[ Upstream commit dbee9c9c45846f003ec2f819710c2f4835630a6a ]
A memory save operation to 8-byte variable in RV32 is divided into
two sw instructions in the put_user macro. The current fixup returns
execution flow to the second sw instead of the one after it.
This patch fixes this fixup code according to the load access part.
Signed-off-by: Alan Kao<alankao@andestech.com>
Cc: Greentime Hu <greentime@andestech.com>
Cc: Vincent Chen <deanbo422@gmail.com>
Signed-off-by: Palmer Dabbelt <palmer@sifive.com>
Signed-off-by: Sasha Levin (Microsoft) <sashal@kernel.org>
commit 10a16997db3d99fc02c026cf2c6e6c670acafab0 upstream.
RISC-V syscall arguments are located in orig_a0,a1..a5 fields
of struct pt_regs.
Due to an off-by-one bug and a bug in pointer arithmetic
syscall_get_arguments() was reading s3..s7 fields instead of a1..a5.
Likewise, syscall_set_arguments() was writing s3..s7 fields
instead of a1..a5.
Link: http://lkml.kernel.org/r/20190329171221.GA32456@altlinux.org
Fixes: e2c0cdfba7f69 ("RISC-V: User-facing API")
Cc: Will Drewry <wad@chromium.org>
Cc: Albert Ou <aou@eecs.berkeley.edu>
Cc: linux-riscv@lists.infradead.org
Cc: stable@vger.kernel.org # v4.15+
Acked-by: Palmer Dabbelt <palmer@sifive.com>
Signed-off-by: Dmitry V. Levin <ldv@altlinux.org>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
At least BBL relies on the flat binaries containing all the bytes in the
actual image to exist in the file. Before this revert the flat images
dropped the trailing zeros, which caused BBL to put its copy of the
device tree where Linux thought the BSS was, which wreaks all sorts of
havoc. Manifesting the bug is a bit subtle because BBL aligns
everything to 2MiB page boundaries, but with large enough kernels you're
almost certain to get bitten by the bug.
While moving the sections around isn't a great long-term fix, it will at
least avoid producing broken images.
This reverts commit 22e6a2e14cb8ebcae059488cf24e778e4058c2bf.
Previously, invalid PTEs and swap PTEs had the same binary
representation, causing errors when attempting to unmap PROT_NONE
mappings, including implicit unmap on exit.
Typical error:
swap_info_get: Bad swap file entry 40000000007a9879
BUG: Bad page map in process a.out pte:3d4c3cc0 pmd:3e521401
Signed-off-by: Stefan O'Rear <sorear2@gmail.com>
This ratio is the most used among all other architectures and make
icache_hygiene libhugetlbfs test pass: this test mmap lots of
hugepages whose addresses, without this patch, reach the end of
the process user address space.
Signed-off-by: Alexandre Ghiti <aghiti@upmem.com>
max_low_pfn should be pfn_size not byte_size.
Signed-off-by: Guo Ren <ren_guo@c-sky.com>
Signed-off-by: Mao Han <mao_han@c-sky.com>
This allows acceleration of cryptography inside QEMU.
Enable generic PCIe by default in the RISC-V defconfig, this allows us
to use QEMU's PCIe support out of the box. CONFIG_RAS=y is
automatically selected by generic PCIe, so it has been dropped from
the defconfig.
Signed-off-by: Alistair Francis <alistair.francis@wdc.com>
[Palmer: Split out PCIE_XILINX and CRYPTO_DEV_VIRTIO]
eb01d42a7778 ("PCI: consolidate PCI config entry in drivers/pci")
reorganized the PCI-related Kconfig entries and resulted in a diff in
our defconfig. This simply removes the diff.
Signed-off-by: Antony Pavlov <antonynpavlov@gmail.com>
There is no CONFIG_64BITS Kconfig macro.
Please see arch/riscv/Kconfig for details, e.g.
linux$ git grep -HnA 1 "config 64BIT" arch/riscv/Kconfig
arch/riscv/Kconfig:6:config 64BIT
arch/riscv/Kconfig-7- bool
of_find_node_by_type already calls of_node_put, don't call it again.
Fixes: 94f9bf118f ("RISC-V: Fix of_node_* refcount")
Signed-off-by: Andreas Schwab <schwab@suse.de>
Reviewed-by: Atish Patra <atish.patra@wdc.com>
The cond_resched() can be used to yield the CPU resource if
CONFIG_PREEMPT is not defined. Otherwise, cond_resched() is a dummy
function. In order to avoid kernel thread occupying entire CPU,
when CONFIG_PREEMPT=y, the kernel thread needs to follow the
rescheduling mechanism like a user thread.
Signed-off-by: Vincent Chen <vincentc@andestech.com>
Tested-by: Guenter Roeck <linux@roeck-us.net>
This is sort of a mix between a new feature and a bug fix. I've managed
to screw up merging this patch set a handful of times but I think it's
OK this time around. The main new feature here is audit support for
RISC-V, with some fixes to audit-related bugs that cropped up along the
way:
* The addition of NR_syscalls into unistd.h, which is necessary for
CONFIG_FTRACE_SYSCALLS.
* The definition of CREATE_TRACE_POINTS so
__tracepoint_sys_{enter,exit} get defined.
* A fix for trace_sys_exit() so we can enable
CONFIG_HAVE_SYSCALL_TRACEPOINTS.
I looked into Documentation/trace/ftrace-design.rst and, I think,
we check all the boxes needed for HAVE_SYSCALL_TRACEPOINTS.
Signed-off-by: David Abdurachmanov <david.abdurachmanov@gmail.com>
Fix compilation error.
Define CREATE_TRACE_POINTS in order to create functions and structures
for the trace events. This is needed if HAVE_SYSCALL_TRACEPOINTS and
CONFIG_FTRACE_SYSCALLS are enabled, otherwise we get linking errors:
MODPOST vmlinux.o
kernel/trace/trace_syscalls.o: In function `.L0 ':
trace_syscalls.c:(.text+0x1152): undefined reference to `__tracepoint_sys_enter'
trace_syscalls.c:(.text+0x126c): undefined reference to `__tracepoint_sys_enter'
trace_syscalls.c:(.text+0x1328): undefined reference to `__tracepoint_sys_enter'
trace_syscalls.c:(.text+0x14aa): undefined reference to `__tracepoint_sys_enter'
trace_syscalls.c:(.text+0x1684): undefined reference to `__tracepoint_sys_exit'
trace_syscalls.c:(.text+0x17a0): undefined reference to `__tracepoint_sys_exit'
trace_syscalls.c:(.text+0x185c): undefined reference to `__tracepoint_sys_exit'
trace_syscalls.c:(.text+0x19de): undefined reference to `__tracepoint_sys_exit'
arch/riscv/kernel/ptrace.o: In function `.L0 ':
ptrace.c:(.text+0x4dc): undefined reference to `__tracepoint_sys_enter'
ptrace.c:(.text+0x632): undefined reference to `__tracepoint_sys_exit'
make: *** [Makefile:1036: vmlinux] Error 1
Fixes: b78002b395b4 ("riscv: add HAVE_SYSCALL_TRACEPOINTS to Kconfig")
This macro is used by kernel/trace/{trace.h,trace_syscalls.c} if we
have CONFIG_FTRACE_SYSCALLS enabled.
This patch adds auditing functions on entry to and exit from every system
call invocation.
On RISC-V (riscv) audit is supported through generic lib/audit.c.
The patch adds required arch specific definitions.
This patch supports dynamic generate got and plt sections mechanism on
rv32. It contains the modification as follows:
- Always enable MODULE_SECTIONS (both rv64 and rv32)
- Change the fixed size type.
This patch had been tested by following modules:
btrfs 6795991 0 - Live 0xa544b000
test_static_keys 17304 0 - Live 0xa28be000
zstd_compress 1198986 1 btrfs, Live 0xa2a25000
zstd_decompress 608112 1 btrfs, Live 0xa24e7000
lzo 8787 0 - Live 0xa2049000
xor 27461 1 btrfs, Live 0xa2041000
zram 78849 0 - Live 0xa2276000
netdevsim 55909 0 - Live 0xa202d000
tun 211534 0 - Live 0xa21b5000
fuse 566049 0 - Live 0xa25fb000
nfs_layout_flexfiles 192597 0 - Live 0xa229b000
ramoops 74895 0 - Live 0xa2019000
xfs 3973221 0 - Live 0xa507f000
libcrc32c 3053 2 btrfs,xfs, Live 0xa34af000
lzo_compress 17302 2 btrfs,lzo, Live 0xa347d000
lzo_decompress 7178 2 btrfs,lzo, Live 0xa3451000
raid6_pq 142086 1 btrfs, Live 0xa33a4000
reed_solomon 31022 1 ramoops, Live 0xa31eb000
test_bitmap 3734 0 - Live 0xa31af000
test_bpf 1588736 0 - Live 0xa2c11000
test_kmod 41161 0 - Live 0xa29f8000
test_module 1356 0 - Live 0xa299e000
test_printf 6024 0 [permanent], Live 0xa2971000
test_static_key_base 5797 1 test_static_keys, Live 0xa2931000
test_user_copy 4382 0 - Live 0xa28c9000
xxhash 70501 2 zstd_compress,zstd_decompress, Live 0xa2055000
Signed-off-by: Zong Li <zong@andestech.com>
Add IPI_CPU_STOP message and use it in smp_send_stop to stop other cpus,
but not itself. Mark cpu offline on reception of IPI_CPU_STOP.
CONFIG_CMDLINE_FORCE doesn't work on RISC-V when no DTB is passed into
the kernel. This is because the code that forces the kernel command
line only runs if a valid DTB is present at boot. During debugging,
it's useful to have the ability to force kernel command lines even
when no DTB is present. This patch adds support for doing so.
Cc: Palmer Dabbelt <palmer@sifive.com>
Cc: linux-kernel@vger.kernel.org (open list)
Signed-off-by: Paul Walmsley <paul.walmsley@sifive.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
The objcopy only emits loadable sections when creating flat kernel
Image. To have minimal possible size of flat kernel Image, we should
have all non-loadable sections after loadable sections.
Currently, execption table section (loadable section) is after BSS
section (non-loadable section) in the RISC-V vmlinux.lds.S. This
is not optimal for having minimal flat kernel Image size hence this
patch makes BSS section as the last section in RISC-V vmlinux.lds.S.
In addition, we make BSS section aligned to 16byte instead of PAGE
aligned which further reduces flat kernel Image size by few KBs.
The flat kernel Image size of Linux-4.20-rc4 using GCC 8.2.0 is
8819980 bytes with current RISC-V vmlinux.lds.S and it reduces to
7991740 bytes with this patch applied. In summary, this patch reduces
Linux-4.20-rc4 flat kernel Image size by 809 KB.
Signed-off-by: Anup Patel <anup@brainfault.org>
Now that Kbuild automatically creates asm-generic wrappers for missing
mandatory headers, it is redundant to list the same headers in
generic-y and mandatory-y.
Suggested-by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
These comments are leftovers of commit fcc8487d477a ("uapi: export all
headers under uapi directories").
Prior to that commit, exported headers must be explicitly added to
header-y. Now, all headers under the uapi/ directories are exported.
This commit removes redundant generic-y defines in
arch/riscv/include/asm/Kbuild.
[1] It is redundant to define the same generic-y in both
arch/$(ARCH)/include/asm/Kbuild and
arch/$(ARCH)/include/uapi/asm/Kbuild.
Remove the following generic-y:
errno.h
fcntl.h
ioctl.h
ioctls.h
ipcbuf.h
mman.h
msgbuf.h
param.h
poll.h
posix_types.h
resource.h
sembuf.h
setup.h
shmbuf.h
signal.h
socket.h
sockios.h
stat.h
statfs.h
swab.h
termbits.h
termios.h
types.h
[2] It is redundant to define generic-y when arch-specific
implementation exists in arch/$(ARCH)/include/asm/*.h
cacheflush.h
module.h
Merge more updates from Andrew Morton:
- procfs updates
- various misc bits
- lib/ updates
- epoll updates
- autofs
- fatfs
- a few more MM bits
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (58 commits)
mm/page_io.c: fix polled swap page in
checkpatch: add Co-developed-by to signature tags
docs: fix Co-Developed-by docs
drivers/base/platform.c: kmemleak ignore a known leak
fs: don't open code lru_to_page()
fs/: remove caller signal_pending branch predictions
mm/: remove caller signal_pending branch predictions
arch/arc/mm/fault.c: remove caller signal_pending_branch predictions
kernel/sched/: remove caller signal_pending branch predictions
kernel/locking/mutex.c: remove caller signal_pending branch predictions
mm: select HAVE_MOVE_PMD on x86 for faster mremap
mm: speed up mremap by 20x on large regions
mm: treewide: remove unused address argument from pte_alloc functions
initramfs: cleanup incomplete rootfs
scripts/gdb: fix lx-version string output
kernel/kcov.c: mark write_comp_data() as notrace
kernel/sysctl: add panic_print into sysctl
panic: add options to print system info when panic happens
bfs: extra sanity checking and static inode bitmap
exec: separate MM_ANONPAGES and RLIMIT_STACK accounting
Patch series "Add support for fast mremap".
This series speeds up the mremap(2) syscall by copying page tables at
the PMD level even for non-THP systems. There is concern that the extra
'address' argument that mremap passes to pte_alloc may do something
subtle architecture related in the future that may make the scheme not
work. Also we find that there is no point in passing the 'address' to
pte_alloc since its unused. This patch therefore removes this argument
tree-wide resulting in a nice negative diff as well. Also ensuring
along the way that the enabled architectures do not do anything funky
with the 'address' argument that goes unnoticed by the optimization.
Build and boot tested on x86-64. Build tested on arm64. The config
enablement patch for arm64 will be posted in the future after more
testing.
The changes were obtained by applying the following Coccinelle script.
(thanks Julia for answering all Coccinelle questions!).
Following fix ups were done manually:
* Removal of address argument from pte_fragment_alloc
* Removal of pte_alloc_one_fast definitions from m68k and microblaze.
// Options: --include-headers --no-includes
// Note: I split the 'identifier fn' line, so if you are manually
// running it, please unsplit it so it runs for you.
virtual patch
@pte_alloc_func_def depends on patch exists@
identifier E2;
identifier fn =~
"^(__pte_alloc|pte_alloc_one|pte_alloc|__pte_alloc_kernel|pte_alloc_one_kernel)$";
type T2;
fn(...
- , T2 E2
@pte_alloc_func_proto_noarg depends on patch exists@
type T1, T2, T3, T4;
identifier fn =~ "^(__pte_alloc|pte_alloc_one|pte_alloc|__pte_alloc_kernel|pte_alloc_one_kernel)$";
- T3 fn(T1, T2);
+ T3 fn(T1);
- T3 fn(T1, T2, T4);
+ T3 fn(T1, T2);
@pte_alloc_func_proto depends on patch exists@
identifier E1, E2, E4;
identifier fn =~
- T3 fn(T1 E1, T2 E2);
+ T3 fn(T1 E1);
- T3 fn(T1 E1, T2 E2, T4 E4);
+ T3 fn(T1 E1, T2 E2);
@pte_alloc_func_call depends on patch exists@
expression E2;
identifier fn =~
fn(...
-, E2
@pte_alloc_macro depends on patch exists@
identifier fn =~
identifier a, b, c;
expression e;
position p;
- #define fn(a, b, c) e
+ #define fn(a, b) e
- #define fn(a, b) e
+ #define fn(a) e
Link: http://lkml.kernel.org/r/20181108181201.88826-2-joelaf@google.com
Signed-off-by: Joel Fernandes (Google) <joel@joelfernandes.org>
Suggested-by: Kirill A. Shutemov <kirill@shutemov.name>
Acked-by: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Kirill A. Shutemov <kirill@shutemov.name>
Cc: William Kucharski <william.kucharski@oracle.com>
Nobody has actually used the type (VERIFY_READ vs VERIFY_WRITE) argument
of the user address range verification function since we got rid of the
old racy i386-only code to walk page tables by hand.
It existed because the original 80386 would not honor the write protect
bit when in kernel mode, so you had to do COW by hand before doing any
user access. But we haven't supported that in a long time, and these
days the 'type' argument is a purely historical artifact.
A discussion about extending 'user_access_begin()' to do the range
checking resulted this patch, because there is no way we're going to
move the old VERIFY_xyz interface to that model. And it's best done at
the end of the merge window when I've done most of my merges, so let's
just get this done once and for all.
This patch was mostly done with a sed-script, with manual fix-ups for
the cases that weren't of the trivial 'access_ok(VERIFY_xyz' form.
There were a couple of notable cases:
- csky still had the old "verify_area()" name as an alias.
- the iter_iov code had magical hardcoded knowledge of the actual
values of VERIFY_{READ,WRITE} (not that they mattered, since nothing
really used it)
- microblaze used the type argument for a debug printout
but other than those oddities this should be a total no-op patch.
I tried to fix up all architectures, did fairly extensive grepping for
access_ok() uses, and the changes are trivial, but I may have missed
something. Any missed conversion should be trivially fixable, though.
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull Kconfig file consolidation from Masahiro Yamada:
"Consolidation of bus (PCI, PCMCIA, EISA, RapidIO) config entries by
Christoph Hellwig.
Currently, every architecture that wants to provide common peripheral
busses needs to add some boilerplate code and include the right
Kconfig files. This series instead just selects the presence (when
needed) and then handles everything in the bus-specific Kconfig file
under drivers/"
* tag 'kconfig-v4.21-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
pcmcia: remove per-arch PCMCIA config entry
eisa: consolidate EISA Kconfig entry in drivers/eisa
rapidio: consolidate RAPIDIO config entry in drivers/rapidio
pcmcia: allow PCMCIA support independent of the architecture
PCI: consolidate the PCI_SYSCALL symbol
PCI: consolidate the PCI_DOMAINS and PCI_DOMAINS_GENERIC config options
MIPS: remove the HT_PCI config option
Pull Kconfig updates from Masahiro Yamada:
- support -y option for merge_config.sh to avoid downgrading =y to =m
- remove S_OTHER symbol type, and touch include/config/*.h files correctly
- fix file name and line number in lexer warnings
- fix memory leak when EOF is encountered in quotation
- resolve all shift/reduce conflicts of the parser
- warn no new line at end of file
- make 'source' statement more strict to take only string literal
- rewrite the lexer and remove the keyword lookup table
- convert to SPDX License Identifier
- compile C files independently instead of including them from zconf.y
- fix various warnings of gconfig
- misc cleanups
* tag 'kconfig-v4.21' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (39 commits)
kconfig: surround dbg_sym_flags with #ifdef DEBUG to fix gconf warning
kconfig: split images.c out of qconf.cc/gconf.c to fix gconf warnings
kconfig: add static qualifiers to fix gconf warnings
kconfig: split the lexer out of zconf.y
kconfig: split some C files out of zconf.y
kconfig: convert to SPDX License Identifier
kconfig: remove keyword lookup table entirely
kconfig: update current_pos in the second lexer
kconfig: switch to ASSIGN_VAL state in the second lexer
kconfig: stop associating kconf_id with yylval
kconfig: refactor end token rules
kconfig: stop supporting '.' and '/' in unquoted words
treewide: surround Kconfig file paths with double quotes
microblaze: surround string default in Kconfig with double quotes
kconfig: use T_WORD instead of T_VARIABLE for variables
kconfig: use specific tokens instead of T_ASSIGN for assignments
kconfig: refactor scanning and parsing "option" properties
kconfig: use distinct tokens for type and default properties
kconfig: remove redundant token defines
kconfig: rename depends_list to comment_option_list
Pull DMA mapping updates from Christoph Hellwig:
"A huge update this time, but a lot of that is just consolidating or
removing code:
- provide a common DMA_MAPPING_ERROR definition and avoid indirect
calls for dma_map_* error checking
- use direct calls for the DMA direct mapping case, avoiding huge
retpoline overhead for high performance workloads
- merge the swiotlb dma_map_ops into dma-direct
- provide a generic remapping DMA consistent allocator for
architectures that have devices that perform DMA that is not cache
coherent. Based on the existing arm64 implementation and also used
for csky now.
- improve the dma-debug infrastructure, including dynamic allocation
of entries (Robin Murphy)
- default to providing chaining scatterlist everywhere, with opt-outs
for the few architectures (alpha, parisc, most arm32 variants) that
can't cope with it
- misc sparc32 dma-related cleanups
- remove the dma_mark_clean arch hook used by swiotlb on ia64 and
replace it with the generic noncoherent infrastructure
- fix the return type of dma_set_max_seg_size (Niklas Söderlund)
- move the dummy dma ops for not DMA capable devices from arm64 to
common code (Robin Murphy)
- ensure dma_alloc_coherent returns zeroed memory to avoid kernel
data leaks through userspace. We already did this for most common
architectures, but this ensures we do it everywhere.
dma_zalloc_coherent has been deprecated and can hopefully be
removed after -rc1 with a coccinelle script"
* tag 'dma-mapping-4.21' of git://git.infradead.org/users/hch/dma-mapping: (73 commits)
dma-mapping: fix inverted logic in dma_supported
dma-mapping: deprecate dma_zalloc_coherent
dma-mapping: zero memory returned from dma_alloc_*
sparc/iommu: fix ->map_sg return value
sparc/io-unit: fix ->map_sg return value
arm64: default to the direct mapping in get_arch_dma_ops
PCI: Remove unused attr variable in pci_dma_configure
ia64: only select ARCH_HAS_DMA_COHERENT_TO_PFN if swiotlb is enabled
dma-mapping: bypass indirect calls for dma-direct
vmd: use the proper dma_* APIs instead of direct methods calls
dma-direct: merge swiotlb_dma_ops into the dma_direct code
dma-direct: use dma_direct_map_page to implement dma_direct_map_sg
dma-direct: improve addressability error reporting
swiotlb: remove dma_mark_clean
swiotlb: remove SWIOTLB_MAP_ERROR
ACPI / scan: Refactor _CCA enforcement
dma-mapping: factor out dummy DMA ops
dma-mapping: always build the direct mapping code
dma-mapping: move dma_cache_sync out of line
dma-mapping: move various slow path functions out of line
The riscv_timer driver can provide sched_clock using "rdtime"
instruction but to achieve this we require generic sched_clock
framework hence this patch selects GENERIC_SCHED_CLOCK for RISCV.
Reviewed-by: Palmer Dabbelt <palmer@sifive.com>
Fix tab/space conversion and use ENTRY/ENDPROC macros.
Now that we have earlycon support in the SBI console driver there is no
reason to have our arch-specific early printk support. This patch set
turns on SBI earlycon support and removes the old early printk.
Added a menu to choose how the built-in command line will be
used and CMDLINE_EXTEND for compatibility with FDT code.
v2: Improved help messages, removed references to bootloader
and made them more descriptive. I also asked help from a
friend who's a language expert just in case.
v3: This time used the corrected text
v4: Copy the config strings from the arm32 port.
v5: Actually copy the config strings from the arm32 port.
Signed-off-by: Nick Kossifidis <mick@ics.forth.gr>
Signed-off-by: Debbie Maliotaki <dmaliotaki@gmail.com>
Noticed while building kernel-4.20.0-0.rc5.git2.1.fc30 for
Fedora 30/RISCV.
BUILDSTDERR: arch/riscv/kernel/ftrace.c: In function 'prepare_ftrace_return':
BUILDSTDERR: arch/riscv/kernel/ftrace.c:135:6: warning: unused variable 'err' [-Wunused-variable]
BUILDSTDERR: int err;
BUILDSTDERR: ^~~
Fixes: e949b6db51dc1 ("riscv/function_graph: Simplify with function_graph_enter()")
Reviewed-by: Olof Johansson <olof@lixom.net>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
use of_node_put() to release the refcount.
Signed-off-by: Yangtao Li <tiny.windzz@gmail.com>
Fix of_node* refcount at various places by using of_node_put.
Signed-off-by: Atish Patra <atish.patra@wdc.com>
If an architecture does not define the atomic_{cmp,}xchg_*() variants,
the generic implementation defaults them to the fully-ordered version.
riscv's had its own variants since "the beginning", but it never told
(#define-d these for) the generic implementation: it is time to do so.
Signed-off-by: Andrea Parri <andrea.parri@amarulasolutions.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
The Kconfig lexer supports special characters such as '.' and '/' in
the parameter context. In my understanding, the reason is just to
support bare file paths in the source statement.
I do not see a good reason to complicate Kconfig for the room of
ambiguity.
The majority of code already surrounds file paths with double quotes,
and it makes sense since file paths are constant string literals.
Make it treewide consistent now.
Acked-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
The EARLY_PRINTK using SBI console calls is not required
any more because we now have RISC-V SBI support in generic
earlycon framework.
This patch enables RISC-V SBI earlycon support in default defconfig
so that we can use "earlycon=sbi" in kernel parameters for early
debug prints.
While the dma-direct code is (relatively) clean and simple we actually
have to use the swiotlb ops for the mapping on many architectures due
to devices with addressing limits. Instead of keeping two
implementations around this commit allows the dma-direct
implementation to call the swiotlb bounce buffering functions and
thus share the guts of the mapping implementation. This also
simplified the dma-mapping setup on a few architectures where we
don't have to differenciate which implementation to use.
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
Tested-by: Jesper Dangaard Brouer <brouer@redhat.com>
Tested-by: Tony Luck <tony.luck@intel.com>
All architectures except for sparc64 use the dma-direct code in some
form, and even for sparc64 we had the discussion of a direct mapping
mode a while ago. In preparation for directly calling the direct
mapping code don't bother having it optionally but always build the
code in. This is a minor hardship for some powerpc and arm configs
that don't pull it in yet (although they should in a relase ot two),
and sparc64 which currently doesn't need it at all, but it will
reduce the ifdef mess we'd otherwise need significantly.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing fixes from Steven Rostedt:
"While rewriting the function graph tracer, I discovered a design flaw
that was introduced by a patch that tried to fix one bug, but by doing
so created another bug.
As both bugs corrupt the output (but they do not crash the kernel), I
decided to fix the design such that it could have both bugs fixed. The
original fix, fixed time reporting of the function graph tracer when
doing a max_depth of one. This was code that can test how much the
kernel interferes with userspace. But in doing so, it could corrupt
the time keeping of the function profiler.
The issue is that the curr_ret_stack variable was being used for two
different meanings. One was to keep track of the stack pointer on the
ret_stack (shadow stack used by the function graph tracer), and the
other use case was the graph call depth. Although, the two may be
closely related, where they got updated was the issue that lead to the
two different bugs that required the two use cases to be updated
differently.
The big issue with this fix is that it requires changing each
architecture. The good news is, I was able to remove a lot of code
that was duplicated within the architectures and place it into a
single location. Then I could make the fix in one place.
I pushed this code into linux-next to let it settle over a week, and
before doing so, I cross compiled all the affected architectures to
make sure that they built fine.
In the mean time, I also pulled in a patch that fixes the sched_switch
previous tasks state output, that was not actually correct"
* tag 'trace-v4.20-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
sched, trace: Fix prev_state output in sched_switch tracepoint
function_graph: Have profiler use curr_ret_stack and not depth
function_graph: Reverse the order of pushing the ret_stack and the callback
function_graph: Move return callback before update of curr_ret_stack
function_graph: Use new curr_ret_depth to manage depth instead of curr_ret_stack
function_graph: Make ftrace_push_return_trace() static
sparc/function_graph: Simplify with function_graph_enter()
sh/function_graph: Simplify with function_graph_enter()
s390/function_graph: Simplify with function_graph_enter()
powerpc/function_graph: Simplify with function_graph_enter()
parisc: function_graph: Simplify with function_graph_enter()
nds32: function_graph: Simplify with function_graph_enter()
MIPS: function_graph: Simplify with function_graph_enter()
microblaze: function_graph: Simplify with function_graph_enter()
arm64: function_graph: Simplify with function_graph_enter()
ARM: function_graph: Simplify with function_graph_enter()
x86/function_graph: Simplify with function_graph_enter()
function_graph: Create function_graph_enter() to consolidate architecture code
The function_graph_enter() function does the work of calling the function
graph hook function and the management of the shadow stack, simplifying the
work done in the architecture dependent prepare_ftrace_return().
Have riscv use the new code, and remove the shadow stack management as well as
having to set up the trace structure.
This is needed to prepare for a fix of a design bug on how the curr_ret_stack
is used.
Cc: Alan Kao <alankao@andestech.com>
Cc: stable@kernel.org
Fixes: 03274a3ffb449 ("tracing/fgraph: Adjust fgraph depth before calling trace return callback")
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Move the definitions to drivers/pci and let the architectures select
them. Two small differences to before: PCI_DOMAINS_GENERIC now selects
PCI_DOMAINS, cutting down the churn for modern architectures. As the
only architectured arm did previously also offer PCI_DOMAINS as a user
visible choice in addition to selecting it from the relevant configs,
this is gone now.
Acked-by: Paul Burton <paul.burton@mips.com>
There is no good reason to duplicate the PCI menu in every architecture.
Instead provide a selectable HAVE_PCI symbol that indicates availability
of PCI support, and a FORCE_PCI symbol to for PCI on and the handle the
rest in drivers/pci.
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
