The double while loops of the CTR mode encryption / decryption functions
are overly complex for little gain. Simplify the functions to a single
while loop at the cost of an additional memcpy of a few bytes for every
4K page worth of data.
Adapt the other crypto functions to make them all look alike.
Reviewed-by: Harald Freudenberger <freude@linux.vnet.ibm.com>
The CPACF code makes some assumptions about the availablity of hardware
support. E.g. if the machine supports KM(AES-256) without chaining it is
assumed that KMC(AES-256) with chaining is available as well. For the
existing CPUs this is true but the architecturally correct way is to
check each CPACF functions on its own. This is what the query function
of each instructions is all about.
The aes and the des module register multiple crypto algorithms
dependent on the availability of specific CPACF instructions.
To simplify the deregistration with crypto_unregister_alg add
an array with pointers to the successfully registered algorithms
and use it for the error handling in the init function and in
the module exit function.
The CPACF instructions can complete with three different condition codes:
CC=0 for successful completion, CC=1 if the protected key verification
failed, and CC=3 for partial completion.
The inline functions will restart the CPACF instruction for partial
completion, this removes the CC=3 case. The CC=1 case is only relevant
for the protected key functions of the KM, KMC, KMAC and KMCTR
instructions. As the protected key functions are not used by the
current code, there is no need for any kind of return code handling.
Use a separate define for the decryption modifier bit instead of
duplicating the function codes for encryption / decrypton.
In addition use an unsigned type for the function code.
This patch replaces use of the obsolete blkcipher with skcipher.
The CPACF instructions are going be used in KVM as well, move the
defines and the inline functions from arch/s390/crypt/crypt_s390.h
to arch/s390/include/asm. Rename the header to cpacf.h and replace
the crypt_s390_xxx names with cpacf_xxx.
While we are at it, cleanup the header as well. The encoding for
the CPACF operations is odd, there is an enum for each of the CPACF
instructions with the hardware function code in the lower 8 bits of
each entry and a software defined number for the CPACF instruction
in the upper 8 bits. Remove the superfluous software number and
replace the enums with simple defines.
The crypt_s390_func_available() function tests for the presence
of a specific CPACF operations. The new name of the function is
cpacf_query and it works slightly different than before. It gets
passed an opcode of an CPACF instruction and a function code for
this instruction. The facility_mask parameter is gone, the opcode
is used to find the correct MSA facility bit to check if the CPACF
instruction itself is available. If it is the query function of the
given instruction is used to test if the requested CPACF operation
is present.
Acked-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Commit 28856a9e52c7 missed the addition of the crypto/xts.h include file
for different architecture-specific AES implementations.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
The patch centralizes the XTS key check logic into the service function
xts_check_key which is invoked from the different XTS implementations.
With this, the XTS implementations in ARM, ARM64, PPC and S390 have now
a sanity check for the XTS keys similar to the other arches.
In addition, this service function received a check to ensure that the
key != the tweak key which is mandated by FIPS 140-2 IG A.9. As the
check is not present in the standards defining XTS, it is only enforced
in FIPS mode of the kernel.
Use the module_cpu_feature_match() module init function to add an
module alias based on required CPU features. The modules are
automatically loaded on hardware that supports the required CPU features.
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
In aes_encrypt() and aes_decrypt(), need let 'sctx->key' be modified,
so remove 'const' for it. The related warnings:
CC [M] arch/s390/crypto/aes_s390.o
arch/s390/crypto/aes_s390.c: In function 'aes_encrypt':
arch/s390/crypto/aes_s390.c:146:37: warning: passing argument 2 of 'crypt_s390_km' discards 'const' qualifier from pointer target type [-Wdiscarded-array-qualifiers]
crypt_s390_km(KM_AES_128_ENCRYPT, &sctx->key, out, in,
In file included from arch/s390/crypto/aes_s390.c:29:0:
arch/s390/crypto/crypt_s390.h:154:19: note: expected 'void *' but argument is of type 'const u8 (*)[32] {aka const unsigned char (*)[32]}'
static inline int crypt_s390_km(long func, void *param,
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
An additional testcase found an issue with the last
series of patches applied: the fallback solution may
not save the iv value after operation. This very small
fix just makes sure the iv is copied back to the
walk/desc struct.
Cc: <stable@vger.kernel.org> # 3.14+
Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com>
The aes-ctr mode uses one preallocated page without any concurrency
protection. When multiple threads run aes-ctr encryption or decryption
this can lead to data corruption.
The patch introduces locking for the page and a fallback solution with
slower en/decryption performance in concurrency situations.
Cc: stable@vger.kernel.org
Some s390 crypto algorithms incorrectly use the crypto_tfm structure to
store private data. As the tfm can be shared among multiple threads, this
can result in data corruption.
This patch fixes aes-xts by moving the xts and pcc parameter blocks from
the tfm onto the stack (48 + 96 bytes).
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Pull crypto update from Herbert Xu:
- Made x86 ablk_helper generic for ARM
- Phase out chainiv in favour of eseqiv (affects IPsec)
- Fixed aes-cbc IV corruption on s390
- Added constant-time crypto_memneq which replaces memcmp
- Fixed aes-ctr in omap-aes
- Added OMAP3 ROM RNG support
- Add PRNG support for MSM SoC's
- Add and use Job Ring API in caam
- Misc fixes
[ NOTE! This pull request was sent within the merge window, but Herbert
has some questionable email sending setup that makes him public enemy
#1 as far as gmail is concerned. So most of his emails seem to be
trapped by gmail as spam, resulting in me not seeing them. - Linus ]
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (49 commits)
crypto: s390 - Fix aes-cbc IV corruption
crypto: omap-aes - Fix CTR mode counter length
crypto: omap-sham - Add missing modalias
padata: make the sequence counter an atomic_t
crypto: caam - Modify the interface layers to use JR API's
crypto: caam - Add API's to allocate/free Job Rings
crypto: caam - Add Platform driver for Job Ring
hwrng: msm - Add PRNG support for MSM SoC's
ARM: DT: msm: Add Qualcomm's PRNG driver binding document
crypto: skcipher - Use eseqiv even on UP machines
crypto: talitos - Simplify key parsing
crypto: picoxcell - Simplify and harden key parsing
crypto: ixp4xx - Simplify and harden key parsing
crypto: authencesn - Simplify key parsing
crypto: authenc - Export key parsing helper function
crypto: mv_cesa: remove deprecated IRQF_DISABLED
hwrng: OMAP3 ROM Random Number Generator support
crypto: sha256_ssse3 - also test for BMI2
crypto: mv_cesa - Remove redundant of_match_ptr
crypto: sahara - Remove redundant of_match_ptr
The cbc-aes-s390 algorithm incorrectly places the IV in the tfm
data structure. As the tfm is shared between multiple threads,
this introduces a possibility of data corruption.
This patch fixes this by moving the parameter block containing
the IV and key onto the stack (the block is 48 bytes long).
The same bug exists elsewhere in the s390 crypto system and they
will be fixed in subsequent patches.
If a machine has no hardware support for the xts-aes or ctr-aes algorithms
they are not registered in aes_s390_init. But aes_s390_fini unconditionally
unregisters the algorithms which causes crypto_remove_alg to crash.
Add two flag variables to remember if xts-aes and ctr-aes have been added.
Signed-off-by: Ingo Tuchscherer <ingo.tuchscherer@de.ibm.com>
Remove the BUG_ON's that check for failure or incomplete
results of the s390 hardware crypto instructions.
Rather report the errors as -EIO to the crypto layer.
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com>
Initialization of cra_list is currently mixed, most ciphers initialize this
field and most shashes do not. Initialization however is not needed at all
since cra_list is initialized/overwritten in __crypto_register_alg() with
list_add(). Therefore perform cleanup to remove all unneeded initializations
of this field in 'arch/s390/crypto/'
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: linux-s390@vger.kernel.org
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Remove the file name from the comment at top of many files. In most
cases the file name was wrong anyway, so it's rather pointless.
Also unify the IBM copyright statement. We did have a lot of sightly
different statements and wanted to change them one after another
whenever a file gets touched. However that never happened. Instead
people start to take the old/"wrong" statements to use as a template
for new files.
So unify all of them in one go.
This patch adds System z hardware acceleration support for AES, DES
and 3DES in CTR mode. The hardware support is available starting with
System z196.
This patch adds System z hardware acceleration support for the AES XTS mode.
The hardware support is available beginning with System z196.
The specification which crypto facility is required for an algorithm is added
as a parameter to the availability check which is done before an algorithm is
registered. With this change it is easier to add new algorithms that require
different facilities.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (31 commits)
crypto: aes_generic - Fix checkpatch errors
crypto: fcrypt - Fix checkpatch errors
crypto: ecb - Fix checkpatch errors
crypto: des_generic - Fix checkpatch errors
crypto: deflate - Fix checkpatch errors
crypto: crypto_null - Fix checkpatch errors
crypto: cipher - Fix checkpatch errors
crypto: crc32 - Fix checkpatch errors
crypto: compress - Fix checkpatch errors
crypto: cast6 - Fix checkpatch errors
crypto: cast5 - Fix checkpatch errors
crypto: camellia - Fix checkpatch errors
crypto: authenc - Fix checkpatch errors
crypto: api - Fix checkpatch errors
crypto: anubis - Fix checkpatch errors
crypto: algapi - Fix checkpatch errors
crypto: blowfish - Fix checkpatch errors
crypto: aead - Fix checkpatch errors
crypto: ablkcipher - Fix checkpatch errors
crypto: pcrypt - call the complete function on error
The fallback code in cipher mode touch the union fallback.blk instead
of fallback.cip. This is wrong because we use the cipher and not the
blockcipher. This did not show any side effects yet because both types /
structs contain the same element right now.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Return the PTR_ERR of the correct pointer.
With the mandatory algorithm testing at registration, we have
now created a deadlock with algorithms requiring fallbacks.
This can happen if the module containing the algorithm requiring
fallback is loaded first, without the fallback module being loaded
first. The system will then try to test the new algorithm, find
that it needs to load a fallback, and then try to load that.
As both algorithms share the same module alias, it can attempt
to load the original algorithm again and block indefinitely.
As algorithms requiring fallbacks are a special case, we can fix
this by giving them a different module alias than the rest. Then
it's just a matter of using the right aliases according to what
algorithms we're trying to find.
Not very helpful when code dies in "init".
See also http://lkml.org/lkml/2008/3/26/557 .
crypto_blkcipher_decrypt is wrong because it does not care about
the IV.
Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc>
Some CPUs support only 128 bit keys in HW. This patch adds SW fallback
support for the other keys which may be required. The generic algorithm
(and the block mode) must be availble in case of a fallback.
This three defines are used in all AES related hardware.
Loading the crypto algorithm by the alias instead of by module directly
has the advantage that all possible implementations of this algorithm
are loaded automatically and the crypto API can choose the best one
depending on its priority.
Additionally it ensures that the generic implementation as well as the
HW driver (if available) is loaded in case the HW driver needs the
generic version as fallback in corner cases.
Register aes-s390 algorithms with the actual supported max keylen size
Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com>
This patch moves the config options for the s390 crypto instructions
to the standard "Hardware crypto devices" menu. In addition some
cleanup has been done: use a flag for supported keylengths, add a
warning about machien limitation, return ENOTSUPP in case the
hardware has no support, remove superfluous printks and update
email addresses.
This patch removes obsolete block operations of the simple cipher type
from drivers. These were preserved so that existing users can make a
smooth transition. Now that the transition is complete, they are no
longer needed.
This patch adds block cipher algorithms for S390. Once all users of the
old cipher type have been converted the existing CBC/ECB non-block cipher
operations will be removed.
Accelerated versions of crypto algorithms must carry a distinct driver name
and priority in order to distinguish themselves from their generic counter-
part.
Now that the tfm is passed directly to setkey instead of the ctx, we no
longer need to pass the &tfm->crt_flags pointer.
This patch also gets rid of a few unnecessary checks on the key length
for ciphers as the cipher layer guarantees that the key length is within
the bounds specified by the algorithm.
Rather than testing dia_setkey every time, this patch does it only once
during crypto_alloc_tfm. The redundant check from crypto_digest_setkey
is also removed.
Up until now algorithms have been happy to get a context pointer since
they know everything that's in the tfm already (e.g., alignment, block
size).
However, once we have parameterised algorithms, such information will
be specific to each tfm. So the algorithm API needs to be changed to
pass the tfm structure instead of the context pointer.
This patch is basically a text substitution. The only tricky bit is
the assembly routines that need to get the context pointer offset
through asm-offsets.h.
Call KM[C] only with a multiple of block size. Check return value of KM[C]
instructions and complain about erros
Add support for the hardware accelerated AES crypto algorithm.
