path: root/arch/ppc/kernel/ppc_ksyms.c
2008-06-10powerpc: Remove arch/ppc and include/asm-ppcPaul Mackerras
All the maintained platforms are now in arch/powerpc, so the old arch/ppc stuff can now go away. Acked-by: Adrian Bunk <bunk@kernel.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Becky Bruce <becky.bruce@freescale.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Jochen Friedrich <jochen@scram.de> Acked-by: John Linn <john.linn@xilinx.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Scott Wood <scottwood@freescale.com> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Acked-by: Segher Boessenkool <segher@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-31[POWERPC] Export empty_zero_page and copy_page in arch/ppcTony Breeds
Currently ext4 and fuse fail to link if modular: ERROR: "copy_page" [fs/fuse/fuse.ko] undefined! ERROR: "empty_zero_page" [fs/ext4/ext4dev.ko] undefined! make[3]: *** [__modpost] Error 1 make[2]: *** [modules] Error 2 make[1]: *** [sub-make] Error 2 While arch ppc exists it may as well compile, so this exports those symbols (which are already exported in arch/powerpc). Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-12[POWERPC] ppc: Include <asm/cacheflush.h> in kernel/ppc_ksyms.cSegher Boessenkool
It needs it: arch/ppc/kernel/ppc_ksyms.c:152: error: '__flush_icache_range' undeclared here (not in a function) and a few more like that. Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-30Basic braille screen reader supportSamuel Thibault
This adds a minimalistic braille screen reader support. This is meant to be used by blind people e.g. on boot failures or when / cannot be mounted etc and thus the userland screen readers can not work. [akpm@linux-foundation.org: fix exports] Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: Jiri Kosina <jikos@jikos.cz> Cc: Dmitry Torokhov <dtor@mail.ru> Acked-by: Alan Cox <alan@redhat.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24[POWERPC] Add strncmp to arch/ppcJosh Boyer
Commit 0119536cd314ef95553604208c25bc35581f7f0a added an assembly version of strncmp to PowerPC. However, it changed a common header file between arch/ppc and arch/powerpc without adding strncmp to arch/ppc. This fixes that omission so that arch/ppc links again. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-18ppc: remove ppc_ide_mdBartlomiej Zolnierkiewicz
* Add special cases for pplus and prep to ide_default_{irq,io_base}() (+ FIXMEs about the need to use IDE platform host driver instead). * Remove no longer needed ppc_ide_md and struct ide_machdep_calls. * Then remove <linux/ide.h> include from: - arch/powerpc/kernel/setup_32.c - arch/ppc/kernel/ppc_ksyms.c - arch/ppc/kernel/setup.c - arch/ppc/platforms/pplus.c - arch/ppc/platforms/prep_setup.c There should be no functional changes caused by this patch. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-28[PPC] Remove 85xx from arch/ppcKumar Gala
85xx exists in arch/powerpc as well as cuImage support to boot from a u-boot that doesn't support device trees. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[PPC] Remove 83xx from arch/ppcKumar Gala
83xx exists in arch/powerpc as well as cuImage support to boot from a u-boot that doesn't support device trees. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] CPM: Rename commproc to cpm1 and cpm2_common.c to cpm2.cJochen Friedrich
Rename commproc.[ch] to cpm1.[ch] to be more consistent with cpm2. Also rename cpm2_common.c to cpm2.c as suggested by Scott Wood. Adjust the includes accordingly. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-17[POWERPC] Remove APUS support from arch/ppcAdrian Bunk
Current status of APUS: - arch/powerpc/: removed in 2.6.23 - arch/ppc/: marked BROKEN since 2 years This therefore removes the remaining parts of APUS support from arch/ppc, include/asm-ppc, arch/powerpc and include/asm-powerpc. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-10[POWERPC] Remove unused do_signal exportChristoph Hellwig
do_signal is never used in modular code (obviously), and no other architecture exports it either. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-23[PPC] Remove duplicate export of __div64_32.Kumar Gala
We now get the export of __div64_32 from lib/div64.c and can drop the one in ppc_ksysm.c Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-26[STRING]: Move strcasecmp/strncasecmp to lib/string.cDavid S. Miller
We have several platforms using local copies of identical code. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-09[PPC] Fix compile error for e500 core based processorsRojhalat Ibrahim
We get the following compiler error: CC arch/ppc/kernel/ppc_ksyms.o arch/ppc/kernel/ppc_ksyms.c:275: error: '__mtdcr' undeclared here (not in a function) arch/ppc/kernel/ppc_ksyms.c:275: warning: type defaults to 'int' in declaration of '__mtdcr' arch/ppc/kernel/ppc_ksyms.c:276: error: '__mfdcr' undeclared here (not in a function) arch/ppc/kernel/ppc_ksyms.c:276: warning: type defaults to 'int' in declaration of '__mfdcr' make[1]: *** [arch/ppc/kernel/ppc_ksyms.o] Error 1 This is due to the EXPORT_SYMBOL for __mtdcr/__mfdcr not having the proper CONFIG protection Signed-off-by: Rojhalat Ibrahim <imr@rtschenk.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-02-07[POWERPC] Compile fixes for arch/powerpc dcr codeDavid Gibson
The new dcr code does not currently compile when configured for native DCR access on ARCH=powerpc. This patch fixes the problems. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-20[POWERPC] clean up ide io accessorsStephen Rothwell
2006-09-20[POWERPC] remove unused asm routinesStephen Rothwell
_insw, _outsw, _insl amd _outsl are all unused, so remove them. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2006-07-10[PATCH] tty: Remove include of screen_info.h from tty.hJon Smirl
screen_info.h doesn't have anything to do with the tty layer and shouldn't be included by tty.h. This patches removes the include and modifies all users to directly include screen_info.h. struct screen_info is mainly used to communicate with the console drivers in drivers/video/console. Note that this patch touches every arch and I have no way of testing it. If there is a mistake the worst thing that will happen is a compile error. [akpm@osdl.org: fix arm build] [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02powerpc/ppc: export strncasecmpKumar Gala
We have a strncasecmp so we might as well export it Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-03-28ppc: Remove CHRP, POWER3 and POWER4 support from arch/ppcPaul Mackerras
32-bit CHRP machines are now supported only in arch/powerpc, as are all 64-bit PowerPC processors. This means that we don't use Open Firmware on any platform in arch/ppc any more. This makes PReP support a single-platform option like every other platform support option in arch/ppc now, thus CONFIG_PPC_MULTIPLATFORM is gone from arch/ppc. CONFIG_PPC_PREP is the option that selects PReP support and is generally what has replaced CONFIG_PPC_MULTIPLATFORM within arch/ppc. _machine is all but dead now, being #defined to 0. Updated Makefiles, comments and Kconfig options generally to reflect these changes. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27ppc: Remove duplicate exports of __down, __up etc.Paul Mackerras
__down, __down_interruptible and __up are defined and exported in arch/powerpc/kernel/semaphore.c, and used from there for ARCH=ppc, so there is no need to export them in arch/ppc/kernel/ppc_ksyms.c. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-20[PATCH] powerpc: remove duplicate exportsOlaf Hering
A few symbols are exported twice, remove them from ppc_ksyms.c Remove users of sys_ctrler in arch/ppc/ WARNING: vmlinux: duplicate symbol '__delay' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol '__up' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol '__down' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol '__down_interruptible' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'sys_ctrler' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strncat' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strncmp' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strchr' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strrchr' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strnlen' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strpbrk' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'memscan' previous definition was in vmlinux WARNING: vmlinux: duplicate symbol 'strstr' previous definition was in vmlinux Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-07[PATCH] ppc: last_task_.... is defined only on non-SMPAl Viro
... so it should be exported only on non-SMP. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-01-15[PATCH] ppc: Remove powermac support from ARCH=ppcPaul Mackerras
This makes it possible to build kernels for PReP and/or CHRP with ARCH=ppc by removing the (non-building) powermac support. It's now also possible to select PReP and CHRP independently. Powermac users should now build with ARCH=powerpc instead of ARCH=ppc. (This does mean that it is no longer possible to build a 32-bit kernel for a G5.) Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-14ppc: Remove duplicate export of get_wchanPaul Mackerras
The arch/powerpc version of process.c exports get_wchan itself. When I moved ARCH=ppc over to using arch/powerpc/kernel/process.c the get_wchan export in arch/ppc/kernel/ppc_ksyms.c became redundant, so remove it. Signed-off-by: Paul Mackerras <paulus@samba.org> (cherry picked from 9871166ad692121d6b944159ef3f053570158ea8 commit)
2006-01-09[PATCH] spufs: The SPU file system, baseArnd Bergmann
This is the current version of the spu file system, used for driving SPEs on the Cell Broadband Engine. This release is almost identical to the version for the 2.6.14 kernel posted earlier, which is available as part of the Cell BE Linux distribution from http://www.bsc.es/projects/deepcomputing/linuxoncell/. The first patch provides all the interfaces for running spu application, but does not have any support for debugging SPU tasks or for scheduling. Both these functionalities are added in the subsequent patches. See Documentation/filesystems/spufs.txt on how to use spufs. Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] PPC_PREP: remove unneeded exportsAdrian Bunk
This patch removes the EXPORT_SYMBOL'ed but completely unused variable ucSystemType and removes the unneeded EXPORT_SYMBOL(_prep_type). Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Tom Rini <trini@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-29[PATCH] ppc: Export symbol needed by MOLOtavio Salvador
Export symbol needed to allow MOL to run. This was changed to be inline in past and forgot to be change here. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-10[PATCH] powerpc: merge code values for identifying platformsPaul Mackerras
This patch merges platform codes. systemcfg->platform is no longer used, systemcfg use in general is deprecated as much as possible (and renamed _systemcfg before it gets completely moved elsewhere in a future patch), _machine is now used on ppc64 along as ppc32. Platform codes aren't gone yet but we are getting a step closer. A bunch of asm code in head[_64].S is also turned into C code. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-10[PATCH] powerpc: Merge cacheflush.h and cache.hDavid Gibson
The ppc32 and ppc64 versions of cacheflush.h were almost identical. The two versions of cache.h are fairly similar, except for a bunch of register definitions in the ppc32 version which probably belong better elsewhere. This patch, therefore, merges both headers. Notable points: - there are several functions in cacheflush.h which exist only on ppc32 or only on ppc64. These are handled by #ifdef for now, but these should probably be consolidated, along with the actual code behind them later. - Confusingly, both ppc32 and ppc64 have a flush_dcache_range(), but they're subtly different: it uses dcbf on ppc32 and dcbst on ppc64, ppc64 has a flush_inval_dcache_range() which uses dcbf. These too should be merged and consolidated later. - Also flush_dcache_range() was defined in cacheflush.h on ppc64, and in cache.h on ppc32. In the merged version it's in cacheflush.h - On ppc32 flush_icache_range() is a normal function from misc.S. On ppc64, it was wrapper, testing a feature bit before calling __flush_icache_range() which does the actual flush. This patch takes the ppc64 approach, which amounts to no change on ppc32, since CPU_FTR_COHERENT_ICACHE will never be set there, but does mean renaming flush_icache_range() to __flush_icache_range() in arch/ppc/kernel/misc.S and arch/powerpc/kernel/misc_32.S - The PReP register info from asm-ppc/cache.h has moved to arch/ppc/platforms/prep_setup.c - The 8xx register info from asm-ppc/cache.h has moved to a new asm-powerpc/reg_8xx.h, included from reg.h - flush_dcache_all() was defined on ppc32 (only), but was never called (although it was exported). Thus this patch removes it from cacheflush.h and from ARCH=powerpc (misc_32.S) entirely. It's left in ARCH=ppc for now, with the prototype moved to ppc_ksyms.c. Built for Walnut (ARCH=ppc), 32-bit multiplatform (pmac, CHRP and PReP ARCH=ppc, pmac and CHRP ARCH=powerpc). Built and booted on POWER5 LPAR (ARCH=powerpc and ARCH=ppc64). Built for 32-bit powermac (ARCH=ppc and ARCH=powerpc). Built and booted on POWER5 LPAR (ARCH=powerpc and ARCH=ppc64). Built and booted on G5 (ARCH=powerpc) Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-10Merge git://oak/home/sfr/kernels/iseries/workPaul Mackerras
2005-11-10[PATCH] powerpc: Merge signal.hDavid Gibson
Having already merged the ppc and ppc64 versions of signal.c, this patch finishes the job by merging signal.h. The two versions were almost identical already. Notable changes: - We use BITS_PER_LONG to correctly size sigset_t - Remove some uneeded #includes and struct forward declarations. This does mean adding an include to signal_32.c which relied on the indirect inclusion of sigcontext.h - As the ppc64 version, the merged signal.h has prototypes for do_signal() and do_signal32(). Thus remove extra prototypes from ppc_ksyms.c which had them directly. Built and booted on POWER5 LPAR (ARCH=ppc64 and ARCH=powerpc). Built for 32-bit powermac (ARCH=ppc and ARCH=powerpc) and Walnut (ARCH=ppc). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-09powerpc: merge irq.cStephen Rothwell
2005-11-03[PATCH] ppc32 8xx: export symbols required for modular IDEMarcelo Tosatti
This fixes these warnings: Building modules, stage 2. MODPOST *** Warning: "__ide_mm_insl" [drivers/ide/ide-core.ko] undefined! *** Warning: "__ide_mm_outsw" [drivers/ide/ide-core.ko] undefined! *** Warning: "__ide_mm_insw" [drivers/ide/ide-core.ko] undefined! *** Warning: "__ide_mm_outsl" [drivers/ide/ide-core.ko] undefined! Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-31ppc: remove duplicate export of cur_cpu_specPaul Mackerras
2005-10-22powerpc: Move agp_special_page export to where it is definedPaul Mackerras
... instead of exporting it in arch/*/kernel/ppc_ksyms.c. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-04ppc32: export a few more things where they are definedPaul Mackerras
... and remove the exports from ppc_ksyms.c. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-01powerpc: merge idle_power4.S and trapc.sStephen Rothwell
Use idle_power4.S from ppc64 as we are not going to support 32 bit power4 in the merged tree. Merge ppc64 traps.c into powerpc traps.c: use ppc64 versions of exception routine names (as they don't have StudlyCaps) make all the versions if die() have the same prototype Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2005-09-19[PATCH] ppc32: Removed non-inlined versions of local_irq* functionsKumar Gala
We always use the inlined versions of local_irq_enable, local_irq_disable, local_save_flags_ptr, and local_irq_restore on ppc32 so the non-inlined versions where just taking up space. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-05[PATCH] ppc32: export cacheable_memcpy()Eugene Surovegin
Add declaration and cacheable_memcpy(). I'll be needing this function in new 4xx EMAC driver I'm going to submit to netdev soon. IMHO, the better place for the declaration would be asm-powerpc/string.h, unfortunately, ppc64 doesn't have this function, so asm-ppc/system.h is the next best place. Signed-off-by: Eugene Surovegin <ebs@ebshome.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] arch/ppc/kernel/ppc_ksyms.c: remove unused #define EXPORT_SYMTAB_STROPSAdrian Bunk
This #define is only used on sparc. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-06ppc: Export __handle_mm_fault for MOLLinus Torvalds
When we did the handle_mm_fault cleanup and get_user_page() race fixes, handle_mm_fault turned into an inline function that called the real __handle_mm_fault() code. The export needed for MOL on ppc wasn't updated to match the new world order, though. Turn it into a GPL export while at it, since this is all about internal interfaces and MOL is GPL'd anwyay.
2005-05-08Add CONFIG_AUDITSC and CONFIG_SECCOMP support for ppc32David Woodhouse
