path: root/arch/s390/Kconfig.debug
2016-01-09arch: consolidate CONFIG_STRICT_DEVM in lib/Kconfig.debugDan Williams
Let all the archs that implement devmem_is_allowed() opt-in to a common definition of CONFIG_STRICT_DEVM in lib/Kconfig.debug. Cc: Kees Cook <keescook@chromium.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [heiko: drop 'default y' for s390] Acked-by: Ingo Molnar <mingo@redhat.com> Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-04-30Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKSStephen Boyd
The help text for this config is duplicated across the x86, parisc, and s390 Kconfig.debug files. Arnd Bergman noted that the help text was slightly misleading and should be fixed to state that enabling this option isn't a problem when using pre 4.4 gcc. To simplify the rewording, consolidate the text into lib/Kconfig.debug and modify it there to be more explicit about when you should say N to this config. Also, make the text a bit more generic by stating that this option enables compile time checks so we can cover architectures which emit warnings vs. ones which emit errors. The details of how an architecture decided to implement the checks isn't as important as the concept of compile time checking of copy_from_user() calls. While we're doing this, remove all the copy_from_user_overflow() code that's duplicated many times and place it into lib/ so that any architecture supporting this option can get the function for free. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Helge Deller <deller@gmx.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09s390/mm: add page table dumperHeiko Carstens
This is more or less the same as the x86 page table dumper which was merged four years ago: 926e5392 "x86: add code to dump the (kernel) page tables for visual inspection by kernel developers". We add a file at /sys/kernel/debug/kernel_page_tables for debugging purposes so it's quite easy to see the kernel page table layout and possible odd mappings: ---[ Identity Mapping ]--- 0x0000000000000000-0x0000000000100000 1M PTE RW ---[ Kernel Image Start ]--- 0x0000000000100000-0x0000000000800000 7M PMD RO 0x0000000000800000-0x00000000008a9000 676K PTE RO 0x00000000008a9000-0x0000000000900000 348K PTE RW 0x0000000000900000-0x0000000001500000 12M PMD RW ---[ Kernel Image End ]--- 0x0000000001500000-0x0000000280000000 10219M PMD RW 0x0000000280000000-0x000003d280000000 3904G PUD I ---[ vmemmap Area ]--- 0x000003d280000000-0x000003d288c00000 140M PTE RW 0x000003d288c00000-0x000003d300000000 1908M PMD I 0x000003d300000000-0x000003e000000000 52G PUD I ---[ vmalloc Area ]--- 0x000003e000000000-0x000003e000009000 36K PTE RW 0x000003e000009000-0x000003e0000ee000 916K PTE I 0x000003e0000ee000-0x000003e000146000 352K PTE RW 0x000003e000146000-0x000003e000200000 744K PTE I 0x000003e000200000-0x000003e080000000 2046M PMD I 0x000003e080000000-0x0000040000000000 126G PUD I This usually makes only sense for kernel developers. The output with CONFIG_DEBUG_PAGEALLOC is not very helpful, because of the huge number of mapped out pages, however I decided for the time being to not add a !DEBUG_PAGEALLOC dependency. Maybe it's helpful for somebody even with that option. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-15[S390] Write protect module text and RO dataJan Glauber
Implement write protection for kernel modules text and read-only data sections by implementing set_memory_[ro|rw] on s390. Since s390 has no execute bit in the pte's NX is not supported. set_memory_[ro|rw] will only work on normal pages and not on large pages, so in case a large page should be modified bail out with a warning. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] cleanup s390 KconfigMartin Schwidefsky
Make use of def_bool and def_tristate where possible and add sensible defaults to the config symbols where applicable. This shortens the defconfig file by another ~40 lines. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-11-10[S390] mm: add devmem_is_allowed() for STRICT_DEVMEM checkingHendrik Brueckner
Provide the devmem_is_allowed() routine to restrict access to kernel memory from userspace. Set the CONFIG_STRICT_DEVMEM config option to switch on checking. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-02-26[S390] uaccess: implement strict user copy checksHeiko Carstens
Same as on x86 and sparc, besides the fact that enabling the option will just emit compile time warnings instead of errors. Keeps allyesconfig kernels compiling. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-04-02generic debug pagealloc: build fixAkinobu Mita
This fixes a build failure with generic debug pagealloc: mm/debug-pagealloc.c: In function 'set_page_poison': mm/debug-pagealloc.c:8: error: 'struct page' has no member named 'debug_flags' mm/debug-pagealloc.c: In function 'clear_page_poison': mm/debug-pagealloc.c:13: error: 'struct page' has no member named 'debug_flags' mm/debug-pagealloc.c: In function 'page_poison': mm/debug-pagealloc.c:18: error: 'struct page' has no member named 'debug_flags' mm/debug-pagealloc.c: At top level: mm/debug-pagealloc.c:120: error: redefinition of 'kernel_map_pages' include/linux/mm.h:1278: error: previous definition of 'kernel_map_pages' was here mm/debug-pagealloc.c: In function 'kernel_map_pages': mm/debug-pagealloc.c:122: error: 'debug_pagealloc_enabled' undeclared (first use in this function) by fixing - debug_flags should be in struct page - define DEBUG_PAGEALLOC config option for all architectures Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Reported-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01generic debug pageallocAkinobu Mita
CONFIG_DEBUG_PAGEALLOC is now supported by x86, powerpc, sparc64, and s390. This patch implements it for the rest of the architectures by filling the pages with poison byte patterns after free_pages() and verifying the poison patterns before alloc_pages(). This generic one cannot detect invalid page accesses immediately but invalid read access may cause invalid dereference by poisoned memory and invalid write access can be detected after a long delay. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05[S390] DEBUG_PAGEALLOC support for s390.Heiko Carstens
2006-07-03[PATCH] lockdep: irqtrace subsystem, s390 supportHeiko Carstens
irqtrace support for s390. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
