path: root/arch/powerpc/sysdev/xilinx_intc.c
2012-02-16irq_domain: Replace irq_alloc_host() with revmap-specific initializersGrant Likely
Each revmap type has different arguments for setting up the revmap. This patch splits up the generator functions so that each revmap type can do its own setup and the user doesn't need to keep track of how each revmap type handles the arguments. This patch also adds a host_data argument to the generators. There are cases where the host_data pointer will be needed before the function returns. ie. the legacy map calls the .map callback for each irq before returning. v2: - Add void *host_data argument to irq_domain_add_*() functions - fixed failure to compile - Moved IRQ_DOMAIN_MAP_* defines into irqdomain.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com> Tested-by: Olof Johansson <olof@lixom.net>
2012-02-14irq_domain/powerpc: Use common irq_domain structure instead of irq_hostGrant Likely
This patch drops the powerpc-specific irq_host structures and uses the common irq_domain strucutres defined in linux/irqdomain.h. It also fixes all the users to use the new structure names. Renaming irq_host to irq_domain has been discussed for a long time, and this patch is a step in the process of generalizing the powerpc virq code to be usable by all architecture. An astute reader will notice that this patch actually removes the irq_host structure instead of renaming it. This is because the irq_domain structure already exists in include/linux/irqdomain.h and has the needed data members. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Milton Miller <miltonm@bga.com> Tested-by: Olof Johansson <olof@lixom.net>
2011-05-04powerpc/irq: Stop exporting irq_mapGrant Likely
First step in eliminating irq_map[] table entirely Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-29powerpc: Convert to new irq_* function namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29powerpc: xilinx: Cleanup flow type handlingThomas Gleixner
The core irq_set_type() function updates the flow type when the chip callback returns 0. So setting the type is bogus. The core also updates the LEVEL flag. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-10powerpc: sysdev/xilinx_intc irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-12-09powerpc: Make "intspec" pointers in irq_host->xlate() constRoman Fietze
Writing a driver using SCLPC on the MPC5200B I detected, that the intspec arrays to map irqs to Linux virq cannot be const, because the mapping and xlate functions only take non const pointers. All those functions do not modify the intspec, so a const pointer could be used. Signed-off-by: Roman Fietze <roman.fietze@telemotive.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-11-24powerpc: Fixup last users of irq_chip->typenameThomas Gleixner
The typename member of struct irq_chip was kept for migration purposes and is obsolete since more than 2 years. Fix up the leftovers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: linuxppc-dev@ozlabs.org Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-30powerpc: Remove get_irq_desc()Michael Ellerman
get_irq_desc() is a powerpc-specific version of irq_to_desc(). That is reason enough to remove it, but it also doesn't know about sparse irq_desc support which irq_to_desc() does (when we enable it). Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-09-05powerpc: Fix i8259 interrupt driver kernel crash on ML510Roderick Colenbrander
This patch fixes a null pointer exception caused by removal of 'ack()' for level interrupts in the Xilinx interrupt driver. A recent change to the xilinx interrupt controller removed the ack hook for level irqs. Signed-off-by: Roderick Colenbrander <thunderbird2k@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-06powerpc/virtex: Add Xilinx ML510 reference design supportRoderick Colenbrander
2009-06-06powerpc/virtex: refactor intc driver and add support for i8259 cascadingGrant Likely
This patch refactors some of the xilinx_intc interrupt controller driver and adds support for cascading an i8259 off one of the irq lines. This patch was based on the ML510 support work done by Roderick Colenbrander. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-05-14powerpc/virtex: Fix duplicate level irq events.John Linn
The interrupt controller was not handling level interrupts correctly such that duplicate interrupts were happening. This fixes the problem and adds edge type interrupts which are needed in Xilinx hardware. Signed-off-by: John Linn <john.linn@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-11-14powerpc/virtex: fix various format/casting printk mismatchesGrant Likely
Various printk format string in code used by the Xilinx Virtex platform are not 32-bit/64-bit safe. Add correct casting to fix the bugs. Reported-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-05-01[POWERPC] Xilinx: Fix compile warningsKumar Gala
arch/powerpc/sysdev/xilinx_intc.c: In function 'xilinx_intc_init': arch/powerpc/sysdev/xilinx_intc.c:111: warning: format '%08X' expects type 'unsigned int', but argument 2 has type 'resource_size_t' drivers/char/xilinx_hwicap/xilinx_hwicap.c: In function 'hwicap_setup': drivers/char/xilinx_hwicap/xilinx_hwicap.c:626: warning: cast to pointer from integer of different size drivers/char/xilinx_hwicap/xilinx_hwicap.c:646: warning: format '%x' expects type 'unsigned int', but argument 6 has type 'resource_size_t' Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-09[POWERPC] Xilinx: update compatible list for interrupt controllerStephen Neuendorffer
These values now match what is generated by the uboot BSP generator. Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-10-03[POWERPC] Virtex: add xilinx interrupt controller driverGrant Likely
Adds support for the Xilinx opb-intc interrupt controller Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
