commit a5b2cf5b1af424ee3dd9e3ce6d5cea18cb927e67 upstream.
The 64bit relocation code places a few symbols in the text segment.
These symbols are only 4 byte aligned where they need to be 8 byte
aligned. Add an explicit alignment.
Tested-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
commit f5295bd8ea8a65dc5eac608b151386314cb978f1 upstream.
In copy_oldmem_page, the current check using max_pfn and min_low_pfn to
decide if the page is backed or not, is not valid when the memory layout is
not continuous.
This happens when running as a QEMU/KVM guest, where RTAS is mapped higher
in the memory. In that case max_pfn points to the end of RTAS, and a hole
between the end of the kdump kernel and RTAS is not backed by PTEs. As a
consequence, the kdump kernel is crashing in copy_oldmem_page when accessing
in a direct way the pages in that hole.
This fix relies on the memblock's service memblock_is_region_memory to
check if the read page is part or not of the directly accessible memory.
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Tested-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
commit 41dd03a94c7d408d2ef32530545097f7d1befe5c upstream.
Currently we're storing a host endian RTAS token in
rtas_stop_self_args.token. We then pass that directly to rtas. This is
fine on big endian however on little endian the token is not what we
expect.
This will typically result in hitting:
panic("Alas, I survived.\n");
To fix this we always use the stop-self token in host order and always
convert it to be32 before passing this to rtas.
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
commit 91b973f90c1220d71923e7efe1e61f5329806380 upstream.
The code in remove_cache_dir() is supposed to remove the "cache"
subdirectory from the sysfs directory for a CPU when that CPU is
being offlined. It tries to do this by calling kobject_put() on
the kobject for the subdirectory. However, the subdirectory only
gets removed once the last reference goes away, and the reference
being put here may well not be the last reference. That means
that the "cache" subdirectory may still exist when the offlining
operation has finished. If the same CPU subsequently gets onlined,
the code tries to add a new "cache" subdirectory. If the old
subdirectory has not yet been removed, we get a WARN_ON in the
sysfs code, with stack trace, and an error message printed on the
console. Further, we ultimately end up with an online cpu with no
This fixes it by doing an explicit kobject_del() at the point where
we want the subdirectory to go away. kobject_del() removes the sysfs
directory even though the object still exists in memory. The object
will get freed at some point in the future. A subsequent onlining
operation can create a new sysfs directory, even if the old object
still exists in memory, without causing any problems.
commit d4edc5b6c480a0917e61d93d55531d7efa6230be upstream.
On POWER platforms, the hypervisor can notify the guest kernel about dynamic
changes in the cpu-numa associativity (VPHN topology update). Hence the
cpu-to-node mappings that we got from the firmware during boot, may no longer
be valid after such updates. This is handled using the arch_update_cpu_topology()
hook in the scheduler, and the sched-domains are rebuilt according to the new
mappings.
But unfortunately, at the moment, CPU hotplug ignores these updated mappings
and instead queries the firmware for the cpu-to-numa relationships and uses
them during CPU online. So the kernel can end up assigning wrong NUMA nodes
to CPUs during subsequent CPU hotplug online operations (after booting).
Further, a particularly problematic scenario can result from this bug:
On POWER platforms, the SMT mode can be switched between 1, 2, 4 (and even 8)
threads per core. The switch to Single-Threaded (ST) mode is performed by
offlining all except the first CPU thread in each core. Switching back to
SMT mode involves onlining those other threads back, in each core.
Now consider this scenario:
1. During boot, the kernel gets the cpu-to-node mappings from the firmware
and assigns the CPUs to NUMA nodes appropriately, during CPU online.
2. Later on, the hypervisor updates the cpu-to-node mappings dynamically and
communicates this update to the kernel. The kernel in turn updates its
cpu-to-node associations and rebuilds its sched domains. Everything is
fine so far.
3. Now, the user switches the machine from SMT to ST mode (say, by running
ppc64_cpu --smt=1). This involves offlining all except 1 thread in each
core.
4. The user then tries to switch back from ST to SMT mode (say, by running
ppc64_cpu --smt=4), and this involves onlining those threads back. Since
CPU hotplug ignores the new mappings, it queries the firmware and tries to
associate the newly onlined sibling threads to the old NUMA nodes. This
results in sibling threads within the same core getting associated with
different NUMA nodes, which is incorrect.
The scheduler's build-sched-domains code gets thoroughly confused with this
and enters an infinite loop and causes soft-lockups, as explained in detail
in commit 3be7db6ab (powerpc: VPHN topology change updates all siblings).
So to fix this, use the numa_cpu_lookup_table to remember the updated
cpu-to-node mappings, and use them during CPU hotplug online operations.
Further, we also need to ensure that all threads in a core are assigned to a
common NUMA node, irrespective of whether all those threads were online during
the topology update. To achieve this, we take care not to use cpu_sibling_mask()
since it is not hotplug invariant. Instead, we use cpu_first_sibling_thread()
and set up the mappings manually using the 'threads_per_core' value for that
particular platform. This helps us ensure that we don't hit this bug with any
combination of CPU hotplug and SMT mode switching.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 70713fe315ed14cd1bb07d1a7f33e973d136ae3d upstream.
Use gva_t instead of unsigned int for eaddr in deliver_tlb_miss().
Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com>
commit 48eaef0518a565d3852e301c860e1af6a6db5a84 upstream.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
[ Upstream commit aee636c4809fa54848ff07a899b326eb1f9987a2 ]
At first Jakub Zawadzki noticed that some divisions by reciprocal_divide
were not correct. (off by one in some cases)
http://www.wireshark.org/~darkjames/reciprocal-buggy.c
He could also show this with BPF:
http://www.wireshark.org/~darkjames/set-and-dump-filter-k-bug.c
The reciprocal divide in linux kernel is not generic enough,
lets remove its use in BPF, as it is not worth the pain with
current cpus.
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Cc: Mircea Gherzan <mgherzan@gmail.com>
Cc: Daniel Borkmann <dxchgb@gmail.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Matt Evans <matt@ozlabs.org>
commit 286e4f90a72c0b0621dde0294af6ed4b0baddabb upstream.
p_end is an 8 byte value embedded in the text section. This means it
is only 4 byte aligned when it should be 8 byte aligned. Fix this
by adding an explicit alignment.
This fixes an issue where POWER7 little endian builds with
CONFIG_RELOCATABLE=y fail to boot.
commit 90ff5d688e61f49f23545ffab6228bd7e87e6dc7 upstream.
In EXCEPTION_PROLOG_COMMON() we check to see if the stack pointer (r1)
is valid when coming from the kernel. If it's not valid, we die but
with a nice oops message.
Currently we allocate a stack frame (subtract INT_FRAME_SIZE) before we
check to see if the stack pointer is negative. Unfortunately, this
won't detect a bad stack where r1 is less than INT_FRAME_SIZE.
This patch fixes the check to compare the modified r1 with
-INT_FRAME_SIZE. With this, bad kernel stack pointers (including NULL
pointers) are correctly detected again.
Kudos to Paulus for finding this.
Signed-off-by: Michael Neuling <mikey@neuling.org>
commit 91648ec09c1ef69c4d840ab6dab391bfb452d554 upstream.
Since kvmppc_hv_find_lock_hpte() is called from both virtmode and
realmode, so it can trigger the deadlock.
Suppose the following scene:
Two physical cpuM, cpuN, two VM instances A, B, each VM has a group of
vcpus.
If on cpuM, vcpu_A_1 holds bitlock X (HPTE_V_HVLOCK), then is switched
out, and on cpuN, vcpu_A_2 try to lock X in realmode, then cpuN will be
caught in realmode for a long time.
What makes things even worse if the following happens,
On cpuM, bitlockX is hold, on cpuN, Y is hold.
vcpu_B_2 try to lock Y on cpuM in realmode
vcpu_A_2 try to lock X on cpuN in realmode
Oops! deadlock happens
Signed-off-by: Liu Ping Fan <pingfank@linux.vnet.ibm.com>
Reviewed-by: Paul Mackerras <paulus@samba.org>
commit cf77ee54362a245f9a01f240adce03a06c05eb68 upstream.
In pte_alloc_one(), pgtable_page_ctor() is passed an address that has
not been converted by page_address() to the newly allocated PTE page.
When the PTE is freed, __pte_free_tlb() calls pgtable_page_dtor()
with an address to the PTE page that has been converted by page_address().
The mismatch in the PTE's page address causes pgtable_page_dtor() to access
invalid memory, so resources for that PTE (such as the page lock) is not
properly cleaned up.
On PPC32, only SMP kernels are affected.
On PPC64, only SMP kernels with 4K page size are affected.
This bug was introduced by commit d614bb041209fd7cb5e4b35e11a7b2f6ee8f62b8
"powerpc: Move the pte free routines from common header".
On a preempt-rt kernel, a spinlock is dynamically allocated for each
PTE in pgtable_page_ctor(). When the PTE is freed, calling
pgtable_page_dtor() with a mismatched page address causes a memory leak,
as the pointer to the PTE's spinlock is bogus.
On mainline, there isn't any immediately obvious symptoms, but the
problem still exists here.
Fixes: d614bb041209fd7c "powerpc: Move the pte free routes from common header"
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Signed-off-by: Hong H. Pham <hong.pham@windriver.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit ec67ad82814bee92251fd963bf01c7a173856555 upstream.
In a recent patch:
commit c13f20ac48328b05cd3b8c19e31ed6c132b44b42
Author: Michael Neuling <mikey@neuling.org>
powerpc/signals: Mark VSX not saved with small contexts
We fixed an issue but an improved solution was later discussed after the patch
was merged.
Firstly, this patch doesn't handle the 64bit signals case, which could also hit
this issue (but has never been reported).
Secondly, the original patch isn't clear what MSR VSX should be set to. The
new approach below always clears the MSR VSX bit (to indicate no VSX is in the
context) and sets it only in the specific case where VSX is available (ie. when
VSX has been used and the signal context passed has space to provide the
state).
This reverts the original patch and replaces it with the improved solution. It
also adds a 64 bit version.
commit c13f20ac48328b05cd3b8c19e31ed6c132b44b42 upstream.
The VSX MSR bit in the user context indicates if the context contains VSX
state. Currently we set this when the process has touched VSX at any stage.
Unfortunately, if the user has not provided enough space to save the VSX state,
we can't save it but we currently still set the MSR VSX bit.
This patch changes this to clear the MSR VSX bit when the user doesn't provide
enough space. This indicates that there is no valid VSX state in the user
context.
This is needed to support get/set/make/swapcontext for applications that use
VSX but only provide a small context. For example, getcontext in glibc
provides a smaller context since the VSX registers don't need to be saved over
the glibc function call. But since the program calling getcontext may have
used VSX, the kernel currently says the VSX state is valid when it's not. If
the returned context is then used in setcontext (ie. a small context without
VSX but with MSR VSX set), the kernel will refuse the context. This situation
has been reported by the glibc community.
Based on patch from Carlos O'Donell.
Tested-by: Haren Myneni <haren@linux.vnet.ibm.com>
commit 5a049f14902982c26538250bdc8d54156d357252 upstream.
Commit fba2369e6ceb (mm: use vm_unmapped_area() on powerpc architecture)
has a bug in slice_scan_available() where we compare an unsigned long
(high_slices) against a shifted int. As a result, comparisons against
the top 32 bits of high_slices (representing the top 32TB) always
returns 0 and the top of our mmap region is clamped at 32TB
This also breaks mmap randomisation since the randomised address is
always up near the top of the address space and it gets clamped down
to 32TB.
Acked-by: Michel Lespinasse <walken@google.com>
commit 631ad691b5818291d89af9be607d2fe40be0886e upstream.
We need add PE to its own PELTV. Otherwise, the errors originated
from the PE might contribute to other PEs. In the result, we can't
clear up the error successfully even we're checking and clearing
errors during access to PCI config space.
Reported-by: kalshett@in.ibm.com
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
commit 411cabf79e684171669ad29a0628c400b4431e95 upstream.
Commit e82b89a6f19bae73fb064d1b3dd91fcefbb478f4 used strcat instead of
strcpy which can result in an overflow of newlines on the buffer.
Signed-off-by: Prarit Bhargava
Cc: benh@kernel.crashing.org
Cc: ben@decadent.org.uk
commit 2bf75084f6d9f9a91ba6e30a501ff070d8a1acf6 upstream.
The MPC5200 LPBFIFO driver requires the bestcomm module to be
enabled, otherwise building will fail. Fix it.
Reported-by: Wolfgang Denk <wd@denx.de>
commit 3f0116c3238a96bc18ad4b4acefe4e7be32fa861 upstream.
Fengguang Wu, Oleg Nesterov and Peter Zijlstra tracked down
a kernel crash to a GCC bug: GCC miscompiles certain 'asm goto'
constructs, as outlined here:
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670
Implement a workaround suggested by Jakub Jelinek.
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Suggested-by: Jakub Jelinek <jakub@redhat.com>
Reviewed-by: Richard Henderson <rth@twiddle.net>
Link: http://lkml.kernel.org/r/20131015062351.GA4666@gmail.com
commit cfc860253abd73e1681696c08ea268d33285a2c4 upstream.
This fixes a typo in the code that saves the guest DSCR (Data Stream
Control Register) into the kvm_vcpu_arch struct on guest exit. The
effect of the typo was that the DSCR value was saved in the wrong place,
so changes to the DSCR by the guest didn't persist across guest exit
and entry, and some host kernel memory got corrupted.
Acked-by: Alexander Graf <agraf@suse.de>
commit 8f21bd0090052e740944f9397e2be5ac7957ded7 upstream.
The csum_partial_copy_generic() function saves the PowerPC non-volatile
r14, r15, and r16 registers for the main checksum-and-copy loop.
Unfortunately, it fails to restore them upon error exit from this loop,
which results in silent corruption of these registers in the presumably
rare event of an access exception within that loop.
This commit therefore restores these register on error exit from the loop.
commit d1211af3049f4c9c1d8d4eb8f8098cc4f4f0d0c7 upstream.
arch/powerpc/kernel/sysfs.c exports PURR with write permission.
This may be valid for kernel in phyp mode. But writing to
the file in guest mode causes crash due to a priviledge violation
Signed-off-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com>
commit d9813c3681a36774b254c0cdc9cce53c9e22c756 upstream.
The csum_partial_copy_generic() uses register r7 to adjust the remaining
bytes to process. Unfortunately, r7 also holds a parameter, namely the
address of the flag to set in case of access exceptions while reading
the source buffer. Lacking a quantum implementation of PowerPC, this
commit instead uses register r9 to do the adjusting, leaving r7's
pointer uncorrupted.
commit e82b89a6f19bae73fb064d1b3dd91fcefbb478f4 upstream.
modalias_show() should return an empty string on error, not -ENODEV.
This causes the following false and annoying error:
> find /sys/devices -name modalias -print0 | xargs -0 cat >/dev/null
cat: /sys/devices/vio/4000/modalias: No such device
cat: /sys/devices/vio/4001/modalias: No such device
cat: /sys/devices/vio/4002/modalias: No such device
cat: /sys/devices/vio/4004/modalias: No such device
cat: /sys/devices/vio/modalias: No such device
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
commit e9bdc3d6143d1c4b8d8ce5231fc958268331f983 upstream.
When we do a treclaim or trecheckpoint we end up running with userspace
PPR and DSCR values. Currently we don't do anything special to avoid
running with user values which could cause a severe performance
degradation.
This patch moves the PPR and DSCR save and restore around treclaim and
trecheckpoint so that we run with user values for a much shorter period.
More care is taken with the PPR as it's impact is greater than the DSCR.
This is similar to user exceptions, where we run HTM_MEDIUM early to
ensure that we don't run with a userspace PPR values in the kernel.
commit a53b27b3abeef406de92a2bb0ceb6fb4c3fb8fc4 upstream.
Commit 4df4899 "Add power8 EBB support" included a bug in the handling
of the FAB_CRESP_MATCH and FAB_TYPE_MATCH fields.
These values are pulled out of the event code using EVENT_THR_CTL_SHIFT,
however we were then or'ing that value directly into MMCR1.
This meant we were failing to set the FAB fields correctly, and also
potentially corrupting the value for PMC4SEL. Leading to no counts for
the FAB events and incorrect counts for PMC4.
The fix is simply to shift left the FAB value correctly before or'ing it
with MMCR1.
Reported-by: Sooraj Ravindran Nair <soonair3@in.ibm.com>
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
commit 1cf389df090194a0976dc867b7fffe99d9d490cb upstream.
Under heavy (DLPAR?) stress, we tripped this panic() in
arch/powerpc/kernel/iommu.c::iommu_init_table():
page = alloc_pages_node(nid, GFP_ATOMIC, get_order(sz));
if (!page)
panic("iommu_init_table: Can't allocate %ld bytes\n", sz);
Before the panic() we got a page allocation failure for an order-2
allocation. There appears to be memory free, but perhaps not in the
ATOMIC context. I looked through all the call-sites of
iommu_init_table() and didn't see any obvious reason to need an ATOMIC
allocation. Most call-sites in fact have an explicit GFP_KERNEL
allocation shortly before the call to iommu_init_table(), indicating we
are not in an atomic context. There is some indirection for some paths,
but I didn't see any locks indicating that GFP_KERNEL is inappropriate.
With this change under the same conditions, we have not been able to
reproduce the panic.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
commit 7bfa9ad55d691f2b836b576769b11eca2cf50816 upstream.
Commit 8e44ddc3f3 ("powerpc/kvm/book3s: Add support for H_IPOLL and
H_XIRR_X in XICS emulation") added a call to get_tb() but didn't
include the header that defines it, and on some configs this means
book3s_xics.c fails to compile:
arch/powerpc/kvm/book3s_xics.c: In function ‘kvmppc_xics_hcall’:
arch/powerpc/kvm/book3s_xics.c:812:3: error: implicit declaration of function ‘get_tb’ [-Werror=implicit-function-declaration]
commit 363edbe2614aa90df706c0f19ccfa2a6c06af0be upstream.
When adding cpuidle support to pSeries, we introduced two
regressions:
- The new cpuidle backend driver only works under hypervisors
supporting the "SLPLAR" option, which isn't the case of the
old POWER4 hypervisor and the HV "light" used on js2x blades
- The cpuidle driver registers fairly late, meaning that for
a significant portion of the boot process, we end up having
all threads spinning. This slows down the boot process and
increases the overall resource usage if the hypervisor has
shared processors.
This fixes both by implementing a "default" idle that will cede
to the hypervisor when possible, in a very simple way without
all the bells and whisles of cpuidle.
Reported-by: Paul Mackerras <paulus@samba.org>
Signed-off-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
Acked-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
commit 230aef7a6a23b6166bd4003bfff5af23c9bd381f upstream.
Normally when we haven't implemented an alignment handler for
a load or store instruction the process will be terminated.
The alignment handler uses the DSISR (or a pseudo one) to locate
the right handler. Unfortunately ldbrx and stdbrx overlap lfs and
stfs so we incorrectly think ldbrx is an lfs and stdbrx is an
stfs.
This bug is particularly nasty - instead of terminating the
process we apply an incorrect fixup and continue on.
With more and more overlapping instructions we should stop
creating a pseudo DSISR and index using the instruction directly,
but for now add a special case to catch ldbrx/stdbrx.
commit f5f6cbb61610b7bf9d9d96db9c3979d62a424bab upstream.
/proc/powerpc/lparcfg is an ancient facility (though still actively used)
which allows access to some informations relative to the partition when
running underneath a PAPR compliant hypervisor.
It makes no sense on non-pseries machines. However, currently, not only
can it be created on these if the kernel has pseries support, but accessing
it on such a machine will crash due to trying to do hypervisor calls.
In fact, it should also not do HV calls on older pseries that didn't have
an hypervisor either.
Finally, it has the plumbing to be a module but is a "bool" Kconfig option.
This fixes the whole lot by turning it into a machine_device_initcall
that is only created on pseries, and adding the necessary hypervisor
check before calling the H_GET_EM_PARMS hypercall
commit bdbc29c19b2633b1d9c52638fb732bcde7a2031a upstream.
On 64-bit, __pa(&static_var) gets miscompiled by recent versions of
gcc as something like:
addis 3,2,.LANCHOR1+4611686018427387904@toc@ha
addi 3,3,.LANCHOR1+4611686018427387904@toc@l
This ends up effectively ignoring the offset, since its bottom 32 bits
are zero, and means that the result of __pa() still has 0xC in the top
nibble. This happens with gcc 4.8.1, at least.
To work around this, for 64-bit we make __pa() use an AND operator,
and for symmetry, we make __va() use an OR operator. Using an AND
operator rather than a subtraction ends up with slightly shorter code
since it can be done with a single clrldi instruction, whereas it
takes three instructions to form the constant (-PAGE_OFFSET) and add
it on. (Note that MEMORY_START is always 0 on 64-bit.)
commit 28e61cc466d8daace4b0f04ba2b83e0bd68f5832 upstream.
If a transaction is rolled back, the Target Address Register (TAR), Processor
Priority Register (PPR) and Data Stream Control Register (DSCR) should be
restored to the checkpointed values before the transaction began. Any changes
to these SPRs inside the transaction should not be visible in the abort
handler.
Currently Linux doesn't save or restore the checkpointed TAR, PPR or DSCR. If
we preempt a processes inside a transaction which has modified any of these, on
process restore, that same transaction may be aborted we but we won't see the
checkpointed versions of these SPRs.
This adds checkpointed versions of these SPRs to the thread_struct and adds the
save/restore of these three SPRs to the treclaim/trechkpt code.
Without this if any of these SPRs are modified during a transaction, users may
incorrectly see a speculated SPR value even if the transaction is aborted.
commit c2d52644e2da8a07ecab5ca62dd0bc563089e8dc upstream.
This moves us to save the Target Address Register (TAR) a earlier in
__switch_to. It introduces a new function save_tar() to do this.
We need to save the TAR earlier as we will overwrite it in the transactional
memory reclaim/recheckpoint path. We are going to do this in a subsequent
patch which will fix saving the TAR register when it's modified inside a
transaction.
commit 2517617e0de65f8f7cfe75cae745d06b1fa98586 upstream.
POWER8 allows the DSCR to be accessed directly from userspace via a new SPR
number 0x3 (Rather than 0x11. DSCR SPR number 0x11 is still used on POWER8 but
like POWER7, is only accessible in HV and OS modes). Currently, we allow this
by setting H/FSCR DSCR bit on boot.
Unfortunately this doesn't work, as the kernel needs to see the DSCR change so
that it knows to no longer restore the system wide version of DSCR on context
switch (ie. to set thread.dscr_inherit).
This clears the H/FSCR DSCR bit initially. If a process then accesses the DSCR
(via SPR 0x3), it'll trap into the kernel where we set thread.dscr_inherit in
facility_unavailable_exception().
We also change _switch() so that we set or clear the H/FSCR DSCR bit based on
the thread.dscr_inherit.
commit 74e400cee6c0266ba2d940ed78d981f1e24a8167 upstream.
This reworks the Facility Status and Control Regsiter (FSCR) config bit
definitions so that we can access the bit numbers. This is needed for a
subsequent patch to fix the userspace DSCR handling.
HFSCR and FSCR bit definitions are the same, so reuse them.
commit 88f094120bd2f012ff494ae50a8d4e0d8af8f69e upstream.
Currently if we take hypervisor facility unavaliable (from 0xf80/0x4f80) we
mark it as an OS facility unavaliable (0xf60) as the two share the same code
path.
The becomes a problem in facility_unavailable_exception() as we aren't able to
see the hypervisor facility unavailable exceptions.
Below fixes this by duplication the required macros.
commit 4e90a2a7375e86827541bda9393414c03e7721c6 upstream.
We want PPC_DENORMALISATION enabled when POWERNV is enabled,
so update the Kconfig.
Acked-by: Michael Neuling <mikey@neuling.org>
commit 3be7db6ab45b21345386d1a466da133b19cde5e4 upstream.
When an associativity level change is found for one thread, the
siblings threads need to be updated as well. This is done today
for PRRN in stage_topology_update() but is missing for VPHN in
update_cpu_associativity_changes_mask(). This patch will correctly
update all thread siblings during a topology change.
Without this patch a topology update can result in a CPU in
init_sched_groups_power() getting stuck indefinitely in a loop.
This loop is built in build_sched_groups(). As a result of the thread
moving to a node separate from its siblings the struct sched_group will
have its next pointer set to point to itself rather than the sched_group
struct of the next thread. This happens because we have a domain without
the SD_OVERLAP flag, which is correct, and a topology that doesn't conform
with reality (threads on the same core assigned to different numa nodes).
When this list is traversed by init_sched_groups_power() it will reach
the thread's sched_group structure and loop indefinitely; the cpu will
be stuck at this point.
The bug was exposed when VPHN was enabled in commit b7abef0 (v3.9).
Reported-by: Jan Stancek <jstancek@redhat.com>
Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com>
commit 0e0ed6406e61434d3f38fb58aa8464ec4722b77e upstream.
Module CRCs are implemented as absolute symbols that get resolved by
a linker script. We build an intermediate .o that contains an
unresolved symbol for each CRC. genksysms parses this .o, calculates
the CRCs and writes a linker script that "resolves" the symbols to
the calculated CRC.
Unfortunately the ppc64 relocatable kernel sees these CRCs as symbols
that need relocating and relocates them at boot. Commit d4703aef
(module: handle ppc64 relocating kcrctabs when CONFIG_RELOCATABLE=y)
added a hook to reverse the bogus relocations. Part of this patch
created a symbol at 0x0:
# head -2 /proc/kallsyms
0000000000000000 T reloc_start
c000000000000000 T .__start
This reloc_start symbol is causing lots of confusion to perf. It
thinks reloc_start is a massive function that stretches from 0x0 to
0xc000000000000000 and we get various cryptic errors out of perf,
including:
problem incrementing symbol count, skipping event
This patch removes the reloc_start linker script label and instead
defines it as PHYSICAL_START. We also need to wrap it with
CONFIG_PPC64 because the ppc32 kernel can set a non zero
PHYSICAL_START at compile time and we wouldn't want to subtract
it from the CRCs in that case.
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
commit 4ea355b5368bde0574c12430df53334c4be3bdcf upstream.
In power_pmu_enable() we still enable the PMU even if we have zero
events. This should have no effect but doesn't make much sense. Instead
just return after telling the hypervisor that we are not using the PMCs.
commit 0a48843d6c5114cfa4a9540ee4d6af87628cec01 upstream.
In power_pmu_enable() we can use the existing out label to reduce the
number of return paths.
commit 7a7a41f9d5b28ac3a916b057a7d3cd3f435ee9a6 upstream.
On Power8 we can freeze PMC5 and 6 if we're not using them. Normally they
run all the time.
As noticed by Anshuman, we should unfreeze them when we disable the PMU
as there are legacy tools which expect them to run all the time.
commit 378a6ee99e4a431ec84e4e61893445c041c93007 upstream.
In pmu_disable() we disable the PMU by setting the FC (Freeze Counters)
bit in MMCR0. In order to do this we have to read/modify/write MMCR0.
It's possible that we read a value from MMCR0 which has PMAO (PMU Alert
Occurred) set. When we write that value back it will cause an interrupt
to occur. We will then end up in the PMU interrupt handler even though
we are supposed to have just disabled the PMU.
We can avoid this by making sure we never write PMAO back. We should not
lose interrupts because when the PMU is re-enabled the overflowed values
will cause another interrupt.
We also reorder the clearing of SAMPLE_ENABLE so that is done after the
PMU is frozen. Otherwise there is a small window between the clearing of
SAMPLE_ENABLE and the setting of FC where we could take an interrupt and
incorrectly see SAMPLE_ENABLE not set. This would for example change the
logic in perf_read_regs().
commit d8bec4c9cd58f6d3679e09b7293851fb92ad7557 upstream.
A mistake we have made in the past is that we pull out the fields we
need from the event code, but don't check that there are no unknown bits
set. This means that we can't ever assign meaning to those unknown bits
in future.
Although we have once again failed to do this at release, it is still
early days for Power8 so I think we can still slip this in and get away
with it.
commit dd023217e17e72b46fb4d49c7734c426938c3dba upstream.
The topology update code that updates the cpu node registration in sysfs
should not be called while in stop_machine(). The register/unregister
calls take a lock and may sleep.
This patch moves these calls outside of the call to stop_machine().
Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com>
spinning_secondaries
commit 8246aca7058f3f2c2ae503081777965cd8df7b90 upstream.
the smp_release_cpus is a normal funciton and called in normal environments,
but it calls the __initdata spinning_secondaries.
need modify spinning_secondaries to match smp_release_cpus.
the related warning:
(the linker report boot_paca.33377, but it should be spinning_secondaries)
WARNING: arch/powerpc/kernel/built-in.o(.text+0x23176): Section mismatch in reference from the function .smp_release_cpus() to the variable .init.data:boot_paca.33377
The function .smp_release_cpus() references
the variable __initdata boot_paca.33377.
This is often because .smp_release_cpus lacks a __initdata
annotation or the annotation of boot_paca.33377 is wrong.
WARNING: arch/powerpc/kernel/built-in.o(.text+0x231fe): Section mismatch in reference from the function .smp_release_cpus() to the variable .init.data:boot_paca.33377
Signed-off-by: Chen Gang <gang.chen@asianux.com>
commit b14b6260efeee6eb8942c6e6420e31281892acb6 upstream.
Similar to the facility unavailble exception, except the facilities are
controlled by HFSCR.
Adapt the facility_unavailable_exception() so it can be called for
either the regular or Hypervisor facility unavailable exceptions.
commit 021424a1fce335e05807fd770eb8e1da30a63eea upstream.
The exception at 0xf60 is not the TM (Transactional Memory) unavailable
exception, it is the "Facility Unavailable Exception", rename it as
such.
Flesh out the handler to acknowledge the fact that it can be called for
many reasons, one of which is TM being unavailable.
Use STD_EXCEPTION_COMMON() for the exception body, for some reason we
had it open-coded, I've checked the generated code is identical.
commit c9f69518e5f08170bc857984a077f693d63171df upstream.
KVMTEST is a macro which checks whether we are taking an exception from
guest context, if so we branch out of line and eventually call into the
KVM code to handle the switch.
When running real guests on bare metal (HV KVM) the hardware ensures
that we never take a relocation on exception when transitioning from
guest to host. For PR KVM we disable relocation on exceptions ourself in
kvmppc_core_init_vm(), as of commit a413f47 "Disable relocation on
exceptions whenever PR KVM is active".
So convert all the RELON macros to use NOTEST, and drop the remaining
KVM_HANDLER() definitions we have for 0xe40 and 0xe80.
