commit 8d3d50bf1913561ef3b1f5b53115c5a481ba9b1e upstream.
During a EEH recover, the pci_dev structure can be null, mainly if an
eeh event is detected during cpi config operation. In this case, the
pci_dev will not be known (and will be null) the kernel will crash
with the following message:
Unable to handle kernel paging request for data at address 0x000000a0
Faulting instruction address: 0xc00000000006b8b4
Oops: Kernel access of bad area, sig: 11 [#1]
NIP [c00000000006b8b4] .eeh_event_handler+0x10c/0x1a0
LR [c00000000006b8a8] .eeh_event_handler+0x100/0x1a0
Call Trace:
[c0000003a80dff00] [c00000000006b8a8] .eeh_event_handler+0x100/0x1a0
[c0000003a80dff90] [c000000000031f1c] .kernel_thread+0x54/0x70
The bug occurs because pci_name() tries to access a null pointer.
This patch just guarantee that pci_name() is not called on Null pointers.
Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com>
Signed-off-by: Linas Vepstas <linasvepstas@gmail.com>
Acked-by: Jeff Mahoney <jeffm@suse.com>
commit f8b67691828321f5c85bb853283aa101ae673130 upstream.
This moves query_cpu_stopped() out of the hotplug cpu code and into
smp.c so it can called in other places and renames it to
smp_query_cpu_stopped().
It also cleans up the return values by adding some #defines
Signed-off-by: Michael Neuling <mikey@neuling.org>
commit aef40e87d866355ffd279ab21021de733242d0d5 upstream.
Currently we always call start-cpu irrespective of if the CPU is
stopped or not. Unfortunatley on POWER7, firmware seems to not like
start-cpu being called when a cpu already been started. This was not
the case on POWER6 and earlier.
This patch checks to see if the CPU is stopped or not via an
query-cpu-stopped-state call, and only calls start-cpu on CPUs which
are stopped.
This fixes a bug with kexec on POWER7 on PHYP where only the primary
thread would make it to the second kernel.
Reported-by: Ankita Garg <ankita@linux.vnet.ibm.com>
Prevent NULL dereference if kmalloc() fails. Also clean up if
of_mdiobus_register() returns an error.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Acked-by: Scott Wood <scottwood@freescale.com>
Patch f598282f5145036312d90875d0ed5c14b49fd8a7 exposed a problem in
powerpc MSI-X functionality, making network interfaces such as ixgbe
and cxgb3 stop to work when MSI-X is enabled. RX interrupts were not
being generated.
The problem was caused because MSI irq was not being effectively
unmasked after device initialization.
Signed-off-by: Andre Detsch <adetsch@br.ibm.com>
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
The creation of the flattened device tree depended on the compiler
putting the constant strings for an object in a section with a
particular name. This was changed with recent compilers. Do this
explicitly instead.
Without this patch, iseries kernels may silently not boot when built with
some compilers.
- serial Console on PSC1
- 64MB SDRAM
- MTD CFI Flash
- Ethernet FEC
- IDE support
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
- 64MB SDRAM
- MTD CFI Flash
- Ethernet FEC
- I2C with PCF8563 and Temp. Sensor ADM9240
- IDE support
Profiling of a page fault scalability microbenchmark shows flush_hash_range
is not calling the batch hpte invalidate hcall (H_BULK_REMOVE).
It turns out we have a duplicate firmware feature for hcall-bulk and the
current setup code stops after finding the first match. This meant we never
batch and always do individual invalidates.
The patch below removes the duplicate and shifts FW_FEATURE_CMO to close
the gap. With the patch applied the single threaded page fault rate improves
from 217169 to 238755 per second on a POWER5 test box, a 10% improvement.
cppcheck found a memory leak in axon_msi, if dcr_base or dcr_len are zero,
we have already allocated msic, so we should free it in the error path.
Signed-off-by: Eric Sesterhenn <eric.sesterhenn@lsexperts.de>
Acked-by: Michael Ellerman <michael@ellerman.id.au>
Since the change of how interrupts are disabled during suspend,
certain PowerBook models started exhibiting various issues during
suspend or resume from sleep.
I finally tracked it down to the code that runs various "platform"
functions (kind of little scripts extracted from the device-tree),
which uses our i2c and PMU drivers expecting interrutps to work,
and at a time where with the new scheme, they have been disabled.
This causes timeouts internally which for some reason results in
the PMU being unable to see the trackpad, among other issues, really
it depends on the machine. Most of the time, we fail to properly adjust
some clocks for suspend/resume so the results are not always
predictable.
This patch fixes it by using IRQF_TIMER for both the PMU and the I2C
interrupts. I prefer doing it this way than moving the call sites since
I really want those platform functions to still be called after all
drivers (and before sysdevs).
We also do a slight cleanup to via-pmu.c driver to make sure the
ADB autopoll mask is handled correctly when doing bus resets
[akpm@linux-foundation.org: fix KVM]
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
Sometimes this is used to hold a simple offset, and sometimes
it is used to hold a pointer. This patch changes it to a union containing
void * and dma_addr_t. get/set accessors are also provided, because it was
getting a bit ugly to get to the actual data.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Use the accessors rather than frobbing bits directly (the new versions
are const).
Signed-off-by: Mike Travis <travis@sgi.com>
Make all seq_operations structs const, to help mitigate against
revectoring user-triggerable function pointers.
This is derived from the grsecurity patch, although generated from scratch
because it's simpler than extracting the changes from there.
Signed-off-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits)
trivial: fix typo in aic7xxx comment
trivial: fix comment typo in drivers/ata/pata_hpt37x.c
trivial: typo in kernel-parameters.txt
trivial: fix typo in tracing documentation
trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c
trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c
trivial: remove unnecessary semicolons
trivial: Fix duplicated word "options" in comment
trivial: kbuild: remove extraneous blank line after declaration of usage()
trivial: improve help text for mm debug config options
trivial: doc: hpfall: accept disk device to unload as argument
trivial: doc: hpfall: reduce risk that hpfall can do harm
trivial: SubmittingPatches: Fix reference to renumbered step
trivial: fix typos "man[ae]g?ment" -> "management"
trivial: media/video/cx88: add __init/__exit macros to cx88 drivers
trivial: fix typo in CONFIG_DEBUG_FS in gcov doc
trivial: fix missing printk space in amd_k7_smp_check
trivial: fix typo s/ketymap/keymap/ in comment
trivial: fix typo "to to" in multiple files
trivial: fix typos in comments s/DGBU/DBGU/
* 'perfcounters-rename-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf: Tidy up after the big rename
perf: Do the big rename: Performance Counters -> Performance Events
perf_counter: Rename 'event' to event_id/hw_event
perf_counter: Rename list_entry -> group_entry, counter_list -> group_list
Manually resolved some fairly trivial conflicts with the tracing tree in
include/trace/ftrace.h and kernel/trace/trace_syscalls.c.
trivial: fix typo "for for" in multiple files
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Bye-bye Performance Counters, welcome Performance Events!
In the past few months the perfcounters subsystem has grown out its
initial role of counting hardware events, and has become (and is
becoming) a much broader generic event enumeration, reporting, logging,
monitoring, analysis facility.
Naming its core object 'perf_counter' and naming the subsystem
'perfcounters' has become more and more of a misnomer. With pending
code like hw-breakpoints support the 'counter' name is less and
less appropriate.
All in one, we've decided to rename the subsystem to 'performance
events' and to propagate this rename through all fields, variables
and API names. (in an ABI compatible fashion)
The word 'event' is also a bit shorter than 'counter' - which makes
it slightly more convenient to write/handle as well.
Thanks goes to Stephane Eranian who first observed this misnomer and
suggested a rename.
User-space tooling and ABI compatibility is not affected - this patch
should be function-invariant. (Also, defconfigs were not touched to
keep the size down.)
This patch has been generated via the following script:
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/PERF_EVENT_/PERF_RECORD_/g' \
-e 's/PERF_COUNTER/PERF_EVENT/g' \
-e 's/perf_counter/perf_event/g' \
-e 's/nb_counters/nb_events/g' \
-e 's/swcounter/swevent/g' \
-e 's/tpcounter_event/tp_event/g' \
$FILES
for N in $(find . -name perf_counter.[ch]); do
M=$(echo $N | sed 's/perf_counter/perf_event/g')
mv $N $M
done
FILES=$(find . -name perf_event.*)
sed -i \
-e 's/COUNTER_MASK/REG_MASK/g' \
-e 's/COUNTER/EVENT/g' \
-e 's/\<event\>/event_id/g' \
-e 's/counter/event/g' \
-e 's/Counter/Event/g' \
$FILES
... to keep it as correct as possible. This script can also be
used by anyone who has pending perfcounters patches - it converts
a Linux kernel tree over to the new naming. We tried to time this
change to the point in time where the amount of pending patches
is the smallest: the end of the merge window.
Namespace clashes were fixed up in a preparatory patch - and some
stylistic fallout will be fixed up in a subsequent patch.
( NOTE: 'counters' are still the proper terminology when we deal
with hardware registers - and these sed scripts are a bit
over-eager in renaming them. I've undone some of that, but
in case there's something left where 'counter' would be
better than 'event' we can undo that on an individual basis
instead of touching an otherwise nicely automated patch. )
Suggested-by: Stephane Eranian <eranian@google.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Paul Mackerras <paulus@samba.org>
Reviewed-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: <linux-arch@vger.kernel.org>
LKML-Reference: <new-submission>
Now that the last users of markers have migrated to the event
tracer we can kill off the (now orphan) support code.
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
LKML-Reference: <20090917173527.GA1699@lst.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (75 commits)
PCI hotplug: clean up acpi_run_hpp()
PCI hotplug: acpiphp: use generic pci_configure_slot()
PCI hotplug: shpchp: use generic pci_configure_slot()
PCI hotplug: pciehp: use generic pci_configure_slot()
PCI hotplug: add pci_configure_slot()
PCI hotplug: clean up acpi_get_hp_params_from_firmware() interface
PCI hotplug: acpiphp: don't cache hotplug_params in acpiphp_bridge
PCI hotplug: acpiphp: remove superfluous _HPP/_HPX evaluation
PCI: Clear saved_state after the state has been restored
PCI PM: Return error codes from pci_pm_resume()
PCI: use dev_printk in quirk messages
PCI / PCIe portdrv: Fix pcie_portdrv_slot_reset()
PCI Hotplug: convert acpi_pci_detect_ejectable() to take an acpi_handle
PCI Hotplug: acpiphp: find bridges the easy way
PCI: pcie portdrv: remove unused variable
PCI / ACPI PM: Propagate wake-up enable for devices w/o ACPI support
ACPI PM: Replace wakeup.prepared with reference counter
PCI PM: Introduce device flag wakeup_prepared
PCI / ACPI PM: Rework some debug messages
PCI PM: Simplify PCI wake-up code
Fixed up conflict in arch/powerpc/kernel/pci_64.c due to OF device tree
scanning having been moved and merged for the 32- and 64-bit cases. The
'needs_freset' initialization added in 6e19314cc ("PCI/powerpc: support
PCIe fundamental reset") is now in arch/powerpc/kernel/pci_of_scan.c.
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (134 commits)
powerpc/nvram: Enable use Generic NVRAM driver for different size chips
powerpc/iseries: Fix oops reading from /proc/iSeries/mf/*/cmdline
powerpc/ps3: Workaround for flash memory I/O error
powerpc/booke: Don't set DABR on 64-bit BookE, use DAC1 instead
powerpc/perf_counters: Reduce stack usage of power_check_constraints
powerpc: Fix bug where perf_counters breaks oprofile
powerpc/85xx: Fix SMP compile error and allow NULL for smp_ops
powerpc/irq: Improve nanodoc
powerpc: Fix some late PowerMac G5 with PCIe ATI graphics
powerpc/fsl-booke: Use HW PTE format if CONFIG_PTE_64BIT
powerpc/book3e: Add missing page sizes
powerpc/pseries: Fix to handle slb resize across migration
powerpc/powermac: Thermal control turns system off too eagerly
powerpc/pci: Merge ppc32 and ppc64 versions of phb_scan()
powerpc/405ex: support cuImage via included dtb
powerpc/405ex: provide necessary fixup function to support cuImage
powerpc/40x: Add support for the ESTeem 195E (PPC405EP) SBC
powerpc/44x: Add Eiger AMCC (AppliedMicro) PPC460SX evaluation board support.
powerpc/44x: Update Arches defconfig
powerpc/44x: Update Arches dts
Fix up conflicts in drivers/char/agp/uninorth-agp.c
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits)
powerpc64: convert to dynamic percpu allocator
sparc64: use embedding percpu first chunk allocator
percpu: kill lpage first chunk allocator
x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA
percpu: update embedding first chunk allocator to handle sparse units
percpu: use group information to allocate vmap areas sparsely
vmalloc: implement pcpu_get_vm_areas()
vmalloc: separate out insert_vmalloc_vm()
percpu: add chunk->base_addr
percpu: add pcpu_unit_offsets[]
percpu: introduce pcpu_alloc_info and pcpu_group_info
percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward
percpu: add @align to pcpu_fc_alloc_fn_t
percpu: make @dyn_size mandatory for pcpu_setup_first_chunk()
percpu: drop @static_size from first chunk allocators
percpu: generalize first chunk allocator selection
percpu: build first chunk allocators selectively
percpu: rename 4k first chunk allocator to page
percpu: improve boot messages
percpu: fix pcpu_reclaim() locking
Fix trivial conflict as by Tejun Heo in kernel/sched.c
That code uses dma_mapping_error() with a NULL device, which is
a bad idea :-) The proper fix might be to start using some kind
of pseudo device for all these low level mappings with the
hypervisor but that will be for another day. Since it directly
calls into the low level iommu code, I see no problem in having
it directly test against DMA_ERROR_CODE instead of using the
accessors with a NULL argument for now.
Currently there is a bug where if you use oprofile on a pSeries
machine, then use perf_counters, then use oprofile again, oprofile
will not work correctly; it will lose the PMU configuration the next
time the hypervisor does a partition context switch, and thereafter
won't count anything.
Maynard Johnson identified the sequence causing the problem:
- oprofile setup calls ppc_enable_pmcs(), which calls
pseries_lpar_enable_pmcs, which tells the hypervisor that we want
to use the PMU, and sets the "PMU in use" flag in the lppaca.
This flag tells the hypervisor whether it needs to save and restore
the PMU config.
- The perf_counter code sets and clears the "PMU in use" flag directly
as it context-switches the PMU between tasks, and leaves it clear
when it finishes.
- oprofile setup, called for a new oprofile run, calls ppc_enable_pmcs,
which does nothing because it has already been called. In particular
it doesn't set the "PMU in use" flag.
This fixes the problem by arranging for ppc_enable_pmcs to always set
the "PMU in use" flag. It makes the perf_counter code call
ppc_enable_pmcs also rather than calling the lower-level function
directly, and removes the setting of the "PMU in use" flag from
pseries_lpar_enable_pmcs, since that is now done in its caller.
This also removes the declaration of pasemi_enable_pmcs because it
isn't defined anywhere.
Reported-by: Maynard Johnson <mpjohn@us.ibm.com>
Cc: <stable@kernel.org)
The following commit introduced a compile error since it removed
the implementation of smp_85xx_basic_setup:
commit 77c0a700c1c292edafa11c1e52821ce4636f81b0
Author: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Date: Fri Aug 28 14:25:04 2009 +1000
powerpc: Properly start decrementer on BookE secondary CPUs
Make it so that smp_ops probe() and setup_cpu() can be set to NULL.
By default, the EEH framework on powerpc does what's known as a "hot
reset" during recovery of a PCI Express device. We've found a case
where the device needs a "fundamental reset" to recover properly. The
current PCI error recovery and EEH frameworks do not support this
distinction.
The attached patch makes changes to EEH to utilize the new bit field.
Signed-off-by: Mike Mason <mmlnx@us.ibm.com>
Signed-off-by: Richard Lary <rlary@us.ibm.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
A misconfiguration by the firmware of the U4 PCIe bridge on PowerMac G5
with the U4 bridge (latest generations, may also affect the iMac G5
"iSight") is causing us to re-assign the PCI BARs of the video card,
which can get it out of sync with the firmware, thus breaking offb.
This works around it by fixing up the bridge configuration properly
at boot time. It also fixes a bug where the firmware provides us with
an incorrect set of accessible regions in the device-tree.
The SLB can change sizes across a live migration, which was not
being handled, resulting in possible machine crashes during
migration if migrating to a machine which has a smaller max SLB
size than the source machine. Fix this by first reducing the
SLB size to the minimum possible value, which is 32, prior to
migration. Then during the device tree update which occurs after
migration, we make the call to ensure the SLB gets updated. Also
add the slb_size to the lparcfg output so that the migration
tools can check to make sure the kernel has this capability
before allowing migration in scenarios where the SLB size will change.
BenH: Fixed #include <asm/mmu-hash64.h> -> <asm/mmu.h> to avoid
breaking ppc32 build
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
The two versions are doing almost exactly the same thing. No need to
maintain them as separate files. This patch also has the side effect
of making the PCI device tree scanning code available to 32 bit powerpc
machines, but no board ports actually make use of this feature at this
point.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
This patch adds support for the ESTeem 195E Hotfoot SBC.
There are several variants of the SBC deployed, single/dual
ethernet+serial, and also 4MB/8MB flash variations. In the interest of
having a single kernel image boot on all boards, the cuboot shim detects
the differences and mangles the DTS tree appropriately.
With the exception of the CF interface that was never populated on
production boards, this code/DTS supports all boardpop options.
Signed-off-by: Solomon Peachy <solomon@linux-wlan.com>
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
This patch adds support for the AMCC (AppliedMicro) PPC460SX Eiger evaluation
board.
Signed-off-by: Tai Tri Nguyen <ttnguyen@amcc.com>
Acked-by: Feng Kan <fkan@amcc.com>
Acked-by: Tirumala Marri <tmarri@amcc.com>
This moves the code to start the decrementer on 40x and BookE into
a separate function which is now called from time_init() and
secondary_time_init(), before the respective clock sources are
registered. We also remove the 85xx specific code for doing it
from the platform code.
This converts uses dma_map_ops struct (in include/linux/dma-mapping.h)
instead of POWERPC homegrown dma_mapping_ops.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
Now swiotlb_pci_dma_ops is identical to swiotlb_dma_ops; we can use
swiotlb_dma_ops with any devices. This removes swiotlb_pci_dma_ops.
This patch adds max_direct_dma_addr to struct dev_archdata to remove
addr_needs_map in struct dma_mapping_ops. It also converts
dma_capable() to use max_direct_dma_addr.
max_direct_dma_addr is initialized in pci_dma_dev_setup_swiotlb(),
called via ppc_md.pci_dma_dev_setup hook.
For further information:
http://marc.info/?t=124719060200001&r=1&w=2
On non-PS3, we get:
| kernel BUG at drivers/rtc/rtc-ps3.c:36!
because the rtc-ps3 platform device is registered unconditionally in a kernel
with builtin support for PS3.
Reported-by: Sachin Sant <sachinp@in.ibm.com>
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Acked-by: Geoff Levand <geoffrey.levand@am.sony.com>
On Thu, Aug 13, 2009 at 04:14:58PM +1000, Benjamin Herrenschmidt wrote:
> On Tue, 2009-08-11 at 11:39 +0200, Bastian Blank wrote:
> > This patch just disables this driver on SMP kernels, as it is obviously
> > not supported.
> Why not remove the #error instead ? :-) I don't think it's still
> meaningful, especially since we use the timebase for delays nowadays
> which doesn't depend on the CPU frequency...
Your call. Take this one:
The build of a PowerMac 32bit kernel currently fails with
error: #warning "WARNING, CPUFREQ not recommended on SMP kernels"
Thie patch removes the not longer applicable SMP warning from the
PowerMac cpufreq code.
Signed-off-by: Bastian Blank <waldi@debian.org>
- Add gpio-controller node for BCSR17, it is used to control USB
speed and VBUS;
- Add timer node for QE GTM, needed for USB host;
- Add usb node itself;
- Add some probing code for BCSR GPIOs.
NOTE: QE USB doesn't work on prototype boards, but should work on
pilot boards if specs and schematics are correct, though we
don't have the pilot boards to actually test it.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
- Add usb node;
- Configure pins and clocks;
- Enable USB function in BCSR.
The support was successfully tested using serial and ethernet gadget
drivers.
mpc8272_ads.c is using BCSR bits definitions from pq2ads.h, but
according to User's Guide the bits are wrong for MPC8272ADS boards
(I guess definitions from pq2ads should only be used for PQ2FADS
boards).
So, let's introduce our own definitions for MPC8272ADS, and don't
include pq2ads.h.
The existing fsl_rstcr_restart function is not applicable to the
mpc8560. The Global Utilities Block on this earlier CPU doesn't have
the control/reset register at 0xe00b0. This implements a board
specific reset function that uses the RCR(Reset Control Register) of
the sbc8560's EPLD to do a reset.
Signed-off-by: Liang Li <Liang.Li@windriver.com>
Add support for the P2020RDB reference board from Freescale.
Overview of P2020RDB platform
- DDR
DDR2 1G
- NOR Flash
16MByte
- NAND Flash
32MByte
- 3 Ethernet interfaces
1) etSEC1
- RGMII
- connected to a 5 port Vitesse Switch(VSC7385)
- Switch is memory mapped through eLBC interface(CS#2)
- IRQ1
2) etSEC2
- SGMII
- connected to VSC8221
- IRQ2
3) etSEC3
- RGMII
- connected to VSC8641
- IRQ3
- 2 1X PCIe interfaces
- SD/MMC ,USB
- SPI EEPROM
- Serial I2C EEPROM
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
As <asm/iommu.h> doesn't contain any other hardware specific definitions
but only interfaces.
Missing tests after ioremap()
