path: root/arch/s390/crypto
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (31 commits) crypto: aes_generic - Fix checkpatch errors crypto: fcrypt - Fix checkpatch errors crypto: ecb - Fix checkpatch errors crypto: des_generic - Fix checkpatch errors crypto: deflate - Fix checkpatch errors crypto: crypto_null - Fix checkpatch errors crypto: cipher - Fix checkpatch errors crypto: crc32 - Fix checkpatch errors crypto: compress - Fix checkpatch errors crypto: cast6 - Fix checkpatch errors crypto: cast5 - Fix checkpatch errors crypto: camellia - Fix checkpatch errors crypto: authenc - Fix checkpatch errors crypto: api - Fix checkpatch errors crypto: anubis - Fix checkpatch errors crypto: algapi - Fix checkpatch errors crypto: blowfish - Fix checkpatch errors crypto: aead - Fix checkpatch errors crypto: ablkcipher - Fix checkpatch errors crypto: pcrypt - call the complete function on error ...
2010-02-05tree-wide: fix 'lenght' typo in comments and codeDaniel Mack
Some misspelled occurences of 'octet' and some comments were also fixed as I was on it. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Jiri Kosina <trivial@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-08crypto: aes_s390 - access .cip instead of .blk in cipher modeRoel Kluin
The fallback code in cipher mode touch the union fallback.blk instead of fallback.cip. This is wrong because we use the cipher and not the blockcipher. This did not show any side effects yet because both types / structs contain the same element right now. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-12-18[S390] s390: PTR_ERR return of wrong pointer in fallback_init_cip()Roel Kluin
Return the PTR_ERR of the correct pointer. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-10-14s390: Remove BKL from prngThomas Gleixner
cycle_kernel_lock() was added during the big BKL pushdown. It should ensure the serializiation against driver init code. In this case there is nothing to serialize. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> LKML-Reference: <20091010153349.601625576@linutronix.de> Acked-by: Jan Glauber <jang@linux.vnet.ibm.com>
2009-09-05crypto: sha-s390 - Fix warnings in import functionJan Glauber
That patch should fix the warnings. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: sha512-s390 - Add export/import supportHerbert Xu
This patch adds export/import support to sha512-s390 (which includes sha384-s390). The exported type is defined by struct sha512_state, which is basically the entire descriptor state of sha512_generic. Since sha512-s390 only supports a 64-bit byte count the import function will reject anything that exceeds that. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-16crypto: s390 - Fix sha build failureSachin Sant
Use struct s390_sha_ctx instead of sha1/sha256_state struct to fix s390 crypto build break. Signed-off-by: Sachin Sant <sachinp@in.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: sha256-s390 - Add export/import supportHerbert Xu
This patch adds export/import support to sha256-s390. The exported type is defined by struct sha256_state, which is basically the entire descriptor state of sha256_generic. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: sha1-s390 - Add export/import supportHerbert Xu
This patch adds export/import support to sha1-s390. The exported type is defined by struct sha1_state, which is basically the entire descriptor state of sha1_generic. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-18crypto: des_s390 - Permit weak keys unless REQ_WEAK_KEY setJarod Wilson
Just started running fips cavs test vectors through an s390x system for giggles, and discovered that I missed patching s390's arch-specific des3 implementation w/an earlier des3 patch to permit weak keys. This change adds the same flag tweaks as ad79cdd77fc1466e45cf923890f66bcfe7c43f12 (crypto: des3_ede - permit weak keys unless REQ_WEAK_KEY set) for s390's des3 implementation, yields expected test results now. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-26Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (81 commits) [S390] remove duplicated #includes [S390] cpumask: use mm_cpumask() wrapper [S390] cpumask: Use accessors code. [S390] cpumask: prepare for iterators to only go to nr_cpu_ids/nr_cpumask_bits. [S390] cpumask: remove cpu_coregroup_map [S390] fix clock comparator save area usage [S390] Add hwcap flag for the etf3 enhancement facility [S390] Ensure that ipl panic notifier is called late. [S390] fix dfp elf hwcap/facility bit detection [S390] smp: perform initial cpu reset before starting a cpu [S390] smp: fix memory leak on __cpu_up [S390] ipl: Improve checking logic and remove switch defaults. [S390] s390dbf: Remove needless check for NULL pointer. [S390] s390dbf: Remove redundant initilizations. [S390] use kzfree() [S390] BUG to BUG_ON changes [S390] zfcpdump: Prevent zcore from beeing built as a kernel module. [S390] Use csum_partial in checksum.h [S390] cleanup lowcore.h [S390] eliminate ipl_device from lowcore ...
2009-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (29 commits) crypto: sha512-s390 - Add missing block size hwrng: timeriomem - Breaks an allyesconfig build on s390: nlattr: Fix build error with NET off crypto: testmgr - add zlib test crypto: zlib - New zlib crypto module, using pcomp crypto: testmgr - Add support for the pcomp interface crypto: compress - Add pcomp interface netlink: Move netlink attribute parsing support to lib crypto: Fix dead links hwrng: timeriomem - New driver crypto: chainiv - Use kcrypto_wq instead of keventd_wq crypto: cryptd - Per-CPU thread implementation based on kcrypto_wq crypto: api - Use dedicated workqueue for crypto subsystem crypto: testmgr - Test skciphers with no IVs crypto: aead - Avoid infinite loop when nivaead fails selftest crypto: skcipher - Avoid infinite loop when cipher fails selftest crypto: api - Fix crypto_alloc_tfm/create_create_tfm return convention crypto: api - crypto_alg_mod_lookup either tested or untested crypto: amcc - Add crypt4xx driver crypto: ansi_cprng - Add maintainer ...
2009-03-26[S390] use kzfree()Johannes Weiner
Use kzfree() instead of memset() + kfree(). Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-03-21crypto: sha512-s390 - Add missing block sizeHerbert Xu
I missed the block size when converting sha512-s390 to shash. Tested-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-26crypto: api - Fix module load deadlock with fallback algorithmsHerbert Xu
With the mandatory algorithm testing at registration, we have now created a deadlock with algorithms requiring fallbacks. This can happen if the module containing the algorithm requiring fallback is loaded first, without the fallback module being loaded first. The system will then try to test the new algorithm, find that it needs to load a fallback, and then try to load that. As both algorithms share the same module alias, it can attempt to load the original algorithm again and block indefinitely. As algorithms requiring fallbacks are a special case, we can fix this by giving them a different module alias than the rest. Then it's just a matter of using the right aliases according to what algorithms we're trying to find. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-18crypto: sha-s390 - Switch to shashHerbert Xu
This patch converts the S390 sha algorithms to the new shash interface. With fixes by Jan Glauber. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25[S390] convert cpacf printks to pr_xxx macros.Jan Glauber
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: (146 commits) IB/umad: BKL is not needed for ib_umad_open() IB/uverbs: BKL is not needed for ib_uverbs_open() bf561-coreb: BKL unneeded for open() Call fasync() functions without the BKL snd/PCM: fasync BKL pushdown ipmi: fasync BKL pushdown ecryptfs: fasync BKL pushdown Bluetooth VHCI: fasync BKL pushdown tty_io: fasync BKL pushdown tun: fasync BKL pushdown i2o: fasync BKL pushdown mpt: fasync BKL pushdown Remove BKL from remote_llseek v2 Make FAT users happier by not deadlocking x86-mce: BKL pushdown vmwatchdog: BKL pushdown vmcp: BKL pushdown via-pmu: BKL pushdown uml-random: BKL pushdown uml-mmapper: BKL pushdown ...
2008-07-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (50 commits) crypto: ixp4xx - Select CRYPTO_AUTHENC crypto: s390 - Respect STFL bit crypto: talitos - Add support for sha256 and md5 variants crypto: hash - Move ahash functions into crypto/hash.h crypto: crc32c - Add ahash implementation crypto: hash - Added scatter list walking helper crypto: prng - Deterministic CPRNG crypto: hash - Removed vestigial ahash fields crypto: hash - Fixed digest size check crypto: rmd - sparse annotations crypto: rmd128 - sparse annotations crypto: camellia - Use kernel-provided bitops, unaligned access helpers crypto: talitos - Use proper form for algorithm driver names crypto: talitos - Add support for 3des crypto: padlock - Make module loading quieter when hardware isn't available crypto: tcrpyt - Remove unnecessary kmap/kunmap calls crypto: ixp4xx - Hardware crypto support for IXP4xx CPUs crypto: talitos - Freescale integrated security engine (SEC) driver [CRYPTO] tcrypt: Add self test for des3_ebe cipher operating in cbc mode [CRYPTO] rmd: Use pointer form of endian swapping operations ...
2008-07-14[S390] Cleanup cpacf printk messages.Jan Glauber
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-12crypto: s390 - Respect STFL bitJan Glauber
Bevore issuing any s390 crypto operation check whether the CPACF facility is enabled in the facility list. That way a virtualization layer can prevent usage of the CPACF facility regardless of the availability of the crypto instructions. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-06-20crypto-prng: BKL pushdownArnd Bergmann
2008-04-21[CRYPTO] sha384: Hardware acceleration for s390Jan Glauber
Exploit the System z10 hardware acceleration for SHA384. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] sha512: Hardware acceleration for s390Jan Glauber
Exploit the System z10 hardware acceleration for SHA512. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] s390: Generic sha_update and sha_finalJan Glauber
The sha_{update|final} functions are similar for every sha variant. Since that is error-prone and redundant replace these functions by a shared generic implementation for s390. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-17[S390] crypto: use more descriptive function names for init/exit routines.Heiko Carstens
Not very helpful when code dies in "init". See also http://lkml.org/lkml/2008/3/26/557 . Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-01-26[S390] constify function pointer tables.Jan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] arch/s390/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] arch/s390: Add missing "space"Joe Perches
2008-01-26[S390] crypto: move s390 Kconfig options.Jan Glauber
Move s390 crypto Kconfig options to drivers/crypto/Kconfig to have all hardware crypto devices in one place. This also makes messing up the kernel source tree easier for some people. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-11[CRYPTO] s390-aes: Use correct encrypt/decrypt function in fallbackSebastian Siewior
crypto_blkcipher_decrypt is wrong because it does not care about the IV. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aes_s390: Add fallback driverSebastian Siewior
Some CPUs support only 128 bit keys in HW. This patch adds SW fallback support for the other keys which may be required. The generic algorithm (and the block mode) must be availble in case of a fallback. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aes: Move common defines into a header fileSebastian Siewior
This three defines are used in all AES related hardware. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] sha: Add header file for SHA definitionsJan Glauber
There are currently several SHA implementations that all define their own initialization vectors and size values. Since this values are idential move them to a header file under include/crypto. Signed-off-by: Jan Glauber <jang@de.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] sha: Load the SHA[1|256] module by an aliasSebastian Siewior
Loading the crypto algorithm by the alias instead of by module directly has the advantage that all possible implementations of this algorithm are loaded automatically and the crypto API can choose the best one depending on its priority. Additionally it ensures that the generic implementation as well as the HW driver (if available) is loaded in case the HW driver needs the generic version as fallback in corner cases. Also remove the probe for sha1 in padlock's init code. Quote from Herbert: The probe is actually pointless since we can always probe when the algorithm is actually used which does not lead to dead-locks like this. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] aes: Rename aes to aes-genericSebastian Siewior
Loading the crypto algorithm by the alias instead of by module directly has the advantage that all possible implementations of this algorithm are loaded automatically and the crypto API can choose the best one depending on its priority. Additionally it ensures that the generic implementation as well as the HW driver (if available) is loaded in case the HW driver needs the generic version as fallback in corner cases. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-07-10[S390] Fixed comment typo.Ralph Wuerthner
Signed-off-by: Ralph Wuerthner <rwuerthn@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-09Fix trivial typos in Kconfig* filesDavid Sterba
Fix several typos in help text in Kconfig* files. Signed-off-by: David Sterba <dave@jikos.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-04[S390] aes-s390 key length.Jan Glauber
Register aes-s390 algorithms with the actual supported max keylen size Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] crypto: cleanup.Jan Glauber
Cleanup code and remove obsolete documentation. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] Support for s390 Pseudo Random Number GeneratorJan Glauber
Starting with the z9 the CPU Cryptographic Assist Facility comes with an integrated Pseudo Random Number Generator. The generator creates random numbers by an algorithm similar to the ANSI X9.17 standard. The pseudo-random numbers can be accessed via a character device driver node called /dev/prandom. Similar to /dev/urandom any amount of bytes can be read from the device without blocking. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] move crypto options and some cleanup.Jan Glauber
This patch moves the config options for the s390 crypto instructions to the standard "Hardware crypto devices" menu. In addition some cleanup has been done: use a flag for supported keylengths, add a warning about machien limitation, return ENOTSUPP in case the hardware has no support, remove superfluous printks and update email addresses. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] Get rid of a lot of sparse warnings.Heiko Carstens
2006-09-28[S390] Inline assembly cleanup.Martin Schwidefsky
Major cleanup of all s390 inline assemblies. They now have a common coding style. Quite a few have been shortened, mainly by using register asm variables. Use of the EX_TABLE macro helps as well. The atomic ops, bit ops and locking inlines new use the Q-constraint if a newer gcc is used. That results in slightly better code. Thanks to Christian Borntraeger for proof reading the changes. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-09-21[CRYPTO] drivers: Remove obsolete block cipher operationsHerbert Xu
This patch removes obsolete block operations of the simple cipher type from drivers. These were preserved so that existing users can make a smooth transition. Now that the transition is complete, they are no longer needed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] s390: Added block cipher versions of CBC/ECBHerbert Xu
This patch adds block cipher algorithms for S390. Once all users of the old cipher type have been converted the existing CBC/ECB non-block cipher operations will be removed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] s390: Added missing driver name and priorityHerbert Xu
Accelerated versions of crypto algorithms must carry a distinct driver name and priority in order to distinguish themselves from their generic counter- part. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
