This was originally motivated by a desire to see the mapping between
logical and hardware cpu numbers.
But it seemed that it made more sense to just add a command to dump
(most of) the paca.
With no arguments "dp" will dump the paca for the current cpu.
It also takes an argument, eg. "dp 3" which is the logical cpu number
in hex. This form does not check if the cpu is possible, but displays
the paca regardless, as well as the cpu's state in the possible, present
and online masks.
Thirdly, "dpa" will display the paca for all possible cpus. If there are
no possible cpus, like early in boot, it will tell you that.
Sample output, number in brackets is the offset into the struct:
2:mon> dp 3
paca for cpu 0x3 @ c00000000ff20a80:
possible = yes
present = yes
online = yes
lock_token = 0x8000 (0x8)
paca_index = 0x3 (0xa)
kernel_toc = 0xc00000000144f990 (0x10)
kernelbase = 0xc000000000000000 (0x18)
kernel_msr = 0xb000000000001032 (0x20)
stab_real = 0x0 (0x28)
stab_addr = 0x0 (0x30)
emergency_sp = 0xc00000003ffe4000 (0x38)
data_offset = 0xa40000 (0x40)
hw_cpu_id = 0x9 (0x50)
cpu_start = 0x1 (0x52)
kexec_state = 0x0 (0x53)
__current = 0xc00000007e568680 (0x218)
kstack = 0xc00000007e5a3e30 (0x220)
stab_rr = 0x1a (0x228)
saved_r1 = 0xc00000007e7cb450 (0x230)
trap_save = 0x0 (0x240)
soft_enabled = 0x0 (0x242)
irq_happened = 0x0 (0x243)
io_sync = 0x0 (0x244)
irq_work_pending = 0x0 (0x245)
nap_state_lost = 0x0 (0x246)
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Rework set_dabr to take a DABRX value as well.
Both the pseries and PS3 hypervisors do some checks on the DABRX
values that are passed in the hcall. This patch stops bogus values
from being passed to hypervisor. Also, in the case where we are
clearing the breakpoint, where DABR and DABRX are zero, we modify the
DABRX value to make it valid so that the hcall won't fail.
Signed-off-by: Michael Neuling <mikey@neuling.org>
There are a few whitespace goolies in xmon.c, some of them appear to
be my fault. Fix them all in one go.
Since the printk internals were reworked the xmon 'dl' command which
dumps the content of __log_buf has stopped working.
It is now a structured buffer, so just dumping it doesn't really work.
Use the helpers added for kgdb to print out the content.
We have a bug report where the kernel hits a warning in the cpumask
code:
WARNING: at include/linux/cpumask.h:107
Which is:
WARN_ON_ONCE(cpu >= nr_cpumask_bits);
The backtrace is:
cpu_cmd
cmds
xmon_core
xmon
die
xmon is iterating through 0 to NR_CPUS. I'm not sure why we are still
open coding this but iterating above nr_cpu_ids is definitely a bug.
This patch iterates through all possible cpus, in case we issue a
system reset and CPUs in an offline state call in.
Perhaps the old code was trying to handle CPUs that were in the
partition but were never started (eg kexec into a kernel with an
nr_cpus= boot option). They are going to die way before we get into
xmon since we haven't set any kernel state up for them.
CC: <stable@kernel.org>
Disintegrate asm/system.h for PowerPC.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
cc: linuxppc-dev@lists.ozlabs.org
This is no longer selectable, so just remove all the dependent code.
The current implementation of lazy interrupts handling has some
issues that this tries to address.
We don't do the various workarounds we need to do when re-enabling
interrupts in some cases such as when returning from an interrupt
and thus we may still lose or get delayed decrementer or doorbell
interrupts.
The current scheme also makes it much harder to handle the external
"edge" interrupts provided by some BookE processors when using the
EPR facility (External Proxy) and the Freescale Hypervisor.
Additionally, we tend to keep interrupts hard disabled in a number
of cases, such as decrementer interrupts, external interrupts, or
when a masked decrementer interrupt is pending. This is sub-optimal.
This is an attempt at fixing it all in one go by reworking the way
we do the lazy interrupt disabling from the ground up.
The base idea is to replace the "hard_enabled" field with a
"irq_happened" field in which we store a bit mask of what interrupt
occurred while soft-disabled.
When re-enabling, either via arch_local_irq_restore() or when returning
from an interrupt, we can now decide what to do by testing bits in that
field.
We then implement replaying of the missed interrupts either by
re-using the existing exception frame (in exception exit case) or via
the creation of a new one from an assembly trampoline (in the
arch_local_irq_enable case).
This removes the need to play with the decrementer to try to create
fake interrupts, among others.
In addition, this adds a few refinements:
- We no longer hard disable decrementer interrupts that occur
while soft-disabled. We now simply bump the decrementer back to max
(on BookS) or leave it stopped (on BookE) and continue with hard interrupts
enabled, which means that we'll potentially get better sample quality from
performance monitor interrupts.
- Timer, decrementer and doorbell interrupts now hard-enable
shortly after removing the source of the interrupt, which means
they no longer run entirely hard disabled. Again, this will improve
perf sample quality.
- On Book3E 64-bit, we now make the performance monitor interrupt
act as an NMI like Book3S (the necessary C code for that to work
appear to already be present in the FSL perf code, notably calling
nmi_enter instead of irq_enter). (This also fixes a bug where BookE
perfmon interrupts could clobber r14 ... oops)
- We could make "masked" decrementer interrupts act as NMIs when doing
timer-based perf sampling to improve the sample quality.
Signed-off-by-yet: Benjamin Herrenschmidt <benh@kernel.crashing.org>
v2:
- Add hard-enable to decrementer, timer and doorbells
- Fix CR clobber in masked irq handling on BookE
- Make embedded perf interrupt act as an NMI
- Add a PACA_HAPPENED_EE_EDGE for use by FSL if they want
to retrigger an interrupt without preventing hard-enable
v3:
- Fix or vs. ori bug on Book3E
- Fix enabling of interrupts for some exceptions on Book3E
v4:
- Fix resend of doorbells on return from interrupt on Book3E
v5:
- Rebased on top of my latest series, which involves some significant
rework of some aspects of the patch.
v6:
- 32-bit compile fix
- more compile fixes with various .config combos
- factor out the asm code to soft-disable interrupts
- remove the C wrapper around preempt_schedule_irq
v7:
- Fix a bug with hard irq state tracking on native power7
Also use local_paca instead of get_paca() to avoid getting into
the smp_processor_id() debugging code from the debugger
Sorry, there was a typo in the #if
signed-off-by: Jimi Xenidis <jimix@pobox.com>
The 'u' command will print the TLB on book3e parts and the SLB on
Book3s parts, but the help system doesn't say that correctly.
Signed-off-by: Jimi Xenidis <jimix@pobox.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
All these files were including module.h just for the basic
EXPORT_SYMBOL infrastructure. We can shift them off to the
export.h header which is a way smaller footprint and thus
realize some compile time gains.
Based on patch by David Gibson <dwg@au1.ibm.com>
xmon has a longstanding bug on systems which are SMP-capable but lack
the MSR[RI] bit. In these cases, xmon invoked by IPI on secondary
CPUs will not properly keep quiet, but will print stuff, thereby
garbling the primary xmon's output. This patch fixes it, by ignoring
the RI bit if the processor does not support it.
There's already a version of this for 4xx upstream, which we'll need
to extend to other RI-lacking CPUs at some point. For now this adds
Book3e processors to the mix.
The only user of MSG_ALL_BUT_SELF in the whole kernel tree is powerpc,
and it only uses it to start the debugger. Both debuggers always call
smp_send_debugger_break with MSG_ALL_BUT_SELF, and only mpic can do
anything more optimal than a loop over all online cpus, but all message
passing implementations have to code for this special delivery target.
Convert smp_send_debugger_break to take void and loop calling the smp_ops
message_pass function for each of the other cpus in the online cpumask.
Use raw_smp_processor_id() because we are either entering the debugger
or trying to start kdump and the additional warning it not useful were
it to trigger.
Signed-off-by: Milton Miller <miltonm@bga.com>
Adapt new API.
Almost change is trivial. Most important change is the below line
because we plan to change task->cpus_allowed implementation.
- ctx->cpus_allowed = current->cpus_allowed;
Recent 64-bit server processors (POWER6 and POWER7) have a "Come-From
Address Register" (CFAR), that records the address of the most recent
branch or rfid (return from interrupt) instruction for debugging purposes.
This saves the value of the CFAR in the exception entry code and stores
it in the exception frame. We also make xmon print the CFAR value in
its register dump code.
Rather than extend the pt_regs struct at this time, we steal the orig_gpr3
field, which is only used for system calls, and use it for the CFAR value
for all exceptions/interrupts other than system calls. This means we
don't save the CFAR on system calls, which is not a great problem since
system calls tend not to happen unexpectedly, and also avoids adding the
overhead of reading the CFAR to the system call entry path.
Some of the 64bit PPC CPU features are MMU-related, so this patch moves
them to MMU_FTR_ bits. All cpu_has_feature()-style tests are moved to
mmu_has_feature(), and seven feature bits are freed as a result.
Signed-off-by: Matt Evans <matt@ozlabs.org>
Use the new MSR_64BIT in a few places. Some of these are already ifdef'ed
for BOOKE vs BOOKS, but it's still clearer, MSR_SF does not immediately
parse as "MSR bit for 64bit".
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from
meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which
resulted in build warnings on all architectures that implement their own
versions of show_mem():
lib/lib.a(show_mem.o): In function `show_mem':
show_mem.c:(.text+0x1f4): multiple definition of `show_mem'
arch/sparc/mm/built-in.o:(.text+0xd70): first defined here
The fix is to remove __show_mem() and add its argument to show_mem() in
all implementations to prevent this breakage.
Architectures that implement their own show_mem() actually don't do
anything with the argument yet, but they could be made to filter nodes
that aren't allowed in the current context in the future just like the
generic implementation.
Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: David Rientjes <rientjes@google.com>
Noone is using tty argument so let's get rid of it.
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Acked-by: Jason Wessel <jason.wessel@windriver.com>
Using perf to trace L1 dcache misses and dumping data addresses I found a few
variables taking a lot of misses. Since they are almost never written, they
should go into the __read_mostly section.
This patch provides an extended_cede_processor() helper function
which takes the cede latency hint as an argument. This hint is to be passed
on to the hypervisor to cede to the corresponding state on platforms
which support it.
Signed-off-by: Gautham R Shenoy <ego@in.ibm.com>
Signed-off-by: Arun R Bharadwaj <arun@linux.vnet.ibm.com>
Prior to the arch/ppc -> arch/powerpc transition, xmon had support for single
stepping on 4xx boards. The functionality was lost when arch/ppc was removed.
This patch restores single step support for 44x boards, and Book-E in general.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
The xmon code relies on MSR_RI being non-zero to indicate that an exception
is recoverable. If it is not, it prints a warning message. However, the
PowerPC 4xx cores do not have an MSR_RI bit and this warning is produced for
every xmon event.
This introduces an unrecoverable_excp function to determine if an exception
is recoverable or not. This gets rid of the erroneous warnings on 4xx.
This contains all the bits that didn't fit in previous patches :-) This
includes the actual exception handlers assembly, the changes to the
kernel entry, other misc bits and wiring it all up in Kconfig.
Gets rid of this warning:
arch/powerpc/xmon/xmon.c: In function 'dump_log_buf':
arch/powerpc/xmon/xmon.c:2133: warning: unused variable 'i'
Hello All,
Quite a while back Michael Ellerman had posted a patch to add support to xmon to print the contents of the console log pointed to by __log_buf.
Here's the link to that patch - http://ozlabs.org/pipermail/linuxppc64-dev/2005-March/003657.html
I've ported the patch in the above link to 2.6.30-rc5 and have tested it.
Thanks & regards,
Vinay
Signed-off-by: Michael Ellerman <michael at ellerman.id.au>
Today the arch/powerpc/xmon/setjmp.S file contains only the
xmon_save_regs function. We want to use it for kdump purposes, so
let's move the file into arch/powerpc/kernel/ and give the function a
more generic name (ppc_save_regs).
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
This makes sure we don't try to call find_bug or is_warning_bug when
CONFIG_BUG=n and CONFIG_XMON=y. Otherwise we get these errors:
arch/powerpc/xmon/xmon.c: In function ‘print_bug_trap’:
arch/powerpc/xmon/xmon.c:1364: error: implicit declaration of function ‘find_bug’
arch/powerpc/xmon/xmon.c:1364: warning: assignment makes pointer from integer without a cast
arch/powerpc/xmon/xmon.c:1367: error: implicit declaration of function ‘is_warning_bug’
arch/powerpc/xmon/xmon.c:1374: error: dereferencing pointer to incomplete type
make[2]: *** [arch/powerpc/xmon/xmon.o] Error 1
make[1]: *** [arch/powerpc/xmon] Error 2
make: *** [sub-make] Error 2
According to the CBEA, the SPU dsisr is not updated for class 0
exceptions.
spu_stopped() is testing the dsisr that was passed to it from the class
0 exception handler, so we return a false positive here.
This patch cleans up the interrupt handler and erroneous tests in
spu_stopped. It also removes the fields from the csa since it is not
needed to process class 0 events.
Signed-off-by: Luke Browning <lukebrowning@us.ibm.com>
Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
This is a little messier than I'd like because xmon.h only exists
on powerpc and we can't have a static inline and an extern declaration
visible at the same time.
warning: Using plain integer as NULL pointer
warning: symbol 'excprint' was not declared. Should it be static?
warning: symbol 'prregs' was not declared. Should it be static?
warning: symbol 'cacheflush' was not declared. Should it be static?
warning: symbol 'read_spr' was not declared. Should it be static?
warning: symbol 'write_spr' was not declared. Should it be static?
warning: symbol 'super_regs' was not declared. Should it be static?
warning: symbol 'mread' was not declared. Should it be static?
warning: symbol 'mwrite' was not declared. Should it be static?
warning: symbol 'byterev' was not declared. Should it be static?
warning: symbol 'memex' was not declared. Should it be static?
warning: symbol 'bsesc' was not declared. Should it be static?
warning: symbol 'dump' was not declared. Should it be static?
warning: symbol 'prdump' was not declared. Should it be static?
warning: symbol 'generic_inst_dump' was not declared. Should it be static?
warning: symbol 'ppc_inst_dump' was not declared. Should it be static?
warning: symbol 'memops' was not declared. Should it be static?
warning: symbol 'memdiffs' was not declared. Should it be static?
warning: symbol 'memlocate' was not declared. Should it be static?
warning: symbol 'memzcan' was not declared. Should it be static?
warning: symbol 'proccall' was not declared. Should it be static?
warning: symbol 'scannl' was not declared. Should it be static?
warning: symbol 'hexdigit' was not declared. Should it be static?
warning: symbol 'flush_input' was not declared. Should it be static?
warning: symbol 'inchar' was not declared. Should it be static?
warning: symbol 'take_input' was not declared. Should it be static?
warning: symbol 'xmon_init' was not declared. Should it be static?
SPU class 0 & 1 exceptions may occur in parallel, so we may end up
overwriting csa.dsisr.
This change adds dedicated fields for each class to the spu and the spu
context so that fault data is not overwritten.
Signed-off-by: Luke Browning <lukebr@linux.vnet.ibm.com>
This moves various definitions used all over the place to parse stack
frames to ptrace.h so only one definition is needed.
Now that we have the alpaca, the reg_save_ptr is no longer needed in the
paca. Eradicate all global uses of it and make it static in the iSeries
lpardata.c
This makes the setjmp/longjmp code used by xmon, generically available
to other code. It also removes the requirement for debugger hooks to
be only called on 0x300 (data storage) exception.
This adds a bit more detail to the xmon SLB output. When the valid
bit is set, this displays the ESID and VSID values, as well as
decoding the segment size -- 1T or 256M -- and displaying the LLP
bits. This supresses the output for any slb entries that contain only
zeros.
sample output from power6 (1T segment support):
00 c000000008000000 40004f7ca3000500 1T ESID= c00000 VSID= 4f7ca3 LLP:100
01 d000000008000000 4000eb71b0000400 1T ESID= d00000 VSID= eb71b0 LLP: 0
08 0000000018000000 0000c8499f8ccc80 256M ESID= 1 VSID= c8499f8cc LLP: 0
09 00000000f8000000 0000d2c1a8e46c80 256M ESID= f VSID= d2c1a8e46 LLP: 0
10 0000000048000000 0000ca87eab1dc80 256M ESID= 4 VSID= ca87eab1d LLP: 0
43 cf00000008000000 400011b260000500 1T ESID= cf0000 VSID= 11b260 LLP:100
sample output from power5 (notice the non-valid but non-zero entries)
10 0000000008000000 00004fd0e077ac80 256M ESID= 0 VSID= 4fd0e077a LLP: 0
11 00000000f8000000 00005b085830fc80 256M ESID= f VSID= 5b085830f LLP: 0
12 0000000048000000 000052ce99fe6c80 256M ESID= 4 VSID= 52ce99fe6 LLP: 0
13 0000000018000000 000050904ed95c80 256M ESID= 1 VSID= 50904ed95 LLP: 0
14 cf00000008000000 0000d59aca40f500 256M ESID=cf0000000 VSID= d59aca40f LLP:100
15 c000000078000000 000045cb97751500 256M ESID=c00000007 VSID= 45cb97751 LLP:100
Tested on power5 and power6.
Signed-Off-By: Will Schmidt <will_schmidt@vnet.ibm.com>
Currently we hardwire the number of SLBs to 64, but PAPR says we
should use the ibm,slb-size property to obtain the number of SLB
entries. This uses this property instead of assuming 64. If no
property is found, we assume 64 entries as before.
This soft patches the SLB handler, so it shouldn't change performance
at all.
This adds a function to xmon to dump the content of the 44x processor
TLB with a little bit of decoding (but not much).
In some configuration, xmon help string is larger than xmon_printf
buffer. We need not to use printf. This patch adds xmon_puts and
change to use it to show help string.
Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp>
xmon_early and xmon_off are only used in this file.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Several kallsyms_lookup() pass dummy arguments but only need, say, module's
name. Make kallsyms_lookup() accept NULLs where possible.
Also, makes picture clearer about what interfaces are needed for all symbol
resolving business.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Whenever we enter xmon we get a WARN_ON out of the rtas code since it
thinks interrupts are still on:
Unable to handle kernel paging request for data at address 0x00000000
Faulting instruction address: 0xd000000000080008
cpu 0x3: Vector: 300 (Data Access) at [c0000000075dba00]
pc: d000000000080008: .doit+0x8/0x40 [oopser]
lr: c000000000077704: .sys_init_module+0x1664/0x1824
sp: c0000000075dbc80
msr: 9000000000009032
dar: 0
dsisr: 42000000
current = 0xc000000003fa64b0
paca = 0xc000000000694280
pid = 2260, comm = insmod
Badness at arch/powerpc/kernel/entry_64.S:651
Call Trace:
[C0000000075DAE70] [C00000000000EB64] .show_stack+0x68/0x1b0 (unreliable)
[C0000000075DAF10] [C000000000216254] .report_bug+0x94/0xe8
[C0000000075DAFA0] [C00000000047B140] __kprobes_text_start+0x178/0x584
[C0000000075DB040] [C0000000000044F4] program_check_common+0xf4/0x100
My patch to add spu disassembly (af89fb8041562508895c8f3ba04790d7c2f4338c)
removed a newline from the xmon help that it shouldn't have, put it back.
It doesn't make any sense to have a priority field in the physical spu
structure. Move it into the spu context instead.
Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
This makes powerpc use the generic BUG machinery. The biggest reports the
function name, since it is redundant with kallsyms, and not needed in general.
There is an overall reduction of code, since module_32/64 duplicated several
functions.
Unfortunately there's no way to tell gcc that BUG won't return, so the BUG
macro includes a goto loop. This will generate a real jmp instruction, which
is never used.
[akpm@osdl.org: build fix]
[paulus@samba.org: remove infinite loop in BUG_ON]
Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org>
Cc: Andi Kleen <ak@muc.de>
Cc: Hugh Dickens <hugh@veritas.com>
Cc: Michael Ellerman <michael@ellerman.id.au>
