Remove trivially unused variables as detected with -Wunused-but-set-variable.
For consistency drop & in front of every proc_handler. Explicity
taking the address is unnecessary and it prevents optimizations
like stubbing the proc_handlers to NULL.
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Joe Perches <joe@perches.com>
It's unused.
It isn't needed -- read or write flag is already passed and sysctl
shouldn't care about the rest.
It _was_ used in two places at arch/frv for some reason.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
The appldata_ops callbacks are called with a spin_lock held. But the
appldata_mem callback then calls all_vm_events(), which calls
get_online_cpus(), which might sleep. This possible deadlock is fixed
by using a mutex instead of a spin_lock.
mod_virt_timer() was used to modify/add cpu timers for cpus that were
set online. This resulted in a one-shot timer for every cpu that was
newly added or previously set offline, instead of an interval timer,
which broke the appldata vtime interval setup.
To fix this, the new mod_virt_timer_periodic() function is used, which
adds interval timers instead of one-shot timers.
unsigned ops->size cannot be negative
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
arch/powerpc/Kconfig
arch/s390/kernel/time.c
arch/x86/kernel/apic_32.c
arch/x86/kernel/cpu/perfctr-watchdog.c
arch/x86/kernel/i8259_64.c
arch/x86/kernel/ldt.c
arch/x86/kernel/nmi_64.c
arch/x86/kernel/smpboot.c
arch/x86/xen/smp.c
include/asm-x86/hw_irq_32.h
include/asm-x86/hw_irq_64.h
include/asm-x86/mach-default/irq_vectors.h
include/asm-x86/mach-voyager/irq_vectors.h
include/asm-x86/smp.h
kernel/Makefile
Avoid compile error by using EXPORT_SYMBOL_GPL(si_swapinfo) only if
CONFIG_SWAP is set.
It's never used and the comments refer to nonatomic and retry
interchangably. So get rid of it.
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Use get_online_cpus() to prevent cpu hotplug in situations where
for_each_online_cpu() is called.
Remove binary sysctls that never worked due to missing strategy functions.
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Gerald Schaefer <geraldsc@de.ibm.com>
arch/s390/Kconfig tells us that CONFIG_APPLDATA_BASE is bool and hence can
never be built modular. Given this, defining appldata_exit() function is
pointless (and wasteful, actually). Remove all that.
Previous patch annotated appldata_offline_cpu() as __cpuexit, but now with the
__exit function appldata_exit() gone, the only callsite that references it is
__cpuinit, so this function can also be __cpuinit, thereby saving space when
HOTPLUG_CPU=n.
Signed-off-by: Satyam Sharma <satyam@infradead.org>
appldata_offline_cpu() is only called from __cpuinit-marked hotplug
notifier callback and from the __exit-marked module_exit function,
therefore candidate for __cpuexit.
BTW the __exit module_exit function appldata_exit() of this driver fails to
unregister_hotcpu_notifier() the notifier_block that was registered by
appldata_init() during module startup. This will lead to oops if hotplug
notification comes after module has been unloaded. Let's fix this by
unregistering the notifier appropriately (before appldata_offline_cpu()'ing
the CPUs).
smp_call_function_single now has the same semantics as s390's
smp_call_function_on. Therefore convert to the *single variant
and get rid of some architecture specific code.
WARNING: arch/s390/kernel/built-in.o(.text+0xb92a):
Section mismatch: reference to .init.text:start_secondary
(between 'restart_addr' and 'stack_overflow')
WARNING: arch/s390/appldata/built-in.o(.data+0xdc):
(between 'appldata_nb' and 'appldata_timer_lock')
Since nonboot CPUs are now disabled after tasks and devices have been
frozen and the CPU hotplug infrastructure is used for this purpose, we need
special CPU hotplug notifications that will help the CPU-hotplug-aware
subsystems distinguish normal CPU hotplug events from CPU hotplug events
related to a system-wide suspend or resume operation in progress. This
patch introduces such notifications and causes them to be used during
suspend and resume transitions. It also changes all of the
CPU-hotplug-aware subsystems to take these notifications into consideration
(for now they are handled in the same way as the corresponding "normal"
ones).
[oleg@tv-sign.ru: cleanups]
Cc: Gautham R Shenoy <ego@in.ibm.com>
Cc: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
arch/s390/appldata/appldata_base.c has some confusing debugging code left
over to allow compiling it as a module. In practice, it cannot be configured
as module and there is no need to keep that code.
Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com>
The semantic effect of insert_at_head is that it would allow new registered
sysctl entries to override existing sysctl entries of the same name. Which is
pain for caching and the proc interface never implemented.
I have done an audit and discovered that none of the current users of
register_sysctl care as (excpet for directories) they do not register
duplicate sysctl entries.
So this patch simply removes the support for overriding existing entries in
the sys_sysctl interface since no one uses it or cares and it makes future
enhancments harder.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Corey Minyard <minyard@acm.org>
Cc: Neil Brown <neilb@suse.de>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Jan Kara <jack@ucw.cz>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: David Chinner <dgc@sgi.com>
Cc: Patrick McHardy <kaber@trash.net>
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn,
prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus
generating compiler warnings of unused symbols, hence forcing people to add
#ifdefs.
the compiler can skip truly unused functions just fine:
1624412 728710 3674856 6027978 5bfaca vmlinux.before
1624412 728710 3674856 6027978 5bfaca vmlinux.after
[akpm@osdl.org: topology.c fix]
Fix up arch-specific work items where possible to use the new work_struct and
delayed_work structs.
Three places that enqueue bits of their stack and then return have been marked
with #error as this is not permitted.
Signed-Off-By: David Howells <dhowells@redhat.com>
sscanf() could leave the interval value unchanged in which case it
would be used uninitialized.
Remove the last few places where a pointer to pt_regs gets passed.
Also make sure we call set_irq_regs() before irq_enter() and after
irq_exit(). This doesn't fix anything but makes sure s390 looks the
same like all other architectures.
Convert s390 page handling macros to functions. In particular this fixes a
problem with s390's SetPageUptodate macro which uses its input parameter
twice which again can cause subtle bugs.
[akpm@osdl.org: build fix]
Don't use static initialization for struct members containing
variables because gcc would generate more code and use double space
on stack.
Introduce asm header that contains the appldata data structures and
the diag inline assembly.
Use __cpuinit for CPU hotplug notifier function.
Use hotplug version of register_cpu_notifier in late init functions.
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial:
Remove obsolete #include <linux/config.h>
remove obsolete swsusp_encrypt
arch/arm26/Kconfig typos
Documentation/IPMI typos
Kconfig: Typos in net/sched/Kconfig
v9fs: do not include linux/version.h
Documentation/DocBook/mtdnand.tmpl: typo fixes
typo fixes: specfic -> specific
typo fixes in Documentation/networking/pktgen.txt
typo fixes: occuring -> occurring
typo fixes: infomation -> information
typo fixes: disadvantadge -> disadvantage
typo fixes: aquire -> acquire
typo fixes: mecanism -> mechanism
typo fixes: bandwith -> bandwidth
fix a typo in the RTC_CLASS help text
smb is no longer maintained
Manually merged trivial conflict in arch/um/kernel/vmlinux.lds.S
The remaining counters in page_state after the zoned VM counter patches
have been applied are all just for show in /proc/vmstat. They have no
essential function for the VM.
We use a simple increment of per cpu variables. In order to avoid the most
severe races we disable preempt. Preempt does not prevent the race between
an increment and an interrupt handler incrementing the same statistics
counter. However, that race is exceedingly rare, we may only loose one
increment or so and there is no requirement (at least not in kernel) that
the vm event counters have to be accurate.
In the non preempt case this results in a simple increment for each
counter. For many architectures this will be reduced by the compiler to a
single instruction. This single instruction is atomic for i386 and x86_64.
And therefore even the rare race condition in an interrupt is avoided for
both architectures in most cases.
The patchset also adds an off switch for embedded systems that allows a
building of linux kernels without these counters.
The implementation of these counters is through inline code that hopefully
results in only a single instruction increment instruction being emitted
(i386, x86_64) or in the increment being hidden though instruction
concurrency (EPIC architectures such as ia64 can get that done).
Benefits:
- VM event counter operations usually reduce to a single inline instruction
on i386 and x86_64.
- No interrupt disable, only preempt disable for the preempt case.
Preempt disable can also be avoided by moving the counter into a spinlock.
- Handling is similar to zoned VM counters.
- Simple and easily extendable.
- Can be omitted to reduce memory use for embedded use.
References:
RFC http://marc.theaimsgroup.com/?l=linux-kernel&m=113512330605497&w=2
RFC http://marc.theaimsgroup.com/?l=linux-kernel&m=114988082814934&w=2
local_t http://marc.theaimsgroup.com/?l=linux-kernel&m=114991748606690&w=2
V2 http://marc.theaimsgroup.com/?t=115014808400007&r=1&w=2
V3 http://marc.theaimsgroup.com/?l=linux-kernel&m=115024767022346&w=2
V4 http://marc.theaimsgroup.com/?l=linux-kernel&m=115047968808926&w=2
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Add CPU ID and steal time, and make OS record size variable.
Remove EXPORT_SYMBOL_GPL(avenrun) from appdata_base.c, since it is
already exported in kernel/timer.c
This patch reverts notifier_block changes made in 2.6.17
Cc: Ashok Raj <ashok.raj@intel.com>
Few of the notifier_chain_register() callers use __devinitdata in the
definition of notifier_block data structure. It is incorrect as the
data structure should be available after the initializations (they do
not unregister them during initializations).
This was leading to an oops when notifier_chain_register() call is
invoked for those callback chains after initialization.
This patch fixes all such usages to _not_ have the notifier_block data
structure in the init data section.
Convert all kmalloc + memset sequences in arch/s390 to kzalloc usage.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X,
ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by
S390, 64BIT and COMPAT.
You could open the /proc/sys/net/ipv4/conf/<if>/<whatever> file, then
wait for interface to go away, try to grab as much memory as possible in
hope to hit the (kfreed) ctl_table. Then fill it with pointers to your
function. Then do read from file you've opened and if you are lucky,
you'll get it called as ->proc_handler() in kernel mode.
So this is at least an Oops and possibly more. It does depend on an
interface going away though, so less of a security risk than it would
otherwise be.
Fix inline assembly that gets miscompiled by gcc 4.
The system might hang when using appldata_mem with high I/O traffic and a
large number of devices. The spinlocks bdev_lock and swaplock are acquired
via calls to si_meminfo() and si_swapinfo() from a tasklet, i.e. interrupt
context, which can lead to a deadlock. Replace tasklet with work queue.
infrastructure for it.
Let it rip!
