path: root/arch/s390/Kconfig
2012-08-08s390/seccomp: add support for system call filtering using BPFHeiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-07-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "This it the second batch of s390 patches for the 3.6 merge window. Included is enablement for two common code changes, killable page faults and sorted exception tables. And the regular set of cleanup and bug fix patches." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390: make use of user_mode() macro where possible s390/mm: rename user_mode variable to addressing_mode s390/mm: fix fault handling for page table walk case s390/mm: make page faults killable s390: update defconfig s390/mm: downgrade page table after fork of a 31 bit process s390/ipl: Use diagnose 8 command separation s390/linker script: use RO_DATA_SECTION s390/exceptions: sort exception table at build time s390/debug: remove module_exit function / move EXPORT_SYMBOLs
2012-07-30ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSIONWill Deacon
Rather than #define the options manually in the architecture code, add Kconfig options for them and select them there instead. This also allows us to select the compat IPC version parsing automatically for platforms using the old compat IPC interface. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30atomic64_test: simplify the #ifdef for atomic64_dec_if_positive() testCatalin Marinas
Introduce CONFIG_ARCH_HAS_ATOMIC64_DEC_IF_POSITIVE and use this instead of the multitude of #if defined() checks in atomic64_test.c Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-26s390/exceptions: sort exception table at build timeHeiko Carstens
Follow x86 and MIPS and sort the main exception table at build time. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-05-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 patches from Heiko Carstens: "A couple of s390 patches for the 3.5 merge window. Just a collection of bug fixes and cleanups." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/uaccess: fix access_ok compile warnings s390/cmpxchg: select HAVE_CMPXCHG_LOCAL option s390/cmpxchg: fix sign extension bugs s390/cmpxchg: fix 1 and 2 byte memory accesses s390/cmpxchg: fix compile warnings specific to s390 s390/cmpxchg: add missing memory barrier to cmpxchg64 s390/cpu: remove cpu "capabilities" sysfs attribute s390/kernel: Fix smp_call_ipl_cpu() for offline CPUs s390/kernel: Introduce memcpy_absolute() function s390/headers: replace __s390x__ with CONFIG_64BIT where possible s390/headers: remove #ifdef __KERNEL__ from not exported headers s390/irq: split irq stats for cpu-measurement alert facilities s390/kexec: Move early_pgm_check_handler() to text section s390/kdump: Use real mode for PSW restart and kexec s390/kdump: Account /sys/kernel/kexec_crash_size changes in OS info s390/kernel: Remove OS info init function call and diag 308 for kdump
2012-05-30s390/cmpxchg: select HAVE_CMPXCHG_LOCAL optionHeiko Carstens
Now that hopefully all cmpxchg/xchg bugs have been fixed select HAVE_CMPXCHG_LOCAL option which uncovered a couple of bugs on s390. The only call site which is affected seems to be within mm/vmstat.c. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-05-24Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner. Various trivial conflict fixups in arch Kconfig due to addition of unrelated entries nearby. And one slightly more subtle one for sparc32 (new user of GENERIC_CLOCKEVENTS), fixed up as per Thomas. * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits) timekeeping: Fix a few minor newline issues. time: remove obsolete declaration ntp: Fix a stale comment and a few stray newlines. ntp: Correct TAI offset during leap second timers: Fixup the Kconfig consolidation fallout x86: Use generic time config unicore32: Use generic time config um: Use generic time config tile: Use generic time config sparc: Use: generic time config sh: Use generic time config score: Use generic time config s390: Use generic time config openrisc: Use generic time config powerpc: Use generic time config mn10300: Use generic time config mips: Use generic time config microblaze: Use generic time config m68k: Use generic time config m32r: Use generic time config ...
2012-05-21Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull smp hotplug cleanups from Thomas Gleixner: "This series is merily a cleanup of code copied around in arch/* and not changing any of the real cpu hotplug horrors yet. I wish I'd had something more substantial for 3.5, but I underestimated the lurking horror..." Fix up trivial conflicts in arch/{arm,sparc,x86}/Kconfig and arch/sparc/include/asm/thread_info_32.h * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits) um: Remove leftover declaration of alloc_task_struct_node() task_allocator: Use config switches instead of magic defines sparc: Use common threadinfo allocator score: Use common threadinfo allocator sh-use-common-threadinfo-allocator mn10300: Use common threadinfo allocator powerpc: Use common threadinfo allocator mips: Use common threadinfo allocator hexagon: Use common threadinfo allocator m32r: Use common threadinfo allocator frv: Use common threadinfo allocator cris: Use common threadinfo allocator x86: Use common threadinfo allocator c6x: Use common threadinfo allocator fork: Provide kmemcache based thread_info allocator tile: Use common threadinfo allocator fork: Provide weak arch_release_[task_struct|thread_info] functions fork: Move thread info gfp flags to header fork: Remove the weak insanity sh: Remove cpu_idle_wait() ...
2012-05-21timers: Fixup the Kconfig consolidation falloutThomas Gleixner
Sigh, I missed to check which architecture Kconfig files actually include the core Kconfig file. There are a few which did not. So we broke them. Instead of adding the includes to those, we are better off to move the include to init/Kconfig like we did already with irqs and others. This does not change anything for the architectures using the old style periodic timer mode. It just solves the build wreckage there. For those architectures which use the clock events infrastructure it moves the include of the core Kconfig file to "General setup" which is a way more logical place than having it at random locations specified by the architecture specific Kconfigs. Reported-by: Ingo Molnar <mingo@kernel.org> Cc: Anna-Maria Gleixner <anna-maria@glx-um.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-05-21s390: Use generic time configAnna-Maria Gleixner
Signed-off-by: Anna-Maria Gleixner <anna-maria@glx-um.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Link: http://lkml.kernel.org/r/20120518163106.595607369@glx-um.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-05-16s390/Kconfig: add HAVE_MARCH_[ARCH]_FEATURES Kconfig symbolsHeiko Carstens
Add HAVE_MARCH_[ARCH]_FEATURES Kconfig symbols. Whenever there is code that needs an instruction that is only present beginning with a hardware generation the #ifdef chain can become quite long. To avoid this add the new Kconfig symbols which are selected if the kernel gets compiled for at least the specified symbol. If for example the kernel gets compiled for z196 this means that also all symbols for all previous architure features are set. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-05-16s390/ipl: remove builtin tape ipl codeHeiko Carstens
Remove the builtin tape ipl code. If somebody really wants to create a tape which can be ipl'ed from, then this can be achieved by using zipl. zipl can write an ipl record to a tape device and aftwards the kernel image must be written to tape. The steps are described in the "Linux on System z - Device Drivers, Features, and Commands" book (SC33-8411). Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-05-16s390/crash dump: add missing SMP dependencyHeiko Carstens
Fix this: arch/s390/kernel/crash_dump.c:296:14: error: 'zfcpdump_save_areas' undeclared (first use in this function) Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-05-16s390/compat: select COMPAT_BINFMT_ELF only if BINFMT_ELF is setHeiko Carstens
Fix this: warning: (COMPAT) selects COMPAT_BINFMT_ELF which has unmet direct dependencies (COMPAT && BINFMT_ELF) Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-05-05init_task: Replace CONFIG_HAVE_GENERIC_INIT_TASKThomas Gleixner
Now that all archs except ia64 are converted, replace the config and let the ia64 select CONFIG_ARCH_INIT_TASK Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20120503085035.867948914@linutronix.de
2012-05-05s390: Use generic init_taskThomas Gleixner
Same code. Use the generic version. The special Makefile treatment is pointless anyway as init_task.o contains only data which is handled by the linker script. So no point on being treated like head text. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Link: http://lkml.kernel.org/r/20120503085035.271439530@linutronix.de
2012-04-26s390: Use generic idle thread allocationThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Link: http://lkml.kernel.org/r/20120420124557.652574928@linutronix.de
2012-04-11[S390] fix tlb flushing for page table pagesMartin Schwidefsky
Git commit 36409f6353fc2d7b6516e631415f938eadd92ffa "use generic RCU page-table freeing code" introduced a tlb flushing bug. Partially revert the above git commit and go back to s390 specific page table flush code. For s390 the TLB can contain three types of entries, "normal" TLB page-table entries, TLB combined region-and-segment-table (CRST) entries and real-space entries. Linux does not use real-space entries which leaves normal TLB entries and CRST entries. The CRST entries are intermediate steps in the page-table translation called translation paths. For example a 4K page access in a three-level page table setup will create two CRST TLB entries and one page-table TLB entry. The advantage of that approach is that a page access next to the previous one can reuse the CRST entries and needs just a single read from memory to create the page-table TLB entry. The disadvantage is that the TLB flushing rules are more complicated, before any page-table may be freed the TLB needs to be flushed. In short: the generic RCU page-table freeing code is incorrect for the CRST entries, in particular the check for mm_users < 2 is troublesome. This is applicable to 3.0+ kernels. Cc: <stable@vger.kernel.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull arch/tile (really asm-generic) update from Chris Metcalf: "These are a couple of asm-generic changes that apply to tile." * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: compat: use sys_sendfile64() implementation for sendfile syscall [PATCH v3] ipc: provide generic compat versions of IPC syscalls
2012-03-23[S390] register cpu devices for SMP=nMartin Schwidefsky
A kernel compiled with SMP=n will not register any cpu devices. The resulting kernel image will not boot with this error message: kernel BUG at fs/sysfs/group.c:65! Use GENERIC_CPU_DEVICES=y if SMP=n to get the missing cpu device. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-03-15[PATCH v3] ipc: provide generic compat versions of IPC syscallsChris Metcalf
When using the "compat" APIs, architectures will generally want to be able to make direct syscalls to msgsnd(), shmctl(), etc., and in the kernel we would want them to be handled directly by compat_sys_xxx() functions, as is true for other compat syscalls. However, for historical reasons, several of the existing compat IPC syscalls do not do this. semctl() expects a pointer to the fourth argument, instead of the fourth argument itself. msgsnd(), msgrcv() and shmat() expect arguments in different order. This change adds an ARCH_WANT_OLD_COMPAT_IPC config option that can be set to preserve this behavior for ports that use it (x86, sparc, powerpc, s390, and mips). No actual semantics are changed for those architectures, and there is only a minimal amount of code refactoring in ipc/compat.c. Newer architectures like tile (and perhaps future architectures such as arm64 and unicore64) should not select this option, and thus can avoid having any IPC-specific code at all in their architecture-specific compat layer. In the same vein, if this option is not selected, IPC_64 mode is assumed, since that's what the <asm-generic> headers expect. The workaround code in "tile" for msgsnd() and msgrcv() is removed with this change; it also fixes the bug that shmat() and semctl() were not being properly handled. Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2012-02-24[S390] KEYS: Enable the compat keyctl wrapper on s390xDavid Howells
Enable the compat keyctl wrapper on s390x so that 32-bit s390 userspace can call the keyctl() syscall. There's an s390x assembly wrapper that truncates all the register values to 32-bits and this then calls compat_sys_keyctl() - but the latter only exists if CONFIG_KEYS_COMPAT is enabled, and the s390 Kconfig doesn't enable it. Without this patch, 32-bit calls to the keyctl() syscall are given an ENOSYS error: [root@devel4 ~]# keyctl show Session Keyring -3: key inaccessible (Function not implemented) Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: dan@danny.cz Cc: Carsten Otte <cotte@de.ibm.com> Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Cc: linux-s390@vger.kernel.org Cc: stable@vger.kernel.org Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-01-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (31 commits) [S390] disassembler: mark exception causing instructions [S390] Enable exception traces by default [S390] return address of compat signals [S390] sysctl: get rid of dead declaration [S390] dasd: fix fixpoint divide exception in define_extent [S390] dasd: add sanity check to detect path connection error [S390] qdio: fix kernel panic for zfcp 31-bit [S390] Add s390x description to Documentation/kdump/kdump.txt [S390] Add VMCOREINFO_SYMBOL(high_memory) to vmcoreinfo [S390] dasd: fix expiration handling for recovery requests [S390] outstanding interrupts vs. smp_send_stop [S390] ipc: call generic sys_ipc demultiplexer [S390] zcrypt: Fix error return codes. [S390] zcrypt: Rework length parameter checking. [S390] cleanup trap handling [S390] Remove Kerntypes leftovers [S390] topology: increase poll frequency if change is anticipated [S390] entry[64].S improvements [S390] make arch/s390 subdirectories depend on config option [S390] kvm: move cmf host id constant out of lowcore ... Fix up conflicts in arch/s390/kernel/{smp.c,topology.c} due to the sysdev removal clashing with "topology: get rid of ifdefs" which moved some of that code around.
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2011-12-27[S390] topology: get rid of ifdefsHeiko Carstens
Remove all ifdefs from topology code and also only compile it for the CONFIG_SCHED_BOOK case. The new code selects SCHED_MC if SCHED_BOOK is selected. SCHED_MC without SCHED_BOOK is not possible anymore. Furthermore various sysfs attributes are not available anymore for the !SCHED_BOOK case. In particular all attributes that correspond to CPU polarization. But since all real world kernels have SCHED_BOOK selected anyway this doesn't matter too much. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-12-08memblock: Kill early_node_map[]Tejun Heo
Now all ARCH_POPULATES_NODE_MAP archs select HAVE_MEBLOCK_NODE_MAP - there's no user of early_node_map[] left. Kill early_node_map[] and replace ARCH_POPULATES_NODE_MAP with HAVE_MEMBLOCK_NODE_MAP. Also, relocate for_each_mem_pfn_range() and helper from mm.h to memblock.h as page_alloc.c would no longer host an alternative implementation. This change is ultimately one to one mapping and shouldn't cause any observable difference; however, after the recent changes, there are some functions which now would fit memblock.c better than page_alloc.c and dependency on HAVE_MEMBLOCK_NODE_MAP instead of HAVE_MEMBLOCK doesn't make much sense on some of them. Further cleanups for functions inside HAVE_MEMBLOCK_NODE_MAP in mm.h would be nice. -v2: Fix compile bug introduced by mis-spelling CONFIG_HAVE_MEMBLOCK_NODE_MAP to CONFIG_MEMBLOCK_HAVE_NODE_MAP in mmzone.h. Reported by Stephen Rothwell. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: "H. Peter Anvin" <hpa@zytor.com>
2011-12-08s390: Use HAVE_MEMBLOCK_NODE_MAPTejun Heo
s390 used early_node_map[] just to prime free_area_init_nodes(). Now memblock can be used for the same purpose and early_node_map[] is scheduled to be dropped. Use memblock instead. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux-s390@vger.kernel.org
2011-11-14[S390] Kconfig: Select CONFIG_KEXEC for CONFIG_CRASH_DUMPMichael Holzheu
The kdump infrastructure is built on top of kexec. Therefore CONFIG_KEXEC has to be enabled when CONFIG_CRASH_DUMP is selected. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-11-13Merge branch 'master' into for-nextJiri Kosina
Sync with Linus tree to have 157550ff ("mtd: add GPMI-NAND driver in the config and Makefile") as I have patch depending on that one.
2011-11-13s390: drop "select HAVE_GET_USER_PAGES_FAST"Paul Bolle
There is no Kconfig symbol named HAVE_GET_USER_PAGES_FAST. The select statement for that symbol is a nop. Drop it. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-30[S390] kdump backend codeMichael Holzheu
This patch provides the architecture specific part of the s390 kdump support. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-10-16PM / Hibernate: Include storage keys in hibernation image on s390Martin Schwidefsky
For s390 there is one additional byte associated with each page, the storage key. This byte contains the referenced and changed bits and needs to be included into the hibernation image. If the storage keys are not restored to their previous state all original pages would appear to be dirty. This can cause inconsistencies e.g. with read-only filesystems. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-08-04Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] signal: use set_restore_sigmask() helper [S390] smp: remove pointless comments in startup_secondary() [S390] qdio: Use kstrtoul_from_user [S390] sclp_async: Use kstrtoul_from_user [S390] exec: remove redundant set_fs(USER_DS) [S390] cpu hotplug: on cpu start wait until being marked active [S390] signal: convert to use set_current_blocked() [S390] asm offsets: fix coding style [S390] Add support for IBM zEnterprise 114 [S390] dasd: check if raw track access is supported [S390] Use diagnose 308 for system reset [S390] Export store_status() function [S390] dasd: use vmalloc for statistics input buffer [S390] Add PSW restart shutdown trigger [S390] missing return in page_table_alloc_pgste [S390] qdio: 2nd stage retry on SIGA-W busy conditions
2011-08-03Add Kconfig option ARCH_HAVE_NMI_SAFE_CMPXCHGHuang Ying
cmpxchg() is widely used by lockless code, including NMI-safe lockless code. But on some architectures, the cmpxchg() implementation is not NMI-safe, on these architectures the lockless code may need a spin_trylock_irqsave() based implementation. This patch adds a Kconfig option: ARCH_HAVE_NMI_SAFE_CMPXCHG, so that NMI-safe lockless code can depend on it or provide different implementation according to it. On many architectures, cmpxchg is only NMI-safe for several specific operand sizes. So, ARCH_HAVE_NMI_SAFE_CMPXCHG define in this patch only guarantees cmpxchg is NMI-safe for sizeof(unsigned long). Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Richard Henderson <rth@twiddle.net> CC: Mikael Starvik <starvik@axis.com> Acked-by: David Howells <dhowells@redhat.com> CC: Yoshinori Sato <ysato@users.sourceforge.jp> CC: Tony Luck <tony.luck@intel.com> CC: Hirokazu Takata <takata@linux-m32r.org> CC: Geert Uytterhoeven <geert@linux-m68k.org> CC: Michal Simek <monstr@monstr.eu> Acked-by: Ralf Baechle <ralf@linux-mips.org> CC: Kyle McMartin <kyle@mcmartin.ca> CC: Martin Schwidefsky <schwidefsky@de.ibm.com> CC: Chen Liqin <liqin.chen@sunplusct.com> CC: "David S. Miller" <davem@davemloft.net> CC: Ingo Molnar <mingo@redhat.com> CC: Chris Zankel <chris@zankel.net> Signed-off-by: Len Brown <len.brown@intel.com>
2011-08-03[S390] Add support for IBM zEnterprise 114Heiko Carstens
Just fix up the Kconfig description and the elf platform. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2011-06-22[S390] kvm-s390: fix kconfig dependenciesChristian Borntraeger
A user can create the Kconfig combination !VIRTUALIZATION, S390_GUEST which results in the following warnings: warning: (S390_GUEST) selects VIRTIO which has unmet direct dependencies (VIRTUALIZATION) warning: (S390_GUEST && VIRTIO_PCI && VIRTIO_BALLOON) selects VIRTIO_RING which has unmet direct dependencies (VIRTUALIZATION && VIRTIO) warning: (S390_GUEST) selects VIRTIO which has unmet direct dependencies (VIRTUALIZATION) warning: (S390_GUEST && VIRTIO_PCI && VIRTIO_BALLOON) selects VIRTIO_RING which has unmet direct dependencies (VIRTUALIZATION && VIRTIO) S390_GUEST has to select VIRTUALIZATION before selecting VIRTIO and friends. Reported-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-06-06[S390] use generic RCU page-table freeing codeMartin Schwidefsky
Replace the s390 specific rcu page-table freeing code with the generic variant. This requires to duplicate the definition for the struct mmu_table_batch as s390 does not use the generic tlb flush code. While we are at it remove the restriction that page table fragments can not be reused after a single fragment has been freed with rcu and split out allocation and freeing of page tables with pgstes. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-26[S390] mm: add ZONE_DMA to 31-bit config againHeiko Carstens
Add ZONE_DMA to 31-bit config again. The performance gain is minimal and hardly anybody cares anymore about a 31-bit kernel. So add ZONE_DMA again to help with SLAB_CACHE_DMA removal for !CONFIG_ZONE_DMA configurations. Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2011-05-23[S390] Remove data execution protectionMartin Schwidefsky
The noexec support on s390 does not rely on a bit in the page table entry but utilizes the secondary space mode to distinguish between memory accesses for instructions vs. data. The noexec code relies on the assumption that the cpu will always use the secondary space page table for data accesses while it is running in the secondary space mode. Up to the z9-109 class machines this has been the case. Unfortunately this is not true anymore with z10 and later machines. The load-relative-long instructions lrl, lgrl and lgfrl access the memory operand using the same addressing-space mode that has been used to fetch the instruction. This breaks the noexec mode for all user space binaries compiled with march=z10 or later. The only option is to remove the current noexec support. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-04-04jump label: Add s390 supportJan Glauber
Implement the architecture backend for jump label support on s390. For a shared kernel booted from a NSS silently disable jump labels because the NSS is read-only. Therefore jump labels will be disabled in a shared kernel and can't be activated. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> LKML-Reference: <6935d2c41ce111e1719176ed4bbd3dbe4de80855.1300299760.git.jbaron@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-03-15[S390] support XZ compressed kernelHeiko Carstens
Add support for XZ compressed kernel. Same as on x86 and sh. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-15[S390] remove redundant stack check optionJan Glauber
Newer gcc versions offer an architecture-independent option to check the stack size and warn if it reaches a certain limit. This option already existed for s390 by using -mwarn-dynamicstack. Since one stack check option is enough remove the s390 specific stack check but keep the option that warns about dynamic stack usage because that is not covered by the generic option. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-31[S390] reset default for CONFIG_CHSC_SCHSebastian Ott
6f9a3c33 "[S390] cleanup s390 Kconfig" accidentally changed the default for CONFIG_CHSC_SCH. Reset it to m. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] mutex: enable spinning mutex on s390Gerald Schaefer
This enables the spinning mutex feature on s390 by removing HAVE_DEFAULT_NO_SPIN_MUTEXES from arch/s390/Kconfig. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] mutex: Introduce arch_mutex_cpu_relax()Gerald Schaefer
The spinning mutex implementation uses cpu_relax() in busy loops as a compiler barrier. Depending on the architecture, cpu_relax() may do more than needed in this specific mutex spin loops. On System z we also give up the time slice of the virtual cpu in cpu_relax(), which prevents effective spinning on the mutex. This patch replaces cpu_relax() in the spinning mutex code with arch_mutex_cpu_relax(), which can be defined by each architecture that selects HAVE_ARCH_MUTEX_CPU_RELAX. The default is still cpu_relax(), so this patch should not affect other architectures than System z for now. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1290437256.7455.4.camel@thinkpad> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-05[S390] cleanup s390 KconfigMartin Schwidefsky
Make use of def_bool and def_tristate where possible and add sensible defaults to the config symbols where applicable. This shortens the defconfig file by another ~40 lines. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-29[S390] ftrace: select HAVE_C_RECORDMCOUNTHeiko Carstens
Select HAVE_C_RECORDMCOUNT for the fast C version of recordmcount. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-29[S390] topology: add SCHED_MC config optionHeiko Carstens
This allows us to easily check for performance differences seen with !CONFIG_SCHED_MC and topology=off. Actually there shouldn't be any (besides a small overhead because of additional code). Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-29[S390] Kconfig: add machine type number to code generation optionsHeiko Carstens
Add machine type number to code generation options. Also clean up and shorten quite a lot of help texts with respect to machine type and architecture terminology. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
