Git commit 36409f6353fc2d7b6516e631415f938eadd92ffa "use generic RCU
page-table freeing code" introduced a tlb flushing bug. Partially revert
the above git commit and go back to s390 specific page table flush code.
For s390 the TLB can contain three types of entries, "normal" TLB
page-table entries, TLB combined region-and-segment-table (CRST) entries
and real-space entries. Linux does not use real-space entries which
leaves normal TLB entries and CRST entries. The CRST entries are
intermediate steps in the page-table translation called translation paths.
For example a 4K page access in a three-level page table setup will
create two CRST TLB entries and one page-table TLB entry. The advantage
of that approach is that a page access next to the previous one can reuse
the CRST entries and needs just a single read from memory to create the
page-table TLB entry. The disadvantage is that the TLB flushing rules are
more complicated, before any page-table may be freed the TLB needs to be
flushed.
In short: the generic RCU page-table freeing code is incorrect for the
CRST entries, in particular the check for mm_users < 2 is troublesome.
This is applicable to 3.0+ kernels.
Cc: <stable@vger.kernel.org>
Pull arch/tile (really asm-generic) update from Chris Metcalf:
"These are a couple of asm-generic changes that apply to tile."
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
compat: use sys_sendfile64() implementation for sendfile syscall
[PATCH v3] ipc: provide generic compat versions of IPC syscalls
A kernel compiled with SMP=n will not register any cpu devices.
The resulting kernel image will not boot with this error message:
kernel BUG at fs/sysfs/group.c:65!
Use GENERIC_CPU_DEVICES=y if SMP=n to get the missing cpu device.
When using the "compat" APIs, architectures will generally want to
be able to make direct syscalls to msgsnd(), shmctl(), etc., and
in the kernel we would want them to be handled directly by
compat_sys_xxx() functions, as is true for other compat syscalls.
However, for historical reasons, several of the existing compat IPC
syscalls do not do this. semctl() expects a pointer to the fourth
argument, instead of the fourth argument itself. msgsnd(), msgrcv()
and shmat() expect arguments in different order.
This change adds an ARCH_WANT_OLD_COMPAT_IPC config option that can be
set to preserve this behavior for ports that use it (x86, sparc, powerpc,
s390, and mips). No actual semantics are changed for those architectures,
and there is only a minimal amount of code refactoring in ipc/compat.c.
Newer architectures like tile (and perhaps future architectures such
as arm64 and unicore64) should not select this option, and thus can
avoid having any IPC-specific code at all in their architecture-specific
compat layer. In the same vein, if this option is not selected, IPC_64
mode is assumed, since that's what the <asm-generic> headers expect.
The workaround code in "tile" for msgsnd() and msgrcv() is removed
with this change; it also fixes the bug that shmat() and semctl() were
not being properly handled.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
Enable the compat keyctl wrapper on s390x so that 32-bit s390 userspace can
call the keyctl() syscall.
There's an s390x assembly wrapper that truncates all the register values to
32-bits and this then calls compat_sys_keyctl() - but the latter only exists if
CONFIG_KEYS_COMPAT is enabled, and the s390 Kconfig doesn't enable it.
Without this patch, 32-bit calls to the keyctl() syscall are given an ENOSYS
error:
[root@devel4 ~]# keyctl show
Session Keyring
-3: key inaccessible (Function not implemented)
Acked-by: dan@danny.cz
Cc: Carsten Otte <cotte@de.ibm.com>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: linux-s390@vger.kernel.org
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (31 commits)
[S390] disassembler: mark exception causing instructions
[S390] Enable exception traces by default
[S390] return address of compat signals
[S390] sysctl: get rid of dead declaration
[S390] dasd: fix fixpoint divide exception in define_extent
[S390] dasd: add sanity check to detect path connection error
[S390] qdio: fix kernel panic for zfcp 31-bit
[S390] Add s390x description to Documentation/kdump/kdump.txt
[S390] Add VMCOREINFO_SYMBOL(high_memory) to vmcoreinfo
[S390] dasd: fix expiration handling for recovery requests
[S390] outstanding interrupts vs. smp_send_stop
[S390] ipc: call generic sys_ipc demultiplexer
[S390] zcrypt: Fix error return codes.
[S390] zcrypt: Rework length parameter checking.
[S390] cleanup trap handling
[S390] Remove Kerntypes leftovers
[S390] topology: increase poll frequency if change is anticipated
[S390] entry[64].S improvements
[S390] make arch/s390 subdirectories depend on config option
[S390] kvm: move cmf host id constant out of lowcore
Fix up conflicts in arch/s390/kernel/{smp.c,topology.c} due to the
sysdev removal clashing with "topology: get rid of ifdefs" which moved
some of that code around.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits)
Kconfig: acpi: Fix typo in comment.
misc latin1 to utf8 conversions
devres: Fix a typo in devm_kfree comment
btrfs: free-space-cache.c: remove extra semicolon.
fat: Spelling s/obsolate/obsolete/g
SCSI, pmcraid: Fix spelling error in a pmcraid_err() call
tools/power turbostat: update fields in manpage
mac80211: drop spelling fix
types.h: fix comment spelling for 'architectures'
typo fixes: aera -> area, exntension -> extension
devices.txt: Fix typo of 'VMware'.
sis900: Fix enum typo 'sis900_rx_bufer_status'
decompress_bunzip2: remove invalid vi modeline
treewide: Fix comment and string typo 'bufer'
hyper-v: Update MAINTAINERS
treewide: Fix typos in various parts of the kernel, and fix some comments.
clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR
gpio: Kconfig: drop unknown symbol 'CS5535_GPIO'
leds: Kconfig: Fix typo 'D2NET_V2'
sound: Kconfig: drop unknown symbol ARCH_CLPS7500
Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new
kconfig additions, close to removed commented-out old ones)
Remove all ifdefs from topology code and also only compile it for the
CONFIG_SCHED_BOOK case. The new code selects SCHED_MC if SCHED_BOOK is
selected. SCHED_MC without SCHED_BOOK is not possible anymore.
Furthermore various sysfs attributes are not available anymore for the
!SCHED_BOOK case. In particular all attributes that correspond to
CPU polarization.
But since all real world kernels have SCHED_BOOK selected anyway this
doesn't matter too much.
Now all ARCH_POPULATES_NODE_MAP archs select HAVE_MEBLOCK_NODE_MAP -
there's no user of early_node_map[] left. Kill early_node_map[] and
replace ARCH_POPULATES_NODE_MAP with HAVE_MEMBLOCK_NODE_MAP. Also,
relocate for_each_mem_pfn_range() and helper from mm.h to memblock.h
as page_alloc.c would no longer host an alternative implementation.
This change is ultimately one to one mapping and shouldn't cause any
observable difference; however, after the recent changes, there are
some functions which now would fit memblock.c better than page_alloc.c
and dependency on HAVE_MEMBLOCK_NODE_MAP instead of HAVE_MEMBLOCK
doesn't make much sense on some of them. Further cleanups for
functions inside HAVE_MEMBLOCK_NODE_MAP in mm.h would be nice.
-v2: Fix compile bug introduced by mis-spelling
CONFIG_HAVE_MEMBLOCK_NODE_MAP to CONFIG_MEMBLOCK_HAVE_NODE_MAP in
mmzone.h. Reported by Stephen Rothwell.
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
s390 used early_node_map[] just to prime free_area_init_nodes(). Now
memblock can be used for the same purpose and early_node_map[] is
scheduled to be dropped. Use memblock instead.
The kdump infrastructure is built on top of kexec. Therefore
CONFIG_KEXEC has to be enabled when CONFIG_CRASH_DUMP is selected.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Sync with Linus tree to have 157550ff ("mtd: add GPMI-NAND driver
in the config and Makefile") as I have patch depending on that one.
There is no Kconfig symbol named HAVE_GET_USER_PAGES_FAST. The select
statement for that symbol is a nop. Drop it.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
This patch provides the architecture specific part of the s390 kdump
support.
For s390 there is one additional byte associated with each page,
the storage key. This byte contains the referenced and changed
bits and needs to be included into the hibernation image.
If the storage keys are not restored to their previous state all
original pages would appear to be dirty. This can cause
inconsistencies e.g. with read-only filesystems.
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6:
[S390] signal: use set_restore_sigmask() helper
[S390] smp: remove pointless comments in startup_secondary()
[S390] qdio: Use kstrtoul_from_user
[S390] sclp_async: Use kstrtoul_from_user
[S390] exec: remove redundant set_fs(USER_DS)
[S390] cpu hotplug: on cpu start wait until being marked active
[S390] signal: convert to use set_current_blocked()
[S390] asm offsets: fix coding style
[S390] Add support for IBM zEnterprise 114
[S390] dasd: check if raw track access is supported
[S390] Use diagnose 308 for system reset
[S390] Export store_status() function
[S390] dasd: use vmalloc for statistics input buffer
[S390] Add PSW restart shutdown trigger
[S390] missing return in page_table_alloc_pgste
[S390] qdio: 2nd stage retry on SIGA-W busy conditions
cmpxchg() is widely used by lockless code, including NMI-safe lockless
code. But on some architectures, the cmpxchg() implementation is not
NMI-safe, on these architectures the lockless code may need a
spin_trylock_irqsave() based implementation.
This patch adds a Kconfig option: ARCH_HAVE_NMI_SAFE_CMPXCHG, so that
NMI-safe lockless code can depend on it or provide different
implementation according to it.
On many architectures, cmpxchg is only NMI-safe for several specific
operand sizes. So, ARCH_HAVE_NMI_SAFE_CMPXCHG define in this patch
only guarantees cmpxchg is NMI-safe for sizeof(unsigned long).
Signed-off-by: Huang Ying <ying.huang@intel.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Richard Henderson <rth@twiddle.net>
CC: Mikael Starvik <starvik@axis.com>
CC: Yoshinori Sato <ysato@users.sourceforge.jp>
CC: Tony Luck <tony.luck@intel.com>
CC: Hirokazu Takata <takata@linux-m32r.org>
CC: Geert Uytterhoeven <geert@linux-m68k.org>
CC: Michal Simek <monstr@monstr.eu>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
CC: Kyle McMartin <kyle@mcmartin.ca>
CC: Martin Schwidefsky <schwidefsky@de.ibm.com>
CC: Chen Liqin <liqin.chen@sunplusct.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: Ingo Molnar <mingo@redhat.com>
CC: Chris Zankel <chris@zankel.net>
Signed-off-by: Len Brown <len.brown@intel.com>
Just fix up the Kconfig description and the elf platform.
A user can create the Kconfig combination !VIRTUALIZATION, S390_GUEST
which results in the following warnings:
warning: (S390_GUEST) selects VIRTIO which has unmet direct dependencies (VIRTUALIZATION)
warning: (S390_GUEST && VIRTIO_PCI && VIRTIO_BALLOON) selects VIRTIO_RING which has unmet direct dependencies (VIRTUALIZATION && VIRTIO)
S390_GUEST has to select VIRTUALIZATION before selecting VIRTIO and
friends.
Reported-by: Jan Glauber <jang@linux.vnet.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Replace the s390 specific rcu page-table freeing code with the
generic variant. This requires to duplicate the definition for the
struct mmu_table_batch as s390 does not use the generic tlb flush
code.
While we are at it remove the restriction that page table fragments
can not be reused after a single fragment has been freed with rcu
and split out allocation and freeing of page tables with pgstes.
Add ZONE_DMA to 31-bit config again. The performance gain is minimal
and hardly anybody cares anymore about a 31-bit kernel.
So add ZONE_DMA again to help with SLAB_CACHE_DMA removal for
!CONFIG_ZONE_DMA configurations.
Acked-by: David Rientjes <rientjes@google.com>
The noexec support on s390 does not rely on a bit in the page table
entry but utilizes the secondary space mode to distinguish between
memory accesses for instructions vs. data. The noexec code relies
on the assumption that the cpu will always use the secondary space
page table for data accesses while it is running in the secondary
space mode. Up to the z9-109 class machines this has been the case.
Unfortunately this is not true anymore with z10 and later machines.
The load-relative-long instructions lrl, lgrl and lgfrl access the
memory operand using the same addressing-space mode that has been
used to fetch the instruction.
This breaks the noexec mode for all user space binaries compiled
with march=z10 or later. The only option is to remove the current
noexec support.
Implement the architecture backend for jump label support on s390.
For a shared kernel booted from a NSS silently disable jump labels
because the NSS is read-only. Therefore jump labels will be disabled
in a shared kernel and can't be activated.
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com>
LKML-Reference: <6935d2c41ce111e1719176ed4bbd3dbe4de80855.1300299760.git.jbaron@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Add support for XZ compressed kernel. Same as on x86 and sh.
Newer gcc versions offer an architecture-independent option to check
the stack size and warn if it reaches a certain limit. This option
already existed for s390 by using -mwarn-dynamicstack. Since one
stack check option is enough remove the s390 specific stack check
but keep the option that warns about dynamic stack usage because
that is not covered by the generic option.
6f9a3c33 "[S390] cleanup s390 Kconfig" accidentally changed
the default for CONFIG_CHSC_SCH. Reset it to m.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
This enables the spinning mutex feature on s390 by removing
HAVE_DEFAULT_NO_SPIN_MUTEXES from arch/s390/Kconfig.
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
The spinning mutex implementation uses cpu_relax() in busy loops as a
compiler barrier. Depending on the architecture, cpu_relax() may do more
than needed in this specific mutex spin loops. On System z we also give
up the time slice of the virtual cpu in cpu_relax(), which prevents
effective spinning on the mutex.
This patch replaces cpu_relax() in the spinning mutex code with
arch_mutex_cpu_relax(), which can be defined by each architecture that
selects HAVE_ARCH_MUTEX_CPU_RELAX. The default is still cpu_relax(), so
this patch should not affect other architectures than System z for now.
LKML-Reference: <1290437256.7455.4.camel@thinkpad>
Make use of def_bool and def_tristate where possible and add sensible
defaults to the config symbols where applicable. This shortens the
defconfig file by another ~40 lines.
Select HAVE_C_RECORDMCOUNT for the fast C version of recordmcount.
This allows us to easily check for performance differences seen with
!CONFIG_SCHED_MC and topology=off.
Actually there shouldn't be any (besides a small overhead because of
additional code).
Add machine type number to code generation options. Also clean up and
shorten quite a lot of help texts with respect to machine type and
architecture terminology.
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits)
kbuild: convert `arch/tile' to the kconfig mainmenu upgrade
README: cite nconfig
Revert "kconfig: Temporarily disable dependency warnings"
kconfig: Use PATH_MAX instead of 128 for path buffer sizes.
kconfig: Fix realloc usage()
kconfig: Propagate const
kconfig: Don't go out from read config loop when you read new symbol
kconfig: fix menuconfig on debian lenny
kbuild: migrate all arch to the kconfig mainmenu upgrade
kconfig: expand file names
kconfig: use the file's name of sourced file
kconfig: constify file name
kconfig: don't emit warning upon rootmenu's prompt redefinition
kconfig: replace KERNELVERSION usage by the mainmenu's prompt
kconfig: delay gconf window initialization
kconfig: expand by default the rootmenu's prompt
kconfig: add a symbol string expansion helper
kconfig: regen parser
kconfig: implement the `mainmenu' directive
kconfig: allow PACKAGE to be defined on the compiler's command-line
Fix up trivial conflict in arch/mn10300/Kconfig
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Add a kernel config option for the IBM zEnterprise 196. This will
produce faster code on newer compilers using the -march=z196 option.
Implement get_user_pages_fast without locking in the fastpath on s390.
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (29 commits)
sched: Export account_system_vtime()
sched: Call tick_check_idle before __irq_enter
sched: Remove irq time from available CPU power
sched: Do not account irq time to current task
x86: Add IRQ_TIME_ACCOUNTING
sched: Add IRQ_TIME_ACCOUNTING, finer accounting of irq time
sched: Add a PF flag for ksoftirqd identification
sched: Consolidate account_system_vtime extern declaration
sched: Fix softirq time accounting
sched: Drop group_capacity to 1 only if local group has extra capacity
sched: Force balancing on newidle balance if local group has capacity
sched: Set group_imb only a task can be pulled from the busiest cpu
sched: Do not consider SCHED_IDLE tasks to be cache hot
sched: Drop all load weight manipulation for RT tasks
sched: Create special class for stop/migrate work
sched: Unindent labels
sched: Comment updates: fix default latency and granularity numbers
tracing/sched: Add sched_pi_setprio tracepoint
sched: Give CPU bound RT tasks preference
sched: Try not to migrate higher priority RT tasks
Provide a mechanism that allows running code in IRQ context. It is
most useful for NMI code that needs to interact with the rest of the
system -- like wakeup a task to drain buffers.
Perf currently has such a mechanism, so extract that and provide it as
a generic feature, independent of perf so that others may also
benefit.
The IRQ context callback is generated through self-IPIs where
possible, or on architectures like powerpc the decrementer (the
built-in timer facility) is set to generate an interrupt immediately.
Architectures that don't have anything like this get to do with a
callback from the timer tick. These architectures can call
irq_work_run() at the tail of any IRQ handlers that might enqueue such
work (like the perf IRQ handler) to avoid undue latencies in
processing the work.
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
[ various fixes ]
LKML-Reference: <1287036094.7768.291.camel@yhuang-dev>
We need to revert the temporary hack in 71ebc01, hence the merge.
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
Reviewed-by: Michal Marek <mmarek@suse.cz>
Use the extended cpu topology information that z11 machines provide
to improve the scheduler's decision making.
LKML-Reference: <20100831082844.604956770@de.ibm.com>
Now that all arches have been converted over to use generic time via
clocksources or arch_gettimeoffset(), we can remove the GENERIC_TIME
config option and simplify the generic code.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
LKML-Reference: <1279068988-21864-4-git-send-email-johnstul@us.ibm.com>
All distros have this option switched on, so lets get rid of at least
one of the tons of config options that are available.
The exception-trace facility on x86 and other architectures prints
traces to dmesg whenever a user space application crashes.
s390 has such a feature since ages however it is called
userprocess_debug and is enabled differently.
This patch makes sure that whenever one of the two procfs files
/proc/sys/kernel/userprocess_debug
/proc/sys/debug/exception-trace
is modified the contents of the second one changes as well.
That way we keep backwards compatibilty but also support the same
interface like other architectures do.
Besides that the output of the traces is improved since it will now
also contain the corresponding filename of the vma (when available)
where the process caused a fault or trap.
* 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits)
ftrace: Add function names to dangling } in function graph tracer
tracing: Simplify memory recycle of trace_define_field
tracing: Remove unnecessary variable in print_graph_return
tracing: Fix typo of info text in trace_kprobe.c
tracing: Fix typo in prof_sysexit_enable()
tracing: Remove CONFIG_TRACE_POWER from kernel config
tracing: Fix ftrace_event_call alignment for use with gcc 4.5
ftrace: Remove memory barriers from NMI code when not needed
tracing/kprobes: Add short documentation for HAVE_REGS_AND_STACK_ACCESS_API
s390: Add pt_regs register and stack access API
tracing/kprobes: Make Kconfig dependencies generic
tracing: Unify arch_syscall_addr() implementations
tracing: Add notrace to TRACE_EVENT implementation functions
ftrace: Allow to remove a single function from function graph filter
tracing: Add correct/incorrect to sort keys for branch annotation output
tracing: Simplify test for function_graph tracing start point
tracing: Drop the tr check from the graph tracing path
tracing: Add stack dump to trace_printk if stacktrace option is set
tracing: Use appropriate perl constructs in recordmcount.pl
tracing: optimize recordmcount.pl for offsets-handling
Add the "bzImage" compile target and the necessary code to generate
compressed kernel images. The old style uncompressed "image" target
is preserved, a simple make will build them both.
Reduces the size of the bug table entries by 50% on 64bit kernels.
Saves around 30kb on a defconfig kernel.
s390 version of b93a531e "allow bug table entries to use relative
pointers (and use it on x86-64)".
This API is needed for the kprobe-based event tracer.
Reviewed-by: Masami Hiramatsu <mhiramat@redhat.com>
LKML-Reference: <20100212123840.GB27548@osiris.boeblingen.de.ibm.com>
Introduce user_mode to replace the two variables switch_amode and
s390_noexec. There are three valid combinations of the old values:
1) switch_amode == 0 && s390_noexec == 0
2) switch_amode == 1 && s390_noexec == 0
3) switch_amode == 1 && s390_noexec == 1
They get replaced by
1) user_mode == HOME_SPACE_MODE
2) user_mode == PRIMARY_SPACE_MODE
3) user_mode == SECONDARY_SPACE_MODE
The new kernel parameter user_mode=[primary,secondary,home] lets
you choose the address space mode the user space processes should
use. In addition the CONFIG_S390_SWITCH_AMODE config option
is removed.
