucas Kannebley Tavares <lucaskt@linux.vnet.ibm.com>
Signed-off-by: Kleber Sacilotto de Souza <klebers@linux.vnet.ibm.com>
5 bits
The firmware_has_feature() function makes it easy to check for supported
features of the hypervisor. This patch extends the capability of
firmware_has_feature() to include checking for specified bits
in vector 5 of the architecture vector as reported in the device tree.
As part of this the #defines used for the architecture vector are re-defined
such that each option has the index into vector 5 and the feature bit encoded
into it. This makes checking for architecture bits when initiating data
for firmware_has_feature much easier.
Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Benjamin Herrenschmidt:
"So from the depth of frozen Minnesota, here's the powerpc pull request
for 3.9. It has a few interesting highlights, in addition to the
usual bunch of bug fixes, minor updates, embedded device tree updates
and new boards:
- Hand tuned asm implementation of SHA1 (by Paulus & Michael
Ellerman)
- Support for Doorbell interrupts on Power8 (kind of fast
thread-thread IPIs) by Ian Munsie
- Long overdue cleanup of the way we handle relocation of our open
firmware trampoline (prom_init.c) on 64-bit by Anton Blanchard
- Support for saving/restoring & context switching the PPR (Processor
Priority Register) on server processors that support it. This
allows the kernel to preserve thread priorities established by
userspace. By Haren Myneni.
- DAWR (new watchpoint facility) support on Power8 by Michael Neuling
- Ability to change the DSCR (Data Stream Control Register) which
controls cache prefetching on a running process via ptrace by
Alexey Kardashevskiy
- Support for context switching the TAR register on Power8 (new
branch target register meant to be used by some new specific
userspace perf event interrupt facility which is yet to be enabled)
by Ian Munsie.
- Improve preservation of the CFAR register (which captures the
origin of a branch) on various exception conditions by Paulus.
- Move the Bestcomm DMA driver from arch powerpc to drivers/dma where
it belongs by Philippe De Muyter
- Support for Transactional Memory on Power8 by Michael Neuling
(based on original work by Matt Evans). For those curious about
the feature, the patch contains a pretty good description."
(See commit db8ff907027b: "powerpc: Documentation for transactional
memory on powerpc" for the mentioned description added to the file
Documentation/powerpc/transactional_memory.txt)
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (140 commits)
powerpc/kexec: Disable hard IRQ before kexec
powerpc/85xx: l2sram - Add compatible string for BSC9131 platform
powerpc/85xx: bsc9131 - Correct typo in SDHC device node
powerpc/e500/qemu-e500: enable coreint
powerpc/mpic: allow coreint to be determined by MPIC version
powerpc/fsl_pci: Store the pci ctlr device ptr in the pci ctlr struct
powerpc/85xx: Board support for ppa8548
powerpc/fsl: remove extraneous DIU platform functions
arch/powerpc/platforms/85xx/p1022_ds.c: adjust duplicate test
powerpc: Documentation for transactional memory on powerpc
powerpc: Add transactional memory to pseries and ppc64 defconfigs
powerpc: Add config option for transactional memory
powerpc: Add transactional memory to POWER8 cpu features
powerpc: Add new transactional memory state to the signal context
powerpc: Hook in new transactional memory code
powerpc: Routines for FP/VSX/VMX unavailable during a transaction
powerpc: Add transactional memory unavaliable execption handler
powerpc: Add reclaim and recheckpoint functions for context switching transactional memory processes
powerpc: Add FP/VSX and VMX register load functions for transactional memory
powerpc: Add helper functions for transactional memory context switching
If we want to stop the tick further idle, we need to be
able to account the cputime without using the tick.
Virtual based cputime accounting solves that problem by
hooking into kernel/user boundaries.
However implementing CONFIG_VIRT_CPU_ACCOUNTING require
low level hooks and involves more overhead. But we already
have a generic context tracking subsystem that is required
for RCU needs by archs which plan to shut down the tick
outside idle.
This patch implements a generic virtual based cputime
accounting that relies on these generic kernel/user hooks.
There are some upsides of doing this:
- This requires no arch code to implement CONFIG_VIRT_CPU_ACCOUNTING
if context tracking is already built (already necessary for RCU in full
tickless mode).
- We can rely on the generic context tracking subsystem to dynamically
(de)activate the hooks, so that we can switch anytime between virtual
and tick based accounting. This way we don't have the overhead
of the virtual accounting when the tick is running periodically.
And one downside:
- There is probably more overhead than a native virtual based cputime
accounting. But this relies on hooks that are already set anyway.
Cc: Li Zhong <zhong@linux.vnet.ibm.com>
Cc: Namhyung Kim <namhyung.kim@lge.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
This adds DAWR supoprt to the set_break().
It does both bare metal and PAPR versions of setting the DAWR.
There is still some work we can do to make full use of the watchpoint but that
will come later.
Signed-off-by: Michael Neuling <mikey@neuling.org>
For PR KVM we allow userspace to map 0xc000000000000000. Because
transitioning from userspace to the guest kernel may use the relocated
exception vectors we have to disable relocation on exceptions whenever
PR KVM is active as we cannot trust that address.
This issue does not apply to HV KVM, since changing from a guest to the
hypervisor will never use the relocated exception vectors.
Currently the hypervisor interface only allows us to toggle relocation
on exceptions on a partition wide scope, so we need to globally disable
relocation on exceptions when the first PR KVM instance is started and
only re-enable them when all PR KVM instances have been destroyed.
It's a bit heavy handed, but until the hypervisor gives us a lightweight
way to toggle relocation on exceptions on a single thread it's only real
option.
Signed-off-by: Ian Munsie <imunsie@au1.ibm.com>
Since we don't know if they new kernel we are kexecing into has been
built to support relocation on exceptions, we disable them before we
kexec.
We do NOT disable them if we are execing a kdump kernel, because we
want to change as little state as possible and it is likely that we are
execing ourselves and will be able to handle them anyway.
We currently do this synchronously at boot from setup_arch. On a large
system this could hypothetically take a little while to complete, so
currently we will give up if we are asked to wait for more than a second
in total.
If we actually start hitting that timeout in practice we can always move
this code into a kernel thread to take care of it in the background.
This patch moves the notification chain for updates to the device tree
from the powerpc/pseries code to the base OF code. This makes this
functionality available to all architectures.
Additionally the notification chain is updated to allow notifications
for property add/remove/update. To make this work a pointer to a new
struct (of_prop_reconfig) is passed to the routines in the notification chain.
The of_prop_reconfig property contains a pointer to the node containing the
property and a pointer to the property itself. In the case of property
updates, the property pointer refers to the new property.
Acked-by: Rob Herring <rob.herring@calxeda.com>
Currently we mark the DABRX to interrupt on all matches
(hypervisor/kernel/user and then filter in software. We can be a lot
smarter now that we can set the DABRX dynamically.
This sets the DABRX based on the flags passed by the user.
Rework set_dabr to take a DABRX value as well.
Both the pseries and PS3 hypervisors do some checks on the DABRX
values that are passed in the hcall. This patch stops bogus values
from being passed to hypervisor. Also, in the case where we are
clearing the breakpoint, where DABR and DABRX are zero, we modify the
DABRX value to make it valid so that the hcall won't fail.
Currently, we have 3 phases for EEH initialization on pSeries platform.
All of them are done through builtin functions: platform initialization,
EEH device creation, and EEH subsystem enablement. All of them are done
no later than ppc_md.setup_arch. That means that the slab/slub isn't ready
yet, so we have to allocate memory chunks on basis of PAGE_SIZE for those
dynamically created EEH devices. That's pretty expensive.
In order to utilize slab/slub for memory allocation, we have to move the EEH
initialization functions around, but all of them should be called after slab
is ready.
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
We never use the XDABR hcall since we check for DABR hcall first.
XDABR syscall is better since it allows us to also set the DABRX.
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci
Pull PCI changes (including maintainer change) from Jesse Barnes:
"This pull has some good cleanups from Bjorn and Yinghai, as well as
some more code from Yinghai to better handle resource re-allocation
when enabled.
There's also a new initcall_debug feature from Arjan which will print
out quirk timing information to help identify slow quirks for fixing
or refinement (Yinghai sent in a few patches to do just that once the
new debug code landed).
Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas.
He's been a core PCI and Linux contributor for some time now, and has
kindly volunteered to take over. I just don't feel I have the time
for PCI review and work that it deserves lately (I've taken on some
other projects), and haven't been as responsive lately as I'd like, so
I approached Bjorn asking if he'd like to manage things. He's going
to give it a try, and I'm confident he'll do at least as well as I
have in keeping the tree managed, patches flowing, and keeping things
stable."
Fix up some fairly trivial conflicts due to other cleanups (mips device
resource fixup cleanups clashing with list handling cleanup, ppc iseries
removal clashing with pci_probe_only cleanup etc)
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits)
PCI: Bjorn gets PCI hotplug too
PCI: hand PCI maintenance over to Bjorn Helgaas
unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h
sparc/PCI: convert devtree and arch-probed bus addresses to resource
powerpc/PCI: allow reallocation on PA Semi
powerpc/PCI: convert devtree bus addresses to resource
powerpc/PCI: compute I/O space bus-to-resource offset consistently
arm/PCI: don't export pci_flags
PCI: fix bridge I/O window bus-to-resource conversion
x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()'
PCI / PCIe: Introduce command line option to disable ARI
PCI: make acpihp use __pci_remove_bus_device instead
PCI: export __pci_remove_bus_device
PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge
PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device
PCI: print out PCI device info along with duration
PCI: Move "pci reassigndev resource alignment" out of quirks.c
PCI: Use class for quirk for usb host controller fixup
PCI: Use class for quirk for ti816x class fixup
PCI: Use class for quirk for intel e100 interrupt fixup
Original EEH implementation depends on struct pci_dn heavily. However,
EEH shouldn't depend on that actually because EEH needn't share much
information with other PCI components. That's to say, EEH should have
worked independently.
The patch introduces struct eeh_dev so that EEH core components needn't
be working based on struct pci_dn in future. Also, struct pci_dn, struct
eeh_dev instances are created in dynamic fasion and the binding with EEH
device, OF node, PCI device is implemented as well.
The EEH devices are created after PHBs are detected and initialized, but
PCI emunation hasn't started yet. Apart from that, PHB might be created
dynamically through DLPAR component and the EEH devices should be creatd
as well. Another case might be OF node is created dynamically by DR
(Dynamic Reconfiguration), which has been defined by PAPR. For those OF
nodes created by DR, EEH devices should be also created accordingly. The
binding between EEH device and OF node is done while the EEH device is
initially created.
The binding between EEH device and PCI device should be done after PCI
emunation is done. Besides, PCI hotplug also needs the binding so that
the EEH devices could be traced from the newly coming PCI buses or PCI
devices.
EEH has been implemented on RTAS-compliant pSeries platform.
That's to say, the EEH operations will be implemented through RTAS
calls eventually. The situation limited feasible extension on EEH.
In order to support EEH on multiple platforms like pseries and powernv
simutaneously. We have to split the platform dependent EEH options
up out of current implementation.
The patch addresses supporting EEH on multiple platforms. The pseries
platform dependent EEH operations will be abstracted by struct eeh_ops.
EEH core components will be built based on the registered EEH operations.
With the mechanism, what the individual platform needs to do is implement
platform dependent EEH operations.
For now, the pseries platform is covered under the mechanism. That means
we have to think about other platforms to support EEH, like powernv.
Besides, we only have framework for the mechanism and we have to implement
it for pseries platform later.
We already use pci_flags, so this just sets pci_flags directly and removes
the intermediate step of figuring out pci_probe_only, then using it to set
pci_flags.
The PCI core provides a pci_flags definition (currently __weak), so drop
the powerpc definitions in favor of that.
CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
CC: linuxppc-dev@lists.ozlabs.org
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
pci_probe_only is set on ppc64 to prevent resource re-allocation
by the core. It's meant to be used in very specific circumstances
such as when operating under a hypervisor that may prevent such
re-allocation.
Instead of default to 1, we make it default to 0 and explicitly
set it in the few cases where we need it.
This fixes FSL PCI which wants it clear among others.
There are two separate flags controlling whether or not the MPIC is
reset during initialization, which is completely unnecessary, and only
one of them can be specified in the device tree.
Also, most platforms in-tree right now do actually want to reset the
MPIC during initialization anyways, which means lots of duplicate code
passing the MPIC_WANTS_RESET flag.
Fix all of the callers which currently do not pass the MPIC_WANTS_RESET
flag to pass the MPIC_NO_RESET flag, then remove the MPIC_WANTS_RESET
flag and make the code reset the MPIC by default.
Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
The mpic->irq_count variable is only used as a software error-checking
limit to determine whether or not an IRQ number is valid. In board code
which does not manually specify an IRQ count to mpic_alloc(), i.e. 0, it
is automatically detected from the number of ISUs and the ISU size.
In practice, all hardware ends up with irq_count == num_sources, so all
of the runtime checks on mpic->irq_count should just check the value of
mpic->num_sources instead.
When platform hardware does not correctly report the number of IRQs,
which only happens on the MPC85xx/MPC86xx, the MPIC_BROKEN_FRR_NIRQS
flag is used to override the detected value of num_sources with the
manual irq_count parameter. Since there's no need to manually specify
the number of IRQs except in this case, the extra flag can be eliminated
and the test changed to "irq_count != 0".
We've had a 180 second panic timeout on ppc64 for as long as I
can remember. This patch reduces it to 10 seconds on pseries for a few
reasons:
- Almost all pseries machines have a hypervisor console so panic
output will be available in a scrollback buffer.
- The 180 seconds impacts our availability, users (other than
kernel hackers) just want the box to come back around so it
can continue its work.
- I spend a lot of my life staring at the 180 second panic timeout.
Many pseries machines take minutes to power cycle, so it's quicker
to sit through the 180 seconds than it is to power cycle.
pSeries
This patch enables cpuidle for pSeries and pSeries_idle is
directly called from the idle loop. As a result of pSeries_idle, cpuidle
driver registered with cpuidle subsystem comes into action. On
failure of loading of the driver or cpuidle framework default idle
is executed as part of the function. This patch
also removes the routines pseries_shared_idle_sleep and
pseries_dedicated_idle_sleep as they are now implemented as part of
pseries_idle cpuidle driver.
Signed-off-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Signed-off-by: Trinabh Gupta <g.trinabh@gmail.com>
Signed-off-by: Arun R Bharadwaj <arun.r.bharadwaj@gmail.com>
This patch implements a back-end cpuidle driver for pSeries
based on pseries_dedicated_idle_loop and pseries_shared_idle_loop
routines. The driver is built only if CONFIG_CPU_IDLE is set. This
cpuidle driver uses global registration of idle states and
not per-cpu.
It turns out that there are only 2 in-tree platforms which use MPICs
which are not "primary": IBM Cell and PowerMac. To reduce the
complexity of the typical board setup code, invert the MPIC_PRIMARY bit
into MPIC_SECONDARY.
All these files were including module.h just for the basic
EXPORT_SYMBOL infrastructure. We can shift them off to the
export.h header which is a way smaller footprint and thus
realize some compile time gains.
Make the VPA, SLB shadow and DTL registration and deregistration
functions print consistent messages on error. I needed the firmware
error code while chasing a kexec bug but we weren't printing it.
On pseries machines, consoles are provided by the hypervisor using
a low level get_chars/put_chars type interface. However, this is
really just a transport to the service processor which implements
them either as "raw" console (networked consoles, HMC, ...) or as
"hvsi" serial ports.
The later is a simple packet protocol on top of the raw character
interface that is supposed to convey additional "serial port" style
semantics. In practice however, all it does is provide a way to
read the CD line and set/clear our DTR line, that's it.
We currently implement the "raw" protocol as an hvc console backend
(/dev/hvcN) and the "hvsi" protocol using a separate tty driver
(/dev/hvsi0).
However this is quite impractical. The arbitrary difference between
the two type of devices has been a major source of user (and distro)
confusion. Additionally, there's an additional mini -hvsi implementation
in the pseries platform code for our low level debug console and early
boot kernel messages, which means code duplication, though that low
level variant is impractical as it's incapable of doing the initial
protocol negociation to establish the link to the FSP.
This essentially replaces the dedicated hvsi driver and the platform
udbg code completely by extending the existing hvc_vio backend used
in "raw" mode so that:
- It now supports HVSI as well
- We add support for hvc backend providing tiocm{get,set}
- It also provides a udbg interface for early debug and boot console
This is overall less code, though this will only be obvious once we
remove the old "hvsi" driver, which is still available for now. When
the old driver is enabled, the new code still kicks in for the low
level udbg console, replacing the old mini implementation in the platform
code, it just doesn't provide the higher level "hvc" interface.
In addition to producing generally simler code, this has several benefits
over our current situation:
- The user/distro only has to deal with /dev/hvcN for the hypervisor
console, avoiding all sort of confusion that has plagued us in the past
- The tty, kernel and low level debug console all use the same code
base which supports the full protocol establishment process, thus the
console is now available much earlier than it used to be with the
old HVSI driver. The kernel console works much earlier and udbg is
available much earlier too. Hackers can enable a hard coded very-early
debug console as well that works with HVSI (previously that was only
supported for the "raw" mode).
I've tried to keep the same semantics as hvsi relative to how I react
to things like CD changes, with some subtle differences though:
- I clear DTR on close if HUPCL is set
- Current hvsi triggers a hangup if it detects a up->down transition
on CD (you can still open a console with CD down). My new implementation
triggers a hangup if the link to the FSP is severed, and severs it upon
detecting a up->down transition on CD.
Future releases of fimrware will enforce a requirement that DTL buffers
do not cross a 4k boundary. Commit
127493d5dc73589cbe00ea5ec8357cc2a4c0d82a satisfies this requirement for
CONFIG_VIRT_CPU_ACCOUNTING=y kernels, but if !CONFIG_VIRT_CPU_ACCOUNTING
&& CONFIG_DTL=y, the current code will fail at dtl registration time.
Fix this by making the kmem cache from
127493d5dc73589cbe00ea5ec8357cc2a4c0d82a visible outside of setup.c and
using the same cache in both dtl.c and setup.c. This requires a bit of
reorganization to ensure ordering of the kmem cache and buffer
allocations.
Note: Since firmware now limits the size of the buffer, I made
dtl_buf_entries read-only in debugfs.
Tested with upcoming firmware with the 4 combinations of
CONFIG_VIRT_CPU_ACCOUNTING and CONFIG_DTL.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Cc: linuxppc-dev@lists.ozlabs.org
Adds support for page coalescing, which is a feature on IBM Power servers
which allows for coalescing identical pages between logical partitions.
Hint text pages as coalesce candidates, since they are the most likely
pages to be able to be coalesced between partitions. This patch also
exports some page coalescing statistics available from firmware via
lparcfg.
[BenH: Moved a couple of things around to fix compile problems]
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
This is a significant rework of the XICS driver, too significant to
conveniently break it up into a series of smaller patches to be honest.
The driver is moved to a more generic location to allow new platforms
to use it, and is broken up into separate ICP and ICS "backends". For
now we have the native and "hypervisor" ICP backends and one common
RTAS ICS backend.
The driver supports one ICP backend instanciation, and many ICS ones,
in order to accomodate future platforms with multiple possibly different
interrupt "sources" mechanisms.
PAPR specifies that DTL buffers can not cross AMS environments (aka CMO
in the PAPR) and can not cross a memory entitlement granule boundary
(4k). This is found in section 14.11.3.2 H_REGISTER_VPA of the PAPR.
kmalloc does not guarantee an alignment of the allocation, though,
beyond 8 bytes (at least in my understanding). Create a special kmem
cache for DTL buffers with the alignment requirement.
Scripted with coccinelle.
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
Currently, when CONFIG_VIRT_CPU_ACCOUNTING is enabled, we use the
PURR register for measuring the user and system time used by
processes, as well as other related times such as hardirq and
softirq times. This turns out to be quite confusing for users
because it means that a program will often be measured as taking
less time when run on a multi-threaded processor (SMT2 or SMT4 mode)
than it does when run on a single-threaded processor (ST mode), even
though the program takes longer to finish. The discrepancy is
accounted for as stolen time, which is also confusing, particularly
when there are no other partitions running.
This changes the accounting to use the timebase instead, meaning that
the reported user and system times are the actual number of real-time
seconds that the program was executing on the processor thread,
regardless of which SMT mode the processor is in. Thus a program will
generally show greater user and system times when run on a
multi-threaded processor than on a single-threaded processor.
On pSeries systems on POWER5 or later processors, we measure the
stolen time (time when this partition wasn't running) using the
hypervisor dispatch trace log. We check for new entries in the
log on every entry from user mode and on every transition from
kernel process context to soft or hard IRQ context (i.e. when
account_system_vtime() gets called). So that we can correctly
distinguish time stolen from user time and time stolen from system
time, without having to check the log on every exit to user mode,
we store separate timestamps for exit to user mode and entry from
user mode.
On systems that have a SPURR (POWER6 and POWER7), we read the SPURR
in account_system_vtime() (as before), and then apportion the SPURR
ticks since the last time we read it between scaled user time and
scaled system time according to the relative proportions of user
time and system time over the same interval. This avoids having to
read the SPURR on every kernel entry and exit. On systems that have
PURR but not SPURR (i.e., POWER5), we do the same using the PURR
rather than the SPURR.
This disables the DTL user interface in /sys/debug/kernel/powerpc/dtl
for now since it conflicts with the use of the dispatch trace log
by the time accounting code.
Right now if we want to busy loop and not give up any time to the hypervisor
we put a very large value into smt_snooze_delay. This is sometimes useful
when running a single partition and you want to avoid any latencies due
to the hypervisor or CPU power state transitions. While this works, it's a bit
ugly - how big a number is enough now we have NO_HZ and can be idle for a very
long time.
The patch below makes smt_snooze_delay signed, and a negative value means loop
forever:
echo -1 > /sys/devices/system/cpu/cpu0/smt_snooze_delay
This change shouldn't affect the existing userspace tools (eg ppc64_cpu), but
I'm cc-ing Nathan just to be sure.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Currently there is a bug where if you use oprofile on a pSeries
machine, then use perf_counters, then use oprofile again, oprofile
will not work correctly; it will lose the PMU configuration the next
time the hypervisor does a partition context switch, and thereafter
won't count anything.
Maynard Johnson identified the sequence causing the problem:
- oprofile setup calls ppc_enable_pmcs(), which calls
pseries_lpar_enable_pmcs, which tells the hypervisor that we want
to use the PMU, and sets the "PMU in use" flag in the lppaca.
This flag tells the hypervisor whether it needs to save and restore
the PMU config.
- The perf_counter code sets and clears the "PMU in use" flag directly
as it context-switches the PMU between tasks, and leaves it clear
when it finishes.
- oprofile setup, called for a new oprofile run, calls ppc_enable_pmcs,
which does nothing because it has already been called. In particular
it doesn't set the "PMU in use" flag.
This fixes the problem by arranging for ppc_enable_pmcs to always set
the "PMU in use" flag. It makes the perf_counter code call
ppc_enable_pmcs also rather than calling the lower-level function
directly, and removes the setting of the "PMU in use" flag from
pseries_lpar_enable_pmcs, since that is now done in its caller.
This also removes the declaration of pasemi_enable_pmcs because it
isn't defined anywhere.
Reported-by: Maynard Johnson <mpjohn@us.ibm.com>
Cc: <stable@kernel.org)
There doesn't appear to be any specific reason that we need to setup the
pseries specific notifier in generic arch pci code. Move it into pseries
land.
This patch also includes the required removal of (unused) inclusion of
<asm/a.out.h> <linux/a.out.h>'s in the arch/ code for these
architectures.
[dwmw2: updated for 2.6.27-rc]
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This fixes an error building powerpc allmodconfig:
ERROR: "CMO_PageSize" [arch/powerpc/platforms/pseries/cmm.ko] undefined!
During platform setup, save off the primary/secondary paging space
pool IDs and the page size. Added accessors in hvcall.h for these
variables. This is needed for a subsequent fix.
Submitted-by: Robert Jennings <rcj@linux.vnet.ibm.com>
For Cooperative Memory Overcommitment (CMO), set the FW_FEATURE_CMO
flag in powerpc_firmware_features from the rtas ibm,get-system-parameters
table prior to calling iommu_init_early_pSeries.
With this, any CMO specific functionality can be controlled by checking:
firmware_has_feature(FW_FEATURE_CMO)
Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com>
Acked-by: Paul Mackerras <paulus@samba.org>
Don't return void in pseries/iommu.c
Make mce_data_buf static in pseries/ras.c
Make things static in pseries/rtasd.c
Make things static in pseries/setup.c
vtermno may as well be static in platforms/pseries/lpar.c
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Add a DEBUG config setting which turns on all (most) of the debugging
under platforms/pseries.
To have this take effect we need to remove all the #undef DEBUG's, in
various files. We leave the #undef DEBUG in platforms/pseries/lpar.c,
as this enables debugging printks from the low-level hash table routines,
and tends to make your system unusable. If you want those enabled you
still have to turn them on by hand.
Also some of the RAS code has a DEBUG block which causes a functional
change, so I've keyed this off a different (non-existant) debug #define.
This is only enabled if you have PPC_EARLY_DEBUG enabled also.
In pseries/lpar.c, fix some printf specifier mismatches, and add
a newline to one printk.
In pseries/rtasd.c add "rtasd" to some messages to make it clear
where they're coming from.
In pseries/scanlog.c remove the hand-rolled runtime debugging support
in there. This file has been largely unchanged for eons, if we need to
debug it in future we can recompile.
pseries_mpic_init_IRQ() implements the same logic as the xics code did to
find the i8259 cascade irq. Now that we've pulled that logic out into
pseries_setup_i8259_cascade() we can use it in the mpic code.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Remove the xics references from xics_setup_8259_cascade(), and merge the
good bits from the almost identical logic in pseries_mpic_init_IRQ().
